查看: 2204|回复: 8
Hotfix_SPB16.60.037_wint_1of1下载链接
发表于 2014-10-15 09:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
上传了两天终于好了,让大家久等了:http://pan.baidu.com/s/1gdmYsbL
- u3 f% @, I8 L& ]
发表于 2014-10-15 11:23 | 只看该作者
thanks, buddy.
    2025-6-13 15:07
  • 签到天数: 389 天
    [LV.9]以坛为家II
    发表于 2014-10-15 14:39 | 只看该作者
    请问,这次都更新什么了能大概说下么?
    发表于 2014-10-16 09:52 | 只看该作者
    请问,这次都更新什么了能大概说下么?
     楼主| 发表于 2014-10-20 11:59 | 只看该作者
    qooo71890800 发表于 2014-10-16 09:52
    0 G) G8 n  h0 R5 t! a" k: [. G请问,这次都更新什么了能大概说下么?
    - x$ E" z( E3 {5 u7 Z
    DATE: 10-10-2014   HOTFIX VERSION: 037, o. }( S" R9 X
    ( s: U+ |7 o& C* ~! @) b6 W+ E8 n& Q* Q* |
    1314031 CONCEPT_HDL    CORE             GenView should automatically refresh the page where the block symbol has been instantiated9 H7 Z* Q2 `; J- H
    1318575 SIG_EXPLORER   SIMULATION       Display Parasitic on Wirebond (selecting the second one) crashes APD8 H. `( m7 z% }8 o- X$ D; X
    1319258 allegro_EDITOR INTERFACES       Enhance IPC-2581 so that the rotation of pad shapes is defined at the LandPattern definition and Pin elements levels: o/ P/ L# z* d* e
    1320054 ALLEGRO_EDITOR INTERFACES       IPC2581 Import Stackup  q2 w% T, j. S  h4 G" j5 E2 q+ _% a. r/ F# X% `% H
    1320467 CONCEPT_HDL    CORE             Incorrect directives in cds.cpm for nconcepthdl (cont.): _( M) b8 N, G
    " b) X( N, j- C/ ]/ S% w  R1320878 ALLEGRO_EDITOR EDIT_ETCH        Allegro crash when using scribble& w% K/ P: H) ?
    9 m! N& O2 a2 ]$ j" x: k1321319 ALLEGRO_EDITOR INTERFACES       Step Export has wrong size
    6 ^+ q( [: j6 C9 W3 X1322394 CONCEPT_HDL    OTHER            Packager runs without errors even when the DEHDL schematic pages are corrupt., V* t' r+ o4 G; _% f5 h
    ' y+ O) f2 R- @, g& i  |1323892 CONCEPT_HDL    CORE             The SI_MODEL_PATH should not write to $HOME/pcbenv/env7 i+ i. I, @2 P% ^+ {
    1324438 SIP_LAYOUT     EXPORT_DATA      SiP Layout - netlist spreadsheet, Error on exporting a spreadsheet on design file& p9 F# W/ @1 {8 G5 j' k0 t
    , c* I8 X) t" X5 {- Y* \5 b6 G; g5 u1324533 F2B            PACKAGERXL       Export Physical fails - pxl.exe has stopped working7 Y+ g) r4 J' U
    发表于 2014-10-21 18:02 | 只看该作者
    英文不好哦,可否翻译一下,因为之前听说更新后,CAM350下 精度有问题,不知道解决了吗?
    发表于 2014-10-21 18:03 | 只看该作者
    zgyzgy 发表于 2014-10-20 11:59  U+ \* ~  N% f  I$ h
    DATE: 10-10-2014   HOTFIX VERSION: 037- U$ Z" a& x$ ?8 S* {
    ) q- U. I, f1 N
    1314031 CONCEPT_HDL    CORE             GenView should a ...
    9 K2 h& w7 F7 b% Y0 r
    ( r0 \7 ?) k( B
     楼主| 发表于 2014-10-24 17:32 | 只看该作者
    百度翻译,自己再理解!
    发表于 2014-10-28 23:07 | 只看该作者
    GMT+8, 2025-11-5 16:40 , Processed in 0.156250 second(s), 23 queries , Gzip On.
