查看: 1306|回复: 0
对齐功能
发表于 2014-12-7 12:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
对齐功能
axlCmdRegister( "aln" 'aln  ?cmdType "interactive" ?doneCmd 'alnDone ?cancelCmd 'alnCancel )
when( (axlVersion('version) >= 16.3 && !axlUIMenuFind(nil "aln")) ; since 16.3
        axlUIMenuRegister( "move" '( ("&Align" "aln") ) )
;  reload script, only for development purpose
/*axlCmdRegister( "lo" 'lo)
procedure( lo()
        load("o:/Sripts/align/align.il")
        load("o:/Sripts/align/align_do.il")
        load("o:/Sripts/align/align_utils.il")
procedure( aln()
(prog ()
        when( axlOKToProceed()
                axlDebug(nil)
;                axlDebug(t)
                axlClearSelSet()
                alnInitGlobalVariable()
                alnInitForm()
                alnInitHotKeys()
                popupA = axlUIPopupDefine( nil
                                (list
                                        (list "Done" 'alnDone)
                                        (list "Oops" 'alnOops)
                                        (list "Cancel" 'alnCancel)
                axlUIPopupSet( popupA )
                axlSetFindFilter(?enabled '(GROUPS SYMBOLS PINS VIAS TEXT NAMEFORM ) ?onButtons _alnCheckedFilterBoxes) ; setup filter
                axlMsgPut("Select object(s)")
                _alnTransactionMark = axlDBTransactionStart()
                while( _alnFinish == nil
                        ; get objects from previous iteration
                        _alnSelectedObjects = axlGetSelSet()
                        if(_alnSelectedObjects then axlMsgPut("Choose action"))
                        ; remove fixed objects from selection
                        _alnSelectedObjects = alnCheckFoRFixedObjects(_alnSelectedObjects)
                        ; wait for object selection
                        axlSelect(?groupMode nil ?prompt nil)
                        ; execute operation chosen in form
                        if( _alnHandler then
                                if( _alnSelectedObjects
                                        then
                                                axlDBTransactionMark(_alnTransactionMark)
;                                                axlDBControl('drcEnable nil)
;                                                axlDBControl('dynamicFilletsOn nil)
                                                funcall(_alnHandler)
                                                ; refresh id
                                                axlDBRefreshId(axlGetSelSet())
                                                ; restore selection
                                                _alnSelectedObjects = alnRefreshIDs(_alnSelectedObjects)
                                                axlSingleSelectObject(_alnSelectedObjects)
;                                                axlDBControl('dynamicFilletsOn t)
;                                                axlDBControl('drcEnable t)
                                                ;axlDRCUpdate(t)
                                        else
                                                axlMsgPut("No object(s) found")
                                _alnHandler = nil
                );end-while
        );endwhen
);end-prog
);endprocedure
;----------------- Menu Call--------------------------------
defun( alnDone ()
        axlDBTransactionCommit( _alnTransactionMark )
        alnExit()
);end-fun
defun( alnOops ()
        if(_alnHandler then axlFinishEnterFun()) ;for exit from 'doPickH or 'doPickV
        axlDBTransactionOops(_alnTransactionMark)
        ; restore selection
        axlAddSelectObject(_alnSelectedObjects)
);end-fun
defun( alnCancel ()
        axlDBTransactionRollback( _alnTransactionMark )
        alnExit()
);end-fun
defun( alnExit ()
        _alnFinish = t
        axlFormClose(_alnFormPtr)
        axlDehighlightObject(_alnSelectedObjects)
        axlCancelEnterFun()
        axlClearSelSet()
        axlUIPopupSet( nil )
        popupA = nil
        _alnCheckedFilterBoxes = axlGetFindFilter(t)
        alnStoreFilter(_alnCheckedFilterBoxes)
        _alnTransactionMark = nil
        alnRestoreHotKeys()
        alnStoreFormData()
);end-defun
;-------------------Parameter form data ------------------
defun( alnInitForm () ;
let( (units multiplier)
when( (axlIsDebug) axlMsgPut("alnInitForm"))
        _alnFormPtr = axlMiniStatusLoad( (gensym) "align.form" '_pARMCallBack)
        ;_alnFormPtr = axlFormCreate( (gensym) "align.form" '(ne canvas msglines 0) '_parmCallBack t)
        units = axlDBGetDesignUnits()
        case( car(units)
                ("mils" multiplier = 1)
                ("inches" multiplier = 0.001)
                ("microns" multiplier = 25.4)
                ("millimeters" multiplier = 0.0254)
                ("centimeters" multiplier = 0.00254)
        when( ( _alnFormData == nil )
                ; first script launch in current session, trying restore settings
                _alnFormData = alnRestoreFormData()
        if( ( _alnFormData == nil )
                then ; first script launch
                        _alnFormData = ncons(t)
                        _alnFormData->units = units
                        axlFormSetField(_alnFormPtr "bxPickH" nil)
                        _alnFormData->usePickH = nil
                        axlFormSetField(_alnFormPtr "bxStepH" nil)
                        _alnFormData->useStepH = nil
                        axlFormSetField(_alnFormPtr "bxPickV" nil)
                        _alnFormData->usePickV = nil
                        axlFormSetField(_alnFormPtr "bxStepV" nil)
                        _alnFormData->useStepV = nil
                        axlFormSetField(_alnFormPtr "fPickH" 0.0)
                        _alnFormData->pickH = 0.0
                        axlFormSetField(_alnFormPtr "fStepH" (100.0 * multiplier))
                        _alnFormData->stepH = 100.0 * multiplier
                        axlFormSetField(_alnFormPtr "fPickV" 0.0)
                        _alnFormData->pickV = 0.0
                        axlFormSetField(_alnFormPtr "fStepV" (100.0 * multiplier))
                        _alnFormData->stepV = 100.0 * multiplier
                        axlFormSetField(_alnFormPtr "bxGap" nil)
                        _alnFormData->useGap = nil
                        axlFormSetField(_alnFormPtr "bxStretch" t)
                        _alnFormData->useStretch = t
                        axlFormSetField(_alnFormPtr "bxRipup" nil)
                        _alnFormData->useRipup = nil
                        axlFormSetField(_alnFormPtr "bxSnapToGrid" t)
                        _alnFormData->snapToGrid = t
                        axlFormSetField(_alnFormPtr "cmbSnapPoint" "center")
                        _alnFormData->snapPoint = "center"
                        axlFormSetField(_alnFormPtr "sPinNumber" "1")
                        _alnFormData->snapPinNumber = "1"
                else ; settings present in session or restored from design
                        when( car(_alnFormData->units) != car(units)
                                ; units were changed, correct multiplier
                                case( car(_alnFormData->units)
        ;                                ("mils" multiplier = multiplier / 1)
                                        ("inches" multiplier = multiplier / 0.001)
                                        ("microns" multiplier = multiplier / 25.4)
                                        ("millimeters" multiplier = multiplier / 0.0254)
                                        ("centimeters" multiplier = multiplier / 0.00254)
                                _alnFormData->pickH        = _alnFormData->pickH * multiplier
                                _alnFormData->stepH        = _alnFormData->stepH * multiplier
                                _alnFormData->pickV = _alnFormData->pickV * multiplier
                                _alnFormData->stepV        = _alnFormData->stepV * multiplier
                        axlFormSetField(_alnFormPtr "bxPickH" _alnFormData->usePickH)
                        axlFormSetField(_alnFormPtr "bxStepH" _alnFormData->useStepH)
                        axlFormSetField(_alnFormPtr "bxPickV" _alnFormData->usePickV)
                        axlFormSetField(_alnFormPtr "bxStepV" _alnFormData->useStepV)
                        axlFormSetDecimal(_alnFormPtr "fPickH" cadr(units))
                        axlFormSetDecimal(_alnFormPtr "fStepH" cadr(units))
                        axlFormSetDecimal(_alnFormPtr "fPickV" cadr(units))
                        axlFormSetDecimal(_alnFormPtr "fStepV" cadr(units))
                        axlFormSetField(_alnFormPtr "fPickH" _alnFormData->pickH)
                        axlFormSetField(_alnFormPtr "fStepH" _alnFormData->stepH)
                        axlFormSetField(_alnFormPtr "fPickV" _alnFormData->pickV)
                        axlFormSetField(_alnFormPtr "fStepV" _alnFormData->stepV)
                        axlFormSetField(_alnFormPtr "bxGap" _alnFormData->useGap)
                        axlFormSetField(_alnFormPtr "bxStretch" _alnFormData->useStretch)
                        axlFormSetField(_alnFormPtr "bxRipup" _alnFormData->useRipup)
                        axlFormSetField(_alnFormPtr "bxSnapToGrid" _alnFormData->snapToGrid)
                        axlFormSetField(_alnFormPtr "cmbSnapPoint" _alnFormData->snapPoint)
                        axlFormSetField(_alnFormPtr "sPinNumber" _alnFormData->snapPinNumber)
        if(_alnFormData->usePickH
                then axlFormSetFieldEditable(_alnFormPtr "fPickH" t)
                else axlFormSetFieldEditable(_alnFormPtr "fPickH" nil)
        if(_alnFormData->usePickV
                then axlFormSetFieldEditable(_alnFormPtr "fPickV" t)
                else axlFormSetFieldEditable(_alnFormPtr "fPickV" nil)
        if(_alnFormData->useStepH
                then axlFormSetFieldEditable(_alnFormPtr "fStepH" t)
                else axlFormSetFieldEditable(_alnFormPtr "fStepH" nil)
        if(_alnFormData->useStepV
                then axlFormSetFieldEditable(_alnFormPtr "fStepV" t)
                else axlFormSetFieldEditable(_alnFormPtr "fStepV" nil)
        if(_alnFormData->useStretch
        then
        if(_alnFormData->useRipup then
                axlFormSetField(_alnFormPtr "bxStretch" nil)
                _alnFormData->useStretch = nil
        if( (_alnFormData->snapPoint == "pin")
                then axlFormSetFieldVisible( _alnFormPtr "sPinNumber" 1)
                else axlFormSetFieldVisible( _alnFormPtr "sPinNumber" 0)
        when( (axlVersion('version) < 15.7) ; since 15.7
                axlFormSetFieldEditable(_alnFormPtr "bxSnapToGrid" nil)
;        axlFormDisplay(_alnFormPtr)
) ;end let
);end-defun
;---------------Form Call Back-----------------------------------------------
defun( _parmCallBack (form)
when( (axlIsDebug) axlMsgPut("_parmCallBack"))
        case( get(form 'curField)
                ( "bnTop" alnOnTop() )
                ( "bnCenterH" alnOnCenterH() )
                ( "bnBottom" alnOnBottom() )
                ( "bnLeft" alnOnLeft() )
                ( "bnCenterV"  alnOnCenterV() )
                ( "bnRight" alnOnRight() )
                ( "bxPickH" _alnFormData->usePickH = form->curValue
                                then axlFormSetFieldEditable(form "fPickH" t)
                                else axlFormSetFieldEditable(form "fPickH" nil)
                ( "fPickH" _alnFormData->pickH = form->curValue )
                ( "bnPickH" alnOnPickH() )
                ( "bxPickV" _alnFormData->usePickV = form->curValue
                                then axlFormSetFieldEditable(form "fPickV" t)
                                else axlFormSetFieldEditable(form "fPickV" nil)
                ( "fPickV" _alnFormData->pickV = form->curValue )
                ( "bnPickV" alnOnPickV() )
                ( "bxStepH"
                        _alnFormData->useStepH = form->curValue
                                then axlFormSetFieldEditable(form "fStepH" t)
                                else axlFormSetFieldEditable(form "fStepH" nil)
                ( "fStepH" _alnFormData->stepH = form->curValue )
                ( "bnDistributeH" alnOnDistributeH() )
                ( "bxStepV"
                        _alnFormData->useStepV = form->curValue
                                then axlFormSetFieldEditable(form "fStepV" t)
                                else axlFormSetFieldEditable(form "fStepV" nil)
                ( "fStepV" _alnFormData->stepV = form->curValue )
                ( "bnDistributeV" alnOnDistributeV() )
                ( "bxGap" _alnFormData->useGap = form->curValue)
                ( "bxStretch"
                        _alnFormData->useStretch = form->curValue
                        then
                                axlFormSetField(form "bxRipup" nil)
                ( "bxRipup"
                        _alnFormData->useRipup = form->curValue
                                axlFormSetField(form "bxStretch" nil)
                ( "bxSnapToGrid" _alnFormData->snapToGrid = form->curValue        )
                ( "cmbSnapPoint"
                        _alnFormData->snapPoint = form->curValue
                                then axlFormSetFieldVisible( form "sPinNumber" 1)
                                else axlFormSetFieldVisible( form "sPinNumber" 0)
                ( "sPinNumber" _alnFormData->snapPinNumber = form->curValue)
        );case
);end-defun
defun( alnInitGlobalVariable ()
        _alnFinish = nil
        when( !boundp('_alnFormData) _alnFormData = nil)
        _alnFormPtr = nil
        _alnHandler = nil
        _alnSelectedObjects = nil
        when( !boundp('_alnCheckedFilterBoxes)
                _alnCheckedFilterBoxes = alnRestoreFilter()
                when( !_alnCheckedFilterBoxes _alnCheckedFilterBoxes = '(SYMBOLS VIAS TEXT)
);end-defun
defun( alnInitHotKeys ()
        let( (aliases alias aliasFunc funckeys funckey funckeyFunc)
                ; store all hotkeys        and find hotkey for oops command
                ; funckeys
                when( (axlVersion('version) >= 16.3) ; since 16.3
                        funckeys = axlGetFunckey(nil)
                        _alnOriginalFunckeys = nil
                        foreach( funckey funckeys
                                funckeyFunc = axlGetFunckey(funckey)
                                _alnOriginalFunckeys = cons(list(funckey funckeyFunc) _alnOriginalFunckeys)
                                when( funckeyFunc == "oops"
                                        _oopsAlias = funckey
                ; aliases
                aliases = axlGetAlias(nil)
                _alnOriginalAliases = nil
                foreach( alias aliases
                        aliasFunc = axlGetAlias(alias)
                        _alnOriginalAliases = cons(list(alias aliasFunc) _alnOriginalAliases)
                        when( aliasFunc == "oops"
                                _oopsAlias = alias
                ; define new actions
                axlCmdRegister( "alnOops" 'alnOops ?cmdType "sub_cmd")
                axlCmdRegister( "alnTop" 'alnOnTop ?cmdType "sub_cmd")
                axlCmdRegister( "alnBottom" 'alnOnBottom ?cmdType "sub_cmd")
                axlCmdRegister( "alnLeft" 'alnOnLeft ?cmdType "sub_cmd")
                axlCmdRegister( "alnRight" 'alnOnRight ?cmdType "sub_cmd")
                axlCmdRegister( "alnCenterH" 'alnOnCenterH ?cmdType "sub_cmd")
                axlCmdRegister( "alnCenterV" 'alnOnCenterV ?cmdType "sub_cmd")
                axlCmdRegister( "alnDistributeH" 'alnOnDistributeH ?cmdType "sub_cmd")
                axlCmdRegister( "alnDistributeV" 'alnOnDistributeV ?cmdType "sub_cmd")
                axlCmdRegister( "alnPickH" 'alnOnPickH ?cmdType "sub_cmd")
                axlCmdRegister( "alnPickV" 'alnOnPickV ?cmdType "sub_cmd")
                ; define new hotkeys
                if( boundp('_oopsAlias) && _oopsAlias
                        then axlSetAlias( _oopsAlias "alnOops")
                        else axlSetAlias( "F3" "alnOops") ; if hotkey for oops command not assigned
                        axlSetFunckey( "a" "alnLeft")
                        axlSetFunckey( "s" "alnBottom")
                        axlSetFunckey( "w" "alnTop")
                        axlSetFunckey( "d" "alnRight")
                        axlSetFunckey( "q" "alnCenterH")
                        axlSetFunckey( "z" "alnCenterV")
                        axlSetFunckey( "e" "alnDistributeH")
                        axlSetFunckey( "c" "alnDistributeV")
                        axlSetFunckey( "r" "alnPickH")
                        axlSetFunckey( "v" "alnPickV")
        ) ; let
);end-defun
defun( alnRestoreHotKeys ()
        let( (funckey alias)
                axlCmdUnregister("alnOops")
                axlCmdUnregister("alnLeft")
                axlCmdUnregister("alnBottom")
                axlCmdUnregister("alnTop")
                axlCmdUnregister("alnRight")
                axlCmdUnregister("alnCenterH")
                axlCmdUnregister("alnCenterV")
                axlCmdUnregister("alnDistributeH")
                axlCmdUnregister("alnDistributeV")
                axlCmdUnregister("alnPickH")
                axlCmdUnregister("alnPickV")
                when( !boundp('_oopsAlias) || !_oopsAlias
                        axlSetAlias( "F3" nil)
                        axlSetFunckey( "a" nil)
                        axlSetFunckey( "s" nil)
                        axlSetFunckey( "w" nil)
                        axlSetFunckey( "d" nil)
                        axlSetFunckey( "q" nil)
                        axlSetFunckey( "z" nil)
                        axlSetFunckey( "e" nil)
                        axlSetFunckey( "c" nil)
                        axlSetFunckey( "r" nil)
                        axlSetFunckey( "v" nil)
                        ; restore funckeys
                        foreach( funckey _alnOriginalFunckeys
                                when( !axlIsProtectAlias(car(funckey)) ; skip readonly
                                        axlSetFunckey(car(funckey) cadr(funckey))
                ; restore aliases
                foreach( alias _alnOriginalAliases
                        when( !axlIsProtectAlias(car(alias)) ; skip readonly
                                axlSetAlias(car(alias) cadr(alias))
        ) ; let
);end-defun
; Store form settings to attachment.
defun( alnStoreFormData ()
        let( (sFormData attachment )
                sFormData = sprintf(nil "%L" _alnFormData)
                attachment = axlGetAttachment("AlignFormData" 'string)
                if( attachment
                then
                        attachment->data = sFormData
                        axlSetAttachment(attachment "QWE123qwe")
                else
                        attachment = axlCreateAttachment("AlignFormData" "QWE123qwe" 0 'string sFormData)
                );if
        ) ; let
);end-defun
; Restore form settings from attachment.
defun( alnRestoreFormData ()
        prog( (formData attachment sFormData )
                formData = nil
                sFormData = attachment->data
                when( sFormData
                        formData = car(errsetstring(strcat("'" sFormData)))
                return(formData)
        ) ; let
);end-defun
; Store selected Find filter checkboxes.
defun( alnStoreFilter (checked)
        let( (attachment sChecked)
                sChecked = sprintf(nil "%L" checked)
                attachment = axlGetAttachment("AlignSelectFilter" 'string)
                if( attachment
                then
                        attachment->data = sChecked
                else
                        attachment = axlCreateAttachment("AlignSelectFilter" "QWE123qwe" 0 'string sChecked)
                );if
        ) ; let
);end-defun
; Restore selected Find filter checkboxes.
defun( alnRestoreFilter ()
        prog( (checked attachment sChecked )
                checked = nil
                sChecked = attachment->data
                when( sChecked
                        checked = car(errsetstring(strcat("'" sChecked)))
                return(checked)
        ) ; let
);end-defun
GMT+8, 2025-8-12 01:10 , Processed in 0.125000 second(s), 24 queries , Gzip On.
