1 第1章 常用封装简介 62 @/ c5 [9 A i- p1 h& Y* e& Y
1.1 封装 6
6 b' t, [" S' s, w- j* I/ ]4 m1.2 封装级别的定义 6& ~% q7 F: L2 ~. j8 t
1.3 封装的发展趋势简介 6
# k5 U; k4 ]+ [# ]; o1.4 常见封装类型介绍 9
7 v- j8 N( z1 R# _0 j1.4.1 TO (Transistor Outline) 9
. r& w+ i9 k9 f- x6 w9 x9 D1.4.2 DIP (Dual In line Package) 9
; I* x" ]7 U" F: {2 a1.4.3 SOP(Small Out-Line Package)/ SOJ( Small Out-Line J-Lead Package) 10
% p7 n6 O+ k" ?% k5 E: r* c1.4.4 PLCC (Plastic Leaded Chip Carrier) 11
$ ^6 q( M- R4 v5 E( E3 K/ V1.4.5 QFP(Quad Flat Package) 11
7 q4 H* K& {8 Z: \! z1.4.6 QFN(Quad Flat No-lead)/LCCC(Leadless Ceramic Chip Carrier) 16 q" n; R& z; _( o0 J; t% \
1.4.7 Lead Frame进化图 17& R- M+ t8 g8 D: d) F
1.4.8 PGA(Pin Grid Array Package) 17; T, w/ _! r. F$ U, q% s$ Y- J( O
1.4.9 LGA (LAND GRID ARRAY) 18
1 L2 G% [+ ]+ ^2 w2 v1.4.10 BGA(Ball Grid Array Package) 18
^) ~# ~" k, m' _7 b1.4.11 T BGA (Tape Ball Grid Array Package) 19/ u" q+ m* B: c$ p
1.4.12 PBGA (Plastic Ball Grid Array Package) 20
& w/ o% D. i+ }1.4.13 CSP Chip Scale/Size Package)/ FBGA (Fine Pitch BGA) 21# x+ z* n3 x8 |1 N
1.4.14 FC-PBGA(Flip-Chip Plastic Ball Grid Array) 22
; h( ?* k. E- }; z! n+ T1.4.15 WLCSP(Wafer-Level Chip Scale Packaging Technology) 23
2 Q" E/ K" H1 s; b' m! r2 V" o1.4.16 MCM(Multi-Chip Module) 25
" l; g# Q. c3 _0 n1.4.17 SIP(System In Package) 26
1 A! m/ p1 O9 x$ A5 s0 |1.4.18 SOC 27
& h& J! `, W- t" g3 i) b1.4.19 PIP(Package In Package) 309 k$ o, z0 I* T# q0 E
1.4.20 POP(Package On Package) 30
) E8 ]# r, k2 Z& ^& a* Q1.4.21 TSV (Through Silicon Via) 32
: P( p+ O! c5 P* I1.5 封装介绍总结: 34" b3 S& E8 W, j7 S4 t
1 第2章Wirebond介绍 5
6 a* b* [% D e$ D H8 u7 |/ n0 M3 s1.1 Wire bond 特点(成熟,工艺,价格) 5
; _: u) X1 m( l4 \( v3 Z1.2 Wribond的操作过程(每步骤有图) 8
2 L8 m# X, t* ?3 @3 x) P' B1.3 哪些封装适合于使用Wire bonding工艺 12
8 w/ X7 s5 J& `7 g& B1.4 Wire bonder机器介绍 14
4 a8 \/ X5 Z% s |' W8 r1 第3章 LEAD FRAME QFP封装设计 6
- E( e: ~8 V" `- _) z9 i; a1.1 QFP Lead Frame介绍 6
9 j2 Z) X5 O5 y( z5 z! Z1.2 Lead frame 材料介绍 8
% X6 }- h$ N" g9 D) j1.3 Lead frame design rule 8
7 T( h8 h% o! Q8 j. s: c7 c1.4 QFP Lead Frame 设计方法 10
. W/ B/ G2 D9 j4 B: h- I/ g1.5 Wire Bonding设计过程(以autocad为例) 17. o6 X* c `: Y4 C0 Y
1.6 Lead frame Molding过程 22
% ? Z& `) g+ C8 p. S6 Q1.7 QFP Punch成型 (整块没Punch lead frame的图) 24
# P" b! H) p% m7 o1.8 常用Molding材料的一些介绍 26, `% u# M/ z4 X
1.9 QFP lead frame生产加工流程 28) t, c/ _* q4 m* X: t
% R& z5 o. E. A4 w, p
第4章 PBGA封装设计 74 o" W4 J Y& C0 j
1 WB_PBGA 设计过程 7
2 T) D7 K+ Z2 N' V1.1 新建.mcm设计文件 7. d, ^6 K0 X1 E% R/ c Y' T" g& Y
1.2 导入芯片文件 8
* ^- @6 p' b" g1.3 生成BGA的footprint 13$ S7 r/ H6 M! }! u4 ~
1.4 编辑BGA的footprint 175 n! R% O: M& _5 `) o
1.5 设置叠层Cross-Section 20
) V r7 X! l. b7 _; }" }1 E& _- Y1.6 设置nets颜色 21
/ q0 C$ `; |- s& s1.7 定义差分对 22
1 ^/ ^+ Z: p* B4 a, s( j. W6 y1.8 标识电源网络 23' Q: c$ {" W* C9 f, Q
1.9 定义电源/地环 24' H5 l. l+ V% `; Z$ C) O
1.10 设置wire bond导向线WB_GUIDE_LINE 27 j1 M( S* {. ^' X1 A5 ~# b, F
1.11 设置wire bond 参数 30# A& Y: R" t/ S) r) C u1 ?7 p9 C
1.12 添加金线 wirebond add 34
+ A, I2 G+ I8 e# `. @2 o% h8 ]0 ?9 f1.13 编辑bonding wire 36
8 o" a7 \$ b6 H5 F( g1 o1.14 BGA附网络assign nets 38
( h9 H C7 V, f1.15 网络交换Pin swap 42
$ r: d! g+ \% A1.16 创建过孔 44
/ K9 K8 G L; k Z4 Z$ o) K1.17 定义设计规则 46' S7 _* F" d8 I k
1.18 基板布线layout 49
+ v6 K7 R$ G! S6 ^) N4 h4 E1.19 铺电源\地平面power/ground plane 51
- `4 ` x/ J( K$ c( Q" C9 Z7 E1.20 调整关键信号布线diff 53
) p2 M2 x3 l, p. r. f0 g1.21 添加Molding gate和DA fiducial mark 56
$ u1 I" d. @# [4 G1.22 添加电镀线plating bar 58% e: e* A9 \4 Z7 }/ w3 l _
1.23 添加放气孔degas void 62
1 w8 s4 u& @6 E7 S" L8 f: X% k1.24 创建阻焊开窗creating solder mask 64+ C9 J L* [ n! n% @
1.25 最终检查check 679 ~ C. O8 j$ F' i' i, f" K
1.26 出制造文件gerber 68
5 m4 \/ ~, p: O+ `8 t1.27 制造文件检查gerber check 72 i* f: b" `: N
1.28 基板加工文件 742 q, \% H/ W" {& ?( K
1.29 封装加工文件 75
3 @8 Y8 e$ d: I- g0 H9 L
' d+ Y( T6 T$ _1 第7章 pbga assembly process 7$ Y5 Z* u8 D# Q& |% B
1.1 Wafer Grinding(晶圆研磨) 7
6 h$ O6 z, b- o$ y. A1.2 Wafer Sawing(晶圆切割) 98 W' n$ j5 d7 J; Y/ ^6 g8 O
1.2.1 Wafer Mounting(晶圆贴片) 10
b/ N- U7 ?8 e% I) [* ]3 N5 [1.2.2 Wafer Sawing(晶圆切割) 10: C+ X! _0 k3 Q, W8 E8 V8 z
1.2.3 UV Illumination(紫外光照射) 115 v$ l7 l- T% q+ Q
1.3 Substrate Pre-bake(基板预烘烤) 11
( w2 k& g1 U/ N0 U: a% U1.4 Die Attach(芯片贴装) 12
* V. U1 H, S( x8 t, d3 h: }1.5 Epoxy Cure(银胶烘烤) 14) B' {4 N4 ]! a; u/ P9 z
1.6 Plasma Clean (电浆清洗Before WB) 14* w; l! V/ a, A# O1 A) g4 J
1.7 Wire Bond(金丝球焊) 157 x, I: @; Z3 f/ ] U) [
1.8 Plasma Clean (电浆清洗Before Molding) 17 i* D( C" X9 r8 T! R4 p
1.9 Molding(塑封) 18
! I# J* K/ m& C" \; e- j, g( G+ p1.10 Post Mold Cure (塑封后烘烤) 193 j7 e7 j1 i; m: C4 @5 p X: r" q
1.11 Marking(打印) 20/ i8 x+ d+ u# v' A
1.12 Ball Mount(置球) 22: T6 P0 ~1 P6 t; T/ a: [
1.13 Singulation(切单) 22
; c/ ?0 b# P. T8 \2 B5 A1.14 Inspection(检查) 23$ d. l: p2 i2 n; _" I- g, g
1.15 Testing(测试) 24
" q- T% O( v) w" o1.16 Packaging & Shipping(包装出货) 25
5 N9 U( u& @( w U+ ~ f
$ u4 Y( {) n* {1 第6章 SIP封装设计 8
S, R+ S+ M1 W* a+ S1.1 SIP Design 流程 9* `! n" O: \9 f; _
1.2 Substrate Design Rule 11
7 F" ]; Q+ \) q* e! P' D) k5 ?1.3 Assembly rule 14* r" f8 w3 Q, c( m; |+ n. ~6 w% l
1.4 多die导入及操作 16, X5 e2 D h% s3 `2 d6 ]8 B1 ^
1.4.1 创建芯片 16
; X* ?5 ]: O3 D$ ~1.4.2 创建原理图 34
- @1 Y ]6 R+ u* |. T) i/ e1.4.3 设置SIP环境,封装叠层 36 h9 [) n3 @* ~/ N) Z! D
1.4.4 导入原理图数据 42
: w' p' ? Q$ w; U8 k1.4.5 分配芯片层别及封装结构 46
8 t- E* X |) m) Z0 e$ r1.4.6 放置各芯片具体位置 49
( ^. u4 ^+ v( G# L# b: R3 S7 B1 Y1.5 power/gnd ring 452 v3 f& ?$ A1 Y) m1 Y# K/ v
1.6 Wire bond Create and edit 599 k/ O( l! y! x, @; u% B$ W$ o3 n( M8 R
1.7 Design a Differential Pair 68
( H' ~$ ^! d8 O1.8 Power Split 73% ^$ W$ K9 N/ P x1 ?
1.9 Plating Bar 78
$ y& g& D( e5 M* v, y1.10 八层芯片叠层 83
9 J+ d5 X% \; R C1.11 Gerber file/option 83
( h$ }- e+ i- m9 \, e, h1.12 封装加工文件输出 91
; e( L3 ~" m$ u5 U: G* N( [% b1.13 SIP加工流程及每步说明 1007 |& q1 m6 R( _! b3 ?
1 第7章 FC-PBGA联合设计 7
# ~2 q1 l* A: ~* ^* g" T9 V u1.1 高PIN数FC-PBGA封装基础知识 7
9 C1 I% O3 \% J3 z& _1.1.1 高PIN数FC-PBGA封装外形 7/ M' Y8 M7 K) c$ H* H( C& `
1.1.2 高PIN数FC-PBGA封装截面图 71 [+ w# V% u4 x% S0 ~
1.1.3 Wafer 8" V" ?9 S d* b! _% K( g' t
1.1.4 Die/Scribe Lines 8
0 H. c$ |$ K* ]2 X1.1.5 MPW(Multi Project Wafer) 85 v K% b0 I% x
1.1.6 BUMP(芯片上的焊球) 9
* C# m5 F9 c4 }# j! J1.1.7 Ball(封装上的焊球) 9
; ?5 I5 S: }5 C" k8 b% j+ r1.1.8 RDL 10" C& v) Y; l3 r& h t6 g- U! H
1.1.9 SMD VS NSMD 11
6 b, F3 L; y2 G3 ~1.1.10 FlipChip到PCB的链路 128 v q: o* P0 |& q1 H
1.2 封装选型 12, ^% q) D( f0 v/ `, v& |
1.2.1 封装选型涉及因素 12
/ ^! R) e. K5 U5 n4 i& O) A$ l1.3 CO-Design 14
1 }; \+ H0 O. ]/ ~# Y1.4 Vendor推荐co-design的流程 14
! y7 S- [/ N4 H7 \- m; D. a1.4.1 Cadence的CO-design示意图 15
) O7 r" M, E& J1.5 实际工程设计中的Co-Design流程 16
* H F d* g/ R( v5 h1.5.1 Floorplan阶段 18
9 B+ m2 Y4 M) T9 D; c" z7 w1.6 FLIPCHIP设计例子 29/ }4 @4 Q- t7 g# b; |3 p- Q
1.6.1 材料设置 29# o9 w3 K2 ^0 f3 Q
1.6.2 Pad_Via定义: 32
6 |3 x/ N+ d. y% l1.6.3 Die 输入文件介绍 34
' ~% q( x5 e: B" a6 J1.7 Die与BGA的生成处理 34
) s3 k' ^1 s, b3 {1.7.1 Die的导入与生成 34
! K2 R! C# ?+ h. A1.7.2 BGA生成及修改 38
# v) b' I9 c' m6 G. w1.7.3 BGA焊球网络分配 44* O' c1 b# x+ [ @4 F3 q9 g$ T
1.7.4 通过EXCEL表格进行的PINMAP 47
$ ~$ a d8 \! B& Y, I; B& f1.7.5 BGA中部分PIN网络整体右移四列例子 48+ D; i0 U/ `9 c4 Q4 ]' m
1.7.6 规则定义 51$ Z* Z9 g7 ]7 y4 }# M! S* x: M
1.7.7 差分线自动生成方法2 58
4 R7 _0 K1 F9 j; {; ?1 r+ |1.7.8 基板Layout 581 w4 W9 v! o% }- b% g2 P
1.8 光绘输出 64
) K4 s( r' p- ~1 I1 第8章 封装链路无源测试 56 J: \2 U3 b: c! |1 k: Q; L: }1 l
1.1 基板链路测试 5; g+ ]# ?: k( ?+ ]6 J
1.2 测量仪器 5
% G3 u3 J F% {2 R1.3 测量例子 5
6 t6 F. j: @: v1 ?8 n3 b1.4 没有SMA头的测试 7
8 O F- z+ o: T; L$ o1 第9章 封装设计自开发辅助工具 5
0 [1 i) n' S1 |, n& D1.1 软件免责声明 5
8 ?# g P6 `# @; X% }! a2 s1.2 Excel 表格PINMAP转入APD 6
+ Y. X5 {4 R: \4 D1.2.1 程序说明 6) t6 x0 g1 I& m- e; @: O, M/ d
1.2.2 软件操作 78 m6 T8 q1 X' h. @& }3 w
1.2.3 问题与解决 138 [- P1 O# T# H# r( y i
1.3 Excel PINMAP任意角度翻转及生成PIN NET格式 14# ?* I# |8 S% a- U' @
1.3.1 程序说明 14
. j8 b" C# [ {; y: x3 m1.3.2 软件操作 14* _% n( R, T1 Y# O# }8 L; S
1.3.3 问题与解决 18
3 l. a* i" q7 H& D5 p2 j- t1.4 把PIN NET格式的文件转为的Excel PINMAP形式 189 c8 F1 Q4 ^- ~) K* S
1.4.1 程序说明 18# d5 [* {4 C J; C
1.4.2 软件操作 19
9 A% G7 Q' p( Y1 ` d2 O! p: d2 l1.4.3 问题与解决 20
4 f# ^) r! i1 r' A8 i0 U |
