3 b7 P& t/ R2 |7 |7 ?1 ]0 I/ f# Q5 o5 J. q) C; m
" q- f3 U$ F! o% ^& R
好處是 HDMI Source 端關電時 MOS 管不會開,防止 Sink 端的電壓灌過來。當要 HDMI 輸出 +5V 時,透過 MOS 管導通又可以免去體二極管順向偏壓(Body Diode Forward Voltage)所造成的壓降。1 R# h/ z9 d6 `8 F( Y+ Q; w+ b
) `' E- I; b" L- }$ O' H- ]
不過根據邪惡美帝「好孩子」(Fairchild)半導體和「暗!瞎密」(On-Semiconducotr)半導體的技術資料說,你光擋 Power 是沒有用的,他們還是有可能從 I/O Pin 倒灌回去,這個問題被稱為反驅動(Backdrive)。(詳見下面敘述)
v0 |/ K# `8 z9 S% w1 p, m" i W# y" _2 Y) x& [
Backdrive Protection0 h8 M' h' P2 U6 C: b8 q
Every external signal is a potential backdrive problem, especially output signals with pullups at the other end of the cable. For bidirectional DDC and CEC lines, the backdrive condition is a potential problem on both the HDMI Source and Sink side.
7 {' @( c, Q3 b# ?( \+ x) f Y& |7 D1 P1 A: {6 }/ F
{:soso_e161:} |
