推荐
楼主 |
发表于 2013-11-21 21:44
只看该作者
+ A- B0 {$ }5 |; b$ A2 ~5 G P4 y+ m//不知道你安装ASI时有没有rename这个步骤,如果没有,是不会成功的。和安装SPB的update一样,需要如下操作。预祝你能和谐成功+ Z; O, F' D7 M$ ?
$ I1 x4 e+ M5 v. h5 G1. You must install Cadence SPB 16.6 before. Then rename the folder SPB_16.6 in the directory C:\Cadence to SPB_16.6=.
) ?# V+ \8 i! P
1 r0 g6 z- b8 W8 s2. Install the program (Cadence ASI 16.6).
0 y) b$ i9 y n' ~5 C8 |) U- l+ y( `; D3 _% W: @
3. Copy the pubkey to tools directory.
! X, Y9 n1 S# j2 r2 x* [1 q% b, e0 g8 J$ @) ~( ~3 \5 p% r
4. In console window (cmd), change the directory to C:\Cadence\SPB_16.6\tools and run the pubkey
! E! s+ P# l* V/ T0 n& R
# ^+ E' j2 l! K5 Y5. Then re-run the pubkey -y" {4 w$ d+ o) j6 N4 H
# ~ r# U3 K2 t" n! w: ]
6. Copy the pubkey to C:\Cadence\SPB_16.6\ASI\Base directory.! _, Z+ L# @; f2 A
; g% Y" V: ]5 X4 z+ {7. In console window (cmd), change the directory to C:\Cadence\SPB_16.6\ASI\Base and run the pubkey
" R2 D6 [" i. i7 A
1 x D% e9 Z" Y- v: M8. Then re-run the pubkey -y
, N( V0 S: S1 v
5 L4 e0 Q3 R$ k9. Copy the folder SPB_16.6 into the folder SPB_16.6=: J# M9 p& o' ]+ {0 {5 z
% Q" p2 [9 A5 f5 q: A6 c; B4 _9 q4 |( v
10. Delete the folder SPB_16.6
. B! F$ d/ ?2 c
) S, D/ l) y6 L$ D/ b( y, `7 J5 x f11. Rename the folder SPB_16.6= to SPB_16.6 |
