查看: 3543|回复: 12
Hotfix_SPB16.60.056_wint_1of1.exe更新
发表于 2015-8-31 18:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 zgyzgy 于 2015-9-1 14:13 编辑 . |3 P; P2 ~$ t% }
, ]' `$ k; [0 p0 [4 b3 KDATE: 08-28-2015   HOTFIX VERSION: 056
, U3 j5 c( J9 m" K% j( V===================================================================================================================================, f' G; P5 a& V$ k- ?& }
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
% l) }) X. Z  N/ Z$ p- _===================================================================================================================================
5 ~! h+ z' k% q" [) F( \% o1134412 allegro_EDITOR PLACEMENT        Place replicate creates redundant vias and shapes- option required to prevent that
" P7 p* l- A+ ~4 V1431136 ALLEGRO_EDITOR OTHER            Cannot z-copy board outline with Contract) F: i: R. c0 D
1432392 ORBITIO        INTERFACES       SiP db import is 鈥渃rashing鈥� if no xda inside: O. h0 z0 E- ?/ O7 Z, r2 {
1444820 CONSTRAINT_MGR concept_HDL      Exporting TCF file from Constraint Manager does not output physical and spacing constraints
3 ]8 T0 h4 b) [$ ]$ p. E1447986 F2B            DESIGNVARI       All the DNI parts not available after saving the variant file) Z* A& s) ]2 _% `4 G4 v. \" R
1455901 CONCEPT_HDL    CORE             Need the ability for the front end tool license to have the High Speed option selected by default8 z8 u0 Z5 Y; i
1456280 ALLEGRO_EDITOR DRC_CONSTR       DRC not shown even when the constraint is violated
1 J: y4 m8 H5 ^1458272 SIP_LAYOUT     ASSY_RULE_CHECK  File size increases by factor 4 after ADRC check on a specific customer design
6 {+ o' s% P, L1458960 CONCEPT_HDL    OTHER            Getting packaging error when SEC_TYPE and PACK_TYPE properties go out of sync due to a manual name change in chips.prt
1 L2 y+ \5 _* E1459961 CONCEPT_HDL    PDF              Publish PDF command issues: Logo (.gif file) not rotated, font changed in the published file
( W& D* B7 D6 G2 \9 g  s1460178 ALLEGRO_EDITOR INTERFACE_DESIGN PCB Editor crashes on deleting vias or nets$ |5 X6 V" Z8 R; Y8 O$ K
1460204 SIP_LAYOUT     IMPORT_DATA      BGA Text In wizard ignores the primary pad layer set in text file
3 b! m5 G7 L4 S6 A2 D/ h4 o1460246 APD            OTHER            axlDeleteObject() command is not removing the die from the design6 q0 X+ [* u4 }& d$ ]3 C8 m; ^! l
1461387 SIP_LAYOUT     skill            axlDBRefreshID(nil) removes ID from assigned variable
4 B4 }$ o8 z2 l6 d1461625 SIP_LAYOUT     ASSY_RULE_CHECK  Core polygon routines are not creating proper polygons; ADRCs reported: "acute angle", "exposed metal to exposed metal". a0 D* Y" K' b1 r3 r
! _( k( [$ ?5 x/ Z0 W* R- d
/ H$ i+ B+ X5 H& z. J/ k- q
正在上传文件中,分享链接稍后。。。。。。
9 w) g+ M, j8 X2 F
% Q, x( V5 M3 B2 W
* a4 {5 H" Y  Y! ^( {7 Ehttp://pan.baidu.com/s/1c04SKG4
/ ]# E, h2 z" W+ v5 n* w
- W* X9 N* o, A' @! E! i
1 s2 s6 f+ K0 Z# S" x5 K/ {( \
- m1 i9 t! a* y0 |; j8 ^; }6 n5 G1 Y! J# Y( Y
' Q1 \- _* W( b# Z
参与人数 2威望 +4 收起 理由
小枫残月 + 2 很给力!
yueyuan2003 + 2
发表于 2015-8-31 22:25 | 只看该作者
必须顶  楼主 太好了
发表于 2015-8-31 22:26 | 只看该作者
刚弄55,马上又来了56,真是忙死了。
我也是,前天才刚装完55  详情 回复 发表于 2015-8-31 22:53
发表于 2015-8-31 22:53 | 只看该作者
txwwn 发表于 2015-8-31 22:26  Y& D) t* W' Z8 `2 |4 c: i: X  V
刚弄55,马上又来了56,真是忙死了。
1 C1 Y1 D# o- r% K3 g/ W我也是,前天才刚装完55% c7 `1 d5 U8 K/ x1 D" v
发表于 2015-9-1 00:03 | 只看该作者
必须顶  楼主 太好了
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2015-9-1 08:50 | 只看该作者
    每次一打完補丁,0 D- h/ y4 V5 f
    新的更新就到了,
    : p$ Y: V! l. d& ?% ]9 A& Z坐等感謝大大提供链接囉!!
    发表于 2015-9-1 16:34 | 只看该作者
    谢谢楼主分享
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2015-9-2 08:35 | 只看该作者
    感謝大大提供分享囉!!
    2025-9-28 15:57
  • 签到天数: 316 天
    [LV.8]以坛为家I
    发表于 2015-9-2 08:54 | 只看该作者
    谢谢楼主分享
    发表于 2015-9-2 09:07 | 只看该作者
    更新的太快了
    发表于 2015-9-6 17:12 | 只看该作者
    谢谢分享,正在下!
    2021-7-21 15:48
  • 签到天数: 51 天
    [LV.5]常住居民I
    13#
    发表于 2015-9-8 10:31 | 只看该作者
    支持下楼主!谢谢楼主的分享!
    GMT+8, 2025-11-6 09:52 , Processed in 0.171875 second(s), 28 queries , Gzip On.
