查看: 1284|回复: 3
出gerber的时候老是出Warning,请大侠指点
发表于 2015-3-16 19:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
2金币
出gerber的时候老是出Warning,% s5 v: M0 `' r! ]
其中一段,不知道什么意思。: M. p5 A+ q4 U& j* x! c3 I5 B
Results from parameter file ...3 h* O  ~( |6 m7 @
    DEVICE-TYPE           GERBER_RS274X
+ \  B8 j) d; C- @3 s- ]) d    OUTPUT-UNITS          INCHES" \% a- m& K$ E7 t5 F& s; N# r# m
    FILM-SIZE             2400000 1600000
% }! i! v2 `; {3 q' J/ F    FORMAT                3.5$ w! b% y. A/ ]2 B
    ABORT-ON-ERROR        NO
  X# ]" Z& C* H8 i' A9 [& e    SCALE                 11 N4 {1 G& a+ c
    SUPPRESS-LEAD-ZEROES  YES0 h3 e0 Q$ {9 h) |: Q: W
    SUPPRESS-TRAIL-ZEROES NO# ~/ i5 \  c0 X3 P, a3 e+ x. S
    SUPPRESS-EQUAL        YES
/ u7 T" i, O$ S  z" O& a    UNDEF-APT-CONT        NO4 b1 f4 z9 i7 U4 A5 i- i7 f
================================================================" f( E) i$ b1 A+ X9 k9 ?/ F# w
     PROCESSING FILM < DRILL >
; j# ?% K: S* W  n" k+ |     TO FILE < F:/GM8138S_HW_V1_0/0305/DRILL.art > ...
. Y4 d+ t: B6 F- f$ ~================================================================& x) v3 X, p1 D2 R" y
  FILM PARAMETERS :7 f" P( X6 b% T9 s2 B5 C
  ---------------------------------------------------------. o, i" y6 K& Z6 Y# U) i
  Undefined line width                6.000
  ]. i3 j% i" a4 a0 O  Suppress shape fill on neg film     NO
1 t  ]- R  E7 X3 x4 Q  Mirror code                         NONE6 F6 q" r" A. O
  Rotate angle                        NONE: Q* m) I9 h( A" \4 N
  Offset x:                           0.000! ?" i! C; R2 i1 a; I& v" E, j
  Offset y:                           0.000
* l* s& M( G' E  _  B' x  Plot negative                       NO
' N8 i+ a& N" ~3 t  u  Suppress unconnected internal pads  NO! y! |  T% ^% K! o* ^( i6 f% Q0 ?
  Draw holes only                     NO
! O7 b/ j4 ^' k& t    WARNING: 0 width line found at (-890.000 2942.000)
( q8 p# f; q; L7 P  R8 r           ... using undefined line width of 6.000! n+ c4 U0 x  e$ n; B- U
    WARNING: Multiple 0 width lines; all will be treated the same as the first.
: j" e3 ^  ~. h+ M; |           ... using undefined line width of 6.000
. l/ U4 S" C- x% N    WARNING: text composed 0 width line found at (-440.500 7531.500)
3 _0 i; s3 g- h& Q" E- ]" L$ o           ... using undefined line width of 6.000
' Z+ ^& V* K; ^9 k# d! Q8 [( O9 {    WARNING: text having Multiple 0 width lines; all will be treated the same as the first.3 B, Y+ ^. X3 p; X8 U3 p
           ... using undefined line width of 6.000+ |: _, w0 |7 y( }; e  R/ e
4 \1 j3 ]4 W5 g! V/ M# Q$ t- x6 U  APERTURES USED:
& e" r5 _7 u) H/ C3 I+ @  ---------------------------------------------------------& D- f9 D  K$ [* x
  TYPE       SIZE/NAME                   ROT   MIRROR MODE 1 e) S/ R: M5 T7 W6 y  }
  ---------------------------------------------------------9 ?9 r' E8 T$ |* ], Y! T3 y4 B
  CIRCLE     0.00600                                  DARK + y( [' a6 C% w; {# W
     DRILL created with warnings,这是其中一段,不是很理解  m: d2 E7 P/ k* s
# ?* _: A. H* D4 j9 D" c* d  v5 g
, T1 b0 U9 M' z
. E: J# G4 `. N4 p4 w# j
5 E7 M4 f/ h% @" MRILL created with warnings
. b  _. S- ^" U        SILKSCREEN-BOT created with warnings
; ]  i' b- }8 `1 o        SILKSCREEN-TOP created with warnings
) Q5 ^( P- c* a3 L. \        PASTEMASK-BOT created with warnings
( U9 {0 p5 x- b2 ?        PASTEMASK-TOP created with warnings. G8 c! x. u; i9 {
        SOLDERMASK-BOT created with warnings
( C. y' {$ e# `! o3 O# A        SOLDERMASK-TOP created with warnings
! H& t( o% _# F8 B( ?+ j( d# B        BOTTOM created with warnings
2 g4 ?* v2 P! b9 G        VCC created2 i! t+ C5 H8 V6 q: j1 s4 w
        GND created 7 D5 T- _- w0 Q/ R% V
       TOP created with warnings& {" m9 o4 u& ]0 u8 k; V. j. {2 B7 g* P
        INN1 created with warnings5 v8 ~7 U' l5 U4 l. D) d3 V- d. ~
发表于 2015-3-17 14:35 | 只看该作者
定义不带宽度属性的,出在gerber中是多少。图中圈圈中不是0就行了
3 |! Z: O; G) \8 L  x1 u& ^- N( ^! W  C2 S8 h) B; N
我写的是6mil ,  详情 回复 发表于 2015-3-18 13:38
 楼主| 发表于 2015-3-18 13:38 | 只看该作者
qiuzhang 发表于 2015-3-17 14:35
" c" |/ t  H; }+ D, W定义不带宽度属性的,出在gerber中是多少。图中圈圈中不是0就行了
' X8 g0 x, l9 c. N0 P我写的是6mil ,
发表于 2017-1-16 11:05 | 只看该作者
版图尺寸太大了,可能在导入DXF或者什么的时候图形飞到边界了~可以调整版图尺寸或者在Manufacturing->Photoplot_Outline中绘制一个光绘外形~
GMT+8, 2025-11-1 20:38 , Processed in 0.171875 second(s), 29 queries , Gzip On.
