查看: 3634|回复: 18
SPB_16.6 26号补丁下载链接--Hotfix_SPB16.60.026_wint_1of1.exe
发表于 2014-4-3 12:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大小955M
9 V$ O( C: f+ T. M  X& j& {7 s* r0 d# {+ |2 O  |
http://www.orcad.nl/patches/Hotfix_SPB16.60.026_wint_1of1.exe
3 H4 C5 |: U9 B/ \$ Z- J
推荐
 楼主| 发表于 2014-4-6 21:52 | 只看该作者
tubegong 发表于 2014-4-6 12:55+ `4 b3 y% I8 W( E
想知道更新了哪些内容
- V" C0 D% j. O1 j: G
DATE: 03-28-2014   HOTFIX VERSION: 0267 H$ H0 G% s* a! K9 A# H" [5 \9 \
===================================================================================================================================0 i: ]7 W' N4 k. [) e# F" [5 t! H+ j
4 _: p# a# b3 @0 v+ LCCRID   PRODUCT        PRODUCTLEVEL2   TITLE6 {) _$ E1 O+ _
% ]& s7 a( Y4 s7 E4 ~  o1190942 CONCEPT_HDL    CORE             Cannot copy locked .xcon files; u- S0 [' c4 [, g3 T2 }
" n8 h- I0 n$ p# P$ h2 B7 P) H1226085 F2B            PACKAGERXL       Winning net NC shorted with loosing net due to PACK_SHORT: H4 C9 Z) Q7 y! n7 u' K2 }! [0 c: u
1244894 SCM            SYSTEM_OBJECT    Get packaging error when adding a pullup/pulldown resistor7 P7 a/ m' ^% q; H, l
; p0 ]* J. v/ Y% L0 X" c$ o1247432 CONSTRAINT_MGR OTHER            pcb Editor crash3 ~1 R$ o' W7 ?8 _2 `
1248560 F2B            DESIGNVARI       Variant Editor > Help about for S024 says unreleased ?6 ?$ l3 m( f0 A
1248712 SIP_LAYOUT     WIREBOND         Changing the charecteristics of a Bond Finger causes it to shift position
, k% _8 k& h: y! x5 S  u1 p1248839 allegro_EDITOR OTHER            16.6 S023/024 crashes on Logic Change Parts command.
& j+ b& I1 U% L7 g1 s  I1249000 SIP_LAYOUT     DIE_EDITOR       unexpected shift of instances/pins by co-design die editor4 @9 d- z4 B( A. _' I( Q- ]4 Z
1249186 ALLEGRO_EDITOR INTERFACES       Bug - Export IPC2581 ignores property UNUSED_pads_IGNORE3 f$ Q. o; R8 w7 c* r3 Q& b
1249272 SIP_LAYOUT     IMPORT_DATA      film resistor pins/pads are created on the wrong layer. Always synthesized on top cond layer regardless of config file
4 e! H; h6 ]; c1 d8 q- B* R1249792 ALLEGRO_EDITOR INTERACTIV       Cannot place rectangular shape as per included width and height.6 i: A" _: {! S* H
+ y2 K6 Y7 @9 _; s; z5 q) U' m# w1249801 ALLEGRO_EDITOR INTERFACES       Bug - Arcs in IPC2581 export are corrupted1 ]/ r$ X$ i3 t2 F: ?
1251006 ALLEGRO_EDITOR INTERFACES       IDX does not recognize PKG_PIN_ONE property7 K  h7 I. ?) L# R" l0 O0 i5 k  V% X$ k) b! Z- @5 f5 b+ l! w4 w
1252142 ALLEGRO_EDITOR INTERFACES       Remove inappropriate Conductivity specs from the dielectric layers from the IPC-2581 output& I, \6 |/ i6 ^- D) i. d
; Z+ S: ?  v  M5 _1253047 ALLEGRO_EDITOR SCRIPTS          Bug: SAV file when creating symbol
推荐
 楼主| 发表于 2014-4-17 22:04 | 只看该作者
eagerous 发表于 2014-4-17 20:584 G- c' D3 ?* F* b7 S
allegro16.6添加泪滴是以shape的形式,如何改成以cline的形式! 跪求啊,求大神指点。
  i% j# ]6 g; e将铜皮shape变line的方法:1.选择菜单Manufacture-->Drafting-->Create Detail,该功能具有放大缩小功能;* h. c+ N( Z# M/ m6 [8 t
1 b: ]: x4 K4 W                                          2.在options一栏设置相应的层面及其他参数,其中Scaling factor为放大缩小倍数;
/ X8 E! E8 b! _2 j/ t" ?1 c$ ^- A5 v' r6 p/ R
                                          3.设置完成后,框选需要改变的铜皮即可。4 }; P' k6 K( |& X- l# [4 k; W
& [$ B$ n4 R/ M注意,line的宽度为0mil,可通过change命令将其变为1mil,效果会更佳!
8 Q. U5 b- G& X
2 Q2 m' k6 \) Q. w0 Z4 o. h如果需要将line 变到到其他层,可通过相应的skill实现。
推荐
发表于 2014-6-23 15:07 | 只看该作者
這侽孓譙悴丶 发表于 2014-6-22 21:51
9 J9 T) _5 u9 P- @0 D& M  j那个补丁是026的,现在补丁都出到030了,建议你还是去下载最新的补丁吧
. H, E4 _6 }! M9 S' y& V  d嗯嗯  谢谢拉  我找到30的补丁了
发表于 2014-4-3 13:15 | 只看该作者
多谢LZ分享
发表于 2014-4-3 14:10 | 只看该作者
请上传BAIDU云
发表于 2014-4-3 14:43 | 只看该作者
百度云 已经有  下载链接:http://pan.baidu.com/s/1sjnTVn3
    2021-10-7 15:18
    发表于 2014-4-3 17:59 | 只看该作者
    谢谢ls共享!
    发表于 2014-4-3 18:53 | 只看该作者
    谢谢ls共享!
     楼主| 发表于 2014-4-3 19:20 | 只看该作者
    szhot 发表于 2014-4-3 14:10+ y8 `2 f7 Y- R# }" L' ~! M, {4 Z
    请上传BAIDU云
    ; ^" ~& Y+ U5 A这个是官网的迅雷下载连接,直接用迅雷打开下载就行了
    2024-5-31 15:50
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    发表于 2014-4-4 09:24 | 只看该作者
    更新太快,跟不上
    发表于 2014-4-4 21:42 | 只看该作者
    这更新速度....
     楼主| 发表于 2014-4-4 22:12 | 只看该作者
    cxt668 发表于 2014-4-4 09:241 t( c  p/ |5 K& `" a7 C0 t
    更新太快,跟不上
    2 L- ?, x; {# X; Y7 U& Q8 e是啊,我刚下了25号补丁一起安装,过几天26号补丁就出来了,早知道就等26号出了再装了
    郁闷
    2019-11-19 15:57
    发表于 2014-4-6 12:55 | 只看该作者
    想知道更新了哪些内容
    14#
    发表于 2014-4-17 20:55 | 只看该作者
    更新速度....so 快
    15#
    发表于 2014-4-17 20:58 | 只看该作者
    GMT+8, 2024-12-23 21:26 , Processed in 0.093750 second(s), 24 queries , Gzip On.
