查看: 4679|回复: 29
Hotfix_SPB16.60.038_wint_1of1
发表于 2014-10-31 15:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 zgyzgy 于 2014-11-2 20:28 编辑 ' E/ P+ |+ V5 d4 i
5 v1 J" x' n% {: q4 x2 {Hotfix_SPB16.60.038_wint_1of1 出了,有需要的说一声我好上传!让大家等久了。。。。。。; r/ T0 m" p  @/ G' t8 m: b1 Q
http://pan.baidu.com/s/1hq3RBwC
4 n" I2 F9 ]) h) t
推荐
 楼主| 发表于 2014-11-16 10:33 | 只看该作者
DATE: 10-31-2014   HOTFIX VERSION: 038 =================================================================================================================================== CCRID   PRODUCT        PRODUCTLEVEL2   TITLE =================================================================================================================================== 1103937 PCB_LIBRARIAN  VERIFICATION     con2con should not have any need for a graphical terminal 1107843 FSP            OTHER            Support for lrf and lmf in archived project 1123765 CAPTURE        GENERAL          .OLBlck file not deleted if library is closed in Capture 1169740 FSP            OTHER            Ability to import "Assigned Pin" column to connect Generic connector and FPGA. 1172641 FSP            FPGA_SUPPORT     Support for 5SGSMD5K2F40I2N device 1177760 CAPTURE        OTHER            IC pins cannot be cross probed from Capture to PCB Editor 1195672 ALLEGRO_EDITOR PLACEMENT        Place replicate update should update component value text 1206563 FSP            GUI              Spreadsheet import support for xc3s400afg400 1208169 FSP            FPGA_SUPPORT     New FPGA model request 1224428 ALLEGRO_EDITOR PLACEMENT        Get message "W-(SPMHGE-579): Unable to complete path to circuit for all selections" when updating place replicate circuit 1230064 ALLEGRO_EDITOR INTERACTIV       Place replicate is trying to match dimensions 1253986 CONCEPT_HDL    CORE             Not able to define Source when adding property to a selected group 1266615 ADW            SHOPINGCART      Error(SPDWUB-48) while placing the part from the shopping cart 1269658 ALLEGRO_EDITOR EDIT_ETCH        Ratsnest disappears near pin when routing 1270158 CONCEPT_HDL    CONSTRAINT_MGR   Orphan nets are visible in CM but not in DE-HDL 1275042 CONCEPT_HDL    COMP_BROWSER     Unit specifier 'HC' not found in UNITS environment while placing the part on schematic 1276269 ALLEGRO_EDITOR TESTPREP         On creating a fixture, a test point is generated but refs are not visible.  1278037 SIP_LAYOUT     ASSY_RULE_CHECK  DRC soldermask to finger check required for cases when the finger has no wire attached 1278475 ALLEGRO_EDITOR DATABASE         Import Logic changes VIA net names to GND 1279162 SIP_LAYOUT     DIE_ABSTRACT_IF  Add codesign die should default shrink/scribe settings from die abstract if abstract contains this information. 1282358 SIP_LAYOUT     OTHER            Why are IC/PKG symbols always mirrored when placed on a sip design? 1283439 CAPTURE        ANNOTATE         Inter Sheet Refs placed on top of Off Page Connector name 1284809 ALLEGRO_EDITOR INTERACTIV       Using the Fix icon in the toolbar will not apply the Fixed property to Groups 1286277 CAPTURE        SCHEMATICS       Capture crashes on adding Bezier curves 1286354 CONCEPT_HDL    CORE             The GENERATE_SCH_METADATA 'ON' directive causes significant DE-HDL performance degradation 1286617 CONCEPT_HDL    CORE             Generate View failure 1287020 CAPTURE        OTHER            Option to disable Autobackup 1287100 FSP            DESIGN_SETTINGS  FSP global edit of Capture library paths 1287877 CONCEPT_HDL    CHECKPLUS        Graphic check in CheckPlus hangs with sch_something view 1289056 ADW            OTHER            MKnet program to also read the alim.auto from ADW_CONF_ROOT 1289107 CONCEPT_HDL    CORE             Find with Schematic Selection fails after clicking Find All three times 1289175 CAPTURE        OPTIONS          Autobackup changes timestamp of each and every part in the library. 1289447 TDA            CORE             Undo Check-out removes new design data from local area 1289677 ALLEGRO_EDITOR SHAPE            Complex shape filling fails without DRC 1289755 ALLEGRO_EDITOR EDIT_ETCH        Timing Vision Display error 1289913 ALLEGRO_EDITOR EDIT_ETCH        Enhance the fanout function to speed up the layout design in Allegro PCB Editor. 1290136 ALLEGRO_EDITOR EDIT_ETCH        Unable to connect IC pin to ground 1290426 SIP_LAYOUT     LOGIC            Deleting a distributed codesign component from parts list does not remove the component information from the design database 1291888 ALLEGRO_EDITOR INTERACTIV       Property DYN_DELETED_ISLAND is not added on all the voids created by Delete Island command 1292206 ALLEGRO_EDITOR OTHER            Allow netname to be visible for pin/cline when viewed in Allegro PDF Publisher 1292234 APD            SHAPE            Shape does not Void around Clines and Vias due to some corruption 1292877 ALLEGRO_EDITOR DATABASE         DB doctor fixed void boundary but deleted all boundary without detail information. 1293041 ADW            COMPONENT_BROWSE Component Browser does not show results if you filter on the PPL and an additional column  1293188 ALLEGRO_EDITOR EDIT_ETCH        fanout function(via in pad) deleted the cline & thermal 1293626 CONCEPT_HDL    CORE             Delete Page command could not delete the dependency file (page2.csd). 1293710 ALLEGRO_EDITOR EDIT_ETCH        PCB Editor crashes during copy fanout 1294355 PSPICE         SIMULATOR        Function "ddt( )" behavior in DC sweep analysis 1295232 CAPTURE        SCHEMATIC_EDITOR Remove from group changes not reflected consistently in Part Manager 1295434 ALLEGRO_EDITOR INTERACTIV       Enable Pin Name to be imported into a .BRD and display this in the show info output as done in APD and SIP 1296583 ALLEGRO_EDITOR FSP_PINSWAP      Crash for FSP Auto Pinswap with PCB Editor 1297095 ADW            LRM              LRM replaces incorrect part in schematic. 1297685 F2B            DESIGNVARI       'Could not open xmodules.dat file' Error during 'Save'. 1297835 ALLEGRO_EDITOR INTERACTIV       DFA-Driven Interactive Placement not working correctly for components on bottom side 1297870 SIP_LAYOUT     ASSY_RULE_CHECK  Wire to Wire Optical short ADRC reports wrong DRC violation 1297994 ALLEGRO_EDITOR INTERACTIV       When moving a via and splitting the stack, the via moves off the design work surface. 1298129 ALLEGRO_EDITOR EDIT_ETCH        Auto Interactive Phase tuning should have option to Allow DRCs 1299050 ADW            PCBCACHE         Need a way to turn off all project ptf file backup files under flatlib 1299873 CONCEPT_HDL    CORE             DE-HDL window size and position is not saved on exit 1300101 ALLEGRO_EDITOR GRAPHICS         Inconsistency in symbol editor and PCB Editor while showing 3D view 1300557 ALLEGRO_EDITOR EDIT_ETCH        Move Component with "Slide Etch" or "Stretch Etch" removes DYN_CLEARANCE_OVERSIZE from clines 1300806 ALLEGRO_EDITOR GRAPHICS         Stroke command in 16.6 works differently as compared with earlier versions 1302103 CONCEPT_HDL    CONSTRAINT_MGR   DE-HDL CM startup time on large hierarchical is extremely large(6-8 min) 1302939 ALLEGRO_EDITOR PARTITION        Place replicate modules lost with design partition 1303078 CAPTURE        STABILITY        Capture crashes on View -- Status Bar with no design open 1303106 ALLEGRO_EDITOR SKILL            Creating shape with SKILL script does not work on SPB16.5 and SPB16.6. 1303442 ALLEGRO_EDITOR EDIT_ETCH        auto-interactive convert corner function crashes PCB Editor 1303921 ADW            COMPONENT_BROWSE Datasheets with spaces are not viewable in component browser 1304042 APD            LOGIC            ERROR(SPMHUT-43):netin command is not working for .mcm. 1304725 ALLEGRO_EDITOR INTERACTIV       Value 0 in Allegro Text Setup not valid anymore 1304734 ALLEGRO_EDITOR PADS_IN          PADS_IN does not follow the settings in the options file 1304882 CONCEPT_HDL    CORE             Hierarchy Viewer jumps up to the top on File Save 1305147 ALLEGRO_EDITOR MANUFACT         Auto silk result is unstable. 1306323 ALLEGRO_EDITOR INTERACTIV       Mirror command does not seem to work correctly. 1306468 ALLEGRO_EDITOR DATABASE         Dbdoctor Crash 1307277 SIP_LAYOUT     IMPORT_DATA      Wants BGA Text-In Wizard to maintain Pad layer set in the text file instead of defaulting to Bottom layer. 1307367 FSP            FPGA_SUPPORT     FSP user needs 5SGSMD5K3F40I3N/5SGSED6K3F40I3N in FPGA models. 1307478 ALLEGRO_EDITOR MENTOR           unable to do PADS Library translation. 1307626 ALLEGRO_EDITOR INTERACTIV       Pick window is different for command and from GUI 1307785 ASI_PI         GUI              Decap Configuration GUI does not update until you deselect then select GND 1308163 SIP_LAYOUT     ORBITIO_IF       Importing OrbitIO with multiple packages and XDA file into SIP layout results in incomplete data 1308289 SIP_LAYOUT     ORBITIO_IF       Import OrbitIO into existing SIP database fails. Testing an ECO type of design flow 1309315 CAPTURE        ANNOTATE         Incremental annotation is not giving correct refdes in case of attached complex hierarchical design 1310614 CONCEPT_HDL    CORE             Part Manager creates bogus directory on linux system 1311184 CAPTURE        NETLIST_ALLEGRO  Incorrect warning for DEVICE property value in netlisting. 1311719 ALLEGRO_EDITOR INTERACTIV       Allegro Component will not place on the canvas 1311757 CONCEPT_HDL    CORE             Cannot change a property from instance level to non-instance level 1311848 CONSTRAINT_MGR OTHER            PFE is adding a capacitor after creating PI CSet 1312553 CONCEPT_HDL    CORE             Customer could not add their net property after deleting it. 1313068 APD            DIE_ESCAPE       die escape gen: Cannot route from pad of Via Structure. 1313239 CONSTRAINT_MGR CONCEPT_HDL      Diff pair constraints disappear if xnet is created for them in Editor 1313850 ALLEGRO_EDITOR PLACEMENT        Place Replicate ignores fillet at pins 1314207 ALLEGRO_EDITOR OTHER            PCB Editor crash when rotating IPF data 1314467 ALLEGRO_EDITOR INTERACTIV       With high_speed option selected, PCB Editor crashes on move operation 1314921 ALLEGRO_EDITOR PLACEMENT        RATS are wrongly displayed. 1314973 CAPTURE        OTHER            Cannot cross-probe all pins from Capture 1316295 ALLEGRO_EDITOR OTHER            .brd extension is removed after running DB Doctor from PCB Editor Utilities. 1316757 ALLEGRO_EDITOR DRC_CONSTR       Spacing constraint error on negative layer 1316959 ALLEGRO_EDITOR PARTITION        Exported soft boundary partition2 symbol still cannot move out of partition boundary 1317157 SIP_LAYOUT     DIE_STACK_EDITOR After moving the Dies to different layers a Wirebond has changed the connection from the pin to a shape. 1317480 ALLEGRO_EDITOR SYMBOL           Allegro DB check "SPMHA1-247 Illegal mirror error" 1317614 ADW            COMPONENT_BROWSE Datasheet_Url is not opening the file browser correctly 1317876 APD            COLOR            APD crashes when executing Color Dialog for Nets 1320028 FSP            DE-HDL_SCHEMATIC Error (10002: Cannot find a ppt part that matches the instance properties 1320438 ALLEGRO_EDITOR GRAPHICS         Could not save DFA spreadsheet 1322600 CONCEPT_HDL    CONSTRAINT_MGR   Cannot extract xnet topology due to missing model even if the model is present 1323327 CONCEPT_HDL    CONSTRAINT_MGR   Deleting Ref Electrical CSet from Diff Pair removes it from a Matched Group in DE-HDL 1325230 CONCEPT_HDL    CORE             DE-HDL crashes once the design is loaded. 1325644 F2B            PACKAGERXL       CDS_LOCATION/$PN not deleted from property file(dcf) backannotation warnings 1325905 CONCEPT_HDL    CORE             Schematic page import causes re-sectioning of the pins. 1326163 SIP_LAYOUT     OTHER            SiP Layout - Void Adjacent Layer - Include option to ignore same net object when voiding 1326696 CONCEPT_HDL    CORE             Cannot get concepthdl -product to invoke with the high speed already available 1327367 CONCEPT_HDL    CORE             Crash when saving after adding block pin 1327569 ADW            LRM              LRM does not update the headers if the part number is also changed 1329271 ALLEGRO_EDITOR DRC_CONSTR       Multithreading DRC check is flagging a DRC on the TOP Layer for Route Keepout that has the property ?SHAPES_ALLOWED? ON. 1329587 CONCEPT_HDL    CORE             Using the GROUP command does NOT place all objects in the group back on grid 1330913 CONCEPT_HDL    COMP_BROWSER     Empty value in PTF file 1332728 SIG_INTEGRITY  OTHER            Signal model assignment form returning SYNTAX ERROR on Linux 5.0 5.7 and 5.9 with hotfix s036 and s037.
推荐
 楼主| 发表于 2014-11-5 21:56 | 只看该作者
rollow 发表于 2014-11-5 11:001 d6 E9 d# a# \( _( G
太感谢了。只是这一次次更新我没发现更新了什么功能啊
3 ~& `8 f& _8 ]/ c3 o7 c安装后可以看见的哈,就在安装目录下的文档里。
推荐
 楼主| 发表于 2014-11-1 18:05 | 只看该作者
还在上传哈,上传比较慢;帖子要顶起来我才有动力哦,这次更新的比较多哈!
发表于 2014-10-31 15:42 | 只看该作者
更新了什么内容?
发表于 2014-10-31 16:14 | 只看该作者
上传百度网盘吧,多谢楼主!
    2025-6-13 15:07
  • 签到天数: 389 天
    [LV.9]以坛为家II
    发表于 2014-10-31 16:43 | 只看该作者
    需要,非常感谢
    2025-6-10 15:51
    发表于 2014-10-31 16:56 | 只看该作者
    需要Hotfix_SPB16.60.038_wint_1of1,非常感谢
    无聊
    2021-8-31 15:05
    发表于 2014-10-31 19:58 | 只看该作者
    不用废话直接上传
    发表于 2014-11-1 12:14 | 只看该作者
    强烈支持上传!
    发表于 2014-11-1 13:05 | 只看该作者
    楼主哥是来炫耀的
    发表于 2014-11-1 15:27 | 只看该作者
    怎么没有提示有新的更新呢?
    13#
    发表于 2014-11-1 19:36 | 只看该作者
    你家网速是瓜牛啊,中午等到现在,都睡了好大一觉了,你还没传完。。。。。
    无聊
    2021-8-31 15:05
    14#
    发表于 2014-11-1 23:06 来自手机 | 只看该作者
    可以列一下更新内容吗
    15#
    发表于 2014-11-2 13:39 | 只看该作者
    贴一下更新说明先啊
    GMT+8, 2025-11-5 18:45 , Processed in 0.171875 second(s), 28 queries , Gzip On.
