查看: 869|回复: 2
请问如何用skill批量修改差分对的名字
发表于 2015-10-14 14:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请路过的高手指点一下,如何用skill修改差分对的名字而不改变其dbID?十分感谢
发表于 2015-10-21 14:40 | 只看该作者
你的目的是,修改差分对名字后,依旧能选取到这个差分对?参考 db = axlDBFindByName('net "GND")
这个函数返回的是component
发表于 2015-10-21 14:53 | 只看该作者
或者也可以参考axlSelectByName这个函数,其中包含DiffPair的选项
axlSelectByName (
    t_objectType
    t_name/lt_name
    [g_wildcard]
⇒ lo_dbid/nil
Object Type Item the function finds
"NET" net name
"COMPONENT" component name
"FUNCTION" function name
"DEVTYPE" device type name
"SYMTYPE" symbol type name
"PIN" refdes.pinname
"REFDES" find symbol by refdes name
"COMPREFDES" find component by refdes name
"GROUP" find group by name
"BUS" find bus by name
"DIFF_PAIR" find differential pair by name
"XNET" find xnet by name
"MATCH_GROUP" find matchgroup by name
"MODULE" find module by name
You can use wildcards with this function:
 “*” matches any sequence of zero or more characters.
 “?” matches any single character.
 “\” is used to send a special character, for example, \x.
GMT+8, 2025-8-20 14:01 , Processed in 0.125000 second(s), 23 queries , Gzip On.
