按照你的办法我的一个电容名为PC306,allegro中信息如下8 i1 w" y3 g* @! I
Component Class: IC
" V6 M+ O- ]! n1 m& j8 U Device Type: CAP NP_C0603_0.1UF,50V
# w& E7 q2 @6 } J# S3 O) K" k/ | Value: 0.1UF,50V
, K/ p4 v7 @' v8 \; ` }/ O3 _% D
D- ^! u B e( @; n$ Z Function(s):
* _" w) ^# ^, ]3 i Designator: F2541; {% ^$ q1 G# a1 b7 i
; c; k8 j+ I' x8 I. [6 E' v- Q Pin(s): 1, 2
4 {, |: ~& Q3 d2 m* Z- X. Q# K+ M8 k' B; R' `. Q4 H8 G0 i7 m' O
Properties attached to component definition
. n w# K, p1 `) A6 A: p) x VALUE = 0.1UF,50V9 }* S T' T8 G+ [
H( ]5 c, q9 e- m$ W
Device Type的值是 CAP NP_C0603_0.1UF,50V,我把Partmap中加入
( G, b& ]8 l" r# c- K% ?8 y4 PCAP_POL_CAP_3528_BBOX NonIdealCap 0.1u 1n 0.1 (2,1)7 q2 A% L1 `: q' g8 K8 i. L$ u) i
X2Y_X2Y_0603 Cap 0.1u (2,3) (1,3) (4,2)7 o! z, d# v8 j5 C. d% T3 n
R_R0805 Res 50 (1,2)
) I" n5 y! a, e# D" B+ i% A# [MPZ1608XXX_R0603 Ind 0.01n (1,2)
0 T$ m) O+ K6 RTHERMISTOR_RGE700 IC# D0 [2 i5 v- A: D# p0 `( p4 d
CAP NP_C0603_0.1UF,50V Cap 0.1u
* A: T5 R( Y! V( w/ x. J8 X$ S4 `3 h5 m& }
没有成功,后来我看到siwave中PC306的Part name是CAP_NP_C0603_0.1UF,50V,CAP和NP之间多了个下划线提到空格,我改成下划线还是不行。
. w$ W, F/ ^7 B+ P. J; \& V不知道问题在哪呢?你这样改后确实PCXX就认了有属性了吗? |
