查看: 235|回复: 0
多节锂电(2~4节)同步升压管理芯片ZCC6983
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-12-31 17:40 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
    特性
    2 r4 m  v5 D; x8 h2 k1 }$ U3.0V to 5.5V Operating Input Voltage
    - I1 [0 w: l5 M5 j# O$ J8 a5 X; a' K" gUp to 26V Sustainable Voltage
    ) A5 e- A8 L# z$ }Up to 2A Configurable Charge Current for Battery4 [: k  J2 s5 u0 m$ `7 T% K5 j
    with 2~4 Cells in Series5 @: [/ z0 h0 F% o9 u
    Configurable Input Voltage Limit
    & H4 C  I& A! V1 j) r! ]Charge Status Indication
    & Q8 \8 z( }, Q. P# J+ f6 z! m+ XConstant Voltage Selectable& j8 ]% |9 F/ K+ w
    Programmable Charge Timeout
    ' D& T" R2 e, i- X* EThermal Regulation Protection
    7 y3 ^% ]. s  u+ S( BExternal Shutdown Function
    4 e: M5 j$ J$ }: ~, W* p6 _Input Voltage UVLO and OVP
    7 ?* V, _" S/ U) G- lOver Temperature Protection
    0 Q# F& ~* h! ]2 l' `6 ?Output Short Cir cuit Protec tion Normal# |' p! Y. n; k0 s  A9 A+ Y% r% j
    Synchronous Boost Operation When Battery
    " l! V* w2 ?7 ]  B1 W; e" I2 FRemoved
    ( ]6 D" ^6 @1 Z+ V1 H7 O6 I9 N描述/ t3 \9 P' m' g0 u, F  A* ]2 K
    ZCC6983 is a highly integrated synchronous boost
    # |0 c* Z- U  h7 [  c0 qcharger IC for Lithium-ion batteries with four cells in
    - s* ^- B3 T  x, A! u9 Z! y, Gseries . The charge current up to 2A can be  ]% K% T) N- p& @. v
    programmed by using the external resistor for different+ u8 C1 j# W; p; @* ]1 h
    portable applications.
    % v% i0 o& p0 n4 e% \$ pRobust protections include input over-voltage- Q) ?3 t2 b* ?3 a
    protection (OVP), battery OVP, battery short protection,6 }& X* N/ H. W. }9 \" z
    thermal shut down, battery temperature monitor, a
    ; t* E) a  W$ cconfigurable timer to prevent prolonged charging of a
    2 w1 R! v0 w5 H1 I9 |dead battery.6 E& c% j3 l+ t2 ?4 v! t5 G$ x: ?
    4 ^7 ~7 h3 ]8 B
    GMT+8, 2025-7-14 06:56 , Processed in 0.109375 second(s), 25 queries , Gzip On.
