查看: 2017|回复: 1
[仿真讨论] Tektronix即将推出70GHz实时示波器
发表于 2013-6-25 22:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
New PeRFormance Oscilloscope Series will Also Offer Improved Signal Fidelity to Power High End Test Applications BEAVERTON, Ore., June 25, 2013 /PRNewswire/ -- Tektronix, Inc., the world's leading manufacturer of oscilloscopes, today announced that its next generation of high performance real-time oscilloscopes will incorporate IBM's latest 9HP silicon-germanium (SiGe) chip-making process. This fifth generation of IBM's semiconductor technology along with other advances such as patent pending Asynchronous Time Interleaving announced previously will result in oscilloscopes with bandwidth capability of 70 GHz and improvements in signal fidelity. ) t& G5 ^! j# z! a9 Z/ R# q
% P5 Y, Y7 q% C# l% gOperating at speeds up to 350 GHz, 9HP is the first SiGe technology in the industry featuring the density of 90nm BiCMOS and delivers higher performance, lower power and higher levels of integration than current 180nm or 130nm SiGe offerings. Tektronix has been a long-time adopter of SiGe, using it to consistently deliver the best performing and most accurate oscilloscopes in the industry. 1 {! _/ F5 Z* ?* Q
6 k) d9 |$ k, ?- v. c- e
The next generation of performance oscilloscopes from Tektronix is due for availability in 2014. With real-time bandwidth of 70 GHz, and the potential for more in future iterations, the new oscilloscope platform will deliver the performance and signal fidelity needed for applications such as 400 Gbps and 1 Tbps optical communications and fourth generation serial data communications. This level of advancement in oscilloscope technology is a direct result of Tektronix's commitment to innovation and one the industry's highest levels of R&D investment year over year. ! w2 E& Q' |4 r4 y. _# _
# n; Y( u& I) Q+ J4 {  l) L& i"By extending our long-standing relationship with technology leader IBM, Tektronix is continuing to push the envelope on what can be achieved in high-fidelity, high-speed data acquisition systems. Early adoption of 9HP has allowed our engineers to explore innovative architectures and performance thresholds once thought unattainable," said Kevin Ilcisin, chief technology officer, Tektronix. "The advanced 9HP SiGe BiCMOS technology provides the faster switching speeds, high integration levels, and low noise our next generation of performance instrumentation requires to meet customer requirements."
. [: v( S5 ]6 s" g# h4 F1 E4 J* [, g6 c5 u- u( X
Improving Signal to Noise ( I* `0 H# ?3 B, h5 o% v( P* X) O
In addition to leveraging the advances made possible by 9HP, Tektronix' forthcoming oscilloscopes will benefit from the use of Asynchronous Time Interleaving technology to improve signal-to-noise ratio beyond the frequency interleaving approach in use by some vendors today. In traditional frequency interleaving, each analog-to-digital converter (ADC) in the signal acquisition system only sees part of the input spectrum. With Asynchronous Time Interleaving, all ADCs see the full spectrum with full signal path symmetry. This offers the performance gains available from interleaved architectures but without the same impact to signal fidelity. To learn more, download the new white paper "Techniques for Extending Real-Time Oscilloscope Bandwidth." : u* _. l% ?* p4 Q
! a  H% u4 }& r) ^
文中大意:于2014年推出70GHz示波器,采用IBM SiGe 9HP工艺(这也是IBM的15代半导体工艺)和非同步交错技术(Asynchronous Time Interleaving) ,用于400G和1T光通信和下一代串行总线。$ J) X. j8 c' m: W/ m! q
( Y5 N+ s1 \( A9 t话说示波器市场创新近年来一直由Agilent引领,希望借助IBM 9HP工艺 350GHz的开关速度,能让Tektronix扬眉吐气一把,毕竟Agilent的InP工艺目前发布的指标只有200GHz。
发表于 2013-7-2 18:50 | 只看该作者
全英文
GMT+8, 2025-8-4 16:44 , Processed in 0.125000 second(s), 24 queries , Gzip On.
