在*.brd文件中导入网络表的时候netrev.lst 提示有如下错误:- q1 `+ c, x, ]8 o9 N" I# d" ^6 _5 A
0 t6 J) x" \) O" Z" ?
#1 WARNING(SPMHNI-192): Device/Symbol check warning detected.# r ]$ C' R3 D8 O
ERROR(SPMHNI-196): Symbol 'HDR1X8' for device '8 HEADER_HDR1X8_8 HEADER' has extra pin '9'.
$ W" P2 u/ ~* E#1 ERROR(SPMHNI-191): Device/Symbol check error detected.! a' ~5 a! A- _7 ?
ERROR(SPMHNI-193): Error finding symbol 'DIP8' for device 'OP-27_DIP8_OP-27': 'ERROR(SPMHDB-181): Database revision 14.x is too old ... must run dbdoctor.'.
) P+ {3 T2 x8 j- L% }#2 ERROR(SPMHNI-191): Device/Symbol check error detected.
( N* v2 I' K, r$ }" o4 rERROR(SPMHNI-193): Error finding symbol 'DIP8' for device 'OP-07_DIP8_OP-07': 'ERROR(SPMHDB-181): Database revision 14.x is too old ... must run dbdoctor.'.3 b5 {" ^: @3 W* H% ?
#2 WARNING(SPMHNI-192): Device/Symbol check warning detected.
. p* m0 K& T3 w! R. [5 SWARNING(SPMHNI-194): Symbol 'TO99' for device 'OPA128/BB_TO99_OPA128/BB' not found in PSMPATH or must be "dbdoctor"ed.: H0 \+ o+ W% t m& V
7 \6 t# x T; C/ d( N* c, M' X. f( d0 c4 o$ W! s+ n5 [0 r
对于warning 1: 在design entry cis 中,我对header8 用“Edit part” 命令看过了,只有8个脚,封装我也打开看过可,只放了8个焊盘,这个“extra pin 9“是什么意思啊?该如何解决呢?. O+ ]) w$ }; q1 H3 Z
对于”must' run dbdoctor“的错误和警告,该如何运行dbdoctor 啊?。我只知道可以用 PCB utility 中的dbdoctor 从外部运行和从pcb Editor 中 运行data base check。。9 a0 j' i1 E- o" r- v6 y
1 v! a2 F0 d$ n7 Y谢谢了。。。 |
