5 P% A% V3 D3 p' s' n
5 ~8 x- i1 x+ I0 J' A6 n/ c" _" dhttp://pan.baidu.com/s/1kToiYV1
( s' H/ f: z+ e# C3 f1 @: X7 k* [
Hotfix_SPB16.60.035_wint_1of1- B1 e0 l+ G- M a% l( \; n! q( r
DATE: 09-11-2014 HOTFIX VERSION: 035
/ |# _1 n6 n, R2 J) Y===================================================================================================================================
/ t9 C' p# A" u2 R7 d/ O' n" bCCRID PRODUCT PRODUCTLEVEL2 TITLE
1 ~# u0 Z6 E# a8 f; ]! @( B7 ^9 C===================================================================================================================================; z+ L# x9 |$ E
1281020 concept_HDL COMP_BROWSER The property of the first entry picked from a PTF row is retained on the next pick7 x7 y( M, z# }$ K2 q4 Q
1294613 allegro_EDITOR ARTWORK Replace Current Films from file command does not work correctly for Suppress shape fill option! g1 e1 E7 `! R, I# Y
1300995 ALLEGRO_EDITOR ARTWORK Import artwork Gerber6x00 ignores the padstack rotation.
9 y+ A2 g) l! Y6 n1 ]1303718 ALLEGRO_EDITOR PLOTTING Published pdf does not show dotted or phantom lines
7 v# G: H. W" k9 L1305554 CONCEPT_HDL CORE Advanced Find displays duplicate refdes values on the TOC page+ v3 l; \8 n/ t* @
1306608 CONCEPT_HDL OTHER QIR 7 variant editor functionality problem select for replacement
; F6 z) ]% S* J, ?' D2 C1307745 ALLEGRO_EDITOR NC NC drill fails with error SPMHGE-2687 Z5 v; `3 ]/ [, b3 n
1308258 SIP_LAYOUT ORBITIO_IF importing OrbitIO into SIP layout results in missing bundle for T3 inteRFace# C5 {: d! N G0 s; i
1308455 CONCEPT_HDL CORE Moving signal names using Group > Move will place them off-grid on the wires.
4 Q0 d0 |- b u7 }2 n( ~1308698 CONCEPT_HDL CORE Changing net name crashes DEHDL$ o, e5 c& W0 {; W) S2 W5 \5 f
1309386 SIP_LAYOUT SYMBOL When moving a symbol the attached Cline loses its Property.0 d2 i0 y! M# |6 i9 ^& j: a
1309481 ALLEGRO_EDITOR EDIT_ETCH allegro crash when routing on layer23 ], h+ L, X# ?7 L8 R* H
1309686 ALLEGRO_EDITOR OTHER The Auto Silkscreen program creates strange component outlines on Autosilk top.0 `3 ^5 P8 Y6 c/ l% A, ~( m0 g3 _5 `
1310139 CONCEPT_HDL CORE Change text not working in replicated blocks% o- R8 O: D. e2 O: a6 ~
1310235 CONCEPT_HDL CORE DEHDL crashes when searching a net name - C33L_RPLD_STRP_CLK
; ]. t# r! |& ?! N$ Q1310274 SIP_LAYOUT OTHER SiP - Need option to use a file as an input to rename net# Y Y1 f& }% t3 |6 W: G/ c
1310486 ALLEGRO_EDITOR INTERFACES Allegro changes component orientation in generated PDF.
8 C' _: J9 h2 P; a* S4 m/ Z5 u; r1310618 ALLEGRO_EDITOR MANUFACT Import Parameters Does not changes the Artwork Domain Settings8 L' X' m; v- I
1310873 SIG_INTEGRITY SIMULATION Delay report does not seem to work correctly.
. Q: q7 X% U. X( _' Q }1311619 ALLEGRO_EDITOR MANUFACT RFETCH consolidated net incorrect: G& d0 ~+ o2 w: V2 C% Y
1311883 CONCEPT_HDL OTHER verilog.v file couldn't be created by glbl_synonym symbol( B: [: U( R+ X6 H6 M
1312179 CONCEPT_HDL ARCHIVER Archvier do not archive large projects! F( l$ K% [: T0 ]! s
1312309 CONCEPT_HDL CORE DEHDL .lck files are not being used properly2 ] x$ C, ~, @$ U+ b: P
1312313 CONCEPT_HDL CORE DEHDL .lck files still can disappear when in tabs and not being worked on
% X* ^1 }6 P! d8 o# l1313354 CONCEPT_HDL CORE Component Modify deletes the SIGNAL_MODEL property Component Replace does not
" y# ~% p* M" [; i$ N+ y7 n1313942 ALLEGRO_EDITOR INTERFACES Exporting IPC-2581 revB from attached board database is terminating without any error/warning message.& u) L! A" F% f2 C3 E
Z, ~. N1 A- }' C% E
4 |& j6 ]1 {( n1 m$ ]
Hotfix_SPB16.50.059_wint_1of1$ Q* J% W# k& {3 d. o# B
DATE: 09-6-2014 HOTFIX VERSION: 059
8 j4 n. g d& ~) G, N3 n& k- h===================================================================================================================================
0 J* d8 e& V- T5 |1 d+ a& WCCRID PRODUCT PRODUCTLEVEL2 TITLE
, r. {" s$ |5 O1 G$ ^# |7 @=================================================================================================================================== t r" K1 Q$ L" W5 x' @
1291054 CONCEPT_HDL ARCHIVER archiver fails to create the cds.lib & cpm files when the -views switch is used in the command line0 J+ K, P* R) Y' I- [: {: P
1304799 FLOWS OTHER Pxl is not updating the pstcmdb.dat file with the NO_SHAPE_CONNECT property @8 G, h! I9 n' n7 }
1 c/ N( W0 ]( H3 `4 ~) g) Y
