查看: 3106|回复: 24
Hotfix_SPB16.60.058_wint_1of1.exe
发表于 2015-9-27 22:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
7 r$ a/ i) |  q5 D% z/ c2 ^9 }5 l6 f; K- ^2 x* H/ Q$ `# [6 R
DATE: 09-25-2015   HOTFIX VERSION: 058- n4 x3 y/ _. T* c+ P
===================================================================================================================================4 a  ^1 i: N, S5 k5 Y  A
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE0 V7 @! m1 X* K4 L: x# V" B
===================================================================================================================================# \  E( I/ k0 H6 S
878770  Pspice         ENCRYPTION       unix2dos should not be required on encrypted model/ i# t7 S7 {4 R$ n
1450418 allegro_EDITOR PLACEMENT        PCB Editor crashes while peRForming Place replicate update
! a8 e- I4 C$ `5 w, s2 l1457138 concept_HDL    CONSTRAINT_MGR   The devices.dml file is different between the _automodel and CM launch
1 n$ W7 S$ t5 X  ^) g1462678 CONCEPT_HDL    CORE             Error "cannot write drawing because of errors" does not show marker window
6 s8 Z0 e& T$ ]; E% L% V9 N0 z1465933 F2B            PACKAGERXL       Illegal characters in LOCATION property are not being detected; error message is ineffective
6 y* h4 ]. g( c* S  Z- G# z: T1466513 F2B            BOM              Batch utility to check if design needs packaging: f, {5 V  C( g4 u1 s
1466610 CONCEPT_HDL    ARCHIVER         Archiver should include full cpm file, not just local file
/ \; a1 u1 f0 Y1 h% B, `" ?1467283 CONCEPT_HDL    CORE             Tools > Options does not warn if the .cpm file is read-only
7 F6 `' u) ~4 @* m) ^: m1467287 CONCEPT_HDL    CORE             DEHDL should flag illegal LOCATION property characters6 @( J# I; {1 X
1467817 ALLEGRO_EDITOR SHAPE            Route keepout disappears after adding connect on pad
$ p4 g& {) ], R+ o: N" _% P/ p% F1468454 ALLEGRO_EDITOR DRC_CONSTR       DRCs appear when removing cline fillets4 t- o- F4 F0 n: l
1469330 CONCEPT_HDL    CREFER           For center justified sig_name properties, the $XR annotation is placed too far away
; i2 f# w# I' v; l0 H  K  y+ u1470339 SIP_LAYOUT     SYMB_EDIT_APPMOD Tool crashes when the Reconnect by pin location option is used with the Refresh co-design die command
  g7 b+ J' Y4 j2 p  m: `2 {1470524 F2B            PACKAGERXL       Improve the "SPI_ERROR: Failed to save project file "project.cpm". An unspecified error occurred." error message
7 k+ N8 O  ?5 F( {8 M  E) X1471183 CONSTRAINT_MGR CONCEPT_HDL      Ability for the cmDiff Report 'single file' option to be available via the command line
( J+ H$ Q: E5 {8 t* L/ ?0 F1471200 CONSTRAINT_MGR OTHER            Remove the temp basecopy pstcmdb2.dat file in the physical folder after netrev completes
- b* \+ d: m5 r/ E7 S9 V1471993 CONSTRAINT_MGR CONCEPT_HDL      Backannotating constraints is not processing all objects
4 P- M# n& ?' c! t# A9 E1472046 ALLEGRO_EDITOR OTHER            Gloss option Eliminate unused stacked vias not removing unused microvias from the stack  ]( s3 J" S8 ?
1473056 ALLEGRO_EDITOR ARTWORK          Gerber export has additional phantom data not on design
  L4 G! I4 F# s, o# V9 l) F1474005 SIP_LAYOUT     EDIT_ETCH        Slide command doesn't work as expected9 H) K, y, Q8 e) l+ O
1474164 APD            DATABASE         Using Gloss - Dielectric causes APD to crash
% r& {; W2 G1 ~) s1474179 ALLEGRO_EDITOR MANUFACT         NC Route command: ncroutebits_auto.txt file is not generated for a rectangular slot6 U$ ?) s- C6 u
1474736 SIP_LAYOUT     OTHER            Cannot create bounding shape
& x* r7 C5 Y1 l1478070 CONCEPT_HDL    PDF              schematic editor crashes when selecting the pagesetup for the PDF Publisher
! G) {% d2 a1 P
/ t& S8 w+ _. J& q( j1 I正在上传文件中,分享链接稍后。。。。。。
8 e3 g* {0 Q# p" }, ^) V9 q
4 Q7 _( v& Y# R2 ^& Z
http://pan.baidu.com/s/1o6MQWae
4 }7 d) E# d0 ]0 Z: d. U( y, K$ S
& u2 P* x5 O; q  r/ v1 O3 z! ^5 L2 z/ k$ f$ C9 {/ a2 U4 r
7 x% r$ E, j  m2 G9 R
参与人数 3威望 +6 收起 理由
elm99 + 2
wangxs_song + 2 支持!
yueyuan2003 + 2
推荐
发表于 2015-9-28 08:51 | 只看该作者
非常感谢,老大,你一定要把16.6的坚持分享到最后一个补丁,最喜欢16.6了,谢谢你啊
    2025-7-30 15:24
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    推荐
    发表于 2015-9-28 09:32 | 只看该作者
    百度也要收费了??无赖, 支持楼主的是奉献精神!
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    推荐
    发表于 2015-9-30 08:52 | 只看该作者
    正在下載中,; x  W/ \! _& e
    感謝大大的提供分享了..
    发表于 2015-9-28 06:19 | 只看该作者
    谢谢分享啊
    发表于 2015-9-28 08:05 | 只看该作者
    总算出来了!谢谢分享!
    发表于 2015-9-28 08:14 | 只看该作者
    好期待啊,谢谢分享
    发表于 2015-9-28 13:35 | 只看该作者
    THS!
    - G' H8 @4 K$ v谢谢分享!* q' ~0 L  L) U$ v
    发表于 2015-9-28 16:14 | 只看该作者
    58都出来了!感谢LZ分享啊
    发表于 2015-9-28 16:19 | 只看该作者
    这简直太快了, 一周一升级呀
    15#
    发表于 2015-9-29 13:55 | 只看该作者
    这个 NB ,才出来,就到位了。
    GMT+8, 2025-11-6 15:04 , Processed in 0.187500 second(s), 26 queries , Gzip On.
