查看: 5337|回复: 6
[ADS仿真] ADS2013发布,加强高速和信号完整性,电源完整性仿真功能
发表于 2013-7-17 20:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
5 B' S6 ^* P9 e; f1 K+ }+ i3 t8 b- ]* y2 C/ E
主要特性与技术指标
0 B, x" ~) [! n0 O$ V1 l
3 @/ {8 ?* e# R, n8 |3 \1 R Advanced Design System (ADS) 2013.06 continues to enhance the industry’s leading integration of channel simulator, transient simulator and EM field solvers.6 L: N+ X$ E3 R! q3 |0 ?
• Pre-standard extension to IBIS AMI for mid-channel re-timers (pictured)
% C; L. D4 s9 H# ~• Power Integrity circuit simulators:
/ _3 @; G; B2 X# Q" a- Touchstone 2 with per-port ref impedance and mixed mode s-parameters
( T; ?2 k. N1 M/ C- Support for power integrity keywords in IBIS models
: Z6 N0 ~0 O8 a# H# U; S  [• Touchstone Combiner for victim/aggressor models from 4-port VNAs" k  V+ X0 `( P
0 Y0 R- H4 e$ L- N! k  h
描述
. d. Y6 |  q9 v0 L4 a$ E, QAgilent's
# q7 M, Y6 q2 r! {Advanced Design System (ADS) 2013.06 continues to enhance the industry’s leading integration of channel simulator, transient simulator and EM field solvers.
3 |/ J) ^6 G4 H; M  eRe-timer Model
A pre-standard extension to IBIS AMI enables you to explore the design space including mid-channel non-linear components.
' z: o3 H% f/ W- v% u
  • Agilent continues to drive the IBIS specification forward by proposing advanced capabilities to IBIS Open Forum’s ATM Committee- `+ C0 h- X2 F; a" `2 _
Touchstone 2 Support
  • Supports Signal Integrity/Power Integrity capabilities:
    • Per-port reference impedance for accurate modeling of power/ground plane coupling to signal traces
    • Mixed mode network parameters for accurate modeling of differential pairs
      4 z, `  w5 ?: U" @) c
  • Industry-standard specification, ratified by IBIS Open Forum7 A8 [0 `, i; o" f' S! {
Power Integrity Keywords in IBIS Models
  • Model Signal Integrity/Power Integrity effects like synchronous switching output noise
  • IBIS models are portable, behavioral model that simulate faster than netlist models
  • Support for [ISSO PU], [ISSO PD], [Composite Current] keywords, as specified in IBIS Open Forum docs BIRD95/98/141
    0 @- O& Y$ W( o, U
Touchstone Combiner
  • Build a multiport victim/aggressor channel model out of readily available 4-port VNA measurement
  • Simplifies a time-consuming and error-prone task using a simple, transparent GUI( g3 r: Q+ q! f( G$ h" @
' t5 Z7 T, R& I4 G0 A+ g# s, i- ?
发表于 2013-7-18 08:40 | 只看该作者
SI\PI方面还是力挺Sigrity和Ansoft
发表于 2013-7-24 13:39 | 只看该作者
eeicciee 发表于 2013-7-18 08:40
4 L1 D$ A4 A  b0 [. H" zSI\PI方面还是力挺Sigrity和Ansoft
% m) W8 T6 A7 P; Q  H7 M4 K; w) j
Sigrity和Ansoft的优点 说明下% M6 u* Y' I- M
都好都好............
发表于 2013-7-31 20:07 | 只看该作者
高速串行信号还是不错的,易操作
发表于 2013-9-23 14:51 | 只看该作者
ADS总是能给人惊喜
发表于 2014-12-16 18:48 | 只看该作者
博士都来了
发表于 2014-12-18 03:19 | 只看该作者
还在学习ADS2009...2012在WIN7下仿真不了,和谐不彻底?
GMT+8, 2025-8-4 19:36 , Processed in 0.125000 second(s), 24 queries , Gzip On.
