QUARTUS II版本:13.0
- j! ?" |; w1 y/ X* X; O% WFPGA型号:EP2C8Q2080 K/ ^/ y9 X. y2 Q
在编译的过程中出现了如下的警告:
# i j# E% X' k, e9 n(1)Critical Warning (332012): Synopsys Design Constraints File file not found: 'exp08_demo.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.
1 S" M1 O% @9 F: O" X& YCritical Warning (332012): Synopsys Design Constraints File file not found: 'exp08_demo.sdc'. A Synopsys Design Constraints File is required by the TimeQuest Timing Analyzer to get proper timing constraints. Without it, the Compiler will not properly optimize the design.- g( x2 L( P/ E% ?( U# u1 b
Critical Warning (332148): Timing requirements not met; }. X6 X- p& w6 i) y
Critical Warning (332148): Timing requirements not met* z# ?% i+ `/ I& o
" Z: b' C: o! C8 v(2)Warning (306006): Found 4 output pins without output pin load capacitance assignment) B8 S9 c2 _4 U& @, `
Info (306007): Pin "Data_Out[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
( I2 e8 z0 ?6 Y& s7 ~$ d6 r q Info (306007): Pin "Data_Out[1]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis
* t$ L; Q+ Q, @8 O2 q- P Info (306007): Pin "Data_Out[2]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis# J1 Z3 \/ E/ P; S9 L0 |- h9 l- f
Info (306007): Pin "Data_Out[3]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis& ]' A1 ?1 G. }3 f0 w
程序是黑金开发板提供的程序:PS2解码 ,仔细检查了下,程序没有问题。& B, Y, Y/ D; u
6 p) n9 Q* o- D4 r
求助大侠,有没有什么好的方法来解决上述两个问题。。。谢谢 |
