查看: 3136|回复: 13
Hotfix_SPB16.60.049_wint_1of1补丁
发表于 2015-5-10 11:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
补丁更新:http://pan.baidu.com/s/1o6KasMe
" s) ?" V( O; Q  f3 t3 a6 s; `+ F
( Q& [$ ~  o9 ^8 `0 A* w" H& S7 T4 v7 zDATE: 05-8-2015    HOTFIX VERSION: 049$ q  t0 Y  o- {
===================================================================================================================================  m* F: s# @4 V2 @1 e, s
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE) Y% p, W" @1 n4 [8 A( k( j
===================================================================================================================================1 S8 J  [7 t+ [' A  U( I% n' H
1397185 PCB_LIBRARIAN  VERIFICATION     con2con is crashing but does not report ERROR message% M" P& A. H3 T$ d
1404854 allegro_EDITOR INTERFACES       Allegro place DXF far from origin when importing' y; f7 h. n. d& V- b9 W
1404858 CONSTRAINT_MGR OTHER            ERROR: Can't import electrical constraint data (pstcmdb.dat)
8 }2 d  n( d: D: a& y0 Q8 S# u/ j1411220 ALLEGRO_EDITOR INTERFACES       Add option to include or exclude the SURFACE_INDEX_1 and SURFACE_2_BELOW_BOTTOM layers.+ ]4 ~8 H( C4 W+ o1 A
1411637 SCM            SCHGEN           Incorrect Ref Des in the Flattened Schematic6 u1 p7 l0 U5 ]9 _; c
1411918 concept_HDL    INTERFACE_DESIGN netgroups displayed even though no block placed
0 l& N% w5 N2 L% I+ X8 h* C5 r1413081 ALLEGRO_EDITOR OTHER            DXF does not get correct pin offset value.
% r) C% T3 x* V+ k4 u1413235 ALLEGRO_EDITOR INTERACTIV       Find by Query with Via Structures: GUI freeze, x2 K! Q# x/ ]$ {# v
1414685 ALLEGRO_EDITOR EDIT_ETCH        Allegro crashes with remove tuning command# u& |. l0 s# e# ?
1415049 CONCEPT_HDL    CONSTRAINT_MGR   cadence crash when "()" exist in diff pair names in ECLS
( @% r$ n# r1 G2 E7 c1415709 ALLEGRO_EDITOR REFRESH          Updating a Mechanical Symbol causes Allegro to create a SAV file
  u7 |4 G4 q: a( Y1 b* Z9 v& ?1416217 ALLEGRO_EDITOR EXTRACT          Problems with extracta! w- C0 Q7 L6 F; M  _( |5 X) ^+ W
* F6 P/ w+ ?. ^6 X0 l2 l4 n( ?5 N
7 u) p7 j* y+ |6 W
参与人数 1威望 +2 收起 理由
yueyuan2003 + 2
    2025-6-10 15:51
    发表于 2015-5-10 14:09 | 只看该作者
    更新速度太快了  谢谢分享
    发表于 2015-5-10 20:16 | 只看该作者
    感谢分享啊
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2015-5-11 12:55 | 只看该作者
    這麼快,更新包又來了呀!!!!
    8 s: O& t4 E9 s& {. Z才剛剛更新到48說...
    7 U2 H% A& b$ T+ g感謝分享囉!!!. `* O2 L! T% D
    发表于 2015-5-11 15:16 | 只看该作者
    补丁打上  结果我的软件还的重新装一遍啊!!!!!!!!!
    奋斗
    2023-2-7 15:02
  • 签到天数: 206 天
    [LV.7]常住居民III
    发表于 2015-5-11 22:28 | 只看该作者
    打补丁不用重新安装软件
    2025-7-30 15:24
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2015-5-13 13:53 | 只看该作者
    好像是039过后SCH手动改 PCB Footprint后,导出网表就出错。 不知各位注意到没有??
    0 t1 O4 \$ e3 i: {4 \% Q$ n具体哪个版本不清楚了。
    发表于 2015-5-15 11:42 | 只看该作者
    又更新到49了
    奋斗
    2020-5-25 15:01
    发表于 2015-5-15 23:25 | 只看该作者
    更新太快了,呵呵
    发表于 2015-5-30 22:59 | 只看该作者
    Thanks for you share!!!
    13#
    发表于 2015-5-31 09:42 | 只看该作者
    谢谢分享 更新太快了
    14#
    发表于 2018-4-11 08:15 | 只看该作者
    大神,能否再分享一下最新最稳定的补丁,16.6的
    GMT+8, 2025-11-6 15:02 , Processed in 0.203125 second(s), 27 queries , Gzip On.
