.SUBCKT irf7304 1 2 3
5 ^% z% l+ g* d* C. E+ O+ N**************************************- V7 A3 D+ N% c! ?7 D) M% M
* Model Generated by MODPEX * e. D/ ~8 k% c) D
*Copyright(c) Symmetry Design Systems*- C% z5 o p j. W
* All Rights Reserved *
% |8 Z7 g* V( S/ S* c) @& S: i' T* UNPUBLISHED LICENSED SOFTWARE *& f" O; x" _& [3 T/ a* i
* Contains Proprietary Information *
; F; h3 }! m) y) |4 F; y* Which is The Property of *& N4 m7 Z9 y1 @! n) x7 z
* SYMMETRY OR ITS LICENSORS *
; y. K9 w4 E( u' {*Commercial Use or Resale Restricted *
$ y, M( F- q* i! a0 p% A9 O6 X* U* by Symmetry License Agreement *8 P4 L+ N# Y& m* J
**************************************6 U7 Z5 I& W" w G' H2 x0 }9 `
* Model generated on Apr 24, 01
G0 }+ X) C( L" S4 E* MODEL FORMAT: SPICE3
4 i# O& @1 @- a* Symmetry POWER MOS Model (Version 1.0)
* g$ k! c# X; x Z& l1 H* External Node Designations
9 g( @2 H; k9 r* Node 1 -> Drain
+ s- i0 j/ p. e# J- W: `5 @: L h3 p* Node 2 -> Gate3 [' W- H: S- W+ l# s0 `! s4 ^3 `" l
* Node 3 -> Source' i& D( b1 |: L; k' V; D* W4 }0 c
M1 9 7 8 8 MM L=100u W=100u* Z* p, l2 [% `$ o+ T3 R
.MODEL MM PMOS LEVEL=1 IS=1e-32& O& n! O& N" Z+ v1 a0 n% O
+VTO=-1.23644 LAMBDA=0 KP=13.37587 g; M2 M2 P/ Z7 k6 i- W/ R! [$ \( q
+CGSO=4.62081e-06 CGDO=1e-11
7 w/ }* ^ F: k2 n7 }4 @5 |5 YRS 8 3 0.0342266& E! x5 k* W& z) x
D1 1 3 MD
) P- z0 R: Q& u) a3 U.MODEL MD D IS=5.88003e-09 RS=0.0322189 N=1.5 BV=20
! E2 Z/ {. z8 K4 Q. ?+IBV=0.00025 EG=1.2 XTI=4 TT=2.95132e-14
& Q+ C: ]4 w- p+ `4 O d: _! D4 O+CJO=6.14875e-10 VJ=0.5 M=0.432471 FC=0.5
: v9 W6 \3 U! v1 _9 i# cRDS 3 1 1.6e+06: }) k- ^2 n# B! _/ m. b. e
RD 9 1 0.0141686) z8 y" M; B3 b- c7 i L, U
RG 2 7 4.48673
' v4 g( Y" S- K, C, k9 _9 jD2 5 4 MD1% p0 ]* p( S. |. ^; h* P& \
* Default values used in MD1:, g4 C6 D" i4 g+ @' L' ~0 Z- d
* RS=0 EG=1.11 XTI=3.0 TT=05 s# g H/ [) j% j- q$ k$ k+ t5 }: v W. v
* BV=infinite IBV=1mA
8 W( x4 \: \* F; E.MODEL MD1 D IS=1e-32 N=50$ r9 R! f0 @9 L5 m( W
+CJO=1.88663e-09 VJ=1.02103 M=0.9 FC=1e-08. a$ G$ E0 f7 Y! |4 O. X
D3 5 0 MD2
( j, c" @# P4 D) T6 q& v1 `* Default values used in MD2:
- @# p5 e& ?3 B8 c* EG=1.11 XTI=3.0 TT=0 CJO=0& r7 }. q" P3 \
* BV=infinite IBV=1mA i0 W( Q N( X! E
.MODEL MD2 D IS=1e-10 N=1 RS=3e-06
" t+ c+ o: ~! }RL 5 10 1+ g+ C' M& D! e
FI2 7 9 VFI2 -1
, s. o" P6 B: R t4 jVFI2 4 0 0
7 q1 B) x% O3 M7 t: c! ~6 l5 k: GEV16 10 0 9 7 1
$ S. }/ u" V- n$ L- x) Q% k) fCAP 11 10 1.88663e-09! K I0 ]+ R2 m) Z) p5 t; u
FI1 7 9 VFI1 -1
4 D+ n0 v6 Y, V- ?2 S, {VFI1 11 6 00 `( r* P6 \; X# K* c7 O
RCAP 6 10 1% ]3 C- O+ |/ K! t' D+ A1 G
D4 6 0 MD3
7 O9 ?# @$ j; k1 a* Default values used in MD3:+ M3 `* p% q& G3 h; o) I4 h( d" N- z& V# G
* EG=1.11 XTI=3.0 TT=0 CJO=0 |" k. k5 S+ p& M6 E# N4 i
* RS=0 BV=infinite IBV=1mA, X+ {5 H' ^; o1 K U7 [
.MODEL MD3 D IS=1e-10 N=1, V% F. ]* f% ?; J6 x* _' D% a' ^
.ENDS irf7304 |
