.SUBCKT irf7304 1 2 3
8 z% l3 Q% R+ ~/ H**************************************
/ K2 ~' |* o6 o# m# x* Model Generated by MODPEX *' k; @( F/ h0 y3 v- l& J
*Copyright(c) Symmetry Design Systems*
- U) y1 c: A$ e* All Rights Reserved *5 h* e/ T- @, G3 w9 \: J% a
* UNPUBLISHED LICENSED SOFTWARE *1 C, J% p8 n0 {+ ^9 r l
* Contains Proprietary Information *
3 I6 A( i& Z# P! {+ N& E8 D: \ _* Which is The Property of *1 b, |) |( x7 L3 ~( x9 A
* SYMMETRY OR ITS LICENSORS *' |! k* c4 q8 A J* k
*Commercial Use or Resale Restricted *7 v7 o2 E$ f" Q4 t
* by Symmetry License Agreement *
C! g0 M# t2 C4 e4 M**************************************
! o+ f- w5 Q1 t/ E6 r* Model generated on Apr 24, 01
& c# _! w0 r6 y7 u1 h% q* MODEL FORMAT: SPICE3
+ `9 x4 {+ l+ n8 |5 V2 i* Symmetry POWER MOS Model (Version 1.0)
" u1 n. @# _! N3 ]# L* External Node Designations
$ W5 I# J6 [1 z+ r" F* Node 1 -> Drain
E3 m Q5 E8 W+ Y' p6 g) P* Node 2 -> Gate
/ v$ t& x/ O) E/ D* Node 3 -> Source
/ V; h F$ h E6 T0 ] `' KM1 9 7 8 8 MM L=100u W=100u
4 _- z/ q! [9 r0 R.MODEL MM PMOS LEVEL=1 IS=1e-329 b$ L. r; w/ W7 I& H8 y/ f* @! }
+VTO=-1.23644 LAMBDA=0 KP=13.3758
" w4 x. Z0 L* L3 A/ {% u' }+CGSO=4.62081e-06 CGDO=1e-11$ \# E5 u8 b3 E* V( p) ^& N
RS 8 3 0.0342266# j, u! z0 h3 m) q- Q: s
D1 1 3 MD/ j% ^9 Y, Q1 C5 C
.MODEL MD D IS=5.88003e-09 RS=0.0322189 N=1.5 BV=20
, v6 X# R- x4 S) q% j8 {# A" g+IBV=0.00025 EG=1.2 XTI=4 TT=2.95132e-14
5 `7 m D+ v0 r2 q/ M9 b+CJO=6.14875e-10 VJ=0.5 M=0.432471 FC=0.5
% ]3 E- {( L3 P8 S0 Z* a7 nRDS 3 1 1.6e+06
7 s# ~7 [1 L( g2 k3 VRD 9 1 0.01416860 R2 ]$ ~0 @* j/ v: ?
RG 2 7 4.48673
: k3 ?+ k. N, v. l4 d) k" aD2 5 4 MD1
2 \% [, M- x% x) e; u* Default values used in MD1:) U4 @+ J6 H$ w) k
* RS=0 EG=1.11 XTI=3.0 TT=0
5 Y# \8 o0 B4 W, ^5 d G* BV=infinite IBV=1mA8 t1 A6 X7 r/ \- G8 t/ S
.MODEL MD1 D IS=1e-32 N=503 }/ a7 C4 |- @$ T8 a
+CJO=1.88663e-09 VJ=1.02103 M=0.9 FC=1e-08
: N0 }. ^+ p( s, \) p3 aD3 5 0 MD2
, P, Z+ V1 {# y1 ~" m+ K* Default values used in MD2:
2 ~5 a- k( s7 A* EG=1.11 XTI=3.0 TT=0 CJO=0- E4 f. t. e% L! u# L
1 y( r: N6 g) h! V0 V.MODEL MD2 D IS=1e-10 N=1 RS=3e-06" a. ~3 d6 b- g0 t8 p! M& M3 }
RL 5 10 1
}$ t3 b. D5 DFI2 7 9 VFI2 -1
+ U$ y& `+ U$ {- f) KVFI2 4 0 0
5 p% V1 H' H. L2 bEV16 10 0 9 7 1
# b2 n9 v$ H, ^: F/ }( a5 Z* oCAP 11 10 1.88663e-093 k& M5 f+ G) \* r+ A
FI1 7 9 VFI1 -1" g3 j; t$ b( p5 h% e: F' \
VFI1 11 6 0
4 P% V/ P4 _! Y" a# NRCAP 6 10 1' N1 Y" h( T/ R1 A3 E" ~6 Q
D4 6 0 MD3+ i8 D" Q$ z3 R) k: o
* Default values used in MD3:
- g7 h ]$ p5 G' n o# r6 E* EG=1.11 XTI=3.0 TT=0 CJO=0
* K: ?- G5 w0 G" x: g+ `* RS=0 BV=infinite IBV=1mA
; c9 \8 z# q4 X: }) |.MODEL MD3 D IS=1e-10 N=1
9 t5 Z+ O; I8 o; p' H- T.ENDS irf7304 |
