查看: 3440|回复: 15
Hotfix_SPB16.60.053 _wint_1of1
发表于 2015-7-22 23:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
+ u* g6 P) H* L  Z) Y! |! u  A& r
) {  X) i# U% F/ q) hDATE: 07-16-2015   HOTFIX VERSION: 053! |; O7 Q3 V% |# M! Y' b
===================================================================================================================================1 Z7 Q' T) M0 A% z3 U% {! U
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
( Q3 t) F+ r7 T1 H$ \3 }& \% h7 x===================================================================================================================================* u' _5 Z2 ?: d; H' T
1045706 SIP_LAYOUT     INTERACTIVE      Enhance the Split Via command to be able to split a stacked via into multiple vias
6 P9 h. D( T: r& r  ^; C1356381 allegro_EDITOR INTERFACE_DESIGN PCB Editor hangs when adding net to a net group" K( s# V9 ^' P6 X) F0 `
1416250 concept_HDL    CORE             Save hierarchy from TDO crashes DesignEntryHDL9 q9 ~9 ]5 Y* j) t8 o4 Z% y  y
1424166 ALLEGRO_EDITOR SHAPE            Dynamic shapes will not fill using the zcopy command
% X$ B5 L& W) B. z1 g1424853 ALLEGRO_EDITOR INTERFACES       Error message "Failed to add (LW)POLYLINE" when importing DXF file into PCB Editor
0 Y3 I8 Z5 @2 I6 R1426668 ALLEGRO_EDITOR DRC_CONSTR       Require shape DRCs with route keepout
- L1 N+ {5 R% {) Q/ U1427168 F2B            DESIGNVARI       Variant directives don't get created in CPM while creating variants) [6 S# H- s8 |' {; O- q3 C) i4 S
1427481 PCB_LIBRARIAN  IMPORT_TEXT      To enhance the import txt file in the PDV8 g3 x. J  W8 n3 q# N6 {, v( X
1428336 PCB_LIBRARIAN  CORE             Symbol Pin Property Attributes not editable with HF49% c, ~. F: n1 h7 |; i: V
1430405 ALLEGRO_EDITOR MANUFACT         Running Export - IPC-2581: The exported .xml data does not contain the Probe figures or the probe information
# p) W/ P# I# A1431570 PCB_LIBRARIAN  VERIFICATION     PDV con2con should read additional properties like NC_PINS from part_table view independant on PACK_TYPE
2 r9 V9 i: F' x  n- t; E! K9 Z2 b1431591 ADW            LRM              LRM should be able to Autofix the parts with $PART_NUMBER even if the SYNC_PROPERTIES has a value of PART_NUMBER- F9 `& N* }7 z+ I9 ?( b/ k
1431875 APD            EDIT_ETCH        When trying to multi-route a group of nets, APD crashes with the .SAV error.
1 n& r$ h- D' `( n1434375 ALLEGRO_EDITOR INTERFACES       Running Export - IPC-2581:  The last or largest pin in a series of pins listed in pinOneCfg.txt is selected  d( \& ?) V* Y' [- Z' d
1434975 ALLEGRO_EDITOR MANUFACT         Running Testprep > Manual causes Allegro PCB Editor to crash
- R. n6 \. ^$ @; ^+ R& U( A3 E1435685 F2B            PACKAGERXL       Export Physical indicates 36 errors are found during backannotation, but the backannotate.log file contains no errors
. l' o7 }. `& W* _1436206 SIP_LAYOUT     ASSY_RULE_CHECK  Ignore shapes autogenerated by the crosshatch void fill routine in the acute angle shape boundary ADRC check
  y+ W' ]$ t# Z7 v7 Q1 I1436699 CONCEPT_HDL    INTERFACE_DESIGN model assignment not working if signal_model exists within a block4 c$ b# u$ {* S( N, }- C! h
1436989 ALLEGRO_EDITOR OTHER            PCB Editor crashes after pouring copper planes
# j* z6 U6 t' C7 k1437150 APD            DIE_GENERATOR    Creating a die using the Compose from Geometry command gives error, "E-(SPMHA1-70): Pin is outside of the extents"
, U' b5 q5 d+ T4 P# R1437287 CONCEPT_HDL    CHECKPLUS        CheckPlus Segmentation Fault in LINUX: E6 \; E# |6 }* O
1437560 ALLEGRO_EDITOR OTHER            APD crashes when running gloss with dielectric generation for the given testcase.8 Z5 U. n. s* C( Q5 r$ \
1437565 F2B            DESIGNVARI       Variant Hier BOM report puts Block DNI in wrong report section
) R$ z+ @3 [. `0 b; b" h/ ~1437725 APD            EDIT_ETCH        Route > Slide exhibits erratic behavior on differential pairs( j3 R# m$ W" ]) I1 V6 V
1437748 SIP_LAYOUT     INTERACTIVE      Allegro Editor and APD have the command opengl report defined in the menu.  Please add this to the SIP menu structure7 M7 Y6 O6 M; @+ A# ^) k
1438933 CONCEPT_HDL    CONSTRAINT_MGR   Model Defined Differential Objects are named differently
0 ~9 C' _% G% Q1439104 ASI_SI         SPDIF            SPDIF popup window" I# [. ]! _2 N4 A9 r
1439574 CONCEPT_HDL    CORE             How do you rotate groups of objects in windows mode?
2 x3 U# S( p* t, v  {9 O1 e1440393 ALLEGRO_EDITOR INTERFACES       Ability to extract STEP properties from DRA requested4 D7 k$ }, `: U  R; n
1440589 ALLEGRO_EDITOR DATABASE         Edit - Change crashes the database with errors." B& x4 ?" ~  m9 Q' k& q( R" v! _0 w3 c
1441665 CONCEPT_HDL    CORE             Property not annotated visible as set in ppt_optionset.dat" D$ {1 f# }5 t/ C4 v
1441672 SIP_LAYOUT     ASSY_RULE_CHECK  ADRC Hangs and does not close3 Z, p, e% g, O( \
1441724 SIP_LAYOUT     PLATING_BAR      Need to be able to set the Plating Bar Width.
  Z, G4 u, ^9 Q9 T/ ?$ V: |1442144 ALLEGRO_EDITOR SCRIPTS          PCB Editor crashes when replaying script5 V" ]+ E9 x: Q& \
1442798 ALLEGRO_EDITOR DATABASE         PCB Editor crashes when running dbdoctor
7 e& N" d4 v' g% ^. k" E# H9 T1443693 ALLEGRO_EDITOR SCRIPTS          Change Accelerator keys for new orcad shape Menu
9 {  N; i/ Y0 ~4 K1443738 F2B            DESIGNVARI       Automatically exclude Nets or Ground Symbols from the Group while adding to Variant1 @/ Z8 Q0 F, A+ d5 z3 ~& j% V
1444066 CONCEPT_HDL    CORE             Replace parts in variant view crash DEHDL if cpm library list contains nonexisting libraries." X7 P. z. b" U: W
1444076 CONCEPT_HDL    CORE             Replacing parts in variants backannotates ALL injected properties in variant view& X0 o2 Y$ N- a; R% n8 V& V
1444676 ALLEGRO_EDITOR SCRIPTS          difference in PCB Editor and OrCAD PCB Editor menus in Hotfix 513 ^. g# @: }8 C9 }, D3 d
, ~. H, ~+ `' Y8 Q* N. S4 I! w下载链接:http://pan.baidu.com/s/1pJoUvtp
/ A# t! Z8 I# S7 ?( R. @
参与人数 2威望 +3 收起 理由
xingnaipeng + 1
yueyuan2003 + 2
发表于 2015-7-24 15:23 | 只看该作者
感谢版主分享。:lol:lol:lol:lol:lol
发表于 2015-7-24 17:36 | 只看该作者
收到!% Z, i6 c4 d! m. Z6 V
大感謝啦!!
GMT+8, 2025-11-5 23:13 , Processed in 0.156250 second(s), 25 queries , Gzip On.
