本帖最后由 祝祝 于 2015-12-2 16:05 编辑 9 _0 m& w6 [# Q* j, Z1 l
0 E! i. h" Y2 G% ~) l n8 u" {' ~6 m在帮助文档中看到,可以更改器件的位号,但是在allegro中没有找“component list”,和Object—change命令。不知是否有人知道如何改位号?/ a! f- e2 [) {
Edit RefDes DialogLets you modify the reference designator values of more than one component simultaneously.9 e# {# a2 Z* L# U0 V, X/ S" N
How to AccessDo the following:
. R" ^! N2 n6 N M: g/ \1. | Select the components whose reference designators you want to change in the Component List. | , ]: V0 z- Z/ A- e) H2 l, Z% {
2. | Choose Object - Change - Ref Des - User Assigned. |
a5 V: _8 n+ W$ E2 n% v: kInstance Name
5 p4 M% d* f: ]+ A | Displays the instance names of the components you selected in the Component List. Z" Z9 Z3 P: K$ Z) J( S; k
| Old RefDes Value
. r* M' K4 ~/ J3 B7 x3 e- I | Displays the reference designator values of the components you selected in the Component List.
( n" t7 g: s3 r0 f# M | New RefDes Value w! J0 P3 B) r7 v, S' y* z
| Enter the new reference designator value for a component.9 x* F2 K! s' T9 T# \- ]3 J
You can also copy reference designator values from another application such as Microsoft Excel and paste them in this column.
! J& R" p( Q8 ?: P& {, p |
# e* l4 ~" C$ s1 A$ m. S' q1 {% U' l: a- X
) Y, ]8 ^; \5 |& O4 q0 ]" K, |$ T
! u T' N+ ?. u8 [% y# x1 i. t# Y z; A4 S$ A/ V9 @+ _# G
