Xilinx has recently released SDAccel, a development environment that includes software tools including its own compiler, tools for code development, profiling, and debugging, and provides a GPU-like work environment. Getman said: ‘Our goal is to make an FPGA as easy to program as a GPU.  SDAccel, which is OpenCL based, does allow people to program in OpenCL and C or C++ and they can now target the FPGA at a very high level.’
In addition, SDAccel provides functionality to swap multiple kernels in and out of the FPGA without disrupting the interface between the server CPU and the FPGA. This could be a key enabler of FPGAs in real-world data centres where turning off some of your resources while you re-optimise them for the next application is not an economically viable strategy at present.
Altera has been working closely with the Khronos group, which oversees a number of open computing standards including OpenCL, OpenGL, and WebGL. Altera released a development toolkit, Altera’s SDK for OpenCL, in May 2013. Strickland said: ‘In May 2013 we achieved a very important conformance test with the standards body – the Khronos group – that manages OpenCL. We had to pass 8,000 tests and that really strengthened the credibility of what we are doing with the FPGA.’
Strickland continued: ‘In the past, there were a lot of FPGA compiler tools that took care of the logic but not the data management. They could take lines of C and automatically generate lines of RTL but they did not take care of how that data would come from the CPU, the optimisation of external memory bandwidth off the FPGA, and that is a large amount of the work.’
Traditionally optimising algorithms to utilise fully the parallel architectures of FPGA technology involved significant experience using HDLs (hardware description languages) because they allowed programmers to write code that would address the FPGA at register-transfer level (RTL).
RTL enables programmers to describe the flow of data between hardware registers, and the logical operations performed on that data. This is typically what creates the difference in performance between more general processors and FPGAs, which can be optimised much more efficiently for a specific algorithm.
The difficulty is that that kind of coding requires expertise and can be very time consuming. Hand-coded RTL may go through several iterations as programmers test the most efficient ways to parallelise the instruction set to take advantage of the programmable hardware on the FPGA.
Strickland said: ‘With OpenCL or the OpenCL compiler, you still write something that is like C code that targets the FPGA. The big difference I would say is the instruction set. The big innovation has been the back end of our complier which can now take that C code and efficiently use the FPGA.’
Strickland noted that Altera’s compiler ‘does more than 200 optimisations when you write some C code. It is doing things like seeing the order in which you access memory so that it can group memory addresses together, improving the efficiency of that memory interface.’
Converting code from different languages into an RTL description has been possible for some time, but these developments in OpenCL make it much easier for programmers without extensive knowledge of HDLs, such as VHDL and Verilog, to make use of FPGAs.
However OpenCL is not the final piece of the puzzle for FPGA programming. Strickland said: ‘Over time you may want to have other high-level interfaces. There is a standard called SPIR (Standard Portable Intermediate Representation). The idea is that this allows you to kind of split up your compiler between the front end and the back end, enabling people to use different high-level language interfaces on the front end.’
Strickland continued: ‘In universities now there is research into domain-specific languages, so people are trying to accomplish a certain class of algorithms may benefit from having a higher level interface than even C. The idea behind exposing this intermediate compiler interface is you can now start working with the ecosystem to have front ends with higher-level interfaces.’
Over the past few years, there have been two ideas behind the best way to program FPGAs: high-level synthesis (HLS) or OpenCL. As OpenCL has matured, Xilinx decided to adopt the standard but to keep the work it had done developing HLS technology and integrate that into the development environment conforming to the OpenCL standard.
Getman said: ‘The main problem is that C is very much designed to go cycle to cycle, step by step. Unfortunately hardware doesn’t. Hardware has a lot of things running at the same time.’ This aspect was what made HLS attractive as a compiler that can take OpenCL, C or C++ and architecturally optimise it for the FPGA hardware.
Xilinx acquired AutoESL and its HLS tool AutoPilot in 2011 and began integrating it into its own development tools for FPGAs. Getman said: ‘That was really the big switching point. For many years, people had been promising really great results with HLS but in reality the results were a lot bigger and a lot slower than what could have been done by hand.’
Getman continued: ‘We have integrated this technology into our tools and added a lot to it. This is really one of the big differentiators from our competition, even though we both have OpenCL support. This technology allows our users the opportunity to create their own libraries in  real-time using  C, C++ or OpenCL, rather than have to wait for the vendor to create specific libraries or specific algorithms for them.
Varma said: ‘The silver bullet in HLS is the ability to take a sequential description that has been written in C and then find this parallelism, the concurrencies, without the user having to think. That was a necessary technology before we could do anything. It has been adopted by thousands of users already as a standalone technology, but what we do is embed that technology inside OpenCL compilers so that now it can be utilised in full software mode and it is fully compatible with OpenCL.’
Getman said: ‘We consciously made a switch over the last few years to expand our customer base by both continuing technology development for our traditional users as well as expand our tool flow to cater to software coders.’
A key facet of this technology is that Xilinx is letting programmers take the work they have done in C and port it over to OpenCL using the technology from HLS that is now integrated into its compilers. Varma said: ‘One thing that changes when you go from software to hardware programming is that C programmers, OpenCL programmers, are used to dealing with a lot of libraries. They do not have to write matrix multiplications or filters or those kinds of things, because they are always available as library elements.  Now hardware languages often have libraries, but they are very specific implementations that you cannot just change for your use.’
Varma concluded: ‘By writing in C, our HLS technology can re-compile that very efficiently and immediately. This gives you a tremendous capability.’
