查看: 3498|回复: 9
Hotfix_SPB16.60.040_wint_1of1.exe 更新
发表于 2014-12-13 21:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
( q- K3 ]6 R3 C* r+ N
$ V# w6 x* y9 Q* @. j* B0 sSPB16.60稍后跟链接           链接:http://pan.baidu.com/s/1o69LWDk 密码:v1l5
7 V* M5 J) \7 `# ?  ~+ M" O$ ^# |+ |3 f
DATE: 12-12-2014   HOTFIX VERSION: 0406 x. Z3 R) c( ?' a& c* z0 o
5 v, @# E, e: T0 @CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
# I9 m" C% _( C$ ^0 G1 b) o===================================================================================================================================
& U  T! G8 ]( K' M3 q# q577694  allegro_EDITOR OTHER            Need to retain padstack edits during "Refresh Symbols"* C9 b* Y* q! ?
1105280 FSP            MODEL_EDITOR     Negative Voltage leads to 'Internal error. Invalid voltage value -12 specified for pin'
- ~4 T4 o8 l! M1 P1198148 FSP            OTHER            In the Symbol Setup form instances instantiated multiple times must be customized individually
9 H' X- ]7 Y1 d' {: c; [2 ?1200015 concept_HDL    CORE             module_order.dat is generated for sym_n view automatically+ p0 `8 X2 o% m3 S( R
1275209 Pspice         NETLISTER        PSpice is not considering 3K9 as 3.9K if inside a condition in PSpice template
/ ]9 {$ L  h  b# e! ~& Q! ]: u1297335 SPECCTRA       FANOUT           Wrong fanout created in PCB Editor on using the Route Automatic option.& L' E9 b" @) ?& `0 v
1316637 CONCEPT_HDL    PDF              PublishPDF does not set arc lines to the defined line width setting
5 V9 L9 h# t4 J/ o: H- {! z2 x1320581 ALLEGRO_EDITOR OTHER            Dangling line listed in Dangling Line report but no line exists.
( k' A* L, f1 V$ U, H9 N1326104 CONCEPT_HDL    CORE             Pin dots, pin text do not stay on grid in symbol editor on moving/copying.
- Y6 H- \: A% o6 L1329848 CONSTRAINT_MGR CONCEPT_HDL      Export Excel from DE-HDL CM displays 'Server busy' message.
% K& M) C: ]' y! ~) [+ |* O" L1330044 CONSTRAINT_MGR OTHER            Need command line equivalent of cmDiffUtility to save reports as HTML
7 z6 e. e) M3 d1330122 SIP_LAYOUT     PLACEMENT        When placing IC type symbols in SiP they are being placed as Wire Bond instead of Flip Chip.
& m: O4 D6 ?" Y4 s; M1330930 CONCEPT_HDL    CORE             Hyperlink in attributes window not working.
3 [4 c7 X4 g: _1336086 SIP_LAYOUT     MANUFACTURING    If a design has bondfingers at a certain angle/position the tool does not create a soldermask opening3 N2 v+ m+ J$ i  G7 x6 A5 r
1338610 MODEL_INTEGRIT TRANSLATION      IBIS to DML failed with incorrect error message.! I, M' \& M, H. {
1338925 ALLEGRO_EDITOR MANUFACT         Need a 16.5 route file option in SPB 16.6., o  }4 [: ~- o6 s& i# E6 Y8 P4 u
1339672 CONCEPT_HDL    CORE             Editing a symbol in PDV results in error (SPCOCN-1731)
; V7 f; w! @2 R, _  U1339987 ALLEGRO_EDITOR skill            axlFormCreate embeddedForm is not working as expected
* i$ M# c; [7 c1339989 PCB_LIBRARIAN  LIBUTIL          Con2con exits if Global section of PTF file has NC_PINS& [  q# N- {' J8 l& V
1340342 F2B            DESIGNVARI       DE-HDL crashes when trying to use Variant commands
  i: J. O/ b4 _* H, \& c/ ~- H1340360 ALLEGRO_EDITOR EDIT_ETCH        On running the AiDT command, if Total Etch Length is defined directly on an XNet, PCB Editor crashes.
% W- \/ @7 x& v7 D9 r) M" q1340854 CONSTRAINT_MGR CONCEPT_HDL      Component properties are lost during backannotation* M; X/ F0 Y6 I8 I$ t9 N: a
1341096 SIP_LAYOUT     ASSY_RULE_CHECK  ADRC rule 'Wire to Pad Optical Short' gives wrong results/ K2 h! e) k2 H/ [# b/ \. [; F
1341330 ALLEGRO_EDITOR DRC_CONSTR       Spacing rules not followed if bond_pad is set to bond_finger
9 g( r( A5 b0 R2 V& H# e4 ~1342705 ALLEGRO_EDITOR INTERFACES       IDX incremental bend areas need delete processed first before adds  o5 R1 p- N) T7 n" s, E
1342910 FSP            SETTINGS         Unable to remove "Don't Use Banks" setting.
1 x) x1 L& o/ j# u1343076 SIG_INTEGRITY  OTHER            'orcad PCB Professional' tier should not allow Differential Pair extraction: X" Y( p9 n2 h& @) U
1343239 PCB_LIBRARIAN  VERIFICATION     Con2con reporting errors against the wrong primitive
: |4 D% F* S. S3 Z: v1343257 SCM            SETUP            In SCM, unable to add termination to design.2 ?, d) x% H% o- X2 d8 O( h
1343403 CONCEPT_HDL    CORE             Return code in Search_History prevents DE-HDL launch.7 A, j( b( Y" _9 }% k
1343749 CONCEPT_HDL    CORE             Global Navigate does not always respond8 I7 V: \* Q6 K; S# n
1343870 ALLEGRO_EDITOR DATABASE         Import Logic changes VIA net names to GND9 A0 W2 r6 k5 o) a$ `9 ^7 g
1343949 FSP            IMPORT_ALLEGRO   Import Instances from PCB Editor does not import FPGA model* Q( V* E" B. u! g; b
1344265 CONCEPT_HDL    CORE             DE-HDL crashes on viewing page search) U1 o0 B0 f+ c. c: l
1344413 SIP_LAYOUT     DIE_GENERATOR    When composing a die From Geometry the die pads are shifting.
/ o7 m: T; a* K+ T3 g, H+ o* \1344745 ALLEGRO_EDITOR EXTRACT          Need information about the changes in the format of the report generated using axlExtractToFile()
9 J  V- p8 K+ c8 }: y- P1346277 SIP_LAYOUT     DIE_ABSTRACT_IF  Shape cannot be read when sip_symed_codesign is set.6 f$ l' X1 }7 b6 Y
1346318 CONSTRAINT_MGR OTHER            cmDiffUtility shows "unrelease_unrelease.." message and stops; K+ `8 i- t5 N# Q0 {
1346621 ASI_PI         GUI              Sigrity tools shown in PI Base Analyze menu regardless of option selected6 \4 P7 |% O  {* s) k; l/ M; I4 Q
1347103 ALLEGRO_EDITOR INTERFACES       Step mapping - 3D view for mechanical symbol$ R) B* C3 O) f0 [8 d
. \, ?7 ?5 d* f2 _
发表于 2014-12-14 00:04 | 只看该作者
此帖仅作者可见
发表于 2014-12-15 08:54 | 只看该作者
此帖仅作者可见
发表于 2014-12-15 09:57 | 只看该作者
此帖仅作者可见
发表于 2014-12-15 11:53 | 只看该作者
此帖仅作者可见
    擦汗
    2019-12-12 15:00
  • 签到天数: 13 天
    [LV.3]偶尔看看II
    发表于 2014-12-17 08:58 | 只看该作者
    此帖仅作者可见
    发表于 2014-12-23 11:20 | 只看该作者
    此帖仅作者可见
    GMT+8, 2025-11-6 13:12 , Processed in 0.156250 second(s), 23 queries , Gzip On.
