查看: 2550|回复: 20
Hotfix_SPB16.60.059_wint_1of1.exe
发表于 2015-10-10 09:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 zgyzgy 于 2015-10-10 11:35 编辑 8 s, S& C' |" |7 k4 K) C
. L  U+ P5 m  q, i
昨天刚出来的。。。。。。
$ b: _2 r6 q# [: B8 V$ M2 D- P4 T1 Q2 P
DATE: 09-31-2015   HOTFIX VERSION: 059
: @0 K/ J' d* T; a  X1 L===================================================================================================================================
# k+ x8 W" g* v) {CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
$ T3 z* ]3 W  C3 j2 t7 B3 c===================================================================================================================================
5 v5 t! C* q0 c  S; n1181942 SIP_LAYOUT     ASSY_RULE_CHECK  ADRC reports different results from the spacing set-up0 ?9 f+ P3 M8 O7 d7 I
1328452 allegro_EDITOR INTERACTIV       When changing the shape type, Right-click - Next does not work for subsequent changes; e8 e8 P8 E3 R, w+ @
1441502 GRE            IFP_INTERACTIVE  Design partition cannot be imported.9 S3 A, z4 Q# e0 g) J: `
1457920 SIP_LAYOUT     OTHER            Wire Bond Import is not working correctly with discrete parts
2 K/ r) X# x( Z. [. T5 X( s( }4 A1464865 concept_HDL    CONSTRAINT_MGR   For identical nets, topology in DE-HDL CM is different from the topology in PCB Editor CM
9 H, X% X2 h7 q& @5 r) B( r1467365 ALLEGRO_EDITOR OTHER            cadence cshrc for LINUX has an extra space in it.
  Z+ k& H( c; n  `( q+ e: X1473744 ALLEGRO_EDITOR INTERACTIV       The 'Chamfer' function does not work correctly if the second Trim Segment value is specified instead of the first.
9 L% s- y0 c4 @' b! {1475599 SIP_LAYOUT     SYMB_EDIT_APPMOD Refresh co-design die of an enlarged die is not placed correctly: [$ G* W% V6 }) M- s- ~" t
1476284 CONSTRAINT_MGR OTHER            Changes with Tpoint pairing not being propagated to the brd file! Y0 S+ F# U# _5 Z) d
1476528 ORBITIO        ALLEGRO_SIP_IF   While translating a .mcm to OrbitIO, the error 'allegro2orbit.exe has stopped working' is thrown
) s/ I& z5 k1 @. N% ]1476855 ALLEGRO_EDITOR DATABASE         Trying to import Netlist, getting SPMHNI-194 error, V- g, i7 A4 U, A6 V+ u4 l& I, O
1476920 CONCEPT_HDL    OTHER            Genview consistently fails in some indeterminant manner.
- k0 @0 Y( s4 V4 d/ p$ o1478111 F2B            DESIGNVARI       Hierarchical block variant not shown in testcase with S57 although it was working with 2015 release; f. G9 e" I  V  |$ {
1478225 SIP_LAYOUT     DIE_EDITOR       IOP incorrectly rotates pins at a co-design die
' y+ B4 X4 V. u( t1478465 SIP_LAYOUT     WIREBOND         Ability to set default bond wire option to on for wirebond import/export commands
& _8 h$ N0 v8 C. o; O% ?. L1478994 SIP_LAYOUT     skill            axlUIMenuChange does not work on Linux
/ A1 {/ M) K8 D3 K0 y1479023 CONSTRAINT_MGR OTHER            The cmDiff reports different data when files are reversed in UI
% a  p- N% x4 f/ V1479785 ORBITIO        ALLEGRO_SIP_IF   brd file does not get loaded in OrbitIO' `1 K3 m) C! e
1480367 SIG_INTEGRITY  OTHER            Differential pair extraction SKILL error, 'parseString: argument #1 should be either a string or a symbol'
: ^# Q. I8 M, m1480538 SIP_LAYOUT     DIE_EDITOR       CTE compensation is limited to 3 decimal places, can that be increased
7 l2 v, R" o9 u& |. Q1481109 APD            MANUFACTURING    control Package Design Integrity for snapping the via to pin6 L+ W. a9 w* M& S$ G& k/ c" `  R* \
1482771 SIP_LAYOUT     WIREBOND         Fingers and wires cross when moving the guide path* f/ O8 X7 p& x) Z
( t3 Z5 P, V6 @- d正在下载文件中,稍后分享链接。。。。。。" M7 r* S8 f8 F" V' S& C
5 h  V7 |% }7 G: u; L
( r) X" O! M# n- R1 t3 S4 ~/ ?& A& Q) L
3 n! M$ }, ~+ l, q/ ]( U' x
! h( p4 m. D) {
0 l! {* L+ R6 g$ m2 ?' K, \
  ?/ |3 f- Q1 J" ^
- G$ ~( f/ r9 N1 w9 ?% p% M" \8 C
& d/ q+ b8 b2 Y# |
$ a- o" {, m+ @7 ]% H% t3 Nhttp://pan.baidu.com/s/1gdnouNx
6 q8 u/ ^( X$ V) w/ D( U/ J
6 ~- t# R8 `; {; H
; H/ V: f0 @2 `
5 |: N# B* W% N3 \( E
+ X- P7 c- `9 m9 g3 a* i9 W
4 m8 N/ u, K. Y/ k  ]1 y
' `' N% j2 b- M- d( R
参与人数 2威望 +4 收起 理由
wangxs_song + 2 虽然不下载,但精神可贵
yueyuan2003 + 2
推荐
 楼主| 发表于 2015-10-10 11:41 | 只看该作者
yueyuan2003 发表于 2015-10-10 09:23
. S+ {3 C+ g- n! m% K$ s楼主你太强大了
4 W7 I& g# i' i( d% I+ n7 x你能跟你们公司反映一下:
# P7 I+ ^& \9 v/ ?. t: D1 L①ORCAD通过下拉菜单里面的选项关闭起始界面还关不掉
$ w& f9 _4 J5 V, i我也和你一样也是用这个软件哈。; \' e6 E: i3 E
能截个图吗?同时论坛里有运行命令的关闭方法。
, O, v+ R' h1 a( x3 {$ D4 r8 n- W1 E2 ?& _( a3 s3 D2 ]- v
推荐
发表于 2015-10-10 09:23 | 只看该作者
本帖最后由 yueyuan2003 于 2015-10-10 09:36 编辑 % o' ^% q/ M7 q3 K' T5 ]
! c( T# ^  b" {2 F) @
楼主你太强大了
+ n! R( u. }+ C6 c% `你能跟你们公司反映一下:9 [* m" h& x4 B0 l4 Q! H
①ORCAD通过下拉菜单里面的选项关闭起始界面还关不掉$ m1 C2 Y7 M: M2 i4 L& |- e' y
②ORCAD的起始界面关了后就打不开了
$ F* K2 O1 F  i  y' @: ythank you very much!
我也和你一样也是用这个软件哈。 能截个图吗?同时论坛里有运行命令的关闭方法。  详情 回复 发表于 2015-10-10 11:41
要跟ORCAD增加向PADS LOGIC一样的网络查看功能就强大了,希望能加上  发表于 2015-10-10 09:59
推荐
 楼主| 发表于 2015-10-20 17:02 | 只看该作者
11xiaohehe 发表于 2015-10-17 20:58( n2 X- z9 I8 q+ `" O
之前更新到058,但是还是出现打开constrain manager软件就崩溃的情况。。。
4 p: P' L! L0 P我的打开不会呀
/ j1 i0 Z( ?; Q) H, @8 B( [
    2024-8-21 15:35
  • 签到天数: 109 天
    [LV.6]常住居民II
    发表于 2015-10-10 09:11 | 只看该作者
    这么快,等会再来瞧瞧
    发表于 2015-10-10 10:30 | 只看该作者
    上传了没有
     楼主| 发表于 2015-10-10 11:35 | 只看该作者
    已经上传好了。。。。。。
    发表于 2015-10-10 12:15 | 只看该作者
    更新很及时啊!谢谢分享!
    无聊
    2020-5-21 15:40
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2015-10-11 11:32 | 只看该作者
    % O& Z* o7 G& j+ ?+ ~+ H这么快, 058还没下几天呢
    13#
    发表于 2015-10-12 21:01 | 只看该作者
    感謝分享!
    6 V  K! U$ t9 v* s$ r, n最近的更新; 真的很頻繁喔!
    14#
    发表于 2015-10-13 06:15 | 只看该作者
    thank you for sharing
    2021-7-21 15:48
  • 签到天数: 51 天
    [LV.5]常住居民I
    15#
    发表于 2015-10-15 09:48 | 只看该作者
    谢谢楼主的分享,速度很快呀!
    GMT+8, 2025-11-6 02:56 , Processed in 0.156250 second(s), 26 queries , Gzip On.
