+ |1 y+ D# y, B2 c
) }* [) ~( g: e5 m( A Intersil ICL7660A 上面講的︰
* l1 M, a/ I: a- C! o6 t' Z/ T3 D. Z0 w' {- j) f' M" }% Q% S) h
Do’s And Don’ts1 t& S+ n6 G7 K& {
- Do not exceed maximum supply voltages.
- Do not connect LV terminal to GROUND for supply voltages greater than 3.5V.
- Do not short circuit the output to V+ supply for supply voltages above 5.5V for extended periods, however, transient conditions including start-up are okay.
- When using polarized capacitors, the + terminal of C1 must be connected to pin 2 of the ICL7660 and CL7660A and the + terminal of C2 must be connected to GROUND.
- If the voltage supply driving the ICL7660 and ICL7660A has a large source impedance (25Ω - 30Ω), then a 2.2μF capacitor from pin 8 to ground may be required to limit rate of rise of input voltage to less than 2V/μs.
- User should insure that the output (pin 5) does not go more positive than GND (pin 3). Device latch up will occur under these conditions. A 1N914 or similar diode placed in parallel with C2 will prevent the device from latching up under these conditions. (Anode pin 5, Cathode pin 3).% j3 n$ a# i% r+ ~$ B7 Q+ g
6 F* H* w2 J4 W" L- K" t# H
* k0 V6 a$ P3 ` l7 e. O5 V試試看吧!$ \- n0 q! b0 t) J, i1 b
1 i/ Y' [2 A/ T2 o, E7 W1 ]
HT7660
/ T c4 z5 ? b3 q0 ULV Pin︰; T* X8 w! F6 l" @% ]0 _ B+ z
Floating this pin enables the voltage regulator. Connect this pin to VSS (Ground) to bypass voltage regulator and improve low voltage operation.
7 O9 T0 O6 ]! W- P5 t4 K' _) I) P( g, K* d2 D; b
{:soso_e103:} |
