今天花了一个多小时看了这个帖子,很敬佩版主的热心!我有两个地方希望能得到您指导下。
8 \! N3 Z, \. O4 c1.想做一个这样的螺丝孔,需要怎样实现?
# e. e# r1 f- ~3 ~6 s" q4 Z5 T2 \* S/ J* F5 {* a
. x% M, r4 S A: Z U, L2.PADS9.0转化成PADS2005的时候,出现如下错误:1 ^/ h4 h+ p0 W% N* [
1.POWERPCB.REP文件:"Tag" piece on layer Top near (135.85, -11.45) (Drawing name: MARK, Id: 152)
9 c/ `) j0 C- [; G% i7 qis not supported in the format you selected for export: unsupported object type.
6 p7 W4 J$ @: }1 e, E4 b3 cPiece skipped.! Q5 I' C! H- l$ u p# g- h9 V
"Tag" piece on layer <All Layers> near (135.85, -11.45) (Drawing name: MARK, Id: 152)
3 ^. n+ _4 U5 N" g: P* Xis not supported in the format you selected for export: unsupported object type.
4 J# c5 h0 s- p$ O% @1 \Piece skipped.. {! Z: I( X# }( M2 |
2.ASCII.ERR文件:Writing PADS-POWERPCB-V2005.0-BASIC ASCII file.
+ Q* Z1 c' ]! |' U7 \9 }) iWARNING: Decals with different number of pins were detected in Part Type NPN/ECB' v% ^6 v5 y* c1 m n. v' G
CORRECTION: Unused Decals was removed. (TO-220AB)! j: }5 M6 [. L. k* c
WARNING: Decals with different number of pins were detected in Part Type PNP/ECB
5 ^& Y- ^- Y9 mCORRECTION: Unused Decals was removed. (TO-220AB)5 A4 X- w9 X3 C1 q/ o T4 n. ^" ~: t9 I
WARNING: Decals with different number of pins were detected in Part Type B-B-12
& \# s1 ^" i y, K# iCORRECTION: Unused Decals was removed. (B-B-12) |
