查看: 804|回复: 2
setSGq and getSGq 函數說明使用
发表于 2015-9-22 15:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Squiggle Arrow (~>) Operator
The squiggle arrow (~>) operator is a generalization of the arrow operator. It works the same way as an arrow operator when applied directly to an object, but it can also accept a list of such objects. It walks the list applying the arrow operator whenever it finds an atomic object.
The underlying functions for ~> operator are the setSGq and getSGq functions, which set and retrieve the value of an attribute or a property. For example,
setSGq(obj value prop)             ; is equivalent to:
obj~>prop=value
a=getSGq(obj prop)                 ; is equivalent to:
a=obj~>prop
info=getSGq(cvId objType)          ; is equivalent to:
info=cvId~>objType
setSGq(rect list(10:10 100:120) bBox) ; is equivalent to:
rect~>bBox=list(10:10 100:120)
发表于 2015-9-22 17:21 | 只看该作者
文档里面没有找到getSGq和setSGq,只有putpropq和~>等价。
请问LZ这个说明是在哪儿找的?
網上找到的資料,很多搜尋軟件都可以找到.  详情 回复 发表于 2015-9-23 08:36
 楼主| 发表于 2015-9-23 08:36 | 只看该作者
请问LZ这个说明是在哪儿找的?
GMT+8, 2025-8-20 11:36 , Processed in 0.125000 second(s), 27 queries , Gzip On.
