查看: 1066|回复: 2
求助pads2007输出asc问题
发表于 2015-4-2 14:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好!pads2007输出powerPCB5.0版本asc文件时导入到powerPCB5.0里没有网络。只有元件,没有网络。报错的提示如下:
) G2 \) p+ V6 m% Z( `" [9 o/ r, l4 U1 _4 S3 A8 k: ~0 d
/ r' U( L2 g+ n* ?% c" n7 n4 sReading file --  C:\Documents and Settings\wuzhenlv\桌面\B314V02.asc
; u. ]. f/ m4 }/ Q/ y% M9 NBad Connection item no# -1" q0 p$ F6 O3 u( W! K' ~
+ ?5 O0 T, G9 @- ~2 c0 _4 k
*Part name not found 381402500
0 h# C/ A5 F! T) R
' ?* j! Y0 I- `7 G381402500 90709000 1 750000 1536
. L& h/ H) J% T# N: Z3 Z3 I+ o$ A4 \  `, K) X; N  j
Bad Connection item no# -14 U6 w' p+ X" h$ r6 y7 M
* J  _4 B& X, ?5 r* b*Part name not found 355185000
5 l8 X# ]# ]& h" A: v2 Y
" `3 _3 L) M; O8 L6 q# \355185000 92944000 1 750000 1536
1 v3 ^0 S' e  G0 i6 N9 o2 s2 |( H5 o. a  z* m6 n% z7 F
/ t4 r* l- z: q
3 h9 X7 x2 ~) ]+ _1 Q# M5 {*Part name not found 352826000% }& w6 B; n& P; W6 o
0 e+ F4 q$ c: x2 c& z
352826000 85701500 65 750000 768  THERMAL  TEARDROP P 90 90 , W1 T1 p& ^6 m" S) N+ U6 l+ A2 Q
: ~! ?# F( m0 W/ VBad Connection item no# -1
3 q, |& a5 \8 H7 F, A( @+ J+ {, J) w; w4 G  ]4 a0 @
*Part name not found 4826075005 {1 K& L% G) x* S/ ]: s- D* j% {
* M# p4 U! X+ k' P6 v
482607500 128525000 1 750000 1280  THERMAL  TEARDROP N 90 90 $ i$ g. }3 u% y1 [
  e0 Y5 o; j+ ]4 X. T: o# hBad Connection item no# -1$ s- Z2 k2 k7 W$ }: [
9 B/ m; o: N5 t) x& F% G*Part name not found 493425000
  i/ F4 n0 P( J5 C. m
: q+ c# k5 i9 H( E, w& z493425000 65677500 1 750000 1536 2 t$ s; b; n" W8 @# K3 {- h& C
9 M1 J8 N% W+ t  D8 M
Bad Connection item no# -18 Q" w- f% t3 H" ]/ ^
9 n& S% a0 B* B5 \# u' w$ |
*Part name not found 484980500
6 c, [& X- x0 I5 p& [; V) C* N
, |$ t" u' k& b) m3 o* a* x484980500 57113000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 . c  R! [" e( I  T- u
4 Q6 s. x* P- H2 n  Y7 V, ]
Bad Connection item no# -1. H& O' ]8 \' O+ y  W
5 f4 P# K& k: B: o" _; _- F*Part name not found 441470500
) H4 c+ w2 @/ X- o: |' D& W, I3 X9 t6 P( v
441470500 71145000 1 750000 1536
2 l' d: k8 R/ _* z# Q% \) U- O2 S; }/ a( \/ J. T* M" M' A
Bad Connection item no# -17 H' A6 W/ d/ ?# w/ J
1 q* J! b% y0 Y, m+ P*Part name not found 393442500, X: R# F4 _9 ?) X% c
! |% H; S0 J, b" o3 _393442500 98000500 1 750000 1536 ' t6 `" Q8 }' B3 I
1 N" s) {. w# A. U2 U# eBad Connection item no# -1" l- j2 j* u3 X& t8 a) w. L
! M# S3 Z( ]2 ^( v% e2 }9 {*Part name not found 3814025003 L0 x3 y: l, b" D8 P
* @" E* F3 B+ P4 G/ D4 y( s381402500 85688000 65 750000 768  THERMAL  TEARDROP P 90 90 6 H& Y6 F* g8 b& F: C; H1 Z  |5 R8 V  B
" I0 v  T+ V6 Q& f4 uBad Connection item no# -1
* G+ `/ {' _2 ^2 d0 M9 y. N( K3 {% p* `* L3 d
*Part name not found 681158000
' _2 q* H! T8 W1 l3 h5 c% Y: p  |! z# J" B$ i9 J0 D
681158000 171425000 1 750000 1280  THERMAL  TEARDROP N 90 90
6 ]) B% w. k) Q" i$ H# L0 B% j1 o% @7 _: b- a1 G
Bad Connection item no# -10 H4 @$ ^( Q" ]. s( R1 H2 j: c
" l' N, U; G2 i0 @% a
*Part name not found 6338550005 L' ~0 r" F8 ]4 \  y8 z
  A4 h* A1 Y7 s" L9 A% N, x633855000 171425000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
3 [) M0 M: T* L/ j" s/ b5 M7 x; _2 r( `% P8 T" A  g% t
8 S5 G, `( z+ M
3 M% M( z; P# `0 O( q*Part name not found 6317850006 s5 h9 [5 ]! i! J; I
9 c0 b) ?$ z% L$ i0 q9 }631785000 171425000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
, _$ b% b' b. Z" e( D
8 ]$ g% K$ l  t; I$ O6 }% \5 {8 ?Bad Connection item no# -1
0 ^- F" w0 G8 ~
( ~( ?. S6 y  I# q*Part name not found 612440000
/ ?+ a1 {8 a6 J4 a5 L7 C7 n$ U+ c- b' P
612440000 171425000 1 750000 1536 ; f5 n) O, m( r0 s
( R7 p" W5 w. i; A7 V8 z; QBad Connection item no# -1
. V( p# |, h7 ]" |, d/ m+ C
% z- B' }7 _% D$ H4 }*Part name not found 598997000+ F4 j7 J* e  X3 ?3 g0 [
! F+ K  _) [3 X, Q9 f1 ]
598997000 135031000 1 750000 1536
4 h; H7 e6 N7 J3 U5 f6 S: }4 d. W5 l: C% l4 R
Bad Connection item no# -1, m( q6 N" j: g& T, k$ i
" C. x' P8 K0 m& X*Part name not found 558986000+ {8 f: ?* T7 Q+ N+ v6 k9 x7 a" Y+ [+ L
/ c: B  n5 d! V. |% S; u4 }558986000 126970000 1 750000 1536
2 N3 A$ T7 B8 l4 [, k% _  ^0 ?( I; D1 E& A
Bad Connection item no# -1' ?2 A/ V" k5 ~( T* |/ b) p1 K
* k" l, Z% I, t9 @
*Part name not found 547436000
  `" h5 B7 W: V2 Z  t  I
" o2 k$ _* \5 ?9 [547436000 138595000 1 750000 1536
9 X0 k5 L: B/ e: @: ]! F( c  z
. `0 f# c8 O3 z1 N  X6 v* L( Q$ cBad Connection item no# -1
# J$ C; Q# O& W2 H  N  W5 N" h5 K
- y. O# R0 `% h3 q6 |2 z6 v*Part name not found 5277110007 V  h8 }5 l4 c5 |
$ v! \! g5 h' Q527711000 129445000 1 750000 1536
+ c# X  F! w/ u% F) V! d
- j7 b5 w: B  ]7 I" ABad Connection item no# -1( x9 L3 B. H' A( p7 ^: }, j" F
/ A- W- l# h/ {4 |
*Part name not found 506988500
3 P* y. F4 M5 s8 C& e. M( o/ t2 |4 C9 k9 v% w; L, h/ o+ q
506988500 141118000 1 750000 1536
- d; c$ N& g( ?) S) ~6 M$ ?
/ ?' n' P4 K6 G1 d% CBad Connection item no# -1
/ f3 p8 N) d9 j! N. a3 ~3 n1 K# J# |+ Z
*Part name not found 506861000% b7 e9 A, b. f5 [2 V: t9 }% Q/ I3 A
) ?2 S- K9 A& S506861000 213574000 1 750000 1536 * m2 \% _- [0 j
* j) D8 G7 Z: O% z: ?; XBad Connection item no# -13 k  o1 N* A2 L7 v. A7 P! ~
' F  b, i7 t! \6 ~! o( E& k; T$ H
*Part name not found 481830000
+ [% U8 J" E( m; b% o
7 N1 i, E+ j0 `. ?$ _3 O481830000 220320000 1 750000 1536 & ?2 K  i2 Q  z8 Q4 |& v$ N+ i
1 u5 N  N: W& y- G* RBad Connection item no# -13 }7 g: `7 j4 a( |
/ f/ W  c: b/ N+ X6 g*Part name not found 479373500
) L$ B. U( h6 z! o2 p2 F% S2 s$ Z
# J( R( m( r0 @% i; k479373500 209132500 1 750000 1536 # V6 }, r/ b* G7 F4 H1 b
6 |" N- x, d- f" }8 T5 h% R
Bad Connection item no# -1$ X) S7 E/ C& k- T
7 g* C7 U  d" Q( W. [*Part name not found 493755000
0 k$ u1 [6 Z: W5 i
6 r% [: Z+ G; H* Y  T7 H* @493755000 139814000 1 750000 1536
+ E, w7 M" `! A" Q, N5 Y0 |; H
6 I, P; D/ e' A" Y) ?  ZBad Connection item no# -1! O; J& A9 `# ~/ P  m; r% a
, C: w- H% t+ o*Part name not found 482607500
! b5 @2 ?  a" M5 F2 w/ c
/ E  ], F. t. ?2 J0 r* P6 V4 R6 m482607500 128525000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
; O7 |! Z) z0 M" U
; a% w1 \5 V- Q, \2 bBad Connection item no# -1, w6 v' K" i5 X6 _0 t3 G( Q
; ]4 d: H6 f4 B0 Q. j1 p*Part name not found 4934250009 a" `; F. \& C+ x  B: i
3 G/ P5 b; c: A: V. a5 P7 m493425000 65677500 1 750000 1536 . J, y/ ^9 p: R8 O" R7 Q
/ R& |, c+ D2 s' NBad Connection item no# -1
$ C' G4 X, O) o8 u( i
" k& D8 M* W9 h9 u1 s6 p  n*Part name not found 4849805008 E9 y* z- O. I
+ o7 t7 e8 m4 ~# p484980500 57113000 65 750000 768  THERMAL  TEARDROP P 90 90
# J4 `( k0 B& s) Y/ P+ Z8 j! M" K6 o7 y
Bad Connection item no# -1" v$ y/ c1 H: C  j
+ z0 w9 B' |9 q*Part name not found 652581500- J7 O/ I2 N7 s2 V1 e. |" ^
' X; [, m: O+ \, T& ^( F" u652581500 171425000 1 750000 1280  THERMAL  TEARDROP N 90 90 % p' d# `$ c; x7 n
( Z! ^7 _* J# G6 s) b) P+ r
+ O: e) @" K8 \+ L6 U5 v! R' \- V1 \( g7 @4 w$ w0 |1 Y& h4 L+ J, h
*Part name not found 6237230005 O# k; k1 k* t8 Y$ L: a
. O4 o7 ?+ Y* j$ I
623723000 192742000 1 750000 1536 3 ]+ C6 C4 C; O6 j. J- p
6 b! ?% ~8 y$ |; Z! q1 I
+ y7 e# ^' t9 l2 W  N( x' g( c' ]) r/ q3 k
*Part name not found 632790000
  B# w) P- C7 o: w5 w
! I* L9 J6 q4 B  R- L7 \/ e- H7 e632790000 174263000 1 750000 1536 0 w6 F! }, A. U$ z
3 h) v1 C* i2 W, O4 B; E. Q; fBad Connection item no# -1
- n, o$ N  r2 H. }
' ^- n1 b5 ?1 Y3 q*Part name not found 631785000
; ^* g4 m. T. @8 [3 Y) i: `; A9 |
% @7 u4 r% @8 E; U. K" c( M631785000 171435000 1 750000 1536 / [, |8 V& @: m2 t; b! e
: f; e% e! y0 F+ a: }Bad Connection item no# -1
5 F" Q8 x7 X# a' n) T! e1 L- ?* y. T1 f5 Z0 w6 n0 }
*Part name not found 6327900004 V4 z' X4 i3 V$ \& }4 g7 {& A
3 C4 _/ K2 J# B  t; o6 i: f* ?/ o; T6 Z632790000 171425000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
' O1 a5 y9 ~& p3 \+ s" ~) {* s7 h- I. o/ S+ N
Bad Connection item no# -12 B8 d$ y2 [  a8 `% S$ E/ s  L  N
  ~, m. @0 n# N4 F5 U2 k  }*Part name not found 632790000
8 L4 N$ ^* J: H% Q9 X- g* A0 |( a7 L8 m% ~: e
$ ]4 r" x) t. ~" U! J, y' u7 ^& q1 A  c- [6 f: A
Bad Connection item no# -18 T) h7 ~& M  X! @" F, }
/ H# o. V* W8 b) Z( l+ i
4 s2 g% G" W; C1 k
( c+ R7 Q( C3 e$ R) x# b632790000 171425000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 9 c, m& V6 Y0 U9 u& n/ U' P
- n; U7 {- O, w; L9 sBad Connection item no# -1/ A% y. l8 }4 x4 _  ?. K3 Y9 i
9 m- f* _) `  t' ^5 X& R+ R
8 k& U" @) R# s& ]0 B+ k2 x* w
3 E0 \, a: \5 j  a2 G' z) d631785000 171435000 1 750000 1536 ! _; s5 M. O2 o0 L" K2 E0 ^% t
3 ^0 u% [$ ~3 L' bBad Connection item no# -1( N% j' K2 y! G2 n
$ N/ T4 k8 D7 F/ u, I
*Part name not found 632840000
2 n$ P+ B0 C( W7 W  l8 i, b* C' N" q2 K2 f2 G( j5 I
632840000 172440000 1 750000 1536
4 ?  l4 Q8 r8 W& D
. w/ B& V# S; s+ M$ [Bad Connection item no# -19 Y5 `5 E5 ]# G5 W2 J; x  }
1 K9 o' U% c5 k) m6 V# R
*Part name not found 652581500( q* H+ N3 t* G4 `8 ~. k5 F: P0 X
7 H; ]' |: s7 M; E, `, o  Z
652581500 171425000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 # a( r5 o$ x% H
: d& d2 J) w- W: e2 J4 v0 s
Bad Connection item no# -11 e- a, F, ~) I
- f0 E5 ^' j( {3 l
*Part name not found 631785000* m0 s! i) Z: w6 ~9 D! p- i( S
' b5 e: _9 Q* ^- e. t/ i$ E9 x631785000 171425000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 ! Y: D0 r& E& W& m% _$ o2 M
5 _  \' z; ~" U$ G
Bad Connection item no# -1$ ?0 N- u1 Z% z5 [/ |* q& Z4 N
! m4 L& L7 o; D) X
*Part name not found 6338550009 D3 r5 p0 b' x- N* _# z
  x$ T- C9 F7 P- Q
( D3 k4 }9 S' b* Z3 [  P6 j% m' ]4 j7 }
3 H- C0 J: U: B1 V! d  ^* _! n$ J, M
*Part name not found 281403500( U2 ~5 U; D) K/ E  m
* \  p; J0 \0 G4 E
281403500 114275000 1 750000 1536 - H7 ~5 E) Q) V" N7 S0 J+ V: B$ A
( `& }" S; N; j0 L( |6 I
: P9 _( G( g8 M7 A- F3 [3 d' x# v  ?  \* L, t9 p5 L
*Part name not found 2306170009 C: }+ f1 L& ], h$ l& T+ @
- S$ n. @+ S: _3 f7 N- a230617000 92074000 1 750000 1536
6 V5 J( A. K% S# ]+ Y5 Y6 Q' S" j. D$ S0 z$ @
Bad Connection item no# -1) A4 @+ z" z' B9 O
4 |; `9 e% G+ }2 L8 S7 `$ {% j
*Part name not found 206178250
. I3 I; Q  h( p8 Y- o+ ?9 Z$ a# k  M: u( T4 f
206178250 91968250 1 750000 1536
) w3 C3 I6 C0 d8 R: E) ~+ y, o: P3 j6 r$ k
: e0 [  e. {& |9 R  w; @5 r5 G
& ^7 q; A. ~" q*Part name not found 1920000002 [- X, p- |* U0 F6 A8 @
0 V5 h! y' a7 w* z& k# W
192000000 86520000 1 750000 1536
% m+ y. a  m" [$ J8 {( `) I' ^
1 K( m4 ?% J  w$ R' H+ w; \Bad Connection item no# -1! X9 p6 B' v" @3 R) S
8 K: i& u) U, Y- V# G4 X) G# v7 N9 h*Part name not found 167277500+ V* u4 G1 a/ {3 m4 x* y  D
  ^& W) F" G% c& ?# Y) u. j167277500 91475000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 * V0 B  ~* t, U: r7 [. U6 x
% I: u) f" H9 ?* jBad Connection item no# -1
0 t) {* G% C4 ?- d3 Z1 Z$ K4 n, X3 \2 n3 D0 |
*Part name not found 165308000
) }+ C+ h4 y! u( u) F9 D& l1 U
0 C, A0 z+ N, f  m) O165308000 91475000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 # w) z, @& G9 S7 x8 G
- k% y5 K( t9 x2 K
/ F7 i$ [4 z* R5 D: [8 P
0 K- y7 b9 R) z' ~*Part name not found 1441370009 _/ ]  k. u7 l- Z4 d$ {8 U8 F
5 J: o' ?; S( M' o* N144137000 85697000 1 750000 1536
8 L% ?; r" w" g$ `0 O
# y0 Y2 _( a5 m! X0 QBad Connection item no# -1
7 t  t9 \: D. a' R0 |: T1 I
7 v9 @/ M! T; l5 \! {*Part name not found 411625000
  L& P2 `3 l, k
$ Q( |$ l( ~  o4 S0 o* d: R411625000 101633500 1 750000 1536 7 M& t& G. B1 b  n
1 w, T8 {. y4 d  Z7 o
; r0 Q- l* L8 b: B. `: T. ?7 x
- [2 Y4 d. I/ l*Part name not found 281406500
# p4 m3 Z2 X) r4 @+ L- Q) R3 S3 y$ h$ U: T
281406500 114278000 65 750000 768  THERMAL  TEARDROP P 90 90 ! M7 ^2 I1 M' u( {2 B! U
+ l& y2 T$ y& D. v4 }Bad Connection item no# -1
0 J& q) @: r" D/ o: a% V
" g/ E" L& C7 N' M, Z' V3 @*Part name not found 424262000
- v* J1 Z1 M+ t% N
5 @" _& i$ Q& x( n424262000 114270500 1 750000 1280  THERMAL  TEARDROP N 90 90 6 a! W" Y, S( B
7 ]2 [/ w  C' w* L0 k( R
Bad Connection item no# -1+ K* H2 N8 Z* v
; L+ }. o4 J* H% |*Part name not found 432043000; o1 m2 s9 p/ s  R! B; S6 ]
6 g1 C& v2 X$ E3 A1 e432043000 114358500 1 750000 1536
7 ~5 B% i5 C9 j6 e- ^
2 _) z* O5 g3 \9 D3 q6 N4 c- WBad Connection item no# -1
0 }+ n8 l5 Y  H3 f9 A3 S1 _
) ^* H2 f! D' W+ e) v*Part name not found 4502515008 v/ e1 ]( J/ \& Q: l2 U
. L( K: Y. T' l. z450251500 79740000 1 750000 1536 7 V7 K/ Q$ g) p! ~, N( z& Y
& ^$ h4 o6 [# m. i& i
Bad Connection item no# -1* E. d$ o( s1 f) I
; D2 r- @  n( I: i. F. J* D0 N3 y0 {*Part name not found 482966500
0 W3 P0 M" u/ C& |6 P6 S; G
2 G& C4 Q4 u8 b6 U# x482966500 75476500 1 750000 1536 : J8 u. C: [9 a7 f2 T3 Q+ G; h& D
! q" P" k7 ~1 \# m- L8 YBad Connection item no# -19 ~) e8 k) V# g% Q5 l
9 m) C& C- K# t! V5 A' U
*Part name not found 4894050008 e( J0 K9 A$ V; j- ~
4 `4 ?0 Z3 W! R- e; T489405000 110701250 1 750000 1536
6 ~0 _4 z. b4 K# h& o: f1 p6 ^! B4 X
0 ]& `1 H- P# q) g5 l. f' ]3 qBad Connection item no# -15 J$ w; [# [2 Q; ~' ?, E
/ Z- _# v# x7 I
*Part name not found 470521250
. k, w8 k, ~5 D, j
# O: v4 ^1 r+ x" S0 I* P* `470521250 129495000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
' f( g: P1 j1 M) t
% g* b, q! F: i3 C6 w& GBad Connection item no# -1+ s7 y& I, u* U% O% ?
0 p, H9 P+ T+ s, P*Part name not found 491430000& c4 O9 X- o) I; o
- l/ j5 Y  Q3 y1 ]3 }9 y
491430000 168797750 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
7 Z7 D" m0 J: C2 u" N/ ?1 c/ Z% s2 d" u
3 |6 j/ W' {2 Y. _" P9 X5 k" j, K; \- w6 X* A1 r
*Part name not found 480360000
/ t# O4 J/ i* C3 E; D( F+ I: p4 e! @# G8 T- `
480360000 205245000 1 750000 1536
8 `& H. x7 i- D" a/ Q4 H. k# F
/ @. }8 h' Q7 S: z! K7 kBad Connection item no# -1
; C7 U& S$ E9 W) p( f' b0 a' r6 u6 J, |' {. u0 B
*Part name not found 4599755000 `3 _  k1 u' T/ u9 l
' }* {) g7 N& g, ?' j3 s
459975500 210570500 65 750000 768  THERMAL  TEARDROP P 90 90
# x: W4 F) u: D% C' e+ K  b3 ?. D4 M# \" p
. l( S5 {  z3 N' H! e) C3 e* h4 R  W8 O$ ?! Q8 r/ p3 w: T
*Part name not found 124278500
; [1 ]' h3 |& E  g" i* N5 ^0 g/ L# h; t; d5 z
124278500 85697000 1 750000 1280  THERMAL  TEARDROP N 90 90 * t. E/ u/ [+ N7 Q4 m% h9 w5 c
; g3 a& x- p& B. ]3 t& y& m' m
( s, d2 J/ Q' V
% _: F- v% ~. ?4 P0 O% f8 c*Part name not found 87375000& m. B. I' g; X
" p& u  J# d. S87375000 74835000 1 750000 1536 7 b8 _7 L; l3 O7 \
! o2 [6 P$ [# ~% A
Bad Connection item no# -17 h4 G& s. j" P3 Z. C4 H0 p& }
, L/ k5 U& G5 G' H/ C*Part name not found 55416500
6 H& s. u  X, B! |
: T. C/ v  W3 T1 D55416500 82181500 1 750000 1536
, K. R6 k7 x3 D9 u7 H5 w! F" X7 G' Z% K4 B$ X! v
Bad Connection item no# -1$ \  F  d' d* a: E% r. [- w
. g7 F2 C2 k( E* p1 {5 I! @9 U  h*Part name not found 50283500
! ?0 f3 ]' l2 ^
+ d9 n$ S' E6 ^: E% r50283500 87355000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 " P* h; g6 B  J1 W6 _! r- _
: g! y" Y6 H7 x$ n) A( z) E- L: kBad Connection item no# -1
) z) Z5 |4 T( H& j4 }' r* i# j% @$ G  U* |
*Part name not found 48793000) O: U# p8 a8 X* _
$ z5 @) q" y; R7 ^0 s/ [( X
48793000 104316500 1 750000 1536
8 Y9 r$ H) l% `+ x4 W4 q- Z9 v8 b( {
8 X/ s) a( T% ^Bad Connection item no# -1% G: F+ j! a: K
% _7 A+ j1 V6 L) H  S
/ |% E. A  e! Z+ r' {) W
0 O# V4 V" z, U' u6 `) a- r144137000 85697000 1 750000 1536
0 q) X, J, c; w0 q; d$ l
* T! ^, p9 i3 E  s( Z$ C* v; KBad Connection item no# -1) }& q4 z- H3 E; }' J' R6 M
5 E# ^, H1 i% a" r! |! L
*Part name not found 1653080008 J1 m$ p$ H0 \) g3 Y; O3 s2 g0 F
. f- ~$ H7 h# D$ e  i6 a* [
165308000 91475000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 1 k1 B- n  S# F+ M+ {* \! O
2 z5 S9 q. A# _; s, g/ zBad Connection item no# -1
& T" K3 Z( w3 u3 I7 v$ z# Z5 m1 W" i6 L' Y0 X! X3 c' W
*Part name not found 167277500/ _. ~; _7 F7 E
- u4 J* p7 v8 K& g+ p% h* S167277500 91475000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 1 R3 F8 J5 ]0 M  i7 B! e' O
/ K* `' c0 A/ D0 W0 J2 J/ `& p
& O: [2 `+ {4 Z; X! d. O8 h! y# f4 F+ t+ E5 i/ U$ l
*Part name not found 166193000
& o8 N& r7 k5 H6 g* E7 _- G3 G1 G) ^4 i4 N* o' c' Z$ c
166193000 90439000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
- P0 ~+ ^, }! I4 |: \# i+ c' J2 x( L4 G0 d$ M9 g. W" b! `7 y
% {+ f; G! w) F4 p& y
% F2 p3 O: C  V2 m; W*Part name not found 167277500$ T( R/ t3 h5 m+ y
- j% J2 X: ?; q9 v7 K
5 [6 M) b. {, w/ S, y) q0 w6 r' P) G' \$ e: b9 \* J
Bad Connection item no# -1: k$ r8 G3 O: X8 t- o( @
8 ~2 {0 p2 d2 P* H- N6 |
*Part name not found 1661930005 M& V8 J, E4 B% Y0 z
$ ^& }. v' O, v0 o' T166193000 90439000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
! p- |. [2 p& N. s- v2 B5 u. H: A# o/ S! K( ^, `, Q
/ h$ e9 Z- X5 o/ b' }( e: [) `  G- q1 `+ k& v
*Part name not found 156749000* t; N2 ]# `, b$ U0 f
+ x8 |7 T/ o9 ]156749000 77326000 1 750000 1536
) C4 B6 X" g" u0 n2 ^
" s5 T1 v3 l+ S% I! P5 g( e3 D" xBad Connection item no# -1. d# X$ A$ I" a: f
/ p  ]: _3 {7 X  T*Part name not found 163538000: m5 A- l2 y3 J0 C
/ w2 X9 i0 k, ~4 K7 \, ]& h
163538000 63607000 1 750000 1536
& m/ e4 p7 U" G  M+ v
/ f" q9 A# Q. v! v* o% rBad Connection item no# -11 T  c2 b/ B' Y* H6 P/ s0 b' Q
" p0 Z- v4 p$ Z2 u( V
*Part name not found 313251000* ~  s7 K  j1 j" W+ q  f# w
8 k6 M4 T2 z1 Z
313251000 221010000 1 750000 1536
2 j( j7 _* a  W8 E5 [. k4 f* \# t2 @. V
! |2 U+ R3 I+ \0 b% Z, l; PBad Connection item no# -1
& z' {2 C8 i: t7 R! B+ R) I
1 ~) o( z. ^8 {! j& k8 v) \% {*Part name not found 366920000+ c" K6 _% _+ U
9 o* r: M# ~  |  ^3 ]% K) D366920000 190705000 1 750000 1536
: a' k, G" F# k
/ A) I: \6 U9 vBad Connection item no# -1
  q8 o& Q* X0 Y; |  c
, U# O0 k- [- Y5 O7 X2 O3 P*Part name not found 459975500
# a  g7 H4 _5 P! m1 ~: B# N# D0 P* U: }/ g) ~" p, t7 L3 n
9 `, Q' s% ^. q$ b* s; j! Q% V  ?" s+ ?9 o- y) U  Q8 H- F) I2 p, d
Bad Connection item no# -1) }- y1 L( J% ~
3 a) u9 W) ~4 u  W+ p3 ]4 d
*Part name not found 302816000
  V. U2 x; P' r& b0 s* R0 w) C
1 t% J8 l8 C8 Q9 P- g302816000 210575000 1 750000 1280  THERMAL  TEARDROP N 90 90 7 k& I, Q; ]( N9 P, G. r
& g2 a, K+ u) @, V  G; H: S
Bad Connection item no# -1( i) `7 {, I7 F2 E* @
# l. q5 ~9 N# v*Part name not found 287940000+ h0 o2 ~3 q1 p7 p5 E: }/ f
8 h' |9 H/ m; ~' z, t2 W& H, B. I* [( [287940000 196005000 1 750000 1536
) F( n6 k( H0 X. l1 l' I' @1 H6 |, X  r6 y+ L% p* c% r
Bad Connection item no# -1! N' s+ p1 A5 C, U0 \. C
# M2 S! P) |" l' |( U*Part name not found 231377000: S$ O2 n# V5 {6 f9 @  v
; d( p, d; |) |- |5 I231377000 210575000 65 750000 768  THERMAL  TEARDROP P 90 90
9 A6 R9 z0 \4 s: c4 m) o6 O
8 ^5 ^' O; W+ @: Z/ xBad Connection item no# -1  w; Y3 ?' p4 J; G
; u* H" ]! K+ x& T, ?0 Q
*Part name not found 231377000; Z  i/ C& f+ n4 s% G& Y
, ?/ ]2 |  s" j1 d
231377000 210575000 1 750000 1280  THERMAL  TEARDROP N 90 90 % p: _3 q0 O3 \4 Z+ H' v
, N5 E9 z4 O% p0 x
9 l" y$ _! o" a6 E! X& k
1 ]+ p- f- Y8 j9 s5 m7 C0 F*Part name not found 202530000
6 g- n3 f* h7 E" M. R; p  [- P' J% n6 o9 M% j$ Q
202530000 220125000 1 750000 1536 , O. o# ^( g4 S  C3 l; ]7 D7 m, C
0 G9 a" ^9 z3 K" v1 O
7 |( _! y  n$ b
  p& M, B0 ~& S" Y5 t; ~+ z/ J*Part name not found 121209000& v) o% i+ T% `1 L) C9 n# v
) T9 |2 i1 Q/ \4 Y' D) O( T1 u
121209000 202920000 1 750000 1536
6 P1 y3 A+ |. ^7 a9 Y# A, D0 H
2 f9 g4 v) w& R4 t. k& ~' |: S5 H9 nBad Connection item no# -1
3 Q5 D, n! D- C6 I! b) c4 W# i: J. ~4 [4 G
*Part name not found 885105004 Y% [/ t. |& m; Z# J: Y
; @5 l4 ~8 i5 g3 I
88510500 210585000 1 750000 1536
! X( S6 F3 |/ \9 v4 h+ o* [! Q+ X6 O0 ]
Bad Connection item no# -1( @2 c1 `, u6 A, Y
* V7 d7 N$ @+ t# u3 e0 T2 t3 K
. W0 W$ ?% U% \7 N% P8 f7 ^2 b9 @0 u0 t# A
163538000 63607000 1 750000 1536 5 R5 \  t. R" K3 _9 A7 y- o
1 \# Y# C0 q( u1 k1 n# ^  pBad Connection item no# -1
% b3 g! s- h# }
% r9 G! p/ Q$ a- f; K, e*Part name not found 156749000
0 F: I- ^* r# z" }) Z& c+ J
+ f. k  Q: Q6 L156749000 77326000 1 750000 1536
. L1 h9 e- p- C$ K6 J
4 m$ u& B) \, U; {0 _Bad Connection item no# -1
4 q+ l# z! k8 N% M! I! J8 r" T: u
; E3 R2 d, F6 G/ J& N# A8 T$ k*Part name not found 166193000$ F0 P4 p8 s8 I1 T4 L# \. `
6 `+ h2 |, _1 ]/ a) o# h166193000 90439000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
: q0 u0 `7 J+ ^5 n8 s" t. q3 u
! r( e* e& L3 ?% aBad Connection item no# -1* c, v. ?( w) W' w( D1 ?
0 ~9 W4 I8 l+ j2 i+ n
*Part name not found 1653835009 b3 ^; n% @1 W: ~( }
7 \3 Q1 G; y1 f. S+ c165383500 91399500 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
4 X9 {, y. v; z6 j7 G$ s
: c. h) Z% H* e  E% f8 ]& D, JBad Connection item no# -1
9 ?" b) z& o, R; k" |" j; [/ g  p+ ~
*Part name not found 165383500" o' Y" ], h( g/ q- s
5 W# j9 ^3 K& \5 L+ v6 y7 b/ ?7 m165383500 91399500 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
) _4 @. d, E- E2 x& a% q1 h# z& R
Bad Connection item no# -13 }2 g! @+ v' c  ?
, g" h" F0 q) S& S
*Part name not found 167277500$ S* F, Z7 q- v4 O! U
# ^- V: z+ P; z) @6 i* @$ _
167277500 91475000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 % s/ J0 \$ B3 e3 P
" o1 |; S; G% |) P% R
2 b8 x# D, B) v/ @4 s& n& g' d9 c8 x9 x
*Part name not found 1661930007 i! Y9 f% H2 U: S2 B
/ c3 B8 r* X' s8 r0 n% y
166193000 90439000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 3 u  n" o/ s/ F5 O$ N: s; v) a, D
) r, ^3 H% i0 ZBad Connection item no# -1
* w- N& Q  G, t, [5 a7 Y5 R
! N0 R  K5 W( P8 j- P0 `*Part name not found 167277500
1 B& u4 \; d/ f) @4 b
9 X8 N7 A. q. v167277500 91475000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
; h) Q' p, ]4 T$ i( ~' M; ]( Z$ D# i( g2 g
Bad Connection item no# -11 D6 z& d; ~5 _
. z  ]9 C; B# U' d' g8 A) s7 x
, h" t/ ?7 f% d
. k) w8 n, a+ k, U$ w167277500 91475000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
6 }/ z) t  z- b
- d& e6 `5 s( p6 d( IBad Connection item no# -1
$ m: k1 w7 l* h+ J
! \7 j; O& K* [! p* v7 Y7 u*Part name not found 165383500
5 N, E7 y4 h4 q# m; J( q; y% H2 [4 T6 Q3 c' o* s$ k
165383500 91399500 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 2 h! D! t; d" b% f+ h1 ~' ~" ^" U# [
: g8 }) A, H- Z" e9 [  V' k
Bad Connection item no# -16 U5 h4 A5 @% L+ ~) ~
# ^4 v5 g. w: ]*Part name not found 166193000
% h  w6 O1 T2 V" v
6 [5 Q7 m1 i; w7 k* P9 [166193000 90439000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 3 i5 c+ q0 e# Y1 }
0 g% C1 C6 d1 e' pBad Connection item no# -1
( X* P" S" N; f5 o" l6 K8 m
. O. f1 g- L3 X3 x9 t! _4 K! f*Part name not found 165308000
$ b3 f- I" H: y( j) h
: N4 t0 e3 _8 _  H1 b165308000 91475000 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90 6 ]% ]: _2 d4 \$ R7 [
1 R1 x& V' y& S, zBad Connection item no# -1
9 ^- m5 q$ A1 g+ u- u  q) w' q5 K; W( X8 W9 u& `
( _) R" x8 _0 N4 X8 @1 W, Z9 g8 K5 {5 d: @* R
# h: B  F5 F1 O0 {) ~
# m4 p) j6 s) {$ ?, YBad Connection item no# -1
! X6 s; S+ A' m& k, P* A8 u/ j  S, }
( V- ?$ Q1 O( H3 P*Part name not found 113416500, r; a$ {5 D' U; E' W
* f6 ~* Q" f  W& t0 ^/ f, k
113416500 74835000 1 750000 1536 1 L6 n: B* U: L- I
4 X0 Y- e: k* P! {- T$ Y4 f' J
Bad Connection item no# -17 |1 \! l% o9 A9 B* ~7 V
2 p( V' B0 i4 g, Y
*Part name not found 80028500
; Y4 \0 |! _4 G9 ?6 }3 s$ [
* C! e! E" J  C) a0 @80028500 82181500 1 750000 1536 2 f' d% \0 o  R0 P# t
- c) J* q: a+ w9 YBad Connection item no# -1
% o" S7 d, [* r7 Q2 i. M1 z
" I" S# k/ {" R4 l*Part name not found 502835007 w% H7 n  L8 n
( N, {- e& C3 G) i! |* ]' a  x50283500 87314500 1 750000 1536 & ^) h3 W5 \) m$ c) i5 i
  E. A' g- J, Z% a
Bad Connection item no# -1' W( H6 o$ [! t7 u! f1 a
  z9 U; ]8 ~+ T- o) k*Part name not found 48992000! d7 P  i, l5 I+ I, ?) ]1 ~2 h
: c% W) z" E, Y+ B, F( S$ C48992000 87355000 1 600000 1536 ( R8 C  k7 L1 K4 l( M9 D* p
' }7 {' t4 [; b: ?Bad Connection item no# -18 l1 u! a3 N' T; E, u9 w' R, L! h; R
! N$ N6 [- s4 x) D
*Part name not found 44088500
, i' F4 h* _+ e' o9 b' m: x+ o& `6 p' r2 {. E7 y  U
44088500 78485500 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
1 ]. U: S3 g) S" W, b* \' c4 H1 n$ \4 A
Bad Connection item no# -14 T$ o) T# X- l$ t2 d
( Z; u5 @9 L" u4 C. I$ _*Part name not found 699890007 p1 ^: y0 D% f) e2 v3 l
: {3 H. r4 X- C; X
69989000 75487000 1 750000 1536 # r; |, B. Y3 y9 `
- V/ d! T+ |4 w! S) TBad Connection item no# -1# C/ W- m8 P: U2 H. u- l! u, P
3 F. _2 v; c, E*Part name not found 77603000! Q! J. v: D# y8 }" J
4 T7 x! X# Q+ Z4 N% Z$ V77603000 58687000 1 750000 1536 - ^4 c% R8 T$ l6 F% _* `$ ?' r
" ?2 @5 @' i) QBad Connection item no# -18 H0 R! ^5 D0 {* k% U
2 K' W- R% ~7 `) G+ Y
*Part name not found 104943500
0 p0 Q5 Y. m4 k' q" t5 Z; I
; H. ~! z: k. c! q; Q) @/ y* G104943500 48812500 1 750000 1536
$ G& V- m( m4 Y. D6 ~$ I9 W" \/ D: O* j) i' g7 g
" ]0 }+ G3 o+ B4 }/ j5 S! v2 _* \. ^& |: j+ |9 \
*Part name not found 136961000: U8 A! a8 d9 n" G: H3 n; A
) A. _( {3 p. ^$ k3 K7 i136961000 65378500 1 750000 1536
3 F5 O8 M( s& [1 Y; ~2 j9 I1 e, X3 o# Y/ Q0 E3 s, S
Bad Connection item no# -1' Z6 L. s& f$ A# X; y, c
- S+ }! G! w( C4 J  \. q*Part name not found 183847500
8 e9 {. T$ u* w6 r8 p
% H( S& y$ q( B4 z9 Y  [% _183847500 18492000 1 600000 1536
4 g0 z, Y9 ^1 h* \- y3 c' N* ^# Q; |% S6 u% S  C2 Q% D6 L. _  H% I
+ z" I, k9 K3 i% [. @3 H( J* J6 G; }/ G& v+ X3 d( I
*Part name not found 293216750
( `* H+ ]; f/ \. B! B# l4 I, @7 T
1 Y; |; {1 `7 o8 F6 F293216750 24327250 1 750000 256  THERMAL  TEARDROP P 90 90  N 90 90
# T9 w/ u- _# @" ?- w$ R  v! m; a/ n% F9 u0 _0 f% B, N) |
/ r- e, S  v" Z! M) P
( Y" d; [1 ~) E0 I*Part name not found 378627500( H5 t9 `) T! k
$ t, ?- E0 D; c9 w% F, X% n3 g- r
378627500 38353000 1 750000 1536 4 L0 G- Q& A% ]7 K$ g
" v8 i3 S% V& A  hBad Connection item no# -1
. x$ k& K# E- A- y$ @
: s& ?+ l/ Z, ]) [' q*Part name not found 419751500) A0 }: Z4 O2 M6 N; g
9 O! b) j( d/ k' {419751500 70099000 1 750000 1536   z4 X& [7 T8 w0 E" U8 x) ?$ j
$ |: x. u, C( x& M2 j- M2 l* aBad Connection item no# -1
* l7 t6 K( e/ W4 n. z- y4 M" |
6 D/ F2 k9 m2 s' n$ k*Part name not found 604927500- |# [1 @2 B7 W
- x7 p1 z6 k6 ]3 B5 k& M0 m: M; f604927500 23760000 1 750000 1536 " X. Q) i9 c( C' F5 [  a1 B
- y% ?/ l/ i5 S* G
Bad Connection item no# -13 `6 r  M$ e/ }6 L- q6 T' M0 K0 D" E
* y$ z8 s; c) o( Q/ |
*Part name not found 6811565001 _- j7 j, \7 _3 y. U$ w
( @; l# d# U2 K/ w+ j681156500 57125000 65 750000 768  THERMAL  TEARDROP P 90 90
, ]9 d1 {) ?* l# h! @$ e, V: C( e; }$ F- _
$ }; b3 J% Z: q* w, v1 d0 {  Q* U, P4 Z5 Z0 I8 k, a# V/ L5 C
*Part name not found 638292500
: W" A2 L% F" U  D; d' N$ n; q+ D) C4 M
638292500 57125000 1 750000 1280  THERMAL  TEARDROP N 90 90 " N( ]8 x+ ^' K# S
7 `' i+ S* i5 X' [* jBad Connection item no# -1$ U$ z3 L( p2 g7 @, E  z
, h  H7 n. n4 J  w. `+ N*Part name not found 620143500
" ^1 i5 ~: H! w% J8 G& H# A3 [1 h7 i3 F) k
620143500 71128500 1 750000 1536 2 Q/ B7 F; n& q8 |+ F/ }
/ p4 m& L1 a7 I2 F# L/ e9 q
Bad Connection item no# -12 A- ]% o, g2 ?1 S' G$ m( }( |: ~
7 Z, w# x: N- u*Part name not found 6056095000 }5 l; b; O2 x5 Y' d& b( G7 x
4 l) K5 U, ?# q3 I) e* U' T
605609500 85697500 1 750000 1536 / V. y4 W- M* |3 f- ?8 a; R
4 ], Y1 ?1 v. t1 V) H+ j; _8 Q: MBad Connection item no# -1) H) @  y. F# E( w
% S) Z/ x. j' L/ |& J0 G; a- y5 t" e
*Part name not found 6056095004 u, J" f9 H  q! e$ e0 g
3 n' D8 v% e" {5 l1 [* O) o- P8 Q
605609500 150644500 1 750000 1536 9 w1 X+ h6 p# @! ?6 ]
; c- o8 w! @  SBad Connection item no# -1: f- d; w6 D  D4 p8 l# Q, y9 h* V
4 H0 ?6 Z. ]- t' J: j" X/ J7 e' U*Part name not found 658296500
5 U; Z) V/ g2 H9 K, b& R+ s8 P
4 b  E) E$ V/ K/ d: l# ?; F: C658296500 153208000 1 750000 1536   D  G, y# }, {* g
9 T$ _' v+ V' q2 R  r% q* B! k% ?Bad Connection item no# -1
6 [5 ~3 c0 C5 p3 {+ [* [  ?4 a( b1 ?
*Part name not found 673380500* p% `- r3 s0 t+ N
/ R+ {& M8 S) o
673380500 148180000 1 750000 1536 ! f! D, @& |3 v. A0 M
1 B  i$ C( j3 H: U. T% ?: @0 ^
Bad Connection item no# -18 ?& c6 n( x6 E4 E9 \
0 d8 J4 r4 m7 C6 ?% t+ l
*Part name not found 712340000* u' \! a/ l/ j& \
. e, ]( U: G$ Y4 v
712340000 155585500 1 750000 1536
+ @0 J8 X* i4 W3 Z. h
1 t3 w3 \5 }! K, B8 S  C7 U+ gBad Connection item no# -1( p3 E5 }4 m' B' b; n6 {: F' L1 v
/ P# b6 w0 @- G/ V5 R- T' B*Part name not found 718586000
' E* ]1 }8 t3 H+ \) U8 M0 V+ r$ R$ r6 K/ l" j: l
718586000 178264000 1 750000 1536 9 A$ v* u/ D! U3 T+ d# p
# V! m2 x' S% O5 i% QBad Connection item no# -1
! y4 K% u# ]# @/ V3 H% f, h& u% K* _4 l* W+ |+ j# M
*Part name not found 634115442) G: ?! R- f6 o; J% B2 V
2 J) B$ R0 N: `! U" e634115442 180999558 1 750000 1536
- B( P7 m% H# q7 {0 T
. l1 a* b2 K+ jBad Connection item no# -1- M3 W' l: L9 Z$ |2 [6 U
3 D* M+ F$ Z; ~3 [; h) l9 I
*Part name not found 631290000, _/ b7 K1 R) S* m( e9 b: p
" t4 O9 L, S$ |8 k
631290000 192825000 65 750000 768  THERMAL  TEARDROP P 90 90 / C. R4 W- v8 Z- p3 e
. T% M1 n' j* H8 ]  o" q4 B( Z# O
Bad Connection item no# -14 J- l" G1 ~- o: x8 I( [
7 v$ p, U5 O5 E*Part name not found 631290000
" L* f; x8 K3 N" A- R9 f. D
' y: `  P* t' y0 q" c631290000 192825000 1 750000 1280  THERMAL  TEARDROP N 90 90
2 o3 H1 {6 ^. q! b3 ?9 X) W& y' n$ \$ r& W
Bad Connection item no# -1( E, ?; q) D0 |3 w/ b& {
4 D0 Q5 C1 D5 O# h- Y& @*Part name not found 634115442
4 \" J4 v3 d  W0 D* A$ r" r
) p+ r8 T% G& D2 K8 M, Q- H8 T634115442 180999558 1 750000 1536 1 g; V" R3 G- E
! ]" `$ c4 G: m' ]  qBad Connection item no# -1
1 |$ E& J2 g! ^- r2 ~, i# _; g; W/ `. c6 P; J1 I; Q$ x
*Part name not found 7185860001 ]) u9 w/ l  R/ d  B
( u  b" g& [4 q9 T% ^/ J3 |
718586000 178264000 1 750000 1536 & ~" X! J' R  h- n/ G0 y
* S8 u" K& o3 U8 y0 e
Bad Connection item no# -13 s8 ]. p& g: z
$ D3 B5 Q* |/ |: f5 P% h* t* W( E*Part name not found 712340000) B5 u1 [" S/ o" H3 }* m
& B4 Z$ d& \& n  T% O712340000 155585500 1 750000 1536 2 ?/ G; \$ D% @9 o8 a
5 I2 @, n! K( r5 n2 h
Bad Connection item no# -12 C' G$ H0 d) }6 \
5 Z' w  M0 W' T3 P*Part name not found 673380500
  u, Y1 l7 r. K3 g  U  N
) l$ a) n! @; X# F# `673380500 148180000 1 750000 1536
- j* Q* }% Q8 Y' f( i% @
  d* T* p. A  |# E- q8 NBad Connection item no# -1
, Z. R2 q# l4 x2 z. \0 u/ N1 g1 Y0 N) I! @# {
*Part name not found 658296500; E, h- v1 D1 k' n5 Y8 X: l
3 n  S  M/ G: W$ ~
: h- h2 h, v+ ]# ]/ x; R% S
3 w+ h8 D! g# S9 {3 \& _Bad Connection item no# -1
  D' r" M5 O2 C/ `# b. \8 H6 I5 S
9 x# A7 Y+ m4 F! w, l! e6 U*Part name not found 605609500
3 G( z+ o" F% P1 o0 c
+ a( A. D, @$ R; k9 f5 p. D4 I  o2 e0 R9 K1 C( D
谢谢大家!
$ g# i6 g$ Y! u# x: q% b+ Q
发表于 2015-4-2 20:47 | 只看该作者
我在07导更低版本时,遇到封装有问题的时候,出过这种错误。看看有没有器件原理封装和PCB封装对不上的,比如引脚数目不同的。
 楼主| 发表于 2015-4-3 08:55 | 只看该作者
好的,我再检查一遍。谢谢!
GMT+8, 2025-10-27 23:36 , Processed in 0.171875 second(s), 23 queries , Gzip On.
