TA的每日心情 | 开心 2022-5-9 15:00 |
签到天数: 28 天 [LV.4]偶尔看看III
特性
& @' f3 b5 s; a# s1 Z■ 3.0V to 5.5V Operating Input Voltage
7 O$ {2 P% \ N% b% G* E■ Up to 26V Sustainable Voltage
6 B$ B5 N5 o7 `* C- K■ Up to 2A Configurable Charge Current for Battery1 D9 w) B- ~3 N5 T: [8 b1 @; _4 G
with 2~4 Cells in Series
3 U- T+ ]) v5 K! R7 J/ o/ G■ Configurable Input Voltage Limit
' m6 ^6 p* M. U; Z$ ^9 r0 x6 y2 ^■ Charge Status Indication
. l/ a$ {3 v. c5 Q9 F* S. x■ Constant Voltage Selectable* G: c8 h2 K- K9 }. `
■ Programmable Charge Timeout
- \( R# O) Z! ~) C■ Thermal Regulation Protection
, \) C9 _# O# @7 d5 }) m■ External Shutdown Function+ {. X9 D( Q# K( f; B1 O2 [ I
■ Input Voltage UVLO and OVP
( c* Z/ B6 L) M) r7 E4 W7 u■ Over Temperature Protection
% \% ~0 ~% L& Z2 L8 x" d■ Output Short Cir cuit Protec tion Normal
8 e: m6 U# P3 i- a1 JSynchronous Boost Operation When Battery: o$ A2 o' p6 c& S
Removed' i q* s f1 E- G1 X V
描述& D1 l5 s: t9 S8 x
ZCC6983 is a highly integrated synchronous boost" {+ ^7 h( Y2 h* D& v: a2 i. `
charger IC for Lithium-ion batteries with four cells in9 A" [/ J D8 ?, m* U+ d' @
series . The charge current up to 2A can be* V; A& [/ X- k; g( i
programmed by using the external resistor for different6 `5 [. g6 \# N( G& O, c
portable applications.7 I% r# f9 A% Z; ~) I
Robust protections include input over-voltage
2 z9 E, d: r5 dprotection (OVP), battery OVP, battery short protection,: @8 b( m h) {6 e
thermal shut down, battery temperature monitor, a
5 e4 N0 C( f; X8 Y& @; \3 C: Vconfigurable timer to prevent prolonged charging of a. w/ D3 ^+ p; `* g9 M
dead battery.
, q/ t1 B' N+ q5 M2 k' R
5 Z' g$ ?! n3 C y. L. ?/ | |
