1 第1章 常用封装简介 6+ z" M) O4 i" W, [. g
1.1 封装 6& h5 C; d. P+ n1 [& m# ~, {
1.2 封装级别的定义 62 Z6 w* k/ ?+ J
1.3 封装的发展趋势简介 6
n+ v* a! p( O8 o. V! F6 w1.4 常见封装类型介绍 9
5 m1 Y1 D1 \5 t- w9 T* d1.4.1 TO (Transistor Outline) 9
; ^' j+ }* |9 r& [1.4.2 DIP (Dual In line Package) 9: C: A9 `4 Q7 E" R. m) W7 T1 j
1.4.3 SOP(Small Out-Line Package)/ SOJ( Small Out-Line J-Lead Package) 107 T& ]6 S! {, P6 u+ M+ ?- J
1.4.4 PLCC (Plastic Leaded Chip Carrier) 11# I- `6 q# j5 I/ H
1.4.5 QFP(Quad Flat Package) 110 n5 [5 N( c! l3 C: h* u+ h. O% i
1.4.6 QFN(Quad Flat No-lead)/LCCC(Leadless Ceramic Chip Carrier) 16, P$ G: q+ j j2 ?6 ?, X3 c
1.4.7 Lead Frame进化图 17
, D5 r4 b4 ]6 i$ k6 |1.4.8 PGA(Pin Grid Array Package) 17+ D# {9 y* e# l- Y$ O
1.4.9 LGA (LAND GRID ARRAY) 18
2 \/ n: P2 |$ X4 H- E; D1.4.10 BGA(Ball Grid Array Package) 18
# C( S! J7 _/ j& `) A) n" D& z1.4.11 T BGA (Tape Ball Grid Array Package) 19
" v6 M- m0 S' s: T0 A" A1.4.12 PBGA (Plastic Ball Grid Array Package) 20! v4 p3 Z! q. P# y7 e- o; d+ `9 p
1.4.13 CSP Chip Scale/Size Package)/ FBGA (Fine Pitch BGA) 21' L- R1 J2 R( M+ e, S
1.4.14 FC-PBGA(Flip-Chip Plastic Ball Grid Array) 22
) D0 p8 Q6 w1 s1 P( t' U1.4.15 WLCSP(Wafer-Level Chip Scale Packaging Technology) 23
! {& m+ h5 M. ^1.4.16 MCM(Multi-Chip Module) 25
# g6 `6 l- _/ W1.4.17 SIP(System In Package) 26
7 x( k8 M4 F3 i# E1.4.18 SOC 27# f- l0 f3 l" Y
1.4.19 PIP(Package In Package) 30' ]$ _& p7 a/ R+ @" V6 I
1.4.20 POP(Package On Package) 303 s2 w% X6 l. x* P4 ~. `
1.4.21 TSV (Through Silicon Via) 32
6 C) F+ d+ y: O5 b7 d2 b! u1 p1.5 封装介绍总结: 34& I& l2 x' P+ I7 v) @4 ~% |+ {
1 第2章Wirebond介绍 5' z9 Y9 w0 l6 Y9 p0 o! J
1.1 Wire bond 特点(成熟,工艺,价格) 5
( A' T( l: A ?1.2 Wribond的操作过程(每步骤有图) 8
7 x$ R5 F' m7 f: w( l( z1.3 哪些封装适合于使用Wire bonding工艺 12
2 \1 _" I6 \' G, |8 ?1.4 Wire bonder机器介绍 14
7 o4 o. q) e5 P5 W7 Q3 C% o) j1 第3章 LEAD FRAME QFP封装设计 6) O! c% Y9 W u/ J3 h9 t; ? M2 g
1.1 QFP Lead Frame介绍 6
/ X% O: f+ M9 F) ]1 N9 Y1.2 Lead frame 材料介绍 8
S5 G# j, X6 H2 T1.3 Lead frame design rule 8& y$ ?& A' M8 ?6 G, D/ g
1.4 QFP Lead Frame 设计方法 10
! T! r$ F: v+ V; V' |# M6 b" s1 t1.5 Wire Bonding设计过程(以autocad为例) 17% W6 R; P7 b8 u6 x4 A
1.6 Lead frame Molding过程 22
. {' K4 R: M/ ^1.7 QFP Punch成型 (整块没Punch lead frame的图) 24( C& Z# h8 ^- S* i
1.8 常用Molding材料的一些介绍 26
- }* b8 d2 Q2 p2 v1 ~# p1.9 QFP lead frame生产加工流程 28
) ]5 J' e% t/ u2 ^8 G5 F/ t
0 Z( B( `' K- k第4章 PBGA封装设计 7
, U$ W! d# }5 K& ^; ]1 WB_PBGA 设计过程 74 C0 m: _( o% F! T' u' o
1.1 新建.mcm设计文件 7: Y; c/ ?, T9 M% j0 B" l8 c
1.2 导入芯片文件 8' p! E2 C7 Z$ P8 r
1.3 生成BGA的footprint 13
" b: S5 m) B$ N) F1 m1.4 编辑BGA的footprint 17
) E, F: s, O* z1.5 设置叠层Cross-Section 20( R; i7 X: X' O8 G
1.6 设置nets颜色 21
* N. W5 J1 C; a1 J1.7 定义差分对 22
. B, c$ h% m/ I7 J1.8 标识电源网络 23! o# k2 q$ `1 [! f* F
1.9 定义电源/地环 24# L6 ?8 H' f1 W3 G$ ~+ U( o X
1.10 设置wire bond导向线WB_GUIDE_LINE 27
# W7 F& k4 v! E: `8 `9 p1.11 设置wire bond 参数 30
# h' Z0 R% e# n; d1.12 添加金线 wirebond add 34
" |1 C4 _; i' K2 F, Q1.13 编辑bonding wire 368 A9 @6 d$ f7 s" d q9 Q
1.14 BGA附网络assign nets 386 A. q8 y9 I- ?7 o G. q& Y
1.15 网络交换Pin swap 42( b" l& }6 M8 a! v% B6 P; [
1.16 创建过孔 449 p( }9 v- @) ]+ O2 ]* ?" w
1.17 定义设计规则 46& v3 w% j0 k: }
1.18 基板布线layout 496 s1 k7 b( P: X3 j/ r0 k' `1 M& ]# U
1.19 铺电源\地平面power/ground plane 51
3 D" L# U0 s9 A6 T1.20 调整关键信号布线diff 53
/ z4 I1 P* B7 f* Q$ c0 V- k& }% s1.21 添加Molding gate和DA fiducial mark 56
0 ]( d; E0 P% z2 ]4 c5 a" _* }* i1.22 添加电镀线plating bar 58
; ]6 f) r1 E0 l3 n: k0 n/ z1.23 添加放气孔degas void 62
4 O% B2 S( l9 s8 ~; z% h& N1.24 创建阻焊开窗creating solder mask 64) H5 \; k1 k5 V7 b) x2 K
1.25 最终检查check 671 [3 Q6 j5 S4 o. w. ], v
1.26 出制造文件gerber 688 L4 ` e, s1 D7 h8 A$ G
1.27 制造文件检查gerber check 72
7 v z. B, e4 L7 r A' E' \1.28 基板加工文件 74, l; X; U3 {! ^# ?3 f# c
1.29 封装加工文件 751 H, f) h5 |% [
& I3 Y; B d1 y9 Q$ T0 C* X
1 第7章 pbga assembly process 7) _7 M+ p$ X. U
1.1 Wafer Grinding(晶圆研磨) 7
: {, q) _; i o6 D- Q( D1.2 Wafer Sawing(晶圆切割) 9
& H% _+ [ ~* {1.2.1 Wafer Mounting(晶圆贴片) 101 B; D4 o/ {% Z3 k# C
1.2.2 Wafer Sawing(晶圆切割) 10
0 w9 h2 q( X0 p2 A- R! w U7 C1.2.3 UV Illumination(紫外光照射) 11; x/ L- ]; Z8 p2 J
1.3 Substrate Pre-bake(基板预烘烤) 11
" X2 X& B* `) F$ X$ q1.4 Die Attach(芯片贴装) 12
. e }; c2 u* q- Q, n7 {0 }2 j1.5 Epoxy Cure(银胶烘烤) 14
# o6 n- I8 O& i; w- P1.6 Plasma Clean (电浆清洗Before WB) 14& X+ L* C. a( F# l' d8 ~8 j E/ N" b
1.7 Wire Bond(金丝球焊) 15
2 i9 N. l1 x7 }/ e+ J! k1.8 Plasma Clean (电浆清洗Before Molding) 17+ P5 Q% `0 h7 Y7 Z A5 Z$ ?7 `5 L
1.9 Molding(塑封) 18
$ {+ r/ K; Y. f5 i4 S/ V T6 j1.10 Post Mold Cure (塑封后烘烤) 19
) @# ?$ P1 r5 Z L1 C1.11 Marking(打印) 20
5 O4 a5 y! \) [. ?! d1.12 Ball Mount(置球) 22
3 X2 I9 ~) p2 t0 w0 K8 o1.13 Singulation(切单) 22& S6 w" x, N2 f8 Y) l4 y
1.14 Inspection(检查) 23$ P5 @0 l) q: m- Y# Y+ D- j
1.15 Testing(测试) 24$ n8 D- t7 }# a# \
1.16 Packaging & Shipping(包装出货) 25" Q& }/ w) {& D
) }0 v8 f/ \$ w1 I F
1 第6章 SIP封装设计 8) j* X2 ?1 V; M1 y( l* {" B
1.1 SIP Design 流程 9" [* A; n5 m% N8 _) p! ]9 @0 q+ R
1.2 Substrate Design Rule 11
$ x5 [6 M, i4 y1.3 Assembly rule 14
g/ g) y& n' h/ V/ _ \7 e1.4 多die导入及操作 16
! J+ b. s2 X. K# ~5 d1.4.1 创建芯片 16
0 a' p) m7 ?' {# s% j" i1.4.2 创建原理图 347 _. h/ `9 @# f' U
1.4.3 设置SIP环境,封装叠层 36
/ S! z4 n5 `$ s; E1.4.4 导入原理图数据 42
3 y* v" g/ I9 G0 K# n1.4.5 分配芯片层别及封装结构 46
* D, V7 x: F5 ?& n* q1.4.6 放置各芯片具体位置 498 m" B: U( R* f' @0 C; ~
1.5 power/gnd ring 45* @/ M3 h3 d# u! F1 b
1.6 Wire bond Create and edit 59& y" O$ _7 _8 Q6 p+ o) j( U
1.7 Design a Differential Pair 68% P O$ m( Q ~: R4 u
1.8 Power Split 73! @6 f3 M- `- H8 j' m
1.9 Plating Bar 78- J P& H0 k2 J3 |/ B
1.10 八层芯片叠层 83, s1 i7 k, j: v" ]- }3 i8 x" v
1.11 Gerber file/option 83/ @: M* {' u& W4 b
1.12 封装加工文件输出 91, }" m5 B: i, @: ~; Z9 d3 C! _& f
1.13 SIP加工流程及每步说明 100
4 d& { d+ q( p' z# ]7 \1 第7章 FC-PBGA联合设计 7
! L/ d! P" x# |" ?' E1.1 高PIN数FC-PBGA封装基础知识 74 |7 H8 m1 @% y5 X" X) f, e: g9 A7 Y
1.1.1 高PIN数FC-PBGA封装外形 7
w( @5 R/ P0 V5 O, m2 i* N1.1.2 高PIN数FC-PBGA封装截面图 7" L1 b% U! |2 q* |* X6 s; U
1.1.3 Wafer 8
1 t1 o) Z9 C' K# a+ Q5 }+ `1.1.4 Die/Scribe Lines 84 V/ y n/ n( D: m/ Q3 H0 g" `
1.1.5 MPW(Multi Project Wafer) 8
1 e# w6 r* G6 Q8 I4 {1.1.6 BUMP(芯片上的焊球) 9# J5 h8 V6 X1 N/ r+ |* l
1.1.7 Ball(封装上的焊球) 9
- u$ _) ?) ~% j8 ?7 v, V1.1.8 RDL 10; R: y7 U2 ]. p/ N) H
1.1.9 SMD VS NSMD 11
/ O2 z) s2 e! r1.1.10 FlipChip到PCB的链路 12
+ f G" X' S. E8 e2 ]1.2 封装选型 12
& a3 W3 ]& ?" K, Q1 a* M1.2.1 封装选型涉及因素 12
$ k" X, x. C9 u1.3 CO-Design 14$ H" h' Z( @1 B+ w. ~
1.4 Vendor推荐co-design的流程 14
+ l$ i" I0 V$ U H' B1.4.1 Cadence的CO-design示意图 15
* d! }8 V. @( C) T1.5 实际工程设计中的Co-Design流程 16
( m7 p6 B6 B9 Q; {. b, {: e' D( Z1.5.1 Floorplan阶段 183 ~5 Z( x/ H9 E; d0 J: J
1.6 FLIPCHIP设计例子 29
! r4 _" j7 D2 r& ?1.6.1 材料设置 29" F) y2 K; f. S
1.6.2 Pad_Via定义: 32; @# `* {% k+ M4 }
1.6.3 Die 输入文件介绍 34
7 J4 ]8 g' I& Q* R& Q1.7 Die与BGA的生成处理 34
9 P+ Y5 u! |7 R$ O8 t. F3 U1.7.1 Die的导入与生成 34: `% }: e+ _+ A H* P
1.7.2 BGA生成及修改 38
$ }: ]$ c# v) h- J5 ] c& f0 K) N& i1 ^1.7.3 BGA焊球网络分配 44: V0 W) n+ {0 d+ ~3 t
1.7.4 通过EXCEL表格进行的PINMAP 47+ k" ^- D0 w/ ]# w* K7 r, Y4 }; |
1.7.5 BGA中部分PIN网络整体右移四列例子 48
! S" B% { B& ^7 f1 A. H# Y1.7.6 规则定义 51- w3 {+ T7 e' ?' q5 c3 g% ^% \
1.7.7 差分线自动生成方法2 58, t1 N0 p+ l/ y" }" m. d, K' g1 u
1.7.8 基板Layout 58
: t/ g2 ~. c7 w6 {1 S* \1.8 光绘输出 64
) ~+ K; U! \- \, q$ a1 第8章 封装链路无源测试 56 G E1 A/ S3 H5 ]( S' l
1.1 基板链路测试 5
+ o( v: O S8 I; h& S" p) l1.2 测量仪器 5& V$ j' t0 ?4 n5 c2 D
1.3 测量例子 50 O' o% _( {; F' S+ b& _6 |3 [% e; n5 ]# y
1.4 没有SMA头的测试 7
1 X* C4 W3 V% y* L9 L1 s1 第9章 封装设计自开发辅助工具 5$ f- ^0 T$ d# r
1.1 软件免责声明 5
9 P5 C7 a$ w9 x; l0 C e1.2 Excel 表格PINMAP转入APD 6
/ J, k E# y: e1.2.1 程序说明 6
0 S8 c* i1 t$ G1 ^7 U4 _9 j) H. k1.2.2 软件操作 7/ ]8 U) S- T9 `9 x6 {
1.2.3 问题与解决 13- _+ E3 j' G4 ~( `4 v1 a" D& P( @8 ]; b
1.3 Excel PINMAP任意角度翻转及生成PIN NET格式 14, a" ?7 S2 P- v+ [' m) |8 M9 h
1.3.1 程序说明 14, M' [, Z3 b3 i: w7 S
1.3.2 软件操作 149 E* ?7 B& @/ \' @/ |$ M0 Q4 P( p$ \/ |" x
1.3.3 问题与解决 18; I% E2 ], F# h& C
1.4 把PIN NET格式的文件转为的Excel PINMAP形式 18
) C/ [) M1 r( Q! Q4 R1.4.1 程序说明 18
H' K! q1 n! k' ^1.4.2 软件操作 19
5 d8 Y8 s/ V% M* s6 ^* s8 G1.4.3 问题与解决 20
4 J. o2 Q, a4 o q$ h! A |
