查看: 3612|回复: 15
Hotfix_SPB16.60.055_wint_1of1.exe更新
发表于 2015-8-16 18:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
/ `+ O( ^8 f. C3 m
8 U! g$ M, f/ S. n) F8 DDATE: 08-14-2015   HOTFIX VERSION: 055===================================================================================================================================CCRID   PRODUCT        PRODUCTLEVEL2   TITLE===================================================================================================================================1378035 ADW            TDA              Team Design Option: The part_table.ptf file is not updated for the modified parts1394052 allegro_EDITOR INTERACTIV       Edit - Mirror: Symbol preview attached to the mouse appears shifted compared to the symbol origin1400866 PCB_LIBRARIAN  EXPORT_OTHER     Converting DE-HDL parts to orcad: Pin text size is incorrect1407945 SIP_LAYOUT     OTHER            Layer compare not generating shapes correctly1433910 ADW            LRM              Library Revision Manager fails to update the property values of the components in the given design1435326 PCB_LIBRARIAN  CORE             When translating a .olb file into an HDL library symbol, symbol pin name shifts or disappears1436070 SIG_EXPLORER   SIMULATION       Incorrect rise time for IBIS buffer when simulated in SigXplorer1441985 CAPTURE        SCHEMATIC_EDITOR Slow peRFormance while working on a hierarchical design over the network1442435 ALLEGRO_EDITOR OTHER            Suppress Warnings related to Footprints if variable netrev_no_footprint_warnings is set1443249 MODEL_INTEGRIT GUI              Model Integrity does not show version information1450135 ASI_SI         OTHER            Linked differential signal waveform of SigNoise report is not displayed in SystemSI viewer1450287 SCM            B2F              Importing a DE-HDL design with a split symbol(s) in SCM does not import the complete symbol(s)1451085 FLOWS          PROJMGR          Project Manager: The Copy Project function is using the same "session_name" in the new project as the source project1451227 RF_PCB         BE_IFF_IMPORT    RF-PCB IFF Import: Modifications made in Advanced Design System (ADS) are not saved1452134 ALLEGRO_EDITOR SHAPE            Void on internal layer at 0,0 when the drill has an offset, and no padstack is defined for the internal layer1452250 ALLEGRO_EDITOR PARTITION        Cannot import a partition in Workflow Manager1455420 SCM            SCHGEN           System Connectivity Manager: Unable to generate correct document schematic1456043 APD            STREAM_IF        Generating stream data: No wirebond layers in the stream file if you flatten geometry and merge overlapping polygons1458049 concept_HDL    OTHER            Reference to last used variant db has moved in the cpm file正在上传文件中,分享链接稍后,请见谅。$ k2 T9 f3 R# D7 f* d) U9 @
http://pan.baidu.com/s/1c0psAcS
参与人数 2威望 +3 收起 理由
yueyuan2003 + 2
muller1981 + 1 很给力!
发表于 2015-8-17 08:14 | 只看该作者
感謝版大的分享!: P1 D; _: {) C5 |& R3 M3 g! n, w
最近的更新動作真是頻繁啊!
发表于 2015-8-17 08:41 | 只看该作者
必须顶  楼主 太好了
但是下载地址 何时放出~
发表于 2015-8-17 16:01 | 只看该作者
晕,刚下了54准备装就看到了这个。。。那我再等55的下载吧。。。。
发表于 2015-8-17 21:32 | 只看该作者
为什么我的提示总是53呢
发表于 2015-8-19 10:13 | 只看该作者
这个公司现在也是在批量生产, ORCAD的起始界面关了后就打不开了,通过下拉菜单里面的选项关闭起始界面还关不掉
发表于 2015-8-20 06:34 | 只看该作者
感谢分享哦
发表于 2015-8-20 17:33 | 只看该作者
这更新速度实在是太快了  跟不上啊
13#
发表于 2015-8-22 16:42 | 只看该作者
不错 , 55 都有了。
    2021-7-21 15:48
  • 签到天数: 51 天
    [LV.5]常住居民I
    14#
    发表于 2015-8-26 10:42 | 只看该作者
    更新速度好快,谢谢楼主!
    GMT+8, 2025-11-6 13:06 , Processed in 0.187500 second(s), 30 queries , Gzip On.
