查看: 2828|回复: 4
16.01出gerber出问题
发表于 2008-9-20 21:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在15.5中是可以出gerber的,现在用16.01出gerber出现这样的提示
' z9 ~, j7 H2 M2 U---- Photoplot outline rectangle not found ... using drawing extents
$ \' X% M% J0 _/ R/ R  [* X
9 q+ H% P9 ^/ k  D  _9 qSat Sep 20 21:01:35 2008    Page     17 I5 t' f4 F; ~7 P4 Z
Photoplot log file
  U% E# O3 l& N, sResults from parameter file ...& B+ ^) C3 @7 q, K. h$ J! [1 {+ ~1 r
DEVICE-TYPE           GERBER_RS274X
9 v4 L+ B# m* v) |$ TOUTPUT-UNITS          MM
6 c7 z( a8 o% O( S4 n5 XFILM-SIZE             24000 16000( P3 h- f  r, @1 u
FORMAT                5.3
( n7 k( e6 c( n4 C% A+ c& BABORT-ON-ERROR        NO
/ q3 D1 `3 [' R  O) x4 [$ z- \SCALE                 1
* j2 b9 s  R: x3 m6 u( J  B% D1 l! tSUPPRESS-LEAD-ZEROES  YES
- q5 A6 @* @& u! Y/ m) s0 k& I  pSUPPRESS-TRAIL-ZEROES NO. P3 T; H5 H: O% |2 u
SUPPRESS-EQUAL        YES' p, {$ J1 H$ v2 T  I" K
UNDEF-APT-CONT        NO, Y5 b4 y2 r5 R
WARNING: for raster artwork formats, artwork accuracy must be
3 u% C( |, L/ F1 b1 G# K3 a  at least one place greater than the database accuracy, up
+ t% M) D, b' C0 m  to the maximum accuracy allowed by the selected output format.
2 U- r0 e! B' K, ]7 X  Increase the accuracy by increasing the "Decimal Places" in+ H& b* ]# {/ ]( f& B
  the FORMAT section of the artwork parameters and then rerun1 _) X. }" U1 E" w& Y% [# U
  artwork.  R  d5 B, A7 X$ N
  The current output is rounding down the data.  Failure to change
  u% `, t2 K! a. p7 Q. I  the format may result in inaccurate arc coordinates in the output# O4 C/ C% m7 B6 Y/ ^6 {. t
  files and possible shape/void plotting failures.
( A! o5 T+ x2 }/ |% J! z; f
* n9 \0 d: q4 S% ^; V. p================================================================3 H! k# e" N: i, V, m+ {' C" m; A
     PROCESSING FILM < TOP.art > ...
* X: k$ v, M' o% O9 \( H================================================================
8 W; o7 |# w6 t7 S, O  FILM PARAMETERS :. N" T! t, b2 U3 F7 F1 V
  ---------------------------------------------------------- R+ h0 `4 @4 g0 B' ]5 x
  Undefined line width                0.2500
' d+ m0 V6 P' V6 J5 {! I  K* q  Mirror code                         NONE
* y% m& r$ P9 j/ V) H8 N* m  Rotate angle                        NONE# V( i/ m) [9 |" L1 v
  Offset x:                           0.0000
9 Z& X0 k5 @. I( z9 a3 A, v+ g4 e  Offset y:                           0.0000
9 b+ y% p3 g, C6 y* u4 V# m4 Y  Plot negative                       NO
/ f7 F' F) I) D' p/ V* Z. R  Suppress unconnected internal pads  NO
) i1 k" G0 h/ {8 e$ J. b) n( @  }! Y    WARNING: 0 width line found at (0.5000 0.0000)- i& ^4 k/ [7 N4 s8 |9 g% x
           ... using undefined line width of 0.25003 ~) X: ?1 e& q  a, M) F
    WARNING: Segment with same start and end points at! s1 i& r1 ^' |- t
(69.7822 34.5562) will be ignored. Increasing output- s/ ]8 V; D6 b2 i* v
accuracy may allow segment to be generated.+ r( a4 M0 f6 e  ?9 E5 H
9 J( B6 c3 J6 H' ^  APERTURES USED:6 @7 f- I# _' k# W, w& F1 F! `5 ?
; ^4 n) ^" K% p  TYPE       SIZE/NAME                   ROT   MIRROR MODE
/ Q6 k; \6 ^! G) b; m  ---------------------------------------------------------- P9 I( ^9 r& P. K4 S0 H' `
  CIRCLE     0.25000                                  DARK
& }; p3 v" j$ I* P# A; ?  CIRCLE     0.30000                                  DARK % t6 c. A! Y5 L) ?0 A
  CIRCLE     0.40000                                  DARK 3 ^7 ^0 J0 U3 v; w& U3 o: ?& D+ N
  CIRCLE     0.60000                                  DARK 0 F7 d. ]; `$ E7 L7 I! z" J
  CIRCLE     0.63500                                  DARK
8 L2 P* Q: X+ l: Z- Z& \  CIRCLE     0.80000                                  DARK
' I9 J8 \" _: j9 ?* Y# C% P9 C  CIRCLE     1.01600                                  DARK
$ k* q+ r! X; c  CIRCLE     1.27000                                  DARK + v0 M$ q  n1 u. t. b2 |! E
  CIRCLE     1.39700                                  DARK
" R( b8 s0 Y7 S( L" s2 }$ y  CIRCLE     1.52400                                  DARK ( E* h4 ?+ O/ j$ k
  CIRCLE     1.65100                                  DARK
; m  ]7 ~* |  d6 h9 @  CIRCLE     2.30000                                  DARK * g" z5 g; `: N8 W" s) F
  CIRCLE     2.79400                                  DARK , _, R7 m( o2 k- v3 ?' d
  CIRCLE     3.25120                                  DARK
- [' a2 ^: f) e7 I# t- J9 Y  CIRCLE     5.00000                                  DARK ) T) B9 Y' ?3 o. N
  SQUARE     0.76200                     0.000 NO     DARK 6 ?) V/ {/ ?# j5 B; K6 D7 P
  SQUARE     0.76200                     0.100 NO     DARK 9 c5 l0 l, v1 o/ {( A+ j
  SQUARE     1.00000                     0.100 NO     DARK
9 B0 B& |: q( h/ R; e. Q) }5 E$ m! i  SQUARE     1.27000                     0.000 NO     DARK ' D3 a: v& c( Q9 t* d
  SQUARE     1.39700                     0.000 NO     DARK / B& B; U! t: Y) W8 O; @
  SQUARE     1.65100                     0.100 NO     DARK ( l1 {' O! j! M: `; I, z
  RECTANGLE  0.30480     x 1.77800       0.000 NO     DARK 9 ]; q$ h  a# ^
  RECTANGLE  0.30480     x 1.77800      90.000 NO     DARK * @1 N8 l- b. s) g  y: q0 k
  RECTANGLE  0.63500     x 2.03200      90.000 NO     DARK
, E7 ?4 [& i: s2 c/ e+ u! ?  RECTANGLE  1.10000     x 3.00000      90.100 NO     DARK 7 O1 t1 }6 \" l
  RECTANGLE  1.14300     x 1.65100       0.100 NO     DARK
0 k4 Q- F$ T: H  ?  RECTANGLE  1.14300     x 1.65100      90.000 NO     DARK
( o: F  Q0 `. q. X. }" F+ e  RECTANGLE  1.14300     x 1.65100      90.100 NO     DARK
8 f* }6 z+ A3 F" n/ S$ G3 `+ R  RECTANGLE  1.22000     x 2.20000       0.000 NO     DARK
) n( ]& _. A7 ?' L  RECTANGLE  1.50000     x 0.30000       0.000 NO     DARK
. h# v* g/ ^- P. m5 `! o  RECTANGLE  1.50000     x 0.30000       0.100 NO     DARK
0 c& U: b& [6 a2 Q8 I- A; E4 J  RECTANGLE  1.50000     x 0.30000      90.000 NO     DARK
: Z" U+ g5 {% ]  RECTANGLE  1.50000     x 0.30000      90.100 NO     DARK
2 p! Q) o5 g6 z$ v3 C& i6 I  RECTANGLE  1.51890     x 1.65100      90.100 NO     DARK
, w% Q! o+ h6 `3 C  RECTANGLE  1.60000     x 2.20000       0.100 NO     DARK
. z7 N" `2 G* c; E9 Q1 {' a  RECTANGLE  1.60000     x 2.20000      90.100 NO     DARK
: I7 S9 m; G/ _  RECTANGLE  2.20000     x 1.50000       0.100 NO     DARK
( `0 Q; q6 ~* x6 ^) V# q! [  RECTANGLE  2.30000     x 3.80000       0.100 NO     DARK
$ a+ {" ~& x+ T' E  RECTANGLE  2.30000     x 3.80000      90.100 NO     DARK
1 \4 p9 b& m& y0 V* u, C  RECTANGLE  3.00000     x 3.20000      90.100 NO     DARK
+ b  D2 W: y6 x  OBLONG     1.60000     x 3.80000       0.100 NO     DARK
# N$ O3 F+ ?2 q' [3 Z0 r  OBLONG     1.60000     x 3.80000      90.100 NO     DARK
4 B% a6 `: l$ n+ m( L% c( s     TOP created with warnings
发表于 2008-9-21 15:47 | 只看该作者
估计是有设置没好,我是15.7的,生成很正常
发表于 2008-9-22 13:49 | 只看该作者
有几个警告的缘故。
1. “---- Photoplot outline rectangle not found ... using drawing extents“说你没有画photoplot outline,软件自动帮你用drawing extents代替了;---没关系3 V) ?  L" P# B8 V8 Z
2. “for raster artwork formats, artwork accuracy must be  at least one place greater than the database accuracy..."精度设置警告:软件里出gerber时的精度(小数点后位数)应比在设计数据中的高出至少3;---修改后此警告消失.4 T) W# b6 K2 [. [: P
3. “0 width line found at (0.5000 0.0000)           ... using undefined line width of 0.2500“ 这个警告讲得应该听清楚地了吧!----看看(0.5000 0.000)处的这根线是否和自己想要得有出入,若有修改即可;6 b# }% ^; M+ G; E4 v- g
4. “Segment with same start and end points at (69.7822 34.5562) will be ignored. Increasing output accuracy may allow segment to be generated.“ 估计还是精度设置的缘故。说的是软件自动忽略一段起点和终点相同的部分(69.7822 34.5562)
1 E1 j0 U- V" }% }8 K另外,关于精度设置的问题不太确定。是小数为越多越好呢还是说有其他方面的约束(比如板厂方面)?请大家多指教!
 楼主| 发表于 2008-9-23 09:36 | 只看该作者
tahoxu 谢谢你  明白了很多
发表于 2008-9-24 08:36 | 只看该作者
一般整数设为3,小数部分为5
GMT+8, 2025-11-6 03:16 , Processed in 0.156250 second(s), 24 queries , Gzip On.
