查看: 2689|回复: 19
Hotfix_SPB16.60.045
发表于 2015-3-15 12:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
) Q$ o+ W% `. z2 l' B; Z" e
+ l% t4 X: S0 M. ?1 eDATE: 03-13-2015   HOTFIX VERSION: 045& Q2 w  L# c7 H3 I- W- K
===================================================================================================================================' ]/ y3 Q7 J$ p2 ]# M
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
6 [* X. u, D1 G! a===================================================================================================================================2 K7 ?- o" U3 G+ v# G: ?4 J) b
1308671 concept_HDL    PDF              Pivotal symbol on Hierarchical Split Symbol bodies needs to be hidden in the generated PDF3 R/ q+ i- v& ?5 F
1349899 Pspice         NETLISTER        PSpice: Getting different simulation results in versions 16.5 and 16.6
& j# F6 Y. H4 ]; U1355271 FSP            DE-HDL_SCHEMATIC FSP generating incorrect connectivity information in HDL
0 r  w7 K- C% X  z! j1370402 ADW            TDA              TDO does not use the specified name for creating the local work area.
2 G" S" {$ b$ \, R1371281 CONCEPT_HDL    CONSTRAINT_MGR   It takes 10 minutes to launch Constraint Manager% X6 |, z, u4 j4 G
1372480 CONCEPT_HDL    CORE             How do I get ASA to recognize changes made to a schematic block?
8 r, V6 P' X1 X6 Y1 d1372939 CONCEPT_HDL    CORE             Save Hierarchy and Save All do not resolve the duplicate refdes issue in a SIZEd part
  V; a+ M1 [! A5 A, E) o2 V1375265 ASI_SI         OTHER            allegro Sigrity SI  to XtractIM translation failed with a workspace file opening error
" u. [. m/ @" }$ l, Y1376225 SIP_LAYOUT     DIE_ABSTRACT_IF  'Refresh co-design die' operation fails with "incorrect number of ETCH subclasses defined" message$ Z: f0 k( [, j) Z$ ~# d! a
1376644 ALLEGRO_EDITOR mentor           Command line mbs2brd still needs SI licenses
3 S$ g  [0 u1 {% t/ _- W1376846 SIP_LAYOUT     IC_IO_EDITING    Running the Show IC Details command generates a drawing/symbol extents error, then SiP crashes% E4 I' W' @' _7 X0 w
1377297 ALLEGRO_EDITOR EDIT_ETCH        PCB Editor crashes when using the Remove Tuning command
- W' x1 P  ~" ?- I" k- l4 |1377587 CONCEPT_HDL    MARKERS          The marker file cannot be loaded using the console command "_! markers load <filename.mkr>".
' A0 f! n. _: h9 I8 R1377711 TRANSLATOR     SPDLINKS         Unable to open an MCM file in XtractIM from APD7 b3 i; L9 Q- F$ a* A. }
1377962 CONCEPT_HDL    CORE             If an instantiated part is removed from the library, DE-HDL hangs while reading the .xcon file
3 q/ w/ b! m8 L( f5 j+ L1378032 ALLEGRO_EDITOR REPORTS          Report command and batch mode give different Waived DRC Report results in PCB Editor6 c. q: S/ b9 L
1379797 F2B            PACKAGERXL       Connections are missing in the generated netlist& k% u% S# X' X  Q6 _8 Z' l
稍后附上链接。。。。。。
2 [# U# E" E! X  @0 b下载链接:
8 H0 J' `& y$ Q# y# Whttp://pan.baidu.com/s/1mgsrKfQ
8 x* Q: C2 h, u" _2 ~0 o
参与人数 1威望 +2 收起 理由
yueyuan2003 + 2
    慵懒
    2022-1-11 15:59
    推荐
    发表于 2015-3-27 09:39 | 只看该作者
    神话2012 发表于 2015-3-26 10:32
    6 a$ y. z- \5 f" l7 M你好,请问这补丁是直接安装就行了吗
    % c8 O% @! W* ~/ f+ g1 c不能直接装 要新建一个文件夹,把旧的里面一个文件拷过去,装完破解再拷回来
    " w  ^7 s( {  u) S8 f( T论坛有具体步骤你找找
    7 B, R3 J( U  L8 r
    推荐
    发表于 2015-3-31 12:31 | 只看该作者
    yueyuan2003 发表于 2015-3-15 13:23
    ) q0 i3 t: S; ~, j! V* q大神,你有16.5的61号补丁吧,也给我一份吧,感谢very much
    : Z, |& T1 c* b" o' X4 O! V
    Hotfix_SPB16.50.062
    5 K, c% ^1 n: n- Vhttp://pan.baidu.com/s/1gdhBNzl# ... 5BB%25B6%252FSPB165
    0 Y  w- ]  O$ g" b/ s3 d2 p4 m! a7 ]5 z' o3 S7 o/ Y5 F
    推荐
     楼主| 发表于 2015-3-15 14:07 | 只看该作者
    yueyuan2003 发表于 2015-3-15 13:23% k" g! g+ K$ G9 L
    6 |& g1 U- Y& y% P. N
    不好意思,我没有16.5的,现在更新到62了
    发表于 2015-3-15 13:23 | 只看该作者
    Hotfix_SPB16.50.062 http://pan.baidu.com/s/1gdhBNzl#path=%252FCadence%25E5%2585%25B1%25E4%25BA%25AB%25E6%2596%2587%25E4%25BB%25B6%252FSPB165  详情 回复 发表于 2015-3-31 12:31
    不好意思,我没有16.5的,现在更新到62了  详情 回复 发表于 2015-3-15 14:07
    发表于 2015-3-15 17:12 | 只看该作者
    灰常感谢楼主
    发表于 2015-3-15 20:56 | 只看该作者
    谢谢分享啊
    发表于 2015-3-16 20:26 | 只看该作者
    谢谢分享啊
    发表于 2015-3-16 20:48 | 只看该作者
    为什么补丁这么多呢!谁知道啊
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2015-3-19 09:37 | 只看该作者
    補丁真是更新的好快喔!!5 x. d4 v6 `9 S* x( F
    感謝大大提供及分享囉!!
    慵懒
    2022-1-11 15:59
    发表于 2015-3-19 22:09 | 只看该作者
    无语了 44昨天更新完 今天见到45了
    你好,请问这补丁是直接安装就行了吗  详情 回复 发表于 2015-3-26 10:32
    13#
    发表于 2015-3-25 17:46 | 只看该作者
    即时更新,跟上节奏
    2023-7-27 15:05
    14#
    发表于 2015-3-26 10:32 | 只看该作者
    小枫残月 发表于 2015-3-19 22:09
    . j0 O3 C: V$ v9 Q$ V5 [6 y7 E; ?: b无语了 44昨天更新完 今天见到45了
    - W3 y% ~$ F' q! o3 i' O你好,请问这补丁是直接安装就行了吗
    . P3 g/ V, V  L
    不能直接装 要新建一个文件夹,把旧的里面一个文件拷过去,装完破解再拷回来 论坛有具体步骤你找找  详情 回复 发表于 2015-3-27 09:39
    15#
    发表于 2015-3-26 22:31 | 只看该作者
    真是佛心來的~~~
    GMT+8, 2025-11-6 02:10 , Processed in 0.187500 second(s), 32 queries , Gzip On.
