查看: 4797|回复: 13
Cadence 16.6 Hotfix_SPB16.60.038
    2025-3-13 15:50
  • 签到天数: 18 天
    [LV.4]偶尔看看III
    发表于 2014-11-14 17:14 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    2 j3 A+ q3 Y$ _( c' z" {& P3 d0 H9 I
    & {! }; x+ m4 S0 U. kcadence 16.6 Hotfix_SPB16.60.0385 j8 ]- m" q' O4 ~& R. G6 [" n( q/ Q
    # x# t, @& M2 n4 [  Phttp://pan.baidu.com/s/1gdCb4cV
    3 p* H- d$ u& f' p3 g7 @  Y3 E
    % h/ P5 H" S6 _! [; D; S) [  b4 k  w( s! g
    8 ?/ U- d: N5 `! b
    + l6 k- G% t' R" ~) u$ ]  ^. i" ADATE: 10-31-2014   HOTFIX VERSION: 038
    0 ^8 N5 [' p' J3 a# q2 I% g7 q1 @" q===================================================================================================================================2 O- T  O9 G, a  H2 u
    CCRID   PRODUCT        PRODUCTLEVEL2   TITLE8 [1 I  M0 o, S9 ?& c
    ===================================================================================================================================0 _; y3 E4 Q+ ]/ ^! u: g& b
    1103937 PCB_LIBRARIAN  VERIFICATION     con2con should not have any need for a graphical terminal
    8 }  e9 }1 i% D& G, t( _. q% }- o1107843 FSP            OTHER            Support for lRF and lmf in archived project, b7 c4 v7 w4 ]( G/ r- z
    1123765 CAPTURE        GENERAL          .OLBlck file not deleted if library is closed in Capture
    6 B) G# N' \& d5 }. f- f1169740 FSP            OTHER            Ability to import "Assigned Pin" column to connect Generic connector and FPGA.
    $ O5 l" M& ?5 B0 ?/ I1172641 FSP            FPGA_SUPPORT     Support for 5SGSMD5K2F40I2N device. f) A" Y5 {4 |" R% i
    1177760 CAPTURE        OTHER            IC pins cannot be cross probed from Capture to PCB Editor
    # ~& {, {. n, F# d; ^" L1195672 allegro_EDITOR PLACEMENT        Place replicate update should update component value text; [& K$ @* ]& |# z
    1206563 FSP            GUI              Spreadsheet import support for xc3s400afg400
    7 ]* ~% E2 Z& h$ e/ j( i, j$ O, ~5 L1208169 FSP            FPGA_SUPPORT     New FPGA model request
    $ U  j* l8 `) I. r1224428 ALLEGRO_EDITOR PLACEMENT        Get message "W-(SPMHGE-579): Unable to complete path to circuit for all selections" when updating place replicate circuit5 S; E7 [, m8 d6 ?- H# h* x
    1230064 ALLEGRO_EDITOR INTERACTIV       Place replicate is trying to match dimensions; t) o2 L  m" p3 A# G6 C7 m  v
    1253986 concept_HDL    CORE             Not able to define Source when adding property to a selected group
    2 b# @7 R3 k- K+ d" e6 X" g& D1266615 ADW            SHOPINGCART      Error(SPDWUB-48) while placing the part from the shopping cart
    ( h% Z) v4 f5 ~/ t3 S' ^1269658 ALLEGRO_EDITOR EDIT_ETCH        Ratsnest disappears near pin when routing
    * X; s- }8 J6 q1270158 CONCEPT_HDL    CONSTRAINT_MGR   Orphan nets are visible in CM but not in DE-HDL
      v0 ]7 a+ G( _5 H8 r1275042 CONCEPT_HDL    COMP_BROWSER     Unit specifier 'HC' not found in UNITS environment while placing the part on schematic
    1 S6 \9 c: L3 }3 j$ Q# F) b1276269 ALLEGRO_EDITOR TESTPREP         On creating a fixture, a test point is generated but refs are not visible. 0 Z9 K' T0 `7 ^" G
    1278037 SIP_LAYOUT     ASSY_RULE_CHECK  DRC soldermask to finger check required for cases when the finger has no wire attached& a! Y4 L4 d+ G3 F
    1278475 ALLEGRO_EDITOR DATABASE         Import Logic changes VIA net names to GND6 I; _2 ^. G4 s$ m, I4 B: O
    1279162 SIP_LAYOUT     DIE_ABSTRACT_IF  Add codesign die should default shrink/scribe settings from die abstract if abstract contains this information.
    , Q" l5 ?% {# G2 X4 b. G6 j1282358 SIP_LAYOUT     OTHER            Why are IC/PKG symbols always mirrored when placed on a sip design?0 Z) M2 S' s4 k' ]% _" H3 ~
    1283439 CAPTURE        ANNOTATE         Inter Sheet Refs placed on top of Off Page Connector name
    7 B7 d0 d' m# |2 k) t1284809 ALLEGRO_EDITOR INTERACTIV       Using the Fix icon in the toolbar will not apply the Fixed property to Groups2 a) t9 ?# m+ {+ y5 }4 |+ N# F
    1286277 CAPTURE        SCHEMATICS       Capture crashes on adding Bezier curves
    - s2 q" E/ j$ Y1286354 CONCEPT_HDL    CORE             The GENERATE_SCH_METADATA 'ON' directive causes significant DE-HDL performance degradation
    4 }& B4 ?7 @* I9 {( T" _1286617 CONCEPT_HDL    CORE             Generate View failure* L* B8 [7 |' I- r  s
    1287020 CAPTURE        OTHER            Option to disable Autobackup, N  B  i1 u- R. I: Y$ a. R5 D
    1287100 FSP            DESIGN_SETTINGS  FSP global edit of Capture library paths
    + p& c" h5 Q4 D& _  T( R1287877 CONCEPT_HDL    CHECKPLUS        Graphic check in CheckPlus hangs with sch_something view
    7 T' o' r" m3 A6 X) @6 H1289056 ADW            OTHER            MKnet program to also read the alim.auto from ADW_CONF_ROOT
    3 {7 U! f( J# T  r" ~; N1289107 CONCEPT_HDL    CORE             Find with Schematic Selection fails after clicking Find All three times
    + V1 I% E2 N2 G! u8 J+ F$ ?1289175 CAPTURE        OPTIONS          Autobackup changes timestamp of each and every part in the library.
    ) ?# V6 Z& {  z2 U1289447 TDA            CORE             Undo Check-out removes new design data from local area
    ' c0 |; i- |; c1 A1289677 ALLEGRO_EDITOR SHAPE            Complex shape filling fails without DRC
    & }2 k0 M8 f' \) z1289755 ALLEGRO_EDITOR EDIT_ETCH        Timing Vision Display error; S( @$ ?6 y0 |! n
    1289913 ALLEGRO_EDITOR EDIT_ETCH        Enhance the fanout function to speed up the layout design in Allegro PCB Editor.! g1 s1 y( A. \0 i8 z7 m# y
    1290136 ALLEGRO_EDITOR EDIT_ETCH        Unable to connect IC pin to ground2 u6 q8 e, s# H# B  `
    1290426 SIP_LAYOUT     LOGIC            Deleting a distributed codesign component from parts list does not remove the component information from the design database
    3 i! B9 e  D+ D1291888 ALLEGRO_EDITOR INTERACTIV       Property DYN_DELETED_ISLAND is not added on all the voids created by Delete Island command
    & \# s& J' s; _  U- |4 g1292206 ALLEGRO_EDITOR OTHER            Allow netname to be visible for pin/cline when viewed in Allegro PDF Publisher
    + O( A! g4 u; U2 i$ D  D/ C1292234 APD            SHAPE            Shape does not Void around Clines and Vias due to some corruption9 f8 l: O  m2 w" e0 X
    1292877 ALLEGRO_EDITOR DATABASE         DB doctor fixed void boundary but deleted all boundary without detail information.5 q: T+ I1 n9 G% s* H% C' n$ H; f* @5 }
    1293041 ADW            COMPONENT_BROWSE Component Browser does not show results if you filter on the PPL and an additional column 0 d/ S$ n1 I/ M6 J1 c$ X
    1293188 ALLEGRO_EDITOR EDIT_ETCH        fanout function(via in pad) deleted the cline & thermal3 N3 M; Z- v* {# s7 @
    1293626 CONCEPT_HDL    CORE             Delete Page command could not delete the dependency file (page2.csd).
    9 U- r( \& P3 Y4 B( _3 p! [4 v1293710 ALLEGRO_EDITOR EDIT_ETCH        PCB Editor crashes during copy fanout
    & }0 I/ e& b5 K$ s* R6 U' {1294355 Pspice         SIMULATOR        Function "ddt( )" behavior in DC sweep analysis
      i  d- q$ h6 P1 ^) ^3 l& e  j- Q1295232 CAPTURE        SCHEMATIC_EDITOR Remove from group changes not reflected consistently in Part Manager9 V# w2 @4 U7 g0 c
    1295434 ALLEGRO_EDITOR INTERACTIV       Enable Pin Name to be imported into a .BRD and display this in the show info output as done in APD and SIP: P7 {5 Q/ o* S! r: w' f
    1296583 ALLEGRO_EDITOR FSP_PINSWAP      Crash for FSP Auto Pinswap with PCB Editor
    ! r6 o( w& d; s' C1297095 ADW            LRM              LRM replaces incorrect part in schematic.( o" N/ I8 v' F$ v
    1297685 F2B            DESIGNVARI       'Could not open xmodules.dat file' Error during 'Save'.$ ~6 m0 d; T& |/ t$ E& o
    1297835 ALLEGRO_EDITOR INTERACTIV       DFA-Driven Interactive Placement not working correctly for components on bottom side7 m0 N5 ^2 S* i7 ]
    1297870 SIP_LAYOUT     ASSY_RULE_CHECK  Wire to Wire Optical short ADRC reports wrong DRC violation. v( J$ R: h' P
    1297994 ALLEGRO_EDITOR INTERACTIV       When moving a via and splitting the stack, the via moves off the design work surface.6 i  F1 \5 `$ n; o6 ^3 @
    1298129 ALLEGRO_EDITOR EDIT_ETCH        Auto Interactive Phase tuning should have option to Allow DRCs
    + G0 R" K/ p' W1 ]) f$ t1299050 ADW            PCBCACHE         Need a way to turn off all project ptf file backup files under flatlib
    4 d: T! W' A- u8 _4 r3 `1299873 CONCEPT_HDL    CORE             DE-HDL window size and position is not saved on exit
    $ p4 h4 H! u" A( m  u# w. Z8 c( h+ Z1300101 ALLEGRO_EDITOR GRAPHICS         Inconsistency in symbol editor and PCB Editor while showing 3D view. Y& D" s( `. j; X
    1300557 ALLEGRO_EDITOR EDIT_ETCH        Move Component with "Slide Etch" or "Stretch Etch" removes DYN_CLEARANCE_OVERSIZE from clines" e  u- e) V$ c8 W! u0 k, S: |1 t
    1300806 ALLEGRO_EDITOR GRAPHICS         Stroke command in 16.6 works differently as compared with earlier versions
    9 `2 z& y8 A3 `3 A: g: c1302103 CONCEPT_HDL    CONSTRAINT_MGR   DE-HDL CM startup time on large hierarchical is extremely large(6-8 min)
    . i. h& i8 ]& F! j4 Z' q1302939 ALLEGRO_EDITOR PARTITION        Place replicate modules lost with design partition  g. ^9 {  j8 G% t1 w
    1303078 CAPTURE        STABILITY        Capture crashes on View -- Status Bar with no design open
    % }: i+ x. W* Y& l- a7 _1303106 ALLEGRO_EDITOR skill            Creating shape with SKILL script does not work on SPB16.5 and SPB16.6.
    ' q! h) Z+ O6 Z7 f4 B% [1303442 ALLEGRO_EDITOR EDIT_ETCH        auto-interactive convert corner function crashes PCB Editor
    , n- P- v) i+ F+ O/ l" F2 M9 j1303921 ADW            COMPONENT_BROWSE Datasheets with spaces are not viewable in component browser! M7 j6 @- G3 m# ?. o
    1304042 APD            LOGIC            ERROR(SPMHUT-43):netin command is not working for .mcm.
    $ y6 U5 j; l3 h$ R1304725 ALLEGRO_EDITOR INTERACTIV       Value 0 in Allegro Text Setup not valid anymore! ]0 O( Q* `7 b
    1304734 ALLEGRO_EDITOR pads_IN          PADS_IN does not follow the settings in the options file
    ; X1 d$ b. \  ^& z1 z1304882 CONCEPT_HDL    CORE             Hierarchy Viewer jumps up to the top on File Save
    9 U, c+ Y; ~  K4 C, @1305147 ALLEGRO_EDITOR MANUFACT         Auto silk result is unstable.! }" y1 P/ L- c( \% d& B2 v6 g/ s
    1306323 ALLEGRO_EDITOR INTERACTIV       Mirror command does not seem to work correctly.4 `. C3 U/ ~4 q4 c+ K7 |( |' P
    1306468 ALLEGRO_EDITOR DATABASE         Dbdoctor Crash2 q: b% Y) W" _$ J2 l$ v) v
    1307277 SIP_LAYOUT     IMPORT_DATA      Wants BGA Text-In Wizard to maintain Pad layer set in the text file instead of defaulting to Bottom layer.
    $ b* e# t2 @/ K9 p- Q$ F; v; g1307367 FSP            FPGA_SUPPORT     FSP user needs 5SGSMD5K3F40I3N/5SGSED6K3F40I3N in FPGA models.2 }- c& e& T# H. K' j
    1307478 ALLEGRO_EDITOR mentor           unable to do PADS Library translation.3 ^* }, S3 `, }/ G
    1307626 ALLEGRO_EDITOR INTERACTIV       Pick window is different for command and from GUI
    8 R! O, v7 B* K' m( h" i3 a1307785 ASI_PI         GUI              Decap Configuration GUI does not update until you deselect then select GND
    9 q8 i6 F5 G$ C: ]6 I' ^4 D1308163 SIP_LAYOUT     ORBITIO_IF       Importing OrbitIO with multiple packages and XDA file into SIP layout results in incomplete data
    / h4 h" F+ c! p) F8 g/ Y" X1 }, [- I- t1308289 SIP_LAYOUT     ORBITIO_IF       Import OrbitIO into existing SIP database fails. Testing an ECO type of design flow
    * S6 Q# H* C7 B0 ?! n. W1309315 CAPTURE        ANNOTATE         Incremental annotation is not giving correct refdes in case of attached complex hierarchical design4 ~0 f; c3 l* v7 n/ @
    1310614 CONCEPT_HDL    CORE             Part Manager creates bogus directory on linux system
    4 t( H, v- i8 P. A1311184 CAPTURE        NETLIST_ALLEGRO  Incorrect warning for DEVICE property value in netlisting.: D+ N2 a% F* o0 ?! A
    1311719 ALLEGRO_EDITOR INTERACTIV       Allegro Component will not place on the canvas
    % I, V' H: V$ D" B9 H! e: h1311757 CONCEPT_HDL    CORE             Cannot change a property from instance level to non-instance level
    0 T# Z) H; b5 E7 U' _% z1311848 CONSTRAINT_MGR OTHER            PFE is adding a capacitor after creating PI CSet( y9 U4 l8 y, P! _$ k3 ~! E
    1312553 CONCEPT_HDL    CORE             Customer could not add their net property after deleting it.
    7 o6 B0 z9 l, f/ [, p1313068 APD            DIE_ESCAPE       die escape gen: Cannot route from pad of Via Structure.
    - }5 k2 Q# r: e1313239 CONSTRAINT_MGR CONCEPT_HDL      Diff pair constraints disappear if xnet is created for them in Editor
    1 _7 P$ [1 c, d6 n! z$ g; `1313850 ALLEGRO_EDITOR PLACEMENT        Place Replicate ignores fillet at pins
    ( H$ g+ T/ o  U( Q' m) ]1314207 ALLEGRO_EDITOR OTHER            PCB Editor crash when rotating IPF data
    2 K1 I, `2 I# }4 P  o6 v- L" K1314467 ALLEGRO_EDITOR INTERACTIV       With high_speed option selected, PCB Editor crashes on move operation
    : Z9 `" O( y( z) x" }  Q- m* z1314921 ALLEGRO_EDITOR PLACEMENT        RATS are wrongly displayed./ O& o, u' L# d( r, n
    1314973 CAPTURE        OTHER            Cannot cross-probe all pins from Capture' j6 S! @# |- f# u
    1316295 ALLEGRO_EDITOR OTHER            .brd extension is removed after running DB Doctor from PCB Editor Utilities.+ D  _2 m; s/ ?
    1316757 ALLEGRO_EDITOR DRC_CONSTR       Spacing constraint error on negative layer
    + m) \: z- c7 @. J% R6 w1316959 ALLEGRO_EDITOR PARTITION        Exported soft boundary partition2 symbol still cannot move out of partition boundary. x' \$ Z) H8 z$ J) C
    1317157 SIP_LAYOUT     DIE_STACK_EDITOR After moving the Dies to different layers a Wirebond has changed the connection from the pin to a shape.
    ) z- W7 a( P4 t* Q" I5 g- d6 \1317480 ALLEGRO_EDITOR SYMBOL           Allegro DB check "SPMHA1-247 Illegal mirror error"
    % c2 K' {' G6 T1317614 ADW            COMPONENT_BROWSE Datasheet_Url is not opening the file browser correctly4 T5 d5 x/ P$ t% J9 I4 H. \5 Z5 g+ z
    1317876 APD            COLOR            APD crashes when executing Color Dialog for Nets2 n# E- ~& h" E& L
    1320028 FSP            DE-HDL_SCHEMATIC Error (10002: Cannot find a ppt part that matches the instance properties
    - H2 e# ^) F7 f1320438 ALLEGRO_EDITOR GRAPHICS         Could not save DFA spreadsheet
    & O% j/ I( I6 ]1322600 CONCEPT_HDL    CONSTRAINT_MGR   Cannot extract xnet topology due to missing model even if the model is present
    " w0 t1 E; H. @# F$ E' W1323327 CONCEPT_HDL    CONSTRAINT_MGR   Deleting Ref Electrical CSet from Diff Pair removes it from a Matched Group in DE-HDL; p7 G4 Q4 F2 f7 E4 o
    1325230 CONCEPT_HDL    CORE             DE-HDL crashes once the design is loaded., C( z# A: l5 ]8 v
    1325644 F2B            PACKAGERXL       CDS_LOCATION/$PN not deleted from property file(dcf) backannotation warnings
    1 c# }: C9 H% q7 b  U1325905 CONCEPT_HDL    CORE             Schematic page import causes re-sectioning of the pins.
    9 k  [( b5 F$ T% D2 [: {: e1326163 SIP_LAYOUT     OTHER            SiP Layout - Void Adjacent Layer - Include option to ignore same net object when voiding" h! b/ R' o- I9 {4 p( o6 |
    1326696 CONCEPT_HDL    CORE             Cannot get concepthdl -product to invoke with the high speed already available
    * X% T3 }% i0 c6 B1 P1327367 CONCEPT_HDL    CORE             Crash when saving after adding block pin" J+ d- _1 T( ]8 X& }, k) q6 k
    1327569 ADW            LRM              LRM does not update the headers if the part number is also changed
    $ C3 u* O' Z, p. q0 g6 m1329271 ALLEGRO_EDITOR DRC_CONSTR       Multithreading DRC check is flagging a DRC on the TOP Layer for Route Keepout that has the property ?SHAPES_ALLOWED? ON." b+ ?7 H9 R# k- W/ _1 z
    1329587 CONCEPT_HDL    CORE             Using the GROUP command does NOT place all objects in the group back on grid, X( f$ b/ y. v6 ^5 z7 u3 ~) w
    1330913 CONCEPT_HDL    COMP_BROWSER     Empty value in PTF file
    % }/ M; L! W2 }' c1 j& y4 b1332728 SIG_INTEGRITY  OTHER            Signal model assignment form returning SYNTAX ERROR on Linux 5.0 5.7 and 5.9 with hotfix s036 and s037.& _6 i9 Z4 f* \# r% [: k
    + j  u! B4 l0 G8 U6 f% z: b
    推荐
    发表于 2014-11-14 21:25 | 只看该作者
    打了这个补丁,生成的钻孔文件cam350不认识,怎么回事?
    发表于 2014-11-16 12:33 | 只看该作者
    怎么感觉打了补丁 和没有打之前一样的呢?' [# c7 X1 @' ]0 n% v
    发表于 2014-11-16 12:37 | 只看该作者
    更新了038的补丁 怎么还是004啊?
    发表于 2014-11-16 13:42 | 只看该作者
    :'(:'(:'( 原理图开不了了
    奋斗
    2024-3-18 15:56
  • 签到天数: 10 天
    [LV.3]偶尔看看II
    发表于 2014-11-16 19:13 | 只看该作者
    难道这个补丁有问题
    发表于 2014-11-16 19:16 | 只看该作者
    打了已经一阵子了,表示这一版本把许多测试内容,变更为正式功能,进步很大,新的功能强势的很。cadence给人的感觉是,本软件的目标就是,软件极度智能,PCB难度大幅度降低,设计周期大幅度缩小。NB的软件不需要解释啊。
    发表于 2014-11-16 20:04 | 只看该作者
    补丁有问题啊
    2025-7-30 15:24
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2014-11-16 20:29 | 只看该作者
    墨客的秋天 发表于 2014-11-16 20:04
    & ^6 P7 N/ k, l" S( M9 F* w补丁有问题啊
    # V0 [& E5 j+ B 大多情况都是自己的问题,只是还没有足够去发现和反省而已。  166的补丁每次都有新改进,智能程度也越来越高了......只是.......
    无聊
    2021-8-31 15:05
    发表于 2014-11-16 20:50 | 只看该作者
    已经安装了,目前没发现问题,不知道是我用的太简单了?呵呵支持
    发表于 2014-11-16 21:49 | 只看该作者
    钻孔文件打不开我觉的是cam350的问题。有人用genesis吗?不知能否打开?https://www.eda365.com/thread-102901-1-1.html
    发表于 2014-12-4 14:36 | 只看该作者
    不错,支持,我也下一个
    1 p3 e* P% E' O, P! c
    13#
    发表于 2014-12-4 14:37 | 只看该作者
    正需要呢,谢谢了
    2025-3-13 15:50
  • 签到天数: 18 天
    [LV.4]偶尔看看III
    14#
     楼主| 发表于 2014-12-4 17:04 | 只看该作者
    sinfy 发表于 2014-12-4 14:37
    4 g5 ^: ?2 j& i; p正需要呢,谢谢了
    : v& K$ g7 [# i& v8 h0 U9 L
    去下最新的039
    + d" Z* N" p! I* {9 ~" I" e$ s& PHotfix_SPB16.60.039
    / X6 @6 g/ F( G* zhttp://pan.baidu.com/s/1mg5McFQ% _' p( H5 S. D- _/ q; Z5 a
    GMT+8, 2025-11-5 18:47 , Processed in 0.156250 second(s), 28 queries , Gzip On.
