查看: 1112|回复: 2
cot
    2024-7-11 15:39
    发表于 2015-5-26 17:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    ; Purpose:        This routine is a very simple utility that will create oblong thermal shape
    ;  (btw: you can get some idea from Create_Thermal_Flash.il also)
    CreateOblThForm()
    defun( CreateOblThForm ()
            MainFormFile=axlTempFile()
            p = outfile(MainFormFile "w")
            f_FormBegin(p 35,20,"Create Oblong Thermal - RichardL." "TOOLWINDOW")
            f_Bitmap(p "cot" "cot" 0 0 14 14)
            ;f_Bitmap1()
            f_Text(p "Outer diameter(A):",15,0)  f_EditFloat(p "A",29,0,5,5,4)
            f_Text(p "Inner diameter(B):",15,3)  f_EditFloat(p "B",29,3,5,5,4)
            f_Text(p "Oblong length(D):", 15,6)  f_EditFloat(p "D",29,6,5,5,4)
            f_Text(p "Circle spoke(C):",  15,9)  f_EditFloat(p "C",29,9,5,5,4)
            f_Text(p "Oblong spoke(E):",  15,12) f_EditFloat(p "E",29,12,5,5,4)
            f_Group(p "Direction",2,14,32,4)
            f_CheckList(p "H", 4,16,"Horizontal","di")
            f_CheckList(p "V",18,16,"Vertical","di")
            f_Button(p "OK",2,19,10,3)
            f_Button(p "Cancel",20,19,10,3)
            f_FormEnd(p)
            close(p)
            MainFormFile
    );func
    CheckCOTValue()
    defun( CheckCOTValue ()
    prog( ()
    let( ()
            if((ot->a>0 && ot->b>0 && ot->c>0 && ot->d>0 && ot->e>0) then
       if((ot->a>ot->b && ot->d>ot->e && ot->b>ot->c) return(t)
       axlMsgPut("Invalid Value between A,B,C,D,E")
            );if
            axlMsgPut("Invalid Value, check your value carefully.")
            return(nil)
    ;global
    defstruct( struOblTh a b c d e dirH)
    ot=nil
    defun( CreateOblongThermal ()
            MainFormFile=CreateOblThForm()
            fw = axlFormCreate((gensym) MainFormFile '("NE" "msglines" 0) 'OblThCallback t nil)
            ot=make_struOblTh(?a 100 ?b 50 ?c 20 ?d 100 ?e 30 ?dirH t)
    (axlFormSetField fw "A" ot->a)
    (axlFormSetField fw "B" ot->b)
    (axlFormSetField fw "C" ot->c)
    (axlFormSetField fw "D" ot->d)
    (axlFormSetField fw "E" ot->e)
            (axlFormSetField fw "H" ot->dirH)
            (axlFormSetField fw "bmp" "cot")
    axlFormDisplay(fw)
    ; return(fw)        ; return form handle to caller
    defun( OblThCallback (fw)
            case(fw->cuRField
                    ("H" ot->dirH=t)
                    ("V" ot->dirH=nil)
                    ("A" ot->a=fw->curValue)
                    ("B" ot->b=fw->curValue)
                    ("C" ot->c=fw->curValue)
                    ("D" ot->d=fw->curValue)
                    ("E" ot->e=fw->curValue)
            if(fw->doneState==2 || fw->doneState==3 ;cancle & close
                    then axlFormClose(fw) axlTempFileRemove(MainFormFile))
            case(fw->doneState
            (1 ;here is the real main thing!
            if(CheckCOTValue() then
            axlShell("done")
    axlSetActiveLayer("etch/top")
            axlDBChangeDesignExtents( '((-1000 -1000) (1000 1000)))
            if(ot->dirH then
            path = axlPathStart( (list -ot->d/2:-ot->a/2))
            axlPathLine(path,0,ot->d/2:-ot->a/2) axlPathArcAngle(path,0,ot->d/2t->a/2,  nil,180)
            axlPathLine(path,0,-ot->d/2t->a/2) axlPathArcAngle(path,0,-ot->d/2:-ot->a/2,nil,180)
            else
            path = axlPathStart( (list ot->a/2:-ot->d/2))
            axlPathLine(path,0,ot->a/2t->d/2) axlPathArcAngle(path,0,-ot->a/2:ot->d/2,  nil,180)
            axlPathLine(path,0,-ot->a/2:-ot->d/2) axlPathArcAngle(path,0,ot->a/2:-ot->d/2,nil,180)
            shapeid=axlDBCreateShape(path t)
            o_poly = axlPolyFromDB(car(shapeid)) axlDeleteObject(car(shapeid))
            i_poly=axlPolyExpand(o_poly -(ot->a-ot->b)/2 'NONE)
            if(ot->dirH
            shapeid=axlDBCreateRectangle(list(-ot->d/2-ot->a/2:-ot->c/2 ot->d/2+ot->a/2:ot->c/2) t)
            shapeid=axlDBCreateRectangle(list(-ot->c/2:-ot->d/2-ot->a/2 ot->c/2:ot->d/2+ot->a/2) t)
            i_poly=append(i_poly axlPolyFromDB(car(shapeid))) axlDeleteObject(car(shapeid))
            if(ot->dirH
            shapeid=axlDBCreateRectangle(list(-ot->e/2:-ot->a/2 ot->e/2:ot->a/2) t)
            shapeid=axlDBCreateRectangle(list(-ot->a/2:-ot->e/2 ot->a/2:ot->e/2) t)
            i_poly = append(i_poly axlPolyFromDB(car(shapeid))) axlDeleteObject(car(shapeid))
            f_poly = axlPolyOperation(o_poly i_poly 'ANDNOT)
            foreach(onepoly f_poly axlDBCreateShape(onepoly t))
            axlWindowFit()
            );CheckCOTValue
            );case
    ;CreateOblongThermal()
    axlCmdRegister( "COT" `CreateOblongThermal)
    ;DESCRIPTION:           basic form operation with tmpfile support
    ;AUTHOR: Richard L.   fpmontreal@gmail.com
    f_FormBegin(p w h title form_opt)  TOOLWINDOW / AUTOGREYTEXT / FIXED_FONT / UNIXHGT
    defun( f_FormBegin (p w h @optional (form_title "by RichardL.") (form_opt "AUTOGREYTEXT"))
            sprintf(dest,"FILE_TYPE=FORM_DEFN VERSION=2\nFORM %s\nFIXED\nPORT %d %d\nHEADER \"%s\"\nTILE\n\n",form_opt,w,h,form_title)
            if(p fprintf(p,"%s",dest))
            dest
    f_FormEnd(p flexmode) StandButtons / EdgeGravity / EdgeGravityOne
    defun( f_FormEnd (p @optional flexmode)
            if(flexmode        sprintf(dest,"FLEXMODE %s\nENDTILE\nENDFORM\n",flexmode)
                    sprintf(dest,"ENDTILE\nENDFORM\n")
            dest
    f_CheckList(field x y name group)
    defun( f_CheckList (p field x y name @optional (group nil))
            if(group==nil
                    sprintf(dest,"FIELD %s\nFLOC %d %d\nCHECKLIST \"%s\" \nENDFIELD\n\n",field,x,y,name)
                    sprintf(dest,"FIELD %s\nFLOC %d %d\nCHECKLIST \"%s\" \"%s\"\nENDFIELD\n\n",field,x,y,name,group)
            dest
    f_Group(field x y w h)
    defun( f_Group (p field x y w h)
            sprintf(dest,"GROUP \"%s\"\nFLOC %d %d\nFSIZE %d %d\nENDGROUP\n\n",field,x,y,w,h)
            dest
    f_Text(field x y)
    defun( f_Text (p text x y)
            sprintf(dest,"TEXT \"%s\"\nFLOC %d %d\nENDTEXT\n\n",text,x,y)
            dest
    f_EditFloat(field x y iw dw dec)    (iw-input width) (dw-data width)
    defun( f_EditFloat (p field x y iw dw dec)
            sprintf(dest,"FIELD %s\nFLOC %d %d\nREALFILLIN %d %d\nDECIMAL %d\nENDFIELD\n\n",field,x,y,iw,dw,dec)
            dest
    f_Button(x y w h)
    defun( f_Button (p name x y w h)        ;close done/ok cancel help print
            sprintf(dest,"FIELD %s\nFLOC %d %d\nMENUBUTTON \"%s\" %d %d\nENDFIELD\n\n",name,x,y,name,w,h)
            dest
    f_Bitmap(name x y w h @optional opt)
    defun( f_Bitmap (p field name x y w h @optional (opt nil))                ;[RIGHT | CENTER | BORDER | BOLD | UNDERLINE]
    bmppath = axlGetVariable("BMPPATH")
        axlSetVariable("BMPPATH" "~/skill/")
            if(opt==nil
            sprintf(dest,"FIELD %s\nTHUMBNAIL %s\nFLOC %d %d\nFSIZE %d %d\nENDFIELD\n\n",field,name,x,y,w,h)
            sprintf(dest,"FIELD %s\nTHUMBNAIL %s\nOPTIONS %s\nFLOC %d %d\nFSIZE %d %d\nENDFIELD\n\n",field,name,opt,x,y,w,h)
            dest
    defun(f_Bitmap1 ()
    printf("%s\n" bmppath)
    ;FIELD bmp
    sprintf(P "FIELD bmp\n")
    sprintf(P "THUMBNAIL cot.bmp\n")
    ;FLOC 1 3
    sprintf(P "FLOC 0 0\n")
    ;FSIZE 23 5
    sprintf(P "FSIZE 14 14\n")
    ;ENDFIELD
    sprintf(P "ENDFIELD\n")
    f_TreeView(field x y w h)
    defun( f_TreeView (p field x y w h)
            sprintf(dest,"FIELD %s\nFLOC %d %d\nTREEVIEW %d %d\nENDFIELD\n\n",field,x,y,w,h)
            dest
    example: CreateMainForm()
    defun( CreateMainForm ()
            f_FormBegin(p 80,20,"Batch Symbol Creater - Richard L.")
            f_Group(p "Select Level",2,2,20,8)
            f_CheckList(p "LevelMax",  4,4,"1 - Maximum","rg")
            f_CheckList(p "LevelMom",  4,6,"2 - Nominal","rg")
            f_CheckList(p "LevelLeast",4,8,"3 - Least",  "rg")
            f_Text(p "SolderMask Ext:",2,12) f_EditFloat(p "SolderMaskOffset",14,12,7,7,4)
            f_Text(p "Silk Gap:",      2,14) f_EditFloat(p "SilkGap",         14,14,7,7,4)
            f_Text(p "SilkWidth",      2,16) f_EditFloat(p "SilkWidth",       14,16,7,7,4)
            f_Text(p "Choice Symbol(s):",24,2)
            f_CheckList(p "AllSym",40,2,"Select All")
            f_TreeView(p "SymTree",24,4,56,12)
            f_Button(p "Run",2,20,10,3)
            f_FormEnd(p)
            close(p)
            MainFormFile
    );func
    2024-7-11 15:39
     楼主| 发表于 2015-5-27 08:47 | 只看该作者
    fllash skill
    GMT+8, 2025-8-20 22:25 , Processed in 0.125000 second(s), 23 queries , Gzip On.
