ARS-14是我们最为敏感的角速度传感器,用于各种高性能的应用,比如视线稳定和精密运动控制系统。ARS-14具备亚纳米弧度角分辨率和低灵敏度的线性加速度输入,使得它非常适合在高动态的环境中使用,如空中和地面车辆。ARS-14也具有低功耗特性,因此能源受限的应用也可以使用该传感器。此外,它装配紧凑、坚固、即使在极端环境中工作也不影响其性能。ARS-14能够满足太空级应用。ARS-14具有宽-3dB频率范围,从小于2Hz到1000Hz以上。ARS-14常规的比例因子是20V/(rad/s),也可以根据客户要求定制。! K) g7 P$ N' e M
* I& k) r3 E' a+ g' y9 S1 gThe ARS-14 is our most sensitive angular rate sensor, designed to work in a variety of high-performance applications, such as line-of-sight stabilization and precision motion control systems. The ARS-14 has sub-nanoradian angular resolution and low sensitivity to linear acceleration inputs making it ideal for use in highly dynamic environments such as aerial and ground-based vehicles. The ARS-14 also features low power consumption making it a candidate for application where power is limited. The assembly is compact, rugged, and capable of handling environmental extremes without affecting performance. The ARS-14 can be space qualified. The ARS-14 has a wide -3dB frequency range from less than 2 Hz to more than 1,000 Hz. The scale factor of the ARS-14 is nominally 20 Volt/(rad/sec) but can be customized based on customer requirements. |
