查看: 6689|回复: 21
Hotfix_SPB16.60.052
发表于 2015-6-28 20:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
6 C1 u; j. X! {4 F' J: N5 U# _+ f" d* Z- j+ }4 Z$ J
这次出大招了更新好多。官网显示是52,DATE里面介绍是51:
$ A* ?+ h! R6 N9 @DATE: 06-26-2015   HOTFIX VERSION: 0519 ^7 a0 r# l0 |: G' C* d' W+ [9 `
===================================================================================================================================: y1 R! q" i( ^$ w! O
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE( i0 G% N( v4 Y7 I8 c' f
5 l/ V' ]1 U, D1 c295747  allegro_EDITOR PLACEMENT        Place manual form takes a long time to open$ Q$ h$ o" ]& C6 X4 v" P
713130  CAPTURE        GENERAL          Bias points get displaced when schematic is copied/pasted in MS Word
+ F, W& Z; x; ?0 B( [832170  SIG_INTEGRITY  SIMULATION       IBIS buffer results with two TV curves do not correlate with HyperLnx or MATLAB results% ?; G* ?% e' ]# o0 s4 G7 S
926138  SIG_INTEGRITY  SIMULATION       IBIS buffer results with two TV curves do not correlate with HyperLnx or MATLAB results
' f; G; d6 ~) ~. l1056824 ALLEGRO_EDITOR INTERACTIV       Need a way to repeat the 'Snap pick to' selection* @. R$ Z3 U% C, R, c* o* _
1131613 concept_HDL    COMP_BROWSER     DE-HDL: inconsistent display of hyperlinks in Component Browser* r4 W; H0 S7 m, p0 M# b
1156766 ALLEGRO_EDITOR INTERACTIV       Retain selected options (lasso, polygon, or path)
7 r2 I7 r6 N' P* t/ B/ l. o1224882 CONCEPT_HDL    CORE             Unable to modify the port position on the sym view if the signal names have double underscores, c" X: O: _( g* b
1225998 CAPTURE        NETGROUPS        Bug: Normal scalar hierarchical pin is getting changed to netgroup pin
. `2 y& G, Z& {1 F. _1281668 ALLEGRO_EDITOR EDIT_ETCH        Arc bump of AiPT
+ ]& M6 T4 [' x- R1286749 FSP            PROCESS          FSP not allowing group swap across inteRFaces in same_vccaux_io region
; D" J0 y* V( }2 o  ?+ P1 Q1306988 SIG_INTEGRITY  SIMULATION       Support needed for the multiple VI and VT waveforms for the buffer with TLSIM* d/ H2 s7 G3 R3 S3 O
1311177 CONCEPT_HDL    CORE             Save Hierarchy for read-only blocks should not produce ERROR(SPCOCN-2123)
& d, D: }$ Z6 Y1315888 SIP_LAYOUT     ASSY_RULE_CHECK  "Dummy" DRC violations with xhatched shapes filled with "crosshatch void fill" function2 [) i; p* f1 M
1319663 PCB_LIBRARIAN  VERIFICATION     con2con always reports the first part name when problems are reported for 2nd or 3rd part name from same primitive
2 j, v* ]5 a. }5 G1321192 APD            VIA_STRUCTURE    When atttempting to delete a layer we get the warning messages stating its a symbol when its a Via Structure issue.
3 Y$ k# v3 D7 V4 S; C7 l+ v9 e1324280 ALLEGRO_EDITOR COLOR            Layer Priority for user-defined Ref Des Layers
3 J9 Q$ F$ e1 ]# M5 ?1327949 CONCEPT_HDL    CORE             not able to add placeholder for VOLTAGE to bodies, \! u, S, Q5 ?$ Q: R8 B+ A
1332123 APD            INTERACTIVE      Snap to pin is snapping to via.
: B: s9 }" }9 L2 T1333113 F2B            PACKAGERXL       A hard LOCATION0 x. S# b% u1 M( B, a
1335908 CIS            RELATIONAL_DB    Relational data fields order do not appear correctly in CIS BOM.6 U( M: l% f+ S; v# t: x
1336970 ADW            LRM              Replaced by report does not show the replacement part2 k, w# X8 P6 r4 P# a& I
1337197 ADW            LRM              DE-HDL crashes and corrupts design during LRM update7 o/ |! V6 F: P4 I, c
1337548 CONCEPT_HDL    COMP_BROWSER     Component Browser in the cached mode crashes when doing a search) J& S# N/ ]- x! Y5 j& I, a) J
1341177 ALLEGRO_EDITOR PLACEMENT        Need the ability to resize the Place Replicate Unmatched Component Interface window
8 j' x3 x& e% G& h' h8 s& g1341940 APD            OTHER            WIRE_COUNT check doesn't work for diepad to diepad bond
" r5 m+ y. K% g1341947 SIG_EXPLORER   OTHER            Sigxplorer hangs when the Wizard_Template_Path variable is set# x/ O5 i5 {0 O; T; y
1343981 SIP_LAYOUT     MANUFACTURING    add an option (Refdes) for Display Pin Text( e6 }5 ~" o, L# r3 O
1345577 TDA            CORE             TDO crashes when attempting to check-out block
' b- ~% u: g/ h! B  }) }1345601 TDA            CORE             Error message when attempting to change to ECO mode& @6 X' h' P8 F5 @
1345629 ADW            LRM              LRM deletes worklib contents when updating schematic design' I! c: j4 d( o) K5 C
1346088 ADW            DSN_MIGRATION    Parts missing in part_table.ptf after design migration
" r) J6 g7 W5 ]) [1346925 APD            STREAM_IF        Need ability to have same class/subclass mapped to more than one stream layer: w$ H- D: O0 `( Q
1347102 CIS            GEN_BOM          MDB file is shown wrong variant name: X% W. B; O( N+ _+ W, K: J" J
1347145 CAPTURE        INTERFACES       Capture crash while editing comapre test bench settings for Pspice design% B$ ?# e% D* S' m& }& I$ F  e
1348619 ADW            LRM              LRM does not update symbol and its attributes in the schematic6 T, D; z; z( _; s
1351123 CONCEPT_HDL    CORE             Changing Net Name in Attribute or using Text > Change deletes constraints
, r. B; \- s0 c+ F- }* O1351700 ADW            LRM              LRM Crashes while loading design: t; g3 B3 T% c, D
1353844 ALLEGRO_EDITOR SHAPE            When creating a copper shape on the M2 layer a void is created running top to the bottom.7 a8 N; S4 Y7 Q7 C3 Y9 V
1354049 SIP_LAYOUT     ASSY_RULE_CHECK  Exclude fillet shapes from the Continuous Solder Mask Coverage ADRC check+ e* p' Y: y% _, v
1354790 CONCEPT_HDL    COMP_BROWSER     Remove limit of 2500 for Component Browser search results: g) ?( V$ O) L: w3 p
1355258 ALLEGRO_EDITOR DATABASE         Matched Groups generating wrong pin pairs6 D$ w4 a# k# y! m% O
1355882 ADW            TDA              ERROR(SPDWSD-58): Unable to copy file ... to folder ... /.sdm/tarballs+ u) N# \- L% E: E* k! e0 @0 k
1357624 CONCEPT_HDL    CORE             DEHDL fails to recognize PTF header changes resolved by LRM7 h% ~* q3 K8 e+ \4 |# r8 r
1357760 CONCEPT_HDL    OTHER            What arguments to use when starting DE-HDL with options?
$ Z7 }1 _# O( F5 G) s1 q* Z1 D1358018 CONCEPT_HDL    CORE             PinPosition from template.tsg located at $CDS_SITE is not honoured for split hier block symbol generation
8 J; M- z" p* v$ J, G* T. N# v. e1358053 TDA            CORE             TDO and VarEdit: Check out variant_cbc.dat separately
1 [" a7 {1 p7 t4 o9 c) X1358511 ALLEGRO_EDITOR INTERACTIV       Replace padstack error message unclear; n; @# B4 D  k% v
1359168 CAPTURE        TCL_INTERFACE    Bug: CIS "Place database part check" tcl command not working
# ?4 @. c5 v% f; C1359357 CONCEPT_HDL    OTHER            HF039 BOM_IGNORE for complex hierarchy is not working normally6 o- T) d. a3 ~; {8 F; _
1360071 CONCEPT_HDL    CORE             The Change Properties dialog does not show a cursor when selecting, U; v7 ~1 W5 k- J- V$ F
1360554 ALLEGRO_EDITOR DRC_CONSTR       Same net DRC disappeared after update DRC.
  \5 m. o# }0 R) O% d$ v6 X1360653 CONCEPT_HDL    CORE             CUSTOM_TXT_CDS not working for defprop in template.tsg. U! l, X  }$ z3 X4 R7 d1 o
1360772 SIP_LAYOUT     INTERACTIVE      Cannot change Clines to a different layer.
' e! @( E3 W6 w. o1361281 ALLEGRO_EDITOR INTERACTIV       Unlike stacked vias, moving non-stacked vias requires an additional step of choosing a pick point
$ B5 ]/ n3 r6 o& U1362156 ALLEGRO_EDITOR PCAD_IN          PCAD import to PCB Editor fails with message "ERROR: netname not NULL for non-etch class"4 g. I+ \) }: F3 W- b3 l  W: M
1363298 ADW            PCBCACHE         Part Manager Error when replacing a part with a
( Z2 U8 z3 Y5 W" P$ Q8 P1365794 ALLEGRO_EDITOR PCAD_IN          PCAD to Allegro translation does not generate the translated board file and also does not give any error message.
. L/ l% U5 ?' [. K: `! ?1 j/ q1366525 ALLEGRO_EDITOR INTERACTIV       The "replace via structure" command of APD and SiP is also required in Allegro PCB Editor2 c- G- U' D/ r" Z
1366976 APD            EDIT_ETCH        Interactive edit etch slide command not working as expected." M% I) C5 l+ M  R" d/ T% n! G
1367224 ALLEGRO_EDITOR INTERACTIV       merge 'shape edit mode' into 16.69.
% F+ @- L$ `. r$ l- Z9 e2 w; e% a1367314 CONCEPT_HDL    OTHER            Setting lock of Reference schematic." z2 T% z+ F( l7 q2 G+ i* c4 K
1367609 F2B            DESIGNVARI       Variant overlay shows the ALT_SYMBOLS attribute for modified inductors
& f; x. ~2 g0 _5 t1 Z1368091 ALLEGRO_EDITOR INTERACTIV       A filled rectangle should be treated as a shape to use the "snap pick to" function with the "Shape Center" option& i) _9 j4 A9 {  T( S7 N
1368159 CONCEPT_HDL    CONSTRAINT_MGR   Make CM_DEFAULT_PRECISION a site.cpm directive
  |2 W( h. m) M3 @+ }# n1370186 SIP_LAYOUT     EDIT_ETCH        Cannot add a via to the selected layer# p" t4 V+ T( s: _
1371015 CAPTURE        OTHER            Tools > Update properties displays Error (ORCAP-1579), \: s( Y+ j3 o8 D  c
1371807 CAPTURE        SCHEMATIC_EDITOR Button Status for 'drag connected objects' hard to see; U$ [8 Y$ x2 B' C4 Z. l& C5 i
1372282 TDA            CORE             Integrator utility to refresh policy
5 u4 E6 P4 D6 Q0 n1372351 CAPTURE        DRC              Browse DRC marker and search of DRC marker are giving different results.
8 y& F4 ^) I0 H5 P% c. m! y1373118 CONCEPT_HDL    CORE             Only generate $HOME/cdssetup/concept files when changes are made; d0 h% v, {. i3 y+ s+ H
1373412 ALLEGRO_EDITOR GRAPHICS         SigXP Print Canvas: Via model is filled by a black via box, t. P9 h, H1 n
1373575 CONCEPT_HDL    INTERFACE_DESIGN Net Group name clash Pin Name9 e7 R+ g' F1 Z. I  Q9 C
1374703 ALLEGRO_EDITOR SHAPE            Inconsistent behavior on shape voiding
5 t! i/ a  q2 p, P% D1375127 ALLEGRO_EDITOR INTERACTIV       The errset skill command with axlSpreadsheetRead crashes the tool$ Q! V5 H! l1 W* f$ O  A4 x
1375940 PCB_LIBRARIAN  PTF_EDITOR       PTF Editor error messages are truncated.
! I; k- G' b5 ^1 E  n1375974 ASI_SI         GUI              want to use SigWave on SI Base
+ n2 C4 [- l) O# U' @1376591 ALLEGRO_EDITOR COLOR            Dehighlight command with "Dehighlight All" option does not remove the color marker swatches from Constraint Manager
0 _# ?1 k8 [9 u" M! x+ K' Y1376634 ALLEGRO_EDITOR INTERACTIV       Snap pick to symbol center not working in symbol editor( U6 S2 b1 f/ h# E
1376765 CONSTRAINT_MGR ANALYSIS         Setup/Hold spreadsheet lists only one pin pair; l* v4 J9 X. n! E( g
1376851 CONSTRAINT_MGR UI_FORMS         CM workbooks change after simulating8 C0 D$ X# F. b: k* V
1377555 ALLEGRO_EDITOR DRC_CONSTR       The "Line to SMD Pin Same Net Spacing" DRC appears and disappears each time Force Update is run for Dynamic Shapes
8 {. W3 t% H- A- k% i- {  Y1377606 APD            REPORTS          APD16.6  Missing Fillets Report ?
* y& {# I& X4 H2 T$ G5 t1378094 CAPTURE        EE_INTERSHEET_RE intersheet References are wrong* `+ w. x9 ]+ f0 n$ A+ v
1378625 ALLEGRO_EDITOR FSP_PINSWAP      FSP crashes while synchronizing design( k6 q7 [; y7 y9 N- L
1378703 CAPTURE        DRC              different DRC results even design and options not changed
, ?: H+ C$ w2 T, b1 X. h1382541 PCB_LIBRARIAN  CORE             Show Pin Numbers in Global Rename Pin dialog for better understanding3 S8 d( D$ N0 M) S
1394552 CONCEPT_HDL    OTHER            The link function enhancement.
8 A8 n) C1 h. I5 O1395007 CONCEPT_HDL    INTERFACE_DESIGN Issue with NET_SPACING_TYPE and NET_PHYSICAL_TYPE properties depending on visibility
# b) b/ d0 V9 U1395033 CAPTURE        HELP             Project opens as text file if the directory or project or project name has .v in it.2 u# q. z5 `3 d1 `7 H
1395356 SIP_LAYOUT     SHAPE            When merging shapes, a certain void in one of the shapes changes location and is resized
3 F8 b- e* G6 q; y- F3 r( B1397564 CONCEPT_HDL    CORE             Design Entry HDL crashes when opening from Part Developer
, X" s- a' [& p4 r; s, G1398919 CONCEPT_HDL    INTERFACE_DESIGN NG buss error
# j5 w* D& ~* Y, r1399924 CAPTURE        OTHER            Error message location always shows in inches
& f- u, h6 k$ [% {1400086 CONCEPT_HDL    CORE             Option to retain the distance between Pin number and wire/pin while moving a pin number.) B4 O+ e8 d5 Y, Y6 r
1400691 CONCEPT_HDL    INTERFACE_DESIGN Rename of netgroups is a must
! S9 Y) f7 K! q" ~1400755 ALLEGRO_EDITOR SHAPE            Updating shapes on design causes a short to a pad
" q4 `6 y( c# q4 Y1 C2 Q0 q0 {1401320 ADW            COMPONENT_BROWSE Issues with filtering in Component Browser( _- i' w* D' e' c
1401900 ALLEGRO_EDITOR MANUFACT         Drill chart resized from V16.5 to V16.6
: L- @' d2 S; c( L" b% Y1402317 ADW            DSN_MIGRATION    Design Migration hangs in the final stage  "saving the design"* W: ~6 _( y/ p/ ~: X) k
1403716 SIP_LAYOUT     SYMB_EDIT_APPMOD SiP layout - Dynamic ability to applying expansion/compression of symbol using app mode' ]" P: J" G* P
1404071 SCM            ERROR_WINDOW     About Violations window messages and Export Physical+ H* f! t5 c" [/ I
1404754 TDA            CORE             setPermissions client API needs to be changed to pass only changed permissions
3 w- U% S! A% O* Y8 e1404993 ALLEGRO_EDITOR DATABASE         dbdoctor falsely reports Illegal rectangle size error has been fixed.
6 B3 D7 }9 B  r1405018 ADW            COMPONENT_BROWSE Need a way to move the Attributes tab first, but make the Properties tab open by default! F4 }8 `' ]; f  f6 N: @
1405201 CONCEPT_HDL    INTERFACE_DESIGN Provide mechanism to sort the Net Groups created in the Interface Browser
5 i1 N% q9 s- B+ h& [* r1405896 CIS            PLACE_DATABASE_P If FPLIST field is set to transfer to design in DBC, Capture CIS crashes
6 N$ G# P: r+ m7 ?1 J1406554 CONCEPT_HDL    INTERFACE_DESIGN When trying to map a port group all members cant be selected
- Q. y9 w3 Z0 H# y; @1406780 CONSTRAINT_MGR OTHER            Deleting cline segments when Constraint Manager is open on net properties bundle crashes PCB Editor+ N/ R% ~6 {  O1 O
1407817 CONCEPT_HDL    INTERFACE_DESIGN Port group mapping issues on saving design when using non-high speed license
. {# L% L. ]' C1408001 ADW            COMPONENT_BROWSE Searchable only properties are missing from a shopping list in UCB
0 v, u, i% v/ F$ z, N9 l& F1408414 ALLEGRO_EDITOR DRC_CONSTR       Waived DRC does not move with the elements it is associated0 d( ~3 W3 ]# M* g- W4 l
1409474 CONCEPT_HDL    GLOBALCHANGE     Global Replace does not retain refdes values
0 u1 S6 b& d# b3 C4 t" U8 d1410333 CONSTRAINT_MGR DATABASE         Unrouted net length does not match total Manhattan length
% Q1 N" N( ?. j6 U1 _+ B1410857 ALLEGRO_EDITOR DRC_CONSTR       Diff Pair Uncoupled length DRC gives different results in SPB16.3,  SPB16.5, and SPB16.6.
  k4 T8 ^( o7 w* F( e" Y1411936 CONCEPT_HDL    CORE             Font support for $PN is inconsistent+ C( `6 D# x1 ~: E6 S
1412878 ADW            COMPONENT_BROWSE Shopping cart tooltip for PPL error has a bad character0 }' Q# F( d  |
1413243 F2B            PACKAGERXL       Backannotation warnings about $PN not deleted from Property file (dcf)3 }/ W; j8 U4 O: Z9 z* ~3 d. O
1413699 F2B            DESIGNVARI       Provide an option to create variant-specific schematics without any variant specific color overwrites; J. Q5 V% E: H" t4 l6 e
1414672 ALLEGRO_EDITOR PAD_EDITOR       Padstack designer Lock mechanisim fails to lock padstack when it's reopened.
$ z( ^3 V* Z8 `; N3 ~0 P0 M, y1415863 CONSTRAINT_MGR OTHER            DCF import ignores Voltage property values
. u3 \' K8 X: `0 C+ w) M1416561 F2B            DESIGNVARI       When using the Replace Component command in DE-HDL, Component Browser takes a long time to load
9 f  N- q$ [5 G# n% w6 x' O1416704 ALLEGRO_EDITOR EDIT_ETCH        AiDT Turning Pattern Corner type option to Arc
0 @% Q* p/ T7 r) o1417283 CONCEPT_HDL    INTERFACE_DESIGN Provide an option to flatten a block when adding it from Component Browser
$ G" {3 g  @# m- s1417802 CONCEPT_HDL    CORE             Multiple ghost images while copying group or objects
0 p/ i- C  @+ Q, B2 [( G0 m1418134 CONCEPT_HDL    CORE             Some objects are removed from the group on using the group move command in Linux
  `8 B$ J8 L9 s3 W3 X# `1418484 SIG_INTEGRITY  SIMULATION       Estimated Xtalk and Simulated Xtalk results do not match in 16.6 ISR044
& {5 i  M$ n% a. ?8 V1419474 CONCEPT_HDL    CORE             CheckPlus, PDF Publisher, should detect invalid view files" I* W2 _- E. n6 N& J( t; K
1419560 ADW            COMPONENT_BROWSE Removing a value from the search criteria, removes the field from the displayed results
( W+ G3 a" D4 w5 @1419954 SIP_LAYOUT     DIE_ABSTRACT_IF  add abstract show ic details to the place codesign die abstract form8 Y' A* Y* F* h7 f  L1 D
1420459 CAPTURE        STABILITY        Capture crashes when library has pages with parts where pin names or numbers have been moved' v2 P5 I5 G3 ]4 b) G' ^- e
1420482 ADW            LRM              LRM deleting symbol properties during the UPDATE process
0 H* }; L" ~# K! j5 `) n7 s1420580 CONSTRAINT_MGR INTERACTIV       Constraint Manager crashes when displaying the Relative Propagation Delay worksheet3 f; j' {% n, [
1420623 CONCEPT_HDL    CREFER           creferhdl fails with message std::bad_alloc on Windows and Linux
7 @9 J6 I% t- [0 H+ O! C% d1421106 ALLEGRO_EDITOR DATABASE         Get message "E- (SPMHDB-183): 'SHAPE' object may not exist on layer 'ETCH/WIRE'" when updating dyanmic shape.2 D2 _: d* H4 D+ I
1421352 ALLEGRO_EDITOR EDIT_ETCH        Application crashes when Create Fanout is executed with a blank end layer.
4 `! |! r, y% ?5 Y7 l0 j1 U$ V1421769 ALLEGRO_EDITOR MANUFACT         NC Drill legend behavior changed from S040 to S0489 h$ b" d& y! p2 m0 `# R# v! `
1422131 APD            DXF_IF           dxf error
+ U! s" \8 H0 n' @: X, x2 l2 R1422153 CONSTRAINT_MGR OTHER            The display in cmDiffUtility is corrupted after a Match Group is removed% c2 z0 x* p, W  y8 U
1422372 CONCEPT_HDL    PDF              Publish PDF-generated file: Unable to click links or copy in Javascript window
, m1 S) @- I* o# E1422993 SIP_LAYOUT     DIE_STACK_EDITOR Diestack Editor graphics depicts die stack incorrectly. The complete stack isn't shown6 O4 }( H+ V2 Y
1423268 SIP_LAYOUT     SYMB_EDIT_APPMOD Update Die Extents causes Die layer change
/ {; E1 p. b+ z1423539 ALLEGRO_EDITOR EDIT_ETCH        Timing Vision crashes for board.
/ y  o, D, I& O/ a) e  ?1423988 ASI_SI         GUI              DesignLink system configuration file is not set automatically on SI-Base+ T3 F; @" h% H% L9 r. Z
1424053 SIP_LAYOUT     ASSY_RULE_CHECK  DRC info of "Acute Angle Merged Metal Check" reports the same via object to itself! L0 A! g$ \9 C/ o& v" N
1424415 GRE            CORE             2 bundles are misbehaving during plan spatial.
2 \" ?9 h9 J- D8 |) i8 T1424773 CONCEPT_HDL    OTHER            How to delete schematic-defined netgroups with locked members in the top-level block
5 J3 W9 v3 D) E2 T. S1425060 RF_PCB         DISCRETE_LIBX_2A Miscellaneous enhancements requested for discrete library translator
8 @4 J. p  w6 Z$ `1425592 F2B            BOM              Generating BOM in CSV format changes the value format
: Y8 G0 N0 O; q$ z7 u1426286 ALLEGRO_EDITOR EXTRACT          Slotted hole within a footprint supported in STEP file3 O# p% s: i% j/ m# |3 _- A% N
1426593 CAPTURE        DRC              orcad Capture crashes on replaying DRC command.8 X: a* B' v  K# }: V( k' X
1426939 CONCEPT_HDL    CORE             Error message SPCOCN-2208 can be misinterpreted
8 M8 f6 l' }7 t1427364 F2B            PACKAGERXL       Board does not backannotate and generates this message: ERROR (SPCOPF-2069): COMP_DEVICE_TYPE: T9 h0 [9 t2 D( I; }
1427690 CONCEPT_HDL    PDF              PDF Publisher on remote display hangs if run on a design with a missing component
; f( j; @' |/ H) S9 B& t" o1427721 CONCEPT_HDL    CORE             The copy paste command on text doesn't preserve the text size
1 K4 \# W- b( W1428130 CONCEPT_HDL    CORE             LRM reports additional parts on schematic which were already synchronized with the cache ptf5 l% Y9 N3 @  @: d. J
1428925 CONCEPT_HDL    CORE             Global signal is not selected as base if it is synonymed to local signal with  ase suffix.
+ v4 H. {! A7 Z0 W) A3 R: ]1429526 ALLEGRO_EDITOR INTERFACES       Export PDF is blank if lanscape mode is selected.
/ u' Y4 N5 J4 y( v! b1429840 SIP_LAYOUT     SYMB_EDIT_APPMOD pin numbers are not applied if I have used library manager
5 F( Z# K4 r4 Z6 `- K' a$ F1430098 ORBITIO        ALLEGRO_SIP_IF   The Die Pads and Vias around Die are missing when the SiP database is imported in ORbitIO
6 b5 [+ ]) d3 i& q1430564 ALLEGRO_EDITOR PLACEMENT        moving group separates Place Bound from group 不好意下载上传都比较慢让大家久等了。下载链接 :http://pan.baidu.com/s/1qWwYnNI- ?) O6 h- a5 D
( e/ R( O, `8 z2 x4 m
" l9 M4 W0 [/ C
参与人数 2威望 +4 收起 理由
inspiron1501 + 2 赞一个!
yueyuan2003 + 2
推荐
发表于 2015-7-1 17:41 | 只看该作者
0 O* g! C; k* g8 r  E- P( u8 `+ s
$ Z- Q) T6 p/ T- C9 A% e/ h- A- T经我安装测试,这个丁丁为51,不过改动相当大,脸都变了
$ s; Z, t/ {- R而且这个版本叫做Cadence 16.6_2015了,不再是之前的16.6了,
' k4 h8 T6 r, N8 B: J$ U( F) M老版本的16.6提示最新版本是Latest Release: 16.6-S050) [# K* g, z( W0 c1 g7 ~
而这个Cadence 16.6_2015会提示Latest: 16.6-2015-S0517 |0 _/ ]% i- ]
% Q. [4 V, G7 H# S  v# T# _) C
9 g  S1 L+ U; N* g0 r: P" V9 D. {- g
# x; v  h' o: Y4 D% ^6 h" F/ i
推荐
 楼主| 发表于 2015-6-30 13:23 | 只看该作者
yueyuan2003 发表于 2015-6-30 10:515 Q- f! Y, D* `! t+ M( ^9 b
恨不得再给你加两分,不给加了,
) @, t8 |6 Y/ c5 G他这个到底是52还是51啊?是52的话51跑哪去了
8 D4 V: \1 W, A6 e
网站上显示52 ,但是资料里面就是51,有次我更新了一个版本,原理图显示没有更新,但是PCB更新成了版本。
; ?8 ]: D$ x$ E. T! [
推荐
 楼主| 发表于 2015-7-11 21:45 | 只看该作者
crskynet008 发表于 2015-7-8 13:59- w$ e& v: R. R
升级安装出问题! 原来破解的许可证不可用了!怎么解决?
+ Y* s. k% x* \, e: h0 S( y' Y
重新破解
5 M  A% A! C" i# d5 p4 p) B( r* |/ A# f
发表于 2015-6-28 22:20 | 只看该作者
好快,就是包包呢
发表于 2015-6-29 09:29 | 只看该作者
继续发扬你那大无畏的分享精神
发表于 2015-6-29 13:26 | 只看该作者
挂52的羊头,卖51的狗肉
 楼主| 发表于 2015-6-30 08:15 | 只看该作者
下载链接在最下哈
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2015-6-30 09:11 | 只看该作者
    一直都有在用16.6,
    * t, ^) h; }' |雖然是偶爾才會安裝補丁,. t% \# m7 n, N# r+ E; H( w
    但要感謝大大的熱情提供分享囉!!" W) M, }6 d9 v, U
    发表于 2015-6-30 10:51 | 只看该作者
    恨不得再给你加两分,不给加了,: F6 H# d! S9 s0 C& D
    他这个到底是52还是51啊?是52的话51跑哪去了. V/ n7 B' N# y( Y
    网站上显示52 ,但是资料里面就是51,有次我更新了一个版本,原理图显示没有更新,但是PCB更新成了版本。  详情 回复 发表于 2015-6-30 13:23
    13#
    发表于 2015-7-5 18:42 | 只看该作者
    安裝了
    & \- e7 `% V1 J" V* t: tLIC卻FAILED了
    2020-3-20 15:39
    14#
    发表于 2015-7-5 23:46 | 只看该作者
    感谢分享啊,这个补丁DRL文件问题有没有解决呢
    GMT+8, 2025-11-5 20:43 , Processed in 0.203125 second(s), 34 queries , Gzip On.
