set ads_autosaverevs = 0
7 i o; {) D3 S" D W' Sset ads_boardrevs = 19 W( v w/ N6 ^9 P+ I
set ads_dbext = brd
* n$ Y/ ^4 i, T; Qset ads_logrevs = 4
( d5 Z6 ?* ~7 [" D0 w& Kset ads_materialname = materials: b. V, Y8 o/ S: W2 ^! s9 v
set ads_msgname = allegro. }/ n$ x" \; I
set ads_norevs = 1% X" z7 v; h( @" v+ T: Y
set ads_textrevs = 2# C ~) u9 ]/ J/ l
set adsboardpath = E:/working/tr5 .
! a: i8 A' K. _: _- N( [set aDSPath = . C:/cadence/SPB_16.6/share/pcb/text
4 |2 Z: w4 u- F8 J! {- pset alibpath = C:/Cadence/SPB_16.6/share/pcb/pcb_lib) {# o2 d! D6 N* d
set allegro_brd2odb = C:\mentorGraphics\Allegro Export ODB++
. U1 K+ f* P6 Z) x- X" iset allegro_dynam_timing_fixedpos =
. w+ |! A6 E' M$ l* L6 x- fset allegro_install_dir = C:/Cadence/SPB_16.6/share/pcb
) d5 O4 W2 @6 q6 }set allegro_install_dll = C:/Cadence/SPB_16.6/tools/pcb/bin# W E1 Y* T! P
set allegro_install_root = C:/Cadence/SPB_16.6
: b4 C1 ?% r1 H6 ?7 J& {$ iset allegro_install_tools = C:/Cadence/SPB_16.6/tools/pcb. @" `5 h/ S$ z1 V* Y; J
set allegro_site = C:/Cadence/SPB_16.6/share/local/pcb1 ]- h+ b: `: U( l" L% P7 I- R
set allegro_type = pcb. E0 t* t3 W8 v' W$ B, y ]0 r
set allusersprofile = C:\ProgramData9 X, \# P3 C1 z c
set ansifont = ansifont6 ~9 S' C4 A. h4 o, T$ v
set appdata = C:\Users\chenmaojie\AppData\Roaming4 i: L! K& p. G# ~$ F# T
set aptpath = . ..
, n; R2 z" I3 z! r! U, Aset artpath = . ..
1 Z$ J7 Z. d! R/ W! H: W/ gset artwork_no_unit_warn =
1 e2 D& _4 C' o4 d! O5 y* Qset autosave =
) J1 R( [3 `% P5 rset autosave_time = 10$ {$ @4 v w: |* h5 b' P4 Z6 e
set base = E:/working/tr5! k# E' h# L, L+ ^ s! e% ?7 @
set batchhelppath = . C:/Cadence/SPB_16.6/share/pcb/batchhelp4 D9 H- k2 H1 a- y; M
set bmppath = . C:/Cadence/SPB_16.6/share/local/pcb/icons C:/Cadence/SPB_16.6/share/pcb/text/icons! u3 B2 @9 b/ r
set brd_dbext = brd
+ u9 C' J! l: p0 [$ S7 d! Sset brd_mcm_tech = EXT=brd:EXTALT=mcm;tech:MSG=BRD/MCM/TECH:TITLE=Select a BRD/MCM/TECH file:
' Q* R0 \! I' A0 `- Rset caetbin = C:\adiva\bin7 ]" G5 S) H+ j3 T
set caetdata = C:\adiva\data
/ @ ?/ ?( x4 @2 Q- ^6 ^: ]set caethelp = C:\adiva\manual2 J7 l7 ~! s; O* J3 J
set cds_lic_file = 5280@chmj- P- m* @# ^& Y: U7 ?& l" Q! E
set cds_lic_only = 1# d# F' O E/ x5 v" ]! ]
set cds_sis_msglog_key = SISMsgLog
% ^9 g, ]! r6 p$ m4 _5 O G' yset cds_site = C:/Cadence/SPB_16.6/share/local9 n# ?: Q5 l7 F+ v! G8 u
set cdsdoc = algcmdref# p& X' R7 {/ G1 S+ n6 n9 J
set cdsplat = wint
% t5 V( l4 |) T9 l i9 q, m; l0 e7 Hset cdsroot = C:\Cadence\SPB_16.6- s4 b7 }7 c8 `/ N) X
set cdsversion = 16.6
4 u' R- e1 v, X7 Y2 @/ Eset chdl_lib_inst_dir = C:\Cadence\SPB_16.63 C) h* w) s$ w8 Y
set cio_dbext = cio* ] p+ a3 ]$ f! k3 {
set class = BOARD GEOMETRY, q6 X% o( P: l l6 a5 C0 t
set clippath = .
& I% J/ t0 z# u! t& q/ ~set commonprogramfiles = C:\Program Files (x86)\Common Files
c! B: R# O% c- L. _! H$ P+ k* Y) Hset commonprogramfiles(x86) = C:\Program Files (x86)\Common Files
' T* G8 j8 I ?3 W+ Iset commonprogramw6432 = C:\Program Files\Common Files9 R& B, O1 K" ^9 V
set compalib = C:/Cadence/SPB_16.6/share/pcb/pcb_lib/symbols C:/Cadence/SPB_16.6/share/pcb/allegrolib/symbols ^: |9 {1 m: Z" ]7 T {
set complibpath = C:/Cadence/SPB_16.6/share/pcb/allegrolib3 @5 Z' w% N0 ~" a# E- q
set computername = CHMJ' {3 y. o4 N+ w# j+ I9 T j8 ]6 ?# F
set comspec = C:\Windows\system32\cmd.exe; k- t; T h& N+ U3 w# N" j- l. e
set concept_inst_dir = C:\Cadence\SPB_16.6" G. u7 [1 X) `( H: W% j* L
set cwd = E:/working/tr50 C5 j" q& [3 k2 `
set dclpath = . .. C:/Cadence/SPB_16.6/share/pcb/pcb_lib C:/Cadence/SPB_16.6/share/pcb/allegrolib8 e; p' T& E) e' X0 f1 r
set devpath = D:\Allegro_LIB\Allegro_LIB\0 z- Z5 P- m- v a
set dfaauditpath = . C:/Cadence/SPB_16.6/share/local/pcb/assembly C:/Cadence/SPB_16.6/share/pcb/assembly
; g1 n" T- t9 c( A( o, ?set dfacnspath = . dfa .. ../dfa C:/Cadence/SPB_16.6/share/local/pcb/dfa1 z; |& O8 t' t' p) n
set display_backingstore = on. y7 @7 J. W$ f; ^- `( k y
set display_nohilitefont = 9 L! j. o1 h$ b4 A
set display_norepair = rats& {3 j% l, O7 }
set display_shapefill = 4) {' W8 k6 r- j
set display_shapefill_analysis = 2
% J7 h0 P# M6 m2 a. N5 bset dpm_dbext = dpm4 G0 ^7 J4 v W$ H- j+ d
set dps_dbext = dps
# C7 m& s( h [9 z- O& x; Mset drawing_4mils =
0 a* i: v- L' n# ^( Y1 d. uset drc_diff_pair_overide = 0% e9 q: H# p# F& d% S
set envpath = C:/Users/chenmaojie/AppData/Roaming/SPB_Data/pcbenv C:/Cadence/SPB_16.6/share/pcb/text
# Q2 {; L( Z7 w$ ^ W" |0 O% ?; L. Qset ext_artwork = art
! V E1 k- P' A/ J% O7 ~) vset ext_drill = drl- o6 i) ]3 ] f% s
set film_nosort = : }/ U6 E0 F, H
set formpath = . C:/Cadence/SPB_16.6/share/local/pcb/forms C:/Cadence/SPB_16.6/share/pcb/text/forms
# {/ D4 o. d1 L2 @; q* |set fp_no_host_check = NO
2 Q! o0 |1 l- C/ }4 D1 ]set global = C:/Cadence/SPB_16.6/share/pcb/text
1 z3 z' N0 j+ K6 @+ B# @set globalpath = . C:/Cadence/SPB_16.6/share/pcb/text' {# N; ^2 R7 Z; E
set helppath = . C:/Cadence/SPB_16.6/share/pcb/help C:/Cadence/SPB_16.6/share/pcb/text/help8 v0 N9 a8 I) e5 z4 B* M/ h
set home = C:/Users/chenmaojie/AppData/Roaming/SPB_Data
/ K4 B5 R! s8 ~6 @# d' Dset homedrive = C:
+ i$ ]% v8 Q% m: pset homepath = \Users\chenmaojie
% K# h/ w; f1 Z$ x- }8 }2 xset ignore_popup_action =
7 H5 D. d3 X2 R; vset imagepath = . C:/Cadence/SPB_16.6/share/pcb/examples/image
! s0 |7 w5 G: y+ G, lset kanjifont1 = kanjifont1* e4 Z8 }; W$ A/ X& g0 O
set kanjifont2 = kanjifont2
" u: t0 J" Q4 B( X4 Vset kanjifontpath = . C:/Cadence/SPB_16.6/share/pcb/text/fonts/kanji6 J% r7 c; g; H+ q( @% y
set ldfpath = .# A) e% e& P. _& j. o3 U3 l
set localappdata = C:\Users\chenmaojie\AppData\Local) C6 [' C8 i+ n$ ^2 r
set localenv = C:/Users/chenmaojie/AppData/Roaming/SPB_Data/pcbenv4 |) E+ k$ U4 H4 ?" i; i+ T
set localpath = . C:/Users/chenmaojie/AppData/Roaming/SPB_Data/pcbenv C:/Cadence/SPB_16.6/share/local/pcb . C:/Cadence/SPB_16.6/share/pcb/text
8 M! r' X5 j- Iset logonserver = \\CHMJ
w. a6 v6 I6 ~/ iset materialpath = . C:/Users/chenmaojie/AppData/Roaming/SPB_Data/pcbenv C:/Cadence/SPB_16.6/share/local/pcb C:/Cadence/SPB_16.6/share/pcb/text
) |! b8 E& f! T9 V3 ?3 w! vset mcm_dbext = mcm: m' C: q( B) H4 p* C
set menuload = allegro
0 k! m) e; L; A# G+ E6 k. F4 N0 Yset menupath = . C:/Cadence/SPB_16.6/share/local/pcb/menus C:/Cadence/SPB_16.6/share/pcb/text/cuimenus2 t+ }: X* A! @' ~1 X
set module = TR5_A0.brd7 x z$ L( F, _' e
set modulepath = . C:/Cadence/SPB_16.6/share/local/pcb/modules/ H5 U6 |+ S" n, Y5 k/ O0 F
set ncdpath = . .. C:/Cadence/SPB_16.6/share/local/pcb/nclegend C:/Cadence/SPB_16.6/share/pcb/text/nclegend
0 J& [: v2 i- r+ s- `: l6 Cset noshow_current_selections = 2 S9 f% i* w1 G( ]$ t+ P
set number_of_processors = 46 h7 a. e4 I6 }+ l. N( l+ s K
set oa_plugin_path = C:\Cadence\SPB_16.6\Share\oaPlugIns
$ ? s* O$ Y& f9 w) {. n2 wset os = Windows_NT
* e6 T4 H6 Q7 Bset padpath = E:\layout working\SPO2 WITH MFI\SPO2 LIB\ D:\ALLEGRO\ E:\LAYOUT WORKING\PACKAGE\1394\ E:\LAYOUT WORKING\PACKAGE\11.10\4 j5 K8 X7 @- Q2 O+ f
set path = C:\MentorGraphics\Allegro Export ODB++\nv\bin C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common C:\Windows\system32 C:\Windows C:\Windows\System32\Wbem C:\Windows\System32\WindowsPowerShell\v1.0\ C:\Program Files (x86)\WinMerge C:\Program Files\TortoiseSVN\bin C:\Program Files (x86)\Skype\Phone\ C:\Cadence\SPB_16.6\openaccess\bin\win32\opt C:\Cadence\SPB_16.6\tools\capture C:\Cadence\SPB_16.6\tools\Pspice C:\Cadence\SPB_16.6\tools\specctra\bin C:\Cadence\SPB_16.6\tools\fet\bin C:\Cadence\SPB_16.6\tools\libutil\bin C:\Cadence\SPB_16.6\tools\bin C:\Cadence\SPB_16.6\tools\pcb\bin
6 x8 R6 X7 X- @1 b/ |set pathext = .COM .EXE .BAT .CMD .VBS .VBE .JS .JSE .WSF .WSH .MSC8 A# _( U' {* K
set pcb_cursor = cross$ L- S+ u; M$ m! k# r$ u8 g
set pcell_lib_path = C:/Cadence/SPB_16.6/share/local/pcb/../../RFsip/sip_pcells . sip_pcells .. ../sip_pcells! Y5 z( }0 U) i# f
set pdfpath = . C:/Cadence/SPB_16.6/share/pcb/help/pdf- c$ E) l$ t- {1 Z/ P& I2 j/ q, M
set pm_cmdmap = allegro# Z7 o5 A1 E) Y7 A
set prfeditpath = . configure/prfedit C:/Users/chenmaojie/AppData/Roaming/SPB_Data/pcbenv/configure/prfedit C:/Cadence/SPB_16.6/share/pcb/configure/prfedit
+ Z# U& A* _$ V' p- N7 Yset processor_architecture = x86
: Q. Z1 ~$ I' O( r( M8 Y5 Z5 ^2 Uset processor_architew6432 = AMD641 O; U8 Z8 x$ O9 @: [& ^
set processor_identifier = Intel64 Family 6 Model 37 Stepping 5, GenuineIntel7 _ f! Z8 y- T6 Y5 r- Q
set processor_level = 6
. u3 d* c/ z, |4 j6 @* Cset processor_revision = 2505: m2 o! b, d0 ]' {/ \5 f5 b
set programdata = C:\ProgramData! E, T$ a; x$ `6 N: H3 ~
set programfiles = C:\Program Files (x86)8 F! d4 \5 m' ?' E! e: \$ v( M
set programfiles(x86) = C:\Program Files (x86)3 {7 C& R; b3 w* s! S( [
set programw6432 = C:\Program Files3 P" y7 g7 K5 b' a( s$ U0 Z8 N" ~2 S
set psmodulepath = C:\Windows\system32\WindowsPowerShell\v1.0\Modules\8 V8 g! t4 _2 W
set psmpath = E:\layout working\SPO2 WITH MFI\SPO2 LIB\ D:\ALLEGRO\ E:\LAYOUT WORKING\PACKAGE\1394\ E:\layout working\package\11.10\8 U+ Z3 ~$ a" [& z5 f1 u
set public = C:\Users\Public. e7 P& N; v0 P4 p5 u$ m
set roaminc = 96
+ o+ v ^- l ~6 N" `set scfpath = . scfs .. ../scfs
0 o# T: E# n& ~, y9 b6 Eset scriptpath = . C:/Cadence/SPB_16.6/share/local/pcb/scripts C:/Cadence/SPB_16.6/share/pcb/text/script
- e! c0 Q; j3 X% d' u5 Rset sessionname = Console; Q/ M# O8 r M! j
set si_model_path = .
$ s9 q# G2 `5 z& S8 Iset signal_install_dir = C:/Cadence/SPB_16.6/share/pcb/signal
1 L, E; G" C x- X5 y5 cset signal_optlib_dir = C:/Cadence/SPB_16.6/share/pcb/signal/optlib
0 H" i# V6 \6 K _+ zset signoisepath = . C:/Users/chenmaojie/AppData/Roaming/SPB_Data/pcbenv C:/Cadence/SPB_16.6/share/local/pcb/signal C:/Cadence/SPB_16.6/share/pcb/signal C:/Cadence/SPB_16.6/share/pcb/signal/optlib C:/Cadence/SPB_16.6/share/pcb/text
w y: M/ m# _0 Y( `5 N$ V. L1 qset sip_dbext = sip
- U1 F* }2 w. M# iset slide_arcs =
/ r# u+ d4 T4 E) l) Mset sproutepath = C:/Cadence/SPB_16.6/share/pcb/configure/sproute
$ s2 {$ B- [+ iset subclass = OUTLINE2 G9 R3 D& z. |' J7 N! {! [
set systemdrive = C:/ n. P/ @& z: U/ |
set systemroot = C:\Windows
' ~& k: g) P$ k1 \set techpath = . C:/Cadence/SPB_16.6/share/local/pcb/tech C:/Cadence/SPB_16.6/share/pcb/text/tech8 B" W+ I3 G9 G
set telenv = C:/Cadence/SPB_16.6/share/pcb/text/env
5 T& W I# ~ |% r2 F `set temp = C:\Users\CHENMA~1\AppData\Local\Temp
! @1 f4 y# m$ p- Yset textpath = . C:/Cadence/SPB_16.6/share/local/pcb/extracta C:/Cadence/SPB_16.6/share/pcb/text/views f6 ]6 |) S6 \8 }6 d2 x S! `
set tilepath = . C:/Cadence/SPB_16.6/share/local/pcb/modules
u3 a7 I8 h/ @) Wset tmp = C:\Users\CHENMA~1\AppData\Local\Temp6 I: {( Z) O% W4 T- |$ D
set topfilelib = C:/Cadence/SPB_16.6/share/pcb/pcb_lib/templates C:/Cadence/SPB_16.6/share/pcb/allegrolib/templates/ m' q3 n7 k+ U1 z
set topology_template_path = . templates .. ../templates C:/Cadence/SPB_16.6/share/local/pcb/topology C:/Cadence/SPB_16.6/share/pcb/pcb_lib/templates C:/Cadence/SPB_16.6/share/pcb/allegrolib/templates0 O* B" r. ?* Q4 z8 L: B+ a
set units = C:/Cadence/SPB_16.6/share/pcb/text/units.dat) R& L; p& ~6 m: p) m) g* J, H/ A
set userdomain = chmj
7 Q: Z, A" W) J" `$ p2 q! N M. e/ v6 dset username = chenmaojie |7 Q' f! u! C5 y) A
set userprofile = C:\Users\chenmaojie
) Y+ [$ Q0 R7 O' c& w" H+ jset vectorfontpath = . C:/Cadence/SPB_16.6/share/pcb/text
4 a7 v3 |5 y# w5 C, n; s: xset viewlog = E:/working/tr5/signoise.log
" Y: d3 v& q8 l3 x+ m- aset viewpath = . C:/Cadence/SPB_16.6/share/local/pcb/views
) O3 L" T7 [$ Z3 t, q5 O4 lset wbpath = . C:/Cadence/SPB_16.6/share/local/pcb/wbtiers+ K, W0 i4 g. m" w- J+ ^/ o* f+ P* c
set windir = C:\Windows7 Q! e2 Z( X/ G8 h. j M) w
set windows_tracing_flags = 3
1 Y0 z" r# r3 F! Aset windows_tracing_logfile = C:\BVTBin\Tests\installpackage\csilogfile.log
& n' x+ A3 H* J7 M9 kset wint = : [2 W3 g5 L6 a7 N
set wirebond_hud_update_frequency = 25
* Q& n. e3 Q9 Z# `+ Aset wirebond_suppress_bondwire_drcs =
" V) L E! K( X" a) Cset wizard_template_path = . .. C:/Cadence/SPB_16.6/share/pcb/pcb_lib/symbols/template% q) x) |3 N+ a3 @, @) r
set xtalk_table_path = . xtalk_tables .. ../xtalk_tables C:/Cadence/SPB_16.6/share/local/pcb/xtalk C:/Cadence/SPB_16.6/share/pcb/pcb_lib/xtalk_tables
8 s# H+ @& t3 ~$ M$ R7 G& \set __compat_layer = DisableThemes. L4 l; u. q" p( f% M
set _allegro_adv_optimize =
) [: f, |0 y" J) }- ~7 ^, Kset _allegro_aibt_built_in =
8 \; o- ~! |- i1 a& ~. S, D% Dset _allegro_cns_regions_ok = 19 V t! f/ ^5 x5 n3 V$ l" a
set _allegro_cstm_nclegend_ok = 1
) Z( T+ v4 z0 R0 e wset _allegro_diffpair_ok = 1
+ { a1 X H9 N. J* rset _allegro_diffpair_static_ok = 1
- F, o, K' A! i, d p/ @set _allegro_ecsetflatten = 1
( s6 Z, o( k8 K9 A* M" Zset _allegro_elec_cns_ok = 1
4 K4 n6 {4 D. z+ \# Vset _allegro_electrical_checks = 1, Q8 c& y ~4 K* B
set _allegro_gre_all = 1
% K% [& d! E8 y# {& yset _allegro_gre_ifd = 1, S: K. H1 ?% o9 A; v& U5 E8 D
set _allegro_gre_view = 1
+ g, B( _ I( \# P5 f' u! S" zset _allegro_group_route = 1: J: |# f8 ~1 B* z! g; \5 ]
set _allegro_ibd_all = 1
5 X9 D% P1 E2 Y: Kset _allegro_ibd_view = 1' G, _* |. w+ Z
set _allegro_mini_ok = 1
, ?/ {6 z! V7 F/ d, [set _allegro_pcb_gxl =
, n( O; L4 h" fset _allegro_ratt_ok = 1
6 O' h% J p* x* [% |1 {set _module = TR5_A0.brd) ^, f. c0 M; E; ?6 n# _/ Q
set _module_base = TR5_A03 W) i0 D& i/ e: P
set _program = allegro
6 B5 Q, v" n1 f5 f1 Y$ z8 i
3 ` G) I8 M8 [: O& v! G
7 }9 T8 l1 K; P7 j4 \2 }9 c8 s0 p' I# \1 J! ~
3 H! F2 i/ h8 W
这个是我allegro 的设置
1 } N* T, L2 P' r* r3 T+ q5 q8 B H; R! I% \1 k' j
