Unable to import file D:\Pcblib\SI_Model\LatticeECP3_FPGA_IBIS_Models.ibs due to the following errors found by ibischk5:# _4 F3 h& C/ `+ Y$ O6 a
, [! c7 G) z8 Z% r6 {+ M4 \- }
IBISCHK5 V5.0.33 I0 o* |1 N. x' r& E
* z; v: u+ h, B d2 u2 W! B! S2 Q# a
Checking D:\Pcblib\SI_Model\LatticeECP3_FPGA_IBIS_Models.ibs for IBIS 3.2 Compatibility...
9 A' }$ V2 b' T, u* m
1 ?9 Y) s w% @; iERROR (line 8) - File name opened 'LatticeECP3_FPGA_IBIS_Models.ibs' not the same as File_name 'ecp3.ibs'. |8 k9 X$ l! c2 e" r7 p7 B
WARNING - Model lvc330s040caaaaaaaio: The [Rising Waveform] ' [: ?0 a# G: q1 u% i; j% X
with [R_fixture]=50 Ohms and [V_fixture]=3.3V
7 ~$ k# r% d# z9 ^; w) y/ i) Y( T has TYP column DC endpoints of 2.89V and 3.30v, but1 \- a' t6 H! @& M4 T
an equivalent load applied to the model's I-V tables yields
1 m0 H) ]% i9 s# I* W* b different voltages ( 2.88V and 3.30V),
# m% c1 y6 ~3 p) @. l$ X a difference of 2.06% and 0.59%, respectively.
6 c3 f5 |! i% X; O$ HWARNING - Model lvc330s040caaaaaaaio: The [Falling Waveform]
1 |* L" c0 \6 V& D# l with [R_fixture]=50 Ohms and [V_fixture]=0V
% b: J( X" X& V( g3 a2 G O has TYP column DC endpoints of 0.00V and 0.43v, but
: L, ]( w& c% o; P7 S! S6 k an equivalent load applied to the model's I-V tables yields
; C8 x' X, s8 @9 z9 e+ {! d0 f1 d different voltages (-0.00V and 0.42V),
" U9 u/ _5 b0 I- n a difference of 0.73% and 2.15%, respectively.
4 [' }! {2 E2 k5 K! s# cWARNING - Model lvc330s040caaaaaaaio: The [Rising Waveform] 7 y4 ~* U- w6 M% E x0 r
with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V) y# N% j5 `3 k) L7 ?& w$ c0 Y$ E) h
has MAX column DC endpoints of 3.10V and 3.47v, but
' F- g7 D8 u3 u: i, x9 p an equivalent load applied to the model's I-V tables yields# @9 o! p9 L% A" x$ s
different voltages ( 3.09V and 3.47V),
" z: s2 w: ^0 A; ~/ _2 j a difference of 2.43% and 0.60%, respectively.& c) B. b& H! L3 h' R8 y1 G: w
WARNING - Model lvc330s040caaaaaaaou: The [Rising Waveform]
$ x6 l6 @3 ]: r w9 Z; l* u with [R_fixture]=50 Ohms and [V_fixture]=3.3V
% s. d- V) e. a% [& E has TYP column DC endpoints of 2.89V and 3.30v, but1 V( l0 G4 B& M
an equivalent load applied to the model's I-V tables yields. o" @$ Z/ j8 _5 Z' x
different voltages ( 2.88V and 3.30V), ?7 @0 |1 o j: N3 v
a difference of 2.06% and 0.59%, respectively.: N' R7 O- Q! ]: M
WARNING - Model lvc330s040caaaaaaaou: The [Falling Waveform] 8 ^. |6 B# b4 W+ |
) Z2 V* g y3 K1 X; s has TYP column DC endpoints of 0.00V and 0.43v, but
. |& ~/ N& K: F: P3 x, T an equivalent load applied to the model's I-V tables yields+ v+ t) |" u4 M! ^" a3 N+ W2 N
) Z: i( U7 S% e a difference of 0.73% and 2.15%, respectively.
+ t+ ^# ~* ]3 \WARNING - Model lvc330s040caaaaaaaou: The [Rising Waveform] % M( u D% _: c* g: X0 o6 y3 T
7 U5 z! ]+ N; D% d3 v3 d4 R has MAX column DC endpoints of 3.10V and 3.47v, but1 r) q, M' a3 [* }3 J! M# \
3 c6 Z9 u$ u. v/ a7 |2 } different voltages ( 3.09V and 3.47V),8 A! e' A/ X& i6 ~
a difference of 2.43% and 0.60%, respectively.# p1 X2 ~3 h: `% K1 Z& R1 g6 k% g
WARNING - Model lvc330s040daaaaaaaio: The [Rising Waveform]
# r( }' x" N7 e. s _# {$ u with [R_fixture]=50 Ohms and [V_fixture]=3.3V
" k* f: I: |, Q: u has TYP column DC endpoints of 2.89V and 3.30v, but
( {* Z2 Y8 O" C1 m an equivalent load applied to the model's I-V tables yields
" T, D& q q5 U1 R different voltages ( 2.88V and 3.30V),
9 k3 s8 ^) _" n% r4 \; ]3 O a difference of 2.06% and 0.59%, respectively.2 u o* M! k% b+ x% K& E4 |
WARNING - Model lvc330s040daaaaaaaio: The [Falling Waveform] 7 h1 h3 C H4 R" `+ |; y3 N* L
with [R_fixture]=50 Ohms and [V_fixture]=0V6 L1 P' w# j+ v, B5 t: x
has TYP column DC endpoints of 0.00V and 0.43v, but8 J, f) z( Y0 O% y! R
* Q1 A7 h" m7 R& z( L+ ]" ] different voltages (-0.00V and 0.42V),
: d2 x9 C( @: J5 l+ ^ a difference of 0.73% and 2.15%, respectively.! o. j0 Z' e5 j6 [5 v
WARNING - Model lvc330s040daaaaaaaio: The [Rising Waveform] , x: E7 O0 ~, O. H7 ^. V
$ [+ @3 q. \% U( T+ P( t has MAX column DC endpoints of 3.10V and 3.47v, but3 [8 T* l+ F7 J/ W/ N
an equivalent load applied to the model's I-V tables yields, Q/ W, i+ L0 p( B7 t, |" b( _1 L
1 z& {' R# V# |; d9 b0 M5 J7 C a difference of 2.43% and 0.60%, respectively.
1 _8 I. B6 L( J; rWARNING - Model lvc330s040gaaaaaaaio: The [Rising Waveform] T& h$ T- q; ~
2 S# o0 N" z2 M9 j' V' m* y/ z has TYP column DC endpoints of 2.89V and 3.30v, but
/ K/ N+ ]+ J0 j7 E" R1 B; F an equivalent load applied to the model's I-V tables yields! w3 I* a' e! t" N+ Y
2 _% a% v+ h J' @& p a difference of 2.06% and 0.59%, respectively.
& G9 l' a2 M( Y8 [% AWARNING - Model lvc330s040gaaaaaaaio: The [Falling Waveform]
7 I$ j5 q3 o! y with [R_fixture]=50 Ohms and [V_fixture]=0V1 [7 U6 h8 a) G6 [
8 e+ v8 G' Y. }6 E; u! h. z: I an equivalent load applied to the model's I-V tables yields# ]0 B, A" H) X% `2 t2 e# B
different voltages (-0.00V and 0.42V),% l6 z( S0 t, V6 K* {0 a1 x1 m. E
a difference of 0.73% and 2.15%, respectively.$ a3 a/ D5 D8 _" Y, r2 J6 T
WARNING - Model lvc330s040gaaaaaaaio: The [Rising Waveform] 0 w+ u1 a) ]/ w) D5 N+ ~( V. X
& k( `0 E+ L" j, l8 P# ^; x0 @ has MAX column DC endpoints of 3.10V and 3.47v, but& e" ]' ~5 g+ U
an equivalent load applied to the model's I-V tables yields8 a. l( }- M1 Z/ j8 m- V
different voltages ( 3.09V and 3.47V),. A1 ]7 u4 i$ x1 P$ |" S
1 u/ b* M7 k& h% l/ @3 bWARNING - Model lvc330s040gaaaaaaaou: The [Rising Waveform] ; o* a: ?% Q0 H3 E
with [R_fixture]=50 Ohms and [V_fixture]=3.3V$ t7 \2 {5 J0 c1 V4 d0 f
has TYP column DC endpoints of 2.89V and 3.30v, but$ V. x' `% K4 L
- F1 O* u) H) h4 k( t8 B* k+ G5 Z different voltages ( 2.88V and 3.30V),
0 ]9 _8 O- Z# Q7 a3 ?. s$ R7 m a difference of 2.06% and 0.59%, respectively.
' q }" d' B) M# j$ FWARNING - Model lvc330s040gaaaaaaaou: The [Falling Waveform]
6 L/ h9 _9 F2 Y! c with [R_fixture]=50 Ohms and [V_fixture]=0V4 _6 q8 N/ b1 w% |5 \6 C
has TYP column DC endpoints of 0.00V and 0.43v, but, d- b/ w* B) U7 D3 e0 ^7 {
* g- |# Q: h% P2 o, y2 m3 ^" q different voltages (-0.00V and 0.42V),' q" [2 K) _( q; J/ ]
a difference of 0.73% and 2.15%, respectively./ V. ?) n8 m5 k% O6 I9 d# m
8 q4 U5 F* L1 ]) x; c4 m8 d# i7 d8 d with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V
, L7 s2 b; T3 D2 O has MAX column DC endpoints of 3.10V and 3.47v, but
( Q, N3 C$ _$ k! b' b( s an equivalent load applied to the model's I-V tables yields9 @% }3 P' L& N
9 A. A8 e) Q7 o' m* ^6 b a difference of 2.43% and 0.60%, respectively.
_+ H, r0 q# l7 NWARNING - Model lvc330s040haaaaaaaio: The [Rising Waveform]
0 N& G4 B3 C' M with [R_fixture]=50 Ohms and [V_fixture]=3.3V: G" r- h- s8 z7 A: T9 B" ]
has TYP column DC endpoints of 2.89V and 3.30v, but# O; ^9 \) }+ C4 \: k
an equivalent load applied to the model's I-V tables yields* _- }' a0 n- }! ]
different voltages ( 2.88V and 3.30V),6 i/ D4 o+ ]- w5 i
) ^7 U! [* M) b. J+ ^9 J4 pWARNING - Model lvc330s040haaaaaaaio: The [Falling Waveform] % O$ i7 a8 t. b( _# n* X
6 u2 i% V/ Y/ l7 i has TYP column DC endpoints of 0.00V and 0.43v, but$ [( Z- O3 c3 Z, L* D$ p2 h
an equivalent load applied to the model's I-V tables yields. \7 ?% P7 r* O# s
different voltages (-0.00V and 0.42V),2 k, f3 H8 c2 b
a difference of 0.73% and 2.15%, respectively.( t. B- j# s3 N# P
: e; w* r7 F9 d' N with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V' w4 ~4 [8 \, _& i Q
has MAX column DC endpoints of 3.10V and 3.47v, but' [! t9 J8 ^+ M6 G+ X0 d
9 ?9 T/ r s4 h' ~/ O6 N2 g different voltages ( 3.09V and 3.47V),( `/ c" q3 t% u: j! J; w
7 I! h t% ?, J1 X ^$ d# {WARNING - Model lvt330s040caaaaaaaio: The [Rising Waveform] G9 T% h# S% }! W
with [R_fixture]=50 Ohms and [V_fixture]=3.3V. u ^, \8 r" U _, X( p5 z
5 o1 m7 S/ Z- J. ` O8 f* i an equivalent load applied to the model's I-V tables yields
& K+ Y: F) Q2 \; y) r% B5 r4 B8 ~ different voltages ( 2.88V and 3.30V),/ J% r5 n. D3 r, |$ K4 @
a difference of 2.06% and 0.59%, respectively. {( c/ H- o( j; t
WARNING - Model lvt330s040caaaaaaaio: The [Falling Waveform] 0 t G4 B5 v" C/ }$ P; o+ c0 X
with [R_fixture]=50 Ohms and [V_fixture]=0V4 M9 {; X& l+ n" W. \. z
, T4 |$ X$ F( z- c6 B' V# f an equivalent load applied to the model's I-V tables yields/ D* T0 c6 M! T" \* A
! m8 z1 d) Y& u0 [6 H: t a difference of 0.73% and 2.15%, respectively.+ K- I. q7 n7 R& C
WARNING - Model lvt330s040caaaaaaaio: The [Rising Waveform] I7 a, z6 F* y
with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V J3 _$ _8 j! O) [+ V( d1 u
has MAX column DC endpoints of 3.10V and 3.47v, but) y* j9 g6 l5 A" `
an equivalent load applied to the model's I-V tables yields( J- ?& K6 H. u! E5 R
& C5 T: S; t e" ^ a difference of 2.43% and 0.60%, respectively.
# L2 \& {: G: Z2 D; e9 ~8 dWARNING - Model lvt330s040caaaaaaaou: The [Rising Waveform]
( ~7 e* s4 Y; J with [R_fixture]=50 Ohms and [V_fixture]=3.3V
% g: a! V9 I/ i. q5 x has TYP column DC endpoints of 2.89V and 3.30v, but4 C# e2 b/ N Q( m% f, t# R
an equivalent load applied to the model's I-V tables yields$ s% i2 W% t6 J, P
/ w$ T1 d/ H2 i$ i a difference of 2.06% and 0.59%, respectively., H% ?# I4 P" g. u: I8 h* l
WARNING - Model lvt330s040caaaaaaaou: The [Falling Waveform] 3 S/ g: X B7 {( y& ~- b) }1 W2 c
5 ]- \: N L& v has TYP column DC endpoints of 0.00V and 0.43v, but4 t# W4 Z- v/ I* c* d* M" w
8 f- ^) r1 l5 }. E! O. W. b$ w different voltages (-0.00V and 0.42V),. D/ h/ b( k e1 l) L$ @: b' Z, N
a difference of 0.73% and 2.15%, respectively.+ T8 g* T, g# f3 E1 ?! x
WARNING - Model lvt330s040caaaaaaaou: The [Rising Waveform] $ I' {+ _4 z- Q8 H. |8 x% }# h8 a
( y9 b- y+ e" T i" Y, ^: _& b( L has MAX column DC endpoints of 3.10V and 3.47v, but) |! F" ~" M2 y E5 m% M0 @
an equivalent load applied to the model's I-V tables yields7 L% K1 U ]+ G# s" I2 x
different voltages ( 3.09V and 3.47V),( L! V* u+ Y$ A' l2 V4 i6 u
a difference of 2.43% and 0.60%, respectively.* G$ S. G4 y4 }( U0 f
WARNING - Model lvt330s040daaaaaaaio: The [Rising Waveform]
* W0 Q, L0 @. O" S# x with [R_fixture]=50 Ohms and [V_fixture]=3.3V
2 e( g# I& o2 N- ^7 S has TYP column DC endpoints of 2.89V and 3.30v, but# |3 L; `( Q8 p& G' X H6 J
; O6 R6 J& A# X. S5 S# Z Y different voltages ( 2.88V and 3.30V),
( v, U% D: }% O3 _4 T$ [( L- Q9 _ a difference of 2.06% and 0.59%, respectively.# T g1 l# E) a; K, T9 a
WARNING - Model lvt330s040daaaaaaaio: The [Falling Waveform]
& J) j! r4 Y* M( x# ~6 F- s4 p with [R_fixture]=50 Ohms and [V_fixture]=0V
" t* Z% J; U; p( o; I has TYP column DC endpoints of 0.00V and 0.43v, but* W2 P( E* H; m" T
+ {, G$ N4 e2 v+ \ different voltages (-0.00V and 0.42V),, W5 O1 I+ e: ^
a difference of 0.73% and 2.15%, respectively.2 m* j" w, t2 | b- e8 x% @' }8 D s
2 W6 O4 {, q- {" d5 W with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V
. `" A$ T0 n" _3 R. c' N: k' W has MAX column DC endpoints of 3.10V and 3.47v, but: z# _0 [: _" r9 u2 d V
an equivalent load applied to the model's I-V tables yields: W; y1 F- b2 q: o9 j- Y/ k* n
! y3 k2 d2 h2 V; e L+ c, s5 E a difference of 2.43% and 0.60%, respectively.$ t- p# H2 w, ]+ @4 q5 `; i/ k# |
WARNING - Model lvt330s040gaaaaaaaio: The [Rising Waveform]
. f% _9 Q, E& C5 T5 m& V* k with [R_fixture]=50 Ohms and [V_fixture]=3.3V
5 b0 {4 N1 m2 w6 r p5 s1 d, W' q has TYP column DC endpoints of 2.89V and 3.30v, but/ l/ I( l/ e; ^
- r3 G3 W6 a% g; R, i different voltages ( 2.88V and 3.30V),' L9 u' w" a6 U5 ]
0 R+ E, \* G$ tWARNING - Model lvt330s040gaaaaaaaio: The [Falling Waveform]
6 t8 N7 q) {* V: I& l: ^3 m with [R_fixture]=50 Ohms and [V_fixture]=0V
& l' {5 B5 I" K; n( ?, H( Z has TYP column DC endpoints of 0.00V and 0.43v, but% R4 g! }5 V1 V% N7 T1 F- Y
an equivalent load applied to the model's I-V tables yields% j. G1 S: }" A9 W
8 }: V9 x, T/ O; J" \# q a difference of 0.73% and 2.15%, respectively.& m0 I: t' H3 a9 n
; N' N8 Y6 f7 t2 _ with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V
9 Y* G2 t8 c- S% ]$ x* f- H2 j& z has MAX column DC endpoints of 3.10V and 3.47v, but
8 b5 S( f4 [2 e1 v+ D' W* j$ Y an equivalent load applied to the model's I-V tables yields
# t% R5 D% p& ?0 J& j Q different voltages ( 3.09V and 3.47V),
' Y. D- G: Z) o) r- f; x; ~ a difference of 2.43% and 0.60%, respectively.' z/ u$ P! H) c: r+ M. {
WARNING - Model lvt330s040gaaaaaaaou: The [Rising Waveform]
- D/ t( ]8 Z$ ~3 E& H: x with [R_fixture]=50 Ohms and [V_fixture]=3.3V+ Z* F; s$ r) G
; S! U* Y& ~/ D9 J+ u. D4 m# @ an equivalent load applied to the model's I-V tables yields: U9 q+ z; J4 _ |9 _
different voltages ( 2.88V and 3.30V),: y n. i5 S, `" O! _ I5 W
; }2 V3 Q9 ~! H# k; E7 e% U/ T$ TWARNING - Model lvt330s040gaaaaaaaou: The [Falling Waveform] # d+ e6 h! l8 A0 s4 q* D' _, X: o
with [R_fixture]=50 Ohms and [V_fixture]=0V2 i3 k! O" F5 w
5 l" Z* H4 O" w$ n! D: ]; U an equivalent load applied to the model's I-V tables yields
& X! V' _) B, T/ U different voltages (-0.00V and 0.42V),
l3 ^4 b9 y0 C) K a difference of 0.73% and 2.15%, respectively.- ]+ T Z5 {" Z% ^
3 C2 H( _% a; s; p( k with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V
( W2 U5 T4 J$ u H; ~, R4 d8 P$ q has MAX column DC endpoints of 3.10V and 3.47v, but
: g* k: }0 r! L6 E5 [2 f an equivalent load applied to the model's I-V tables yields5 J1 U6 w: h9 @% t
different voltages ( 3.09V and 3.47V),# T* _# I6 V& @) |+ I
a difference of 2.43% and 0.60%, respectively.5 o( H3 X0 X4 Q8 ~5 V5 ^
WARNING - Model lvt330s040haaaaaaaio: The [Rising Waveform] , H" p1 R' k! w+ |% V& P
with [R_fixture]=50 Ohms and [V_fixture]=3.3V7 P0 v3 {. q5 i* o9 T
has TYP column DC endpoints of 2.89V and 3.30v, but/ Z4 a9 c6 W* k+ U1 M: _
( O) ?% t% P: u6 W different voltages ( 2.88V and 3.30V),
A7 I; S! s0 U) U2 k+ t$ O# ^! ^ a difference of 2.06% and 0.59%, respectively.
8 j) p6 L0 Z, V1 k6 ~& ZWARNING - Model lvt330s040haaaaaaaio: The [Falling Waveform]
6 n+ J7 _, I% W+ R with [R_fixture]=50 Ohms and [V_fixture]=0V2 [: K% l E$ A$ k3 G' g1 ]
5 R( y, u* _* B4 P an equivalent load applied to the model's I-V tables yields
" }& I- _- s+ y4 F different voltages (-0.00V and 0.42V),# ^: {- C1 V- }4 f
8 G) E; ?' m8 Q+ i/ Z6 j, ]WARNING - Model lvt330s040haaaaaaaio: The [Rising Waveform]
* x6 r- g! d2 u with [R_fixture]=50 Ohms and [V_fixture_max]=3.47V9 y; [9 z# i2 o! |' t u
has MAX column DC endpoints of 3.10V and 3.47v, but( Y7 q8 C& n- n5 ?8 [# U
6 A0 ?% A( \/ K% l* @6 N1 B different voltages ( 3.09V and 3.47V),. Z2 D/ h5 ~% R% B+ Q
a difference of 2.43% and 0.60%, respectively.! Z6 h' u3 \7 P$ z" x3 o( d
WARNING - Model lvc250s040caaaaaaaio: The [Rising Waveform] & C+ ^. ?- C2 g3 ]3 B% m9 F
with [R_fixture]=50 Ohms and [V_fixture]=2.5V' w% g* u! ]. R5 }& `) i2 W
has TYP column DC endpoints of 2.10V and 2.50v, but, y% }. e( o: J4 c! x2 ?
an equivalent load applied to the model's I-V tables yields A- ]1 @( R3 K5 l/ v% @8 c
different voltages ( 2.09V and 2.50V), N3 E' @. {9 \& R
9 K( U' H# `% G+ dWARNING - Model lvc250s040caaaaaaaio: The [Rising Waveform] / L+ R) N* t. R# E# L! A2 m
with [R_fixture]=50 Ohms and [V_fixture_max]=2.63V, P3 t: q# Z' ~' u( K
has MAX column DC endpoints of 2.27V and 2.63v, but2 z/ _9 i7 D9 J8 o5 ]" `3 e8 o; y
% d: F8 A8 I' \1 a. P8 d- R different voltages ( 2.26V and 2.63V),# F& A+ e, w1 i/ w8 B
a difference of 2.43% and 0.62%, respectively.
$ Q6 Q% I; R, k- o) K# u" MWARNING - Model lvc250s040caaaaaaaou: The [Rising Waveform] ' @. b0 C0 J/ t& @7 x V
with [R_fixture]=50 Ohms and [V_fixture]=2.5V' I. J! ]7 d I/ o
has TYP column DC endpoints of 2.10V and 2.50v, but. f, W3 F8 I8 i& s1 m* N
5 E) W, z! D% z5 W. ~ different voltages ( 2.09V and 2.50V),) L& S5 ]& J. b% f7 D
a difference of 2.06% and 0.59%, respectively.7 `; J0 Y6 i1 T% x
& h+ X; x8 h* m' } with [R_fixture]=50 Ohms and [V_fixture_max]=2.63V
! ?, ]9 I/ s$ e6 v has MAX column DC endpoints of 2.27V and 2.63v, but
6 b# Q" M, Q% w3 ?4 Q& Y# L, i an equivalent load applied to the model's I-V tables yields) @/ l- D3 b; d8 L
% J4 e0 \; t9 }/ P" p3 t+ N9 k a difference of 2.43% and 0.62%, respectively.6 b9 Z( o3 b( D# m5 A! J
WARNING - Model lvc250s040daaaaaaaod: The [Rising Waveform] ! ]$ J6 k4 h' Z5 A
; T& c5 W# B% ?6 f5 \ has TYP column DC endpoints of 2.10V and 2.50v, but
2 B& g* H$ s% z* X) J# ^9 e# k; d5 X an equivalent load applied to the model's I-V tables yields
2 n1 v0 Q4 W" \3 {9 ] different voltages ( 2.09V and 2.50V),
( |4 R/ c3 N: D/ F) b a difference of 2.52% and 0.02%, respectively.
1 m/ c \& W0 \2 _& [9 }1 v4 f {WARNING - Model lvc250s040gaaaaaaaio: The [Rising Waveform]
* K- z% D/ S+ i/ F with [R_fixture]=50 Ohms and [V_fixture]=2.5V
! S* h" I1 y9 f. q( K, r has TYP column DC endpoints of 2.10V and 2.50v, but
2 R/ Q: [0 u6 i1 u, x an equivalent load applied to the model's I-V tables yields
$ m5 ]8 t, p# {1 ~ different voltages ( 2.09V and 2.50V),) W8 h/ U# {5 D3 J1 F/ G3 Z
a difference of 2.06% and 0.59%, respectively.+ S. O3 ?, w" U$ u
WARNING - Model lvc250s040gaaaaaaaio: The [Rising Waveform] . \$ @3 _' ]4 d& n& Y
with [R_fixture]=50 Ohms and [V_fixture_max]=2.63V' B+ Q* ^5 @/ Q7 _8 Z
5 Q% g' S, K8 W$ [$ R an equivalent load applied to the model's I-V tables yields: B% ?2 k1 a( [
B& E; \' S; h0 q6 p( F, i a difference of 2.43% and 0.62%, respectively.
; e( w4 d# L1 G6 J% ]0 _WARNING - Model lvc250s040gaaaaaaaou: The [Rising Waveform]
6 F- G9 H. u; Z P# J# T5 F$ U with [R_fixture]=50 Ohms and [V_fixture]=2.5V
$ |8 T6 q D( h, E. e% v has TYP column DC endpoints of 2.10V and 2.50v, but, q4 V; u2 ^$ V$ u7 b9 ?5 J4 O
5 C5 A6 s& r7 r8 S% q% K different voltages ( 2.09V and 2.50V),* |+ W4 ]5 N! M0 f1 x
( ?9 e( M( T: c2 Q7 fWARNING - Model lvc250s040gaaaaaaaou: The [Rising Waveform] ! t5 [) s: R' |+ N5 G- h( R8 c
with [R_fixture]=50 Ohms and [V_fixture_max]=2.63V ?! J: x& c( W; Z0 B( l% L
/ H3 l% i( r1 @, X% x0 h( h an equivalent load applied to the model's I-V tables yields b9 I( k7 O9 v9 Q: Y
! g2 y& M4 d1 O6 H( r a difference of 2.43% and 0.62%, respectively.
# G0 L- { N0 a# m* h5 x" s h' j" MWARNING - Model lvc250s040haaaaaaaod: The [Rising Waveform] 0 s, R( L2 Q' [
with [R_fixture]=50 Ohms and [V_fixture]=2.5V4 B7 y0 ] C* `8 ]& H4 p% F
has TYP column DC endpoints of 2.10V and 2.50v, but) Z( s9 \& Z1 T7 f
# l+ f+ d+ R" H) t* c Y different voltages ( 2.09V and 2.50V),+ m& L( _- n# b) w% N( s! H1 }9 g
7 n7 { G2 y# u+ j/ AWARNING - Model lvc180s040baaaaaaaio: The [Falling Waveform]
, f2 U8 c4 C- T6 T+ H' T7 r5 T. ^ with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V
1 K- Q# C% X' _! p1 Q. Q7 p has MAX column DC endpoints of 1.53V and 1.89v, but0 s1 c( m: W2 a" M* c
6 s9 [0 |: i$ j% O5 J& e- s different voltages ( 1.53V and 1.89V),. c4 O+ J( J" e6 O8 K
a difference of 2.48% and 0.34%, respectively.% ?) \! _5 g% e* Z& }8 o* B* b- Q
WARNING - Model lvc180s040baaaaaaaou: The [Falling Waveform]
7 g( M- [% _' m with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V E1 A+ t- a* ]2 `
5 C; V' u; u3 C7 e4 B! z4 \5 { an equivalent load applied to the model's I-V tables yields
! a6 v6 Y5 @( C& r( I5 }# A m different voltages ( 1.53V and 1.89V),
) r; }& D' p/ R( G/ M9 Q a difference of 2.48% and 0.34%, respectively.$ y! g2 ?, j/ q. b
WARNING - Model lvc180s040caaaaaaaio: The [Rising Waveform]
0 B: o7 a& C/ a/ q with [R_fixture]=50 Ohms and [V_fixture]=1.8V' H( T' Z$ I N7 L
has TYP column DC endpoints of 1.41V and 1.80v, but
, J% j) K/ |0 l6 Y an equivalent load applied to the model's I-V tables yields
. u+ D$ M: X+ u8 G0 Z5 J* x+ k different voltages ( 1.40V and 1.80V),( E8 ]" F7 V, ^. C0 W0 F
a difference of 1.99% and 0.58%, respectively.
4 o' [3 U2 C; P- {3 U) dWARNING - Model lvc180s040caaaaaaaio: The [Falling Waveform]
$ T7 c, W v+ Y with [R_fixture]=50 Ohms and [V_fixture]=0V
1 l+ W' q, ~* z& {* N( D has TYP column DC endpoints of 0.00V and 0.39v, but
. p* L; R+ S+ N" | an equivalent load applied to the model's I-V tables yields
% ^7 L( e" B8 r f( c different voltages (-0.00V and 0.38V),/ F$ T) J4 C- J: f" q: G
a difference of 0.56% and 2.13%, respectively." h! O7 n! h* y. n. m2 {
9 e$ {; `5 Q" _0 K with [R_fixture]=50 Ohms and [V_fixture_min]=0V
# H; g, E+ Y, b6 |9 g has MIN column DC endpoints of 0.00V and 0.37v, but+ i4 \0 n8 n* i& s
& v4 D5 B1 P+ z- q8 |: O$ `1 M! J different voltages (-0.00V and 0.36V),
2 B8 L. _/ Q% A1 A* {/ H0 B a difference of 1.00% and 2.21%, respectively.
]! w9 v( _/ U, U4 F9 HWARNING - Model lvc180s040caaaaaaaio: The [Rising Waveform]
3 a5 J# G, Y' w. {: Q with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V- x1 S' w9 N D" F4 }- n3 k% g
has MAX column DC endpoints of 1.52V and 1.89v, but0 |; e) S% y7 m4 ^- Q# p/ A
. L! L& t z. {1 o }! k2 _ different voltages ( 1.52V and 1.89V),
3 W, v, j( Y( R2 p: W+ r+ N a difference of 2.28% and 0.63%, respectively.4 P4 ?/ L, o$ M! W$ T
% e6 y& v7 v+ h0 ]+ h with [R_fixture]=50 Ohms and [V_fixture_max]=0V8 d: j. A: c* c- r1 Z/ F3 z
has MAX column DC endpoints of 0.00V and 0.37v, but$ X8 M; v9 G" C z7 W$ e
' A- R. O/ u" q1 H! I" h# o: g different voltages ( 0.00V and 0.36V),
! s3 K% R3 K7 H4 T9 q2 J& z a difference of 0.06% and 2.14%, respectively.& `1 a. h# k' O& i& i9 Q/ e
WARNING - Model lvc180s040caaaaaaaou: The [Rising Waveform] ; n: p' s3 x& g( z7 T. A* z
# w- X- L8 I& E& Z& g% ^2 k has TYP column DC endpoints of 1.41V and 1.80v, but" U0 f, T% k: I) M
1 Z0 v0 l6 k+ `: N0 j different voltages ( 1.40V and 1.80V),
! b z. ~8 q9 U( s$ O a difference of 1.99% and 0.58%, respectively.
8 u" r. k0 l7 ], D6 _WARNING - Model lvc180s040caaaaaaaou: The [Falling Waveform]
+ x+ n7 r8 M+ L* u0 d2 i# M with [R_fixture]=50 Ohms and [V_fixture]=0V' v4 I+ Q! R Q+ O# G9 Q! J
has TYP column DC endpoints of 0.00V and 0.39v, but5 m: t) T: ?$ Q4 \4 @( N, _
' f" r5 D/ ]5 W different voltages (-0.00V and 0.38V),
8 z; h% C' n' @& u9 E L a difference of 0.56% and 2.13%, respectively.
' a2 s3 D2 W1 ?0 IWARNING - Model lvc180s040caaaaaaaou: The [Falling Waveform]
9 B5 X1 H) P/ z% Q# v( v7 L with [R_fixture]=50 Ohms and [V_fixture_min]=0V" ?* W1 E& G+ D5 {( z/ I
has MIN column DC endpoints of 0.00V and 0.37v, but! F0 ] g F6 d" B$ |: l3 F
an equivalent load applied to the model's I-V tables yields+ p" z% A9 h0 M5 G" W7 F5 f4 y
, |: Q: F) ?, T' ?) g/ t0 G( u; f( ` a difference of 1.00% and 2.21%, respectively.5 R# t& N* o2 S
$ i! P. C5 [* ^8 a3 K: n! @ with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V# Q; G t- o7 c& K# D
has MAX column DC endpoints of 1.52V and 1.89v, but2 W3 q5 M. X; |1 Q4 n) P( E- z
an equivalent load applied to the model's I-V tables yields! b. e. `/ _) _' x* p
& H4 y8 B2 ?: B# {' r# W a difference of 2.28% and 0.63%, respectively.
# q7 i9 d" I* o# h- W* O/ ~* CWARNING - Model lvc180s040caaaaaaaou: The [Falling Waveform]
; {6 ^4 j0 k5 a2 V with [R_fixture]=50 Ohms and [V_fixture_max]=0V
& c! Q8 D1 Y8 _8 ]+ W. y* O has MAX column DC endpoints of 0.00V and 0.37v, but
6 Q' g% a7 G& ^# A$ I: P- N# k an equivalent load applied to the model's I-V tables yields2 N8 C' m+ D/ J; m/ d) F
% z4 R. ~: G6 V: E1 ` a difference of 0.06% and 2.14%, respectively.
) }, W* y' N" K* m4 S, Q m7 X$ eWARNING - Model lvc180s040daaaaaaaio: The [Falling Waveform]
: w- ^2 A: Q0 d2 q1 @ with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V! C4 \0 r X. R/ I% n2 p6 F4 A& r" {
1 K; s! {9 V$ `. O5 v an equivalent load applied to the model's I-V tables yields+ O% d9 d% m8 b3 X- D7 x0 G2 |
~2 ?$ m: B2 a! E( E a difference of 2.48% and 0.34%, respectively.
' `8 V. K$ G0 `2 C! ZWARNING - Model lvc180s040daaaaaaaod: The [Rising Waveform] ; K1 B! ~( H9 e+ p! C2 K4 z
with [R_fixture]=50 Ohms and [V_fixture_min]=1.71V
- R3 a4 g4 [( a7 m( C/ C) b5 m has MIN column DC endpoints of 1.25V and 1.71v, but
/ V0 B: J- [ T+ i9 X& l m an equivalent load applied to the model's I-V tables yields
! ], K, r* I6 H3 i- ^$ p3 P different voltages ( 1.27V and 1.71V),# O, G* L- x1 y9 Z) Y" X. R
a difference of 4.46% and 0.02%, respectively.; e+ |3 |0 [7 Z- b! Y4 }+ G! i
WARNING - Model lvc180s040daaaaaaaou: The [Falling Waveform]
' a, o$ u7 w8 u/ [ with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V) x6 O$ q1 v# n1 t9 C7 X
has MAX column DC endpoints of 1.53V and 1.89v, but+ \5 O6 t4 O/ N- z2 t' m
# q3 x1 U! F. N6 t1 x different voltages ( 1.53V and 1.89V),5 x8 a4 V" F$ z
a difference of 2.48% and 0.34%, respectively.+ O, s1 k, g9 b% U$ V. L1 [* @9 I
WARNING - Model lvc180s040faaaaaaaio: The [Falling Waveform]
4 |6 k* E# b' @# x, t3 F with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V; J6 j) S2 H( G% d
has MAX column DC endpoints of 1.53V and 1.89v, but& F& [& ^. ^& [ ]- W
; x) m1 q$ A) b7 J8 s different voltages ( 1.53V and 1.89V),- I; _1 } v n* K
a difference of 2.48% and 0.34%, respectively.0 z4 e4 F/ `% D$ X$ K% k( N( f
WARNING - Model lvc180s040faaaaaaaou: The [Falling Waveform] 3 p4 | u/ A* H; c8 N
( @# j+ b, y' S+ X has MAX column DC endpoints of 1.53V and 1.89v, but
) z& K- ~1 e6 H2 ^. }7 K an equivalent load applied to the model's I-V tables yields0 ]: u( Y! ]- w/ T& l2 h$ z
different voltages ( 1.53V and 1.89V),5 Q* o/ p, L/ y0 p
- u% W& X8 F7 ^) Y$ ?6 jWARNING - Model lvc180s040gaaaaaaaio: The [Rising Waveform]
: A% o9 I6 s T1 x with [R_fixture]=50 Ohms and [V_fixture]=1.8V- r; }/ T3 x* {' `
has TYP column DC endpoints of 1.41V and 1.80v, but/ \$ @; D" |' i# C. u7 X' m
- W# Z0 H$ z! L different voltages ( 1.40V and 1.80V),, H; B: @7 b2 f& l6 E
a difference of 1.99% and 0.58%, respectively." [6 K1 L3 [* N$ P. t
WARNING - Model lvc180s040gaaaaaaaio: The [Falling Waveform] / k- M! i" H4 p& o$ \
with [R_fixture]=50 Ohms and [V_fixture]=0V' V c7 P0 T9 H" v8 o
has TYP column DC endpoints of 0.00V and 0.39v, but2 [$ r4 C' d+ O8 A: ?, E
an equivalent load applied to the model's I-V tables yields3 c6 T5 h# S ~8 p
" {7 I! U9 N8 z$ ]1 U a difference of 0.56% and 2.13%, respectively.
& M; n; @1 x# U' I- y3 c$ \; @WARNING - Model lvc180s040gaaaaaaaio: The [Falling Waveform] - s! c4 G. ]4 S1 R# r3 E
with [R_fixture]=50 Ohms and [V_fixture_min]=0V& Z4 d( Y5 d$ Z& R; z# k: E
has MIN column DC endpoints of 0.00V and 0.37v, but' ]3 D" r1 V! @! j3 R, F8 V
an equivalent load applied to the model's I-V tables yields6 \. L! I& {) J: A; E) _
different voltages (-0.00V and 0.36V),+ ~" Z+ e$ E' M
a difference of 1.00% and 2.21%, respectively.! R# i' r, I9 Z6 A( R
WARNING - Model lvc180s040gaaaaaaaio: The [Rising Waveform] # Y- I: k: u9 p
with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V8 v& X1 M! r% Y
has MAX column DC endpoints of 1.52V and 1.89v, but: X6 i4 b! J1 I, G/ c s& Y0 {
; ^( U8 L$ @! M% Y4 P/ i% K different voltages ( 1.52V and 1.89V),
- ^8 ~4 ^$ m" x a difference of 2.28% and 0.63%, respectively.! |/ z) ^# j3 M0 {# a* k) C9 r
$ U. |! g/ c4 K% R( J with [R_fixture]=50 Ohms and [V_fixture_max]=0V
* X) m2 ]2 p8 N$ r e4 B has MAX column DC endpoints of 0.00V and 0.37v, but4 D$ Z" k8 [! ^8 e; O- I, W
an equivalent load applied to the model's I-V tables yields$ P8 E) M. W; L
different voltages ( 0.00V and 0.36V),6 `6 I0 g, H* y0 Y
a difference of 0.06% and 2.14%, respectively.9 k$ ^2 d" H- g: o9 h2 W4 w
WARNING - Model lvc180s040gaaaaaaaou: The [Rising Waveform]
7 F$ h% p) {: f' `% _+ N( B with [R_fixture]=50 Ohms and [V_fixture]=1.8V
3 d; q$ [' v! _* A$ [ has TYP column DC endpoints of 1.41V and 1.80v, but9 s1 S5 d0 R& [* u7 U5 |: ?8 L
an equivalent load applied to the model's I-V tables yields% m( Q: a" ~, m; o
, Q# q2 K. J3 r a difference of 1.99% and 0.58%, respectively.
% J- Z- Y. m( ~7 f9 tWARNING - Model lvc180s040gaaaaaaaou: The [Falling Waveform]
% ]6 X' g9 t, Y+ ] s* y with [R_fixture]=50 Ohms and [V_fixture]=0V
, n# Z- r+ a _ has TYP column DC endpoints of 0.00V and 0.39v, but
' i% A/ d( R3 V% \$ \% ?) Y! j* R an equivalent load applied to the model's I-V tables yields0 S2 k, m7 Y' h( O, X
( N9 u' S# k( I a difference of 0.56% and 2.13%, respectively.
4 {" T/ U! v8 B XWARNING - Model lvc180s040gaaaaaaaou: The [Falling Waveform] ) I% P2 X! h4 Y W
+ v% g9 e, G& n- v5 Q has MIN column DC endpoints of 0.00V and 0.37v, but, ^6 b% B# \0 X. [$ H$ w W) f- s
an equivalent load applied to the model's I-V tables yields3 C$ J8 H2 x1 v
different voltages (-0.00V and 0.36V),) n: @% I$ q4 d
a difference of 1.00% and 2.21%, respectively.; A+ w8 P0 R# `6 e" h, _
WARNING - Model lvc180s040gaaaaaaaou: The [Rising Waveform] * s% i$ \6 t5 O4 O8 B; i
with [R_fixture]=50 Ohms and [V_fixture_max]=1.89V4 }7 I4 ~5 F% o( i
has MAX column DC endpoints of 1.52V and 1.89v, but" c/ X9 K5 H7 S: }4 Y( k
# R0 ^, g9 N" Q2 I3 S# l different voltages ( 1.52V and 1.89V),
! @* ~6 W- I3 Z, u9 o/ y; Y a difference of 2.28% and 0.63%, respectively.
# W& W- l# \" Y: x' @ G: `WARNING - Model lvc180s040gaaaaaaaou: The [Falling Waveform] 9 |3 }. `- u' {) c* Y6 x3 L
' n& M4 t* ?2 J4 j$ R has MAX column DC endpoints of 0.00V and 0.37v, but1 \+ O. r! O' ^, }0 k' @
an equivalent load applied to the model's I-V tables yields Z- y. K A! O0 {, R/ P* L$ N B
& s% f% F# u7 `1 d ~! [: P* M# B a difference of 0.06% and 2.14%, respectively.
& C( j/ d* P# e# d7 z, lWARNING - Model lvc180s040haaaaaaaio: The [Falling Waveform] 7 ?! F8 x% P; b2 y
) V9 G- i S Y: ?/ h$ b/ A has MAX column DC endpoints of 1.53V and 1.89v, but
; W! ^! K- a+ y1 l- o an equivalent load applied to the model's I-V tables yields
8 X) X# v$ m$ V8 O different voltages ( 1.53V and 1.89V),
7 O& p; ?/ U) z( z% P1 O a difference of 2.48% and 0.34%, respectively.4 D/ l5 m, U* c, j
WARNING - Model lvc180s040haaaaaaaod: The [Rising Waveform] - s* u' F- [5 e( h
with [R_fixture]=50 Ohms and [V_fixture_min]=1.71V! S9 p# `; Q2 x9 C$ g
has MIN column DC endpoints of 1.25V and 1.71v, but5 d7 }9 k! d5 u" A& w
+ ^. m" z: ]1 ?; Z2 C+ t different voltages ( 1.27V and 1.71V),
1 p8 q! x0 K0 u4 _, N& ] a difference of 4.46% and 0.02%, respectively.
7 f/ c2 p2 M3 ~: U* U7 RWARNING - Model lvc180s040haaaaaaaou: The [Falling Waveform] * h9 A! [: k2 m3 _: p' w( c
( V% ~, G4 ]' }0 ^ has MAX column DC endpoints of 1.53V and 1.89v, but" Y8 ]) V, z6 h4 w' @2 S" m
! G% s% A8 R- b. P8 s$ e different voltages ( 1.53V and 1.89V),
. P/ l$ a+ u2 o a difference of 2.48% and 0.34%, respectively.
7 N z; P( D2 B* Q+ d/ nWARNING - Model lvc150s040baaaaaaaio: The [Falling Waveform]
9 T3 {) Y! e0 {4 b7 p with [R_fixture]=50 Ohms and [V_fixture]=1.5V
: R" ^$ N' ?2 ?8 ` N, k has TYP column DC endpoints of 1.12V and 1.50v, but
' U k& z1 G& E$ @% H' V+ O1 Q. J an equivalent load applied to the model's I-V tables yields8 @3 o7 m4 o. s, X* l
different voltages ( 1.12V and 1.50V),% V+ W+ r/ w% e% \) A i5 y; Y: U
a difference of 2.13% and 0.00%, respectively. A- {1 M* D9 \* a8 B* B
WARNING - Model lvc150s040baaaaaaaio: The [Rising Waveform]
' g5 [2 s! C {8 H with [R_fixture]=50 Ohms and [V_fixture_max]=0V
0 l0 T) U, c1 q" d has MAX column DC endpoints of 0.00V and 0.32v, but, g4 p) O! W2 {7 O' _% ^
an equivalent load applied to the model's I-V tables yields3 M, H- Y' ?4 h, a* X
different voltages ( 0.00V and 0.32V),
/ A3 Y+ g; I% r, K a difference of 0.02% and 2.56%, respectively./ {& l! q! O+ Q( d; L* I; o
WARNING - Model lvc150s040baaaaaaaou: The [Falling Waveform]
1 j! z! `& }5 m) a( _6 R* k# n with [R_fixture]=50 Ohms and [V_fixture]=1.5V
/ b3 m( r% h) F3 l; a8 Y0 X9 u has TYP column DC endpoints of 1.12V and 1.50v, but; v% c( n! w% J) N
an equivalent load applied to the model's I-V tables yields# i* {$ h# ]3 u! L0 u$ M1 F
+ Q( {0 U9 y9 ~, `8 A: C$ P a difference of 2.13% and 0.00%, respectively.
, L1 M" }2 i/ j J$ I" f8 |: CWARNING - Model lvc150s040baaaaaaaou: The [Rising Waveform] 1 }) r r( g: Y( g+ P& z# e, V7 z7 e
7 l+ R* P5 _2 ]( S1 a has MAX column DC endpoints of 0.00V and 0.32v, but. s: c" I$ I. v; W- P' D6 j
an equivalent load applied to the model's I-V tables yields7 q6 R+ V$ j1 [+ P& |$ N4 A
( O) c; O- @8 z. U7 r5 e a difference of 0.02% and 2.56%, respectively.1 u ~" }4 k5 f3 R# L
WARNING - Model lvc150s040caaaaaaaio: The [Falling Waveform] 7 n9 J4 I7 q) ^' O" f' _: q ^
with [R_fixture]=50 Ohms and [V_fixture]=0V) x; y. E+ h# I8 ]0 @& l, q1 d
has TYP column DC endpoints of 0.00V and 0.34v, but8 b) W4 _# p8 e9 n! ~2 G/ g4 z
an equivalent load applied to the model's I-V tables yields0 m, b4 F/ z' y* Y- u6 \
different voltages (-0.00V and 0.33V),
, q! K0 [2 Q0 h+ n3 s! h- i a difference of 0.61% and 2.35%, respectively.7 K0 u; l# I* M' {
, }- ]: I! [- x/ l, f/ p: Q. T with [R_fixture]=50 Ohms and [V_fixture_min]=0V) G9 f/ Z, V6 A* ^
has MIN column DC endpoints of 0.00V and 0.35v, but: \9 ? b" p/ |" Z
an equivalent load applied to the model's I-V tables yields/ a* d# y0 [* m4 D/ I7 W1 U
different voltages (-0.00V and 0.34V), D5 x) f; a' P7 a1 t% \
a difference of 0.94% and 2.22%, respectively., X( V* V! Z& k! i) T
WARNING - Model lvc150s040caaaaaaaio: The [Rising Waveform] ( u- w/ D) c- X! p% T! {5 n: d
with [R_fixture]=50 Ohms and [V_fixture_max]=1.58V
: C* N- J& X/ D# w3 @3 K. a7 V has MAX column DC endpoints of 1.22V and 1.58v, but' G( V! [5 u1 ?0 Z. N+ V
an equivalent load applied to the model's I-V tables yields# q8 Q4 ~6 i( W5 R1 \) n/ a: C
different voltages ( 1.21V and 1.58V),' g# b) {9 W( S
a difference of 2.26% and 0.66%, respectively.- q/ C/ l( b( S0 Z+ C' \
WARNING - Model lvc150s040caaaaaaaio: The [Falling Waveform] 1 a* {3 T: U) s9 w$ d: Q7 `
' \2 p+ }* ?+ D( h6 b- F# r$ b has MAX column DC endpoints of 0.00V and 0.32v, but
) k2 L- x1 E6 H an equivalent load applied to the model's I-V tables yields
$ U1 w! w; I4 V2 Q; D; U different voltages ( 0.00V and 0.31V),0 O* T$ r% d7 @3 O
a difference of 0.10% and 2.37%, respectively.
7 y: V0 c7 C/ mWARNING - Model lvc150s040caaaaaaaou: The [Falling Waveform]
* z9 X) q) F: v& m4 A9 O3 {9 q with [R_fixture]=50 Ohms and [V_fixture]=0V' B/ Q# a2 C7 A! y
has TYP column DC endpoints of 0.00V and 0.34v, but0 ]7 Z& E) n( i
3 f3 A) i) L Q1 \ M, K& J* O different voltages (-0.00V and 0.33V),
- x# J! [; K# M( R9 R( m a difference of 0.61% and 2.35%, respectively.
5 e* A& J7 Q6 H$ L" mWARNING - Model lvc150s040caaaaaaaou: The [Falling Waveform] 8 T& e. w3 }1 L3 q4 R1 _
with [R_fixture]=50 Ohms and [V_fixture_min]=0V3 |) W7 F0 L$ |0 f& t; a# A
has MIN column DC endpoints of 0.00V and 0.35v, but3 j! l! F% k! f" u# M
an equivalent load applied to the model's I-V tables yields# x; x, t- R% ^+ w6 L, N
" v( B+ C$ `7 U3 y% n* C% P a difference of 0.94% and 2.22%, respectively.6 n6 l8 R: ]/ h
WARNING - Model lvc150s040caaaaaaaou: The [Rising Waveform] 2 S, D9 d' Z& P2 i; w6 z7 p
+ z+ c, m: O9 A% ]3 x8 R" l8 _1 T has MAX column DC endpoints of 1.22V and 1.58v, but
4 D* ?' x2 Z: n# T4 ^ an equivalent load applied to the model's I-V tables yields1 I ?6 }5 n. I& p* B
different voltages ( 1.21V and 1.58V),5 E5 K k" a: m* A* k
$ N' M) l( C8 q7 TWARNING - Model lvc150s040caaaaaaaou: The [Falling Waveform]
8 e2 a' u- k5 ]8 i1 N with [R_fixture]=50 Ohms and [V_fixture_max]=0V3 y9 K: L; t5 v) l: o$ _) |
) Z x5 B Q" A) Q8 ^ O8 G an equivalent load applied to the model's I-V tables yields
$ P0 s% m* M" J+ ~# Q different voltages ( 0.00V and 0.31V),/ Z4 H7 @+ m9 C2 q/ X
a difference of 0.10% and 2.37%, respectively." ?9 [( @7 a) M7 O" d
WARNING - Model lvc150s040daaaaaaaio: The [Falling Waveform] . i' p8 \( i+ o0 ?% { Y& j
with [R_fixture]=50 Ohms and [V_fixture]=1.5V ^3 Z+ v( Y* \7 i: Z1 ?, Q0 j
has TYP column DC endpoints of 1.12V and 1.50v, but& y& r C6 i: l9 h* C$ w& B4 m9 t
! p/ W0 @( [2 h+ r/ ]9 d9 N different voltages ( 1.12V and 1.50V),2 U' \/ N5 i1 V) G* C) c
3 `( X* [2 U# A h. u2 ?WARNING - Model lvc150s040daaaaaaaio: The [Rising Waveform] 3 b( V/ i# q: k3 ~- ~' z
with [R_fixture]=50 Ohms and [V_fixture_max]=0V. k6 J0 _) P2 D8 y, Z7 u7 x5 o
has MAX column DC endpoints of 0.00V and 0.32v, but& K N* U$ j" H. s# i2 c
an equivalent load applied to the model's I-V tables yields. T+ k) `5 j( v4 H) _ h$ _3 X7 }
different voltages ( 0.00V and 0.32V),/ Z$ \0 F; S; c4 J% m# }) h9 |
a difference of 0.02% and 2.57%, respectively.
" O- N) I1 |& z% \. OWARNING - Model lvc150s040daaaaaaaou: The [Falling Waveform] 3 y C% w* j6 g, @+ |# N, i
with [R_fixture]=50 Ohms and [V_fixture]=1.5V* s+ h" d! V! O
# o8 f! Y8 U" l/ k6 U/ h H an equivalent load applied to the model's I-V tables yields, l4 V3 J0 B o! U0 O
, n9 i* J% ^3 H3 A$ V1 F! L a difference of 2.13% and 0.00%, respectively.
( \7 R( `( ]* h1 Z/ @, F% FWARNING - Model lvc150s040daaaaaaaou: The [Rising Waveform]
0 n9 b5 W6 F# z with [R_fixture]=50 Ohms and [V_fixture_max]=0V% p) O6 ]* x( s' }8 i
has MAX column DC endpoints of 0.00V and 0.32v, but5 y) u ?5 j' d7 O# N
! w5 d% v e( x N6 V7 c different voltages ( 0.00V and 0.32V),
0 e) R% w" V/ k- c/ M a difference of 0.02% and 2.57%, respectively.
9 i$ Z* p7 j) x" LWARNING - Model lvc150s040faaaaaaaio: The [Falling Waveform] ! J3 O7 Y, D1 n1 E$ K7 y
with [R_fixture]=50 Ohms and [V_fixture]=1.5V. S8 N; X3 B5 R4 E# V; t
has TYP column DC endpoints of 1.12V and 1.50v, but, q, k3 r; e6 h! f& q' Y! `0 y: ?
an equivalent load applied to the model's I-V tables yields2 G/ ~1 k7 p* l% f8 N5 e% e: O4 d) O
different voltages ( 1.12V and 1.50V),- j7 ]6 Z6 l* G' ~3 u' {9 {
a difference of 2.13% and 0.00%, respectively." N' }7 |% t4 `
WARNING - Model lvc150s040faaaaaaaio: The [Rising Waveform]
: p8 i( B8 W( b/ Y$ l4 J with [R_fixture]=50 Ohms and [V_fixture_max]=0V' h# F; `( O2 n) e
has MAX column DC endpoints of 0.00V and 0.32v, but, Q0 N6 R( y3 ~$ b& q1 H2 E8 _' i
an equivalent load applied to the model's I-V tables yields2 p( F# s% o3 J3 s% O9 v
7 _. w4 ^+ Y4 [( R/ @& U) c5 j a difference of 0.02% and 2.56%, respectively.0 d# j; k* V1 x6 q4 J4 e
WARNING - Model lvc150s040faaaaaaaou: The [Falling Waveform] 1 G3 g9 K! j( B* b8 C
! i3 E* P% e' ]( C has TYP column DC endpoints of 1.12V and 1.50v, but
* ^: F# E/ y8 e$ Y6 D an equivalent load applied to the model's I-V tables yields! q& U/ \+ a l
8 b: K3 z. w" p' K+ | a difference of 2.13% and 0.00%, respectively.' u+ A1 o4 U5 }6 J. y0 [( a1 T) {
WARNING - Model lvc150s040faaaaaaaou: The [Rising Waveform]
( \+ n$ c7 \) T* S2 ^$ X o with [R_fixture]=50 Ohms and [V_fixture_max]=0V$ z, s( G9 f1 c! o' T) I# V' W7 c
, D, W" ~1 s" ?7 z' j/ {6 b: I an equivalent load applied to the model's I-V tables yields4 C& P. O$ F9 Q# `3 D( j
& G( k2 T( [0 V* z% ?* A' g a difference of 0.02% and 2.56%, respectively.
; n; u- |# o2 e8 gWARNING - Model lvc150s040gaaaaaaaio: The [Falling Waveform]
8 N" Z4 |% `. H) D4 @8 n, m6 \. L: G with [R_fixture]=50 Ohms and [V_fixture]=0V
- Z0 W- u1 U1 V# M has TYP column DC endpoints of 0.00V and 0.34v, but V5 K- u! f; l2 S0 N/ G
an equivalent load applied to the model's I-V tables yields! J) t4 c$ }3 H9 [7 Z) w8 D
different voltages (-0.00V and 0.33V),- N b% b8 u7 a3 ^9 S, e5 L' d+ I
j& \- ?6 n: | {4 I6 S: Z# RWARNING - Model lvc150s040gaaaaaaaio: The [Falling Waveform]
. n) r: n& ~ C% i/ ? with [R_fixture]=50 Ohms and [V_fixture_min]=0V, v; g E5 N7 X; U( e' d
has MIN column DC endpoints of 0.00V and 0.35v, but; R1 |' g; W7 h* G
$ G1 n& E% |$ L+ x# ] different voltages (-0.00V and 0.34V),, b& O+ K& k& v2 u4 m7 d0 {+ z" Y
a difference of 0.94% and 2.22%, respectively.; _) [- y0 N5 [, I7 I0 T' k* H9 z
WARNING - Model lvc150s040gaaaaaaaio: The [Rising Waveform]
. @6 W% B0 L+ J3 s! G$ K9 U. i! B" E with [R_fixture]=50 Ohms and [V_fixture_max]=1.58V
0 ^/ M7 t/ g G8 t has MAX column DC endpoints of 1.22V and 1.58v, but) a6 i- ^1 \- ?. y3 n7 I( l
an equivalent load applied to the model's I-V tables yields* m$ u, o, }( a, T1 ?/ G s `1 D
, _) J! E' u( A5 ~( S" ` a difference of 2.26% and 0.66%, respectively.
4 F3 ]* b; m% |7 \# s9 k( g, WWARNING - Model lvc150s040gaaaaaaaio: The [Falling Waveform]
6 L& R* G K1 i$ _ with [R_fixture]=50 Ohms and [V_fixture_max]=0V) f1 a( H' }9 x1 x* E l
% `# i* ^' g) y) x6 d* Q4 Y3 u/ ` an equivalent load applied to the model's I-V tables yields
1 k; `/ l, t/ T, }6 X9 q/ S different voltages ( 0.00V and 0.31V),
9 U, b3 f/ |9 Q! ?. W a difference of 0.10% and 2.37%, respectively.
- |% u% W. i4 C# `. Y$ \( mWARNING - Model lvc150s040gaaaaaaaou: The [Falling Waveform]
9 l( \9 I) ?; x with [R_fixture]=50 Ohms and [V_fixture]=0V
' x5 l T0 C: q# I/ `: m7 m% k has TYP column DC endpoints of 0.00V and 0.34v, but
6 h4 e% a. `; w7 f, v an equivalent load applied to the model's I-V tables yields
i/ G' ~& p# {6 A3 a different voltages (-0.00V and 0.33V),8 r+ W, t( S0 R. l5 c" ~* b7 c' `
" ]5 m( D8 \" l. M2 P' {, xWARNING - Model lvc150s040gaaaaaaaou: The [Falling Waveform]
; B8 | P% G |6 c8 C3 U& A2 m3 ^ with [R_fixture]=50 Ohms and [V_fixture_min]=0V
l& [5 U5 h4 q3 \) c" Q- v. A has MIN column DC endpoints of 0.00V and 0.35v, but
, I6 `# _. X2 D8 o; v an equivalent load applied to the model's I-V tables yields
# P- T" R2 e$ Y0 {; F7 z different voltages (-0.00V and 0.34V),2 j& L: X7 T3 _4 e5 X
a difference of 0.94% and 2.22%, respectively.' w0 f# w" Q: ~1 C! r
WARNING - Model lvc150s040gaaaaaaaou: The [Rising Waveform]
2 o; N" v) R* A; y# a. { with [R_fixture]=50 Ohms and [V_fixture_max]=1.58V
9 a! @2 o) B4 g- }. n- C9 v has MAX column DC endpoints of 1.22V and 1.58v, but0 ^- F# f1 q6 d$ w' r9 J2 s3 h
an equivalent load applied to the model's I-V tables yields1 R& {/ j h6 x5 q5 c
different voltages ( 1.21V and 1.58V),' O, t; g- G3 m! L) b4 k4 W
a difference of 2.26% and 0.66%, respectively.1 N8 p8 n5 d- ~: s3 F
WARNING - Model lvc150s040gaaaaaaaou: The [Falling Waveform] . k& z' D3 h( m1 Y* F2 Z
with [R_fixture]=50 Ohms and [V_fixture_max]=0V3 O/ T! P* B. s
8 o% Y2 W0 K1 r/ i$ T. K' W0 H an equivalent load applied to the model's I-V tables yields) A" i! {( Y1 u! m7 v: { `/ @/ r; m
different voltages ( 0.00V and 0.31V),% t4 l" n' `+ n) c$ P! c$ v
; V) o( b8 {1 e eWARNING - Model lvc150s040haaaaaaaio: The [Falling Waveform]
$ S# C4 z4 k; ?4 ]0 [2 @ with [R_fixture]=50 Ohms and [V_fixture]=1.5V' w" N, \3 J! h8 w5 b3 }) o
has TYP column DC endpoints of 1.12V and 1.50v, but! O9 b/ n! Y: R" t% C$ v2 j' q, m* T
an equivalent load applied to the model's I-V tables yields* J9 l( C3 Q. w
) Y* ?. b) n0 l; K a difference of 2.13% and 0.00%, respectively.' O5 K. w# z& E5 b, r4 a6 ]: g
WARNING - Model lvc150s040haaaaaaaio: The [Rising Waveform]
, t+ }6 A( h: u) ~ with [R_fixture]=50 Ohms and [V_fixture_max]=0V2 r) c4 P, z* s1 E- n/ V3 Y
% s j% a5 ]6 {8 @- p/ U3 w an equivalent load applied to the model's I-V tables yields
$ U2 o" N4 ~* e/ S9 K: ~, D different voltages ( 0.00V and 0.32V),
% Q' h# Q. }& a6 d! a a difference of 0.02% and 2.57%, respectively.3 v% b" d4 w. R* d3 c; F/ @2 E
WARNING - Model lvc150s040haaaaaaaou: The [Falling Waveform]
% B6 @5 S( `) s1 n1 t8 g$ e0 t1 l with [R_fixture]=50 Ohms and [V_fixture]=1.5V( T/ f4 m, _2 ~4 E5 }$ }6 o/ P
3 d: S6 n# E4 i2 M& \ an equivalent load applied to the model's I-V tables yields
' c0 j, ]4 A- l! h7 ~& L different voltages ( 1.12V and 1.50V),
+ D, u& i- p" h* F2 C# l a difference of 2.13% and 0.00%, respectively.9 l8 o3 Y. k7 V8 k4 m
WARNING - Model lvc150s040haaaaaaaou: The [Rising Waveform]
% O) [/ l8 q0 G" O X with [R_fixture]=50 Ohms and [V_fixture_max]=0V
4 w9 R/ H1 ~8 e has MAX column DC endpoints of 0.00V and 0.32v, but
, k+ U3 k9 E7 \1 {; z' Y6 R an equivalent load applied to the model's I-V tables yields8 [( L& i e1 c R& N3 q7 Q
3 e& e/ E4 S3 P- Q' n' Z a difference of 0.02% and 2.57%, respectively.
% [6 s/ ?, w, l& J' OWARNING - Model lvc120f020caaaaaaaio: The [Rising Waveform]
% a7 q3 X/ @4 ?; Q' Z5 R/ P with [R_fixture]=50 Ohms and [V_fixture_min]=0V/ z2 N) U4 M) n
has MIN column DC endpoints of 0.00V and 0.41v, but
5 Y0 t0 ?% q. s. F/ v1 G5 W+ _ k an equivalent load applied to the model's I-V tables yields
2 e* T" g# x) T# C8 i3 m different voltages (-0.00V and 0.40V),
1 Q6 ~1 w+ e$ t0 P a difference of 0.27% and 2.30%, respectively./ S' G% v1 g/ Z( s2 V
WARNING - Model lvc120f020caaaaaaaio: The [Rising Waveform] 3 G$ p# k) Y. t! H
with [R_fixture]=50 Ohms and [V_fixture_max]=0V7 Y5 X" L+ {7 x) N8 [
has MAX column DC endpoints of 0.00V and 0.68v, but
. s$ R- c8 _* B! \, {7 W( T8 U an equivalent load applied to the model's I-V tables yields. V8 Q" }" K* _( \9 D) s4 @
different voltages ( 0.00V and 0.67V),
: c% e+ l* a' n" j2 U* m9 P3 ? a difference of 0.06% and 2.27%, respectively.( n' s% O7 R2 t0 Y7 `
WARNING - Model lvc120f020caaaaaaaou: The [Rising Waveform] / d L. a; C [& T6 h
with [R_fixture]=50 Ohms and [V_fixture_min]=0V0 P' l$ f* i. N4 u% I; V$ c4 ]; ?+ ?( Y
5 T+ K1 \% n9 B; U. ?- ` an equivalent load applied to the model's I-V tables yields
6 K7 _3 m+ y/ `+ H different voltages (-0.00V and 0.40V),& \' {! x6 a0 ~/ i/ ]8 _
a difference of 0.27% and 2.30%, respectively.+ O t5 a% P5 e o
% u+ a, i t% \ with [R_fixture]=50 Ohms and [V_fixture_max]=0V
/ l% l& v9 D8 f has MAX column DC endpoints of 0.00V and 0.68v, but
# v$ e W; F. Y% E# }; U# S; i an equivalent load applied to the model's I-V tables yields" R7 C1 [: U7 n) ]# Z: b7 Q& `* N
different voltages ( 0.00V and 0.67V),# o! Z/ }0 R$ ~ E4 G4 e6 G
a difference of 0.06% and 2.27%, respectively.8 u" D0 j+ k# [( i1 V) W% h
WARNING - Model lvc120f020gaaaaaaaio: The [Rising Waveform] 7 |0 [1 q5 h* l3 X& r' c% `
- o# z9 O9 o1 Z- E' }/ X, v, [ has MIN column DC endpoints of 0.00V and 0.41v, but
2 e8 ~, J, Z6 _! ]2 T4 b5 [ an equivalent load applied to the model's I-V tables yields
" h0 u( g& R( s# d different voltages (-0.00V and 0.40V),' f: i2 u5 M3 b( n) f& C- y
; G% Y* g# V0 vWARNING - Model lvc120f020gaaaaaaaio: The [Rising Waveform]
5 o3 Y8 [1 ] h% m' @ with [R_fixture]=50 Ohms and [V_fixture_max]=0V" T/ F5 M- {! M! ^3 Q! G* {
has MAX column DC endpoints of 0.00V and 0.68v, but) t& v2 _% ^# x; Y
7 m& j1 B( O1 J( h different voltages ( 0.00V and 0.67V),( T q- V0 O0 _* Z- v3 u/ z( q( B- v
a difference of 0.06% and 2.27%, respectively.: U5 e x* l8 d$ C, w7 O- E) x
WARNING - Model lvc120f020gaaaaaaaou: The [Rising Waveform]
9 J% m$ j i& } with [R_fixture]=50 Ohms and [V_fixture_min]=0V
/ c$ U) R% \4 X F4 \0 K( o. k has MIN column DC endpoints of 0.00V and 0.41v, but9 N' q$ Y* p' X: a$ {
an equivalent load applied to the model's I-V tables yields! n! t3 m8 v! x2 R8 E
different voltages (-0.00V and 0.40V),: [# i! k7 q8 D5 G/ o6 g+ v6 Q
% T' g& k5 M- U# @8 b& H6 T1 TWARNING - Model lvc120f020gaaaaaaaou: The [Rising Waveform]
- K4 |1 A6 _7 k with [R_fixture]=50 Ohms and [V_fixture_max]=0V
; T8 Q8 d) t- u% r3 [8 g. i has MAX column DC endpoints of 0.00V and 0.68v, but7 m) B( Y' o0 ~( t b0 P' i
an equivalent load applied to the model's I-V tables yields5 S; V! x) V, t" ~8 X6 ?9 H
; t5 V! E' k2 c# o7 `9 v a difference of 0.06% and 2.27%, respectively.
, T$ H0 [; S0 rWARNING - Model lvc120s020aaaaaaaaio: The [Falling Waveform] $ x) u2 B- X5 v C5 Q- Z3 X! c
with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V; `3 \7 U* G5 X% G9 U+ U+ o
has MIN column DC endpoints of 0.75V and 1.14v, but
! K l2 c( l; t' H) |% b) c, [ an equivalent load applied to the model's I-V tables yields
9 \) m9 o. x* @) k4 A. i } different voltages ( 0.74V and 1.14V),
+ s# G' I8 @: E- W k a difference of 2.07% and 0.00%, respectively.
2 W7 {! F6 I5 cWARNING - Model lvc120s020aaaaaaaaou: The [Falling Waveform]
* L; g1 O$ e! N& T& r with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V
: U6 d' m! D: T7 E has MIN column DC endpoints of 0.75V and 1.14v, but9 m) B! h# f f3 l' A
an equivalent load applied to the model's I-V tables yields& K6 }, H7 a4 s; I$ b3 @
( o4 Y* [9 [$ F% c7 g+ J7 x- U! ? a difference of 2.07% and 0.00%, respectively.
- h; c& ~! X, t, G% m7 d; q$ RWARNING - Model lvc120s020caaaaaaaio: The [Rising Waveform] 8 x7 \% [9 h( q! A- j# ], u7 y8 Q
with [R_fixture]=50 Ohms and [V_fixture_min]=0V( ~$ s. I5 x% a4 z( U5 g
has MIN column DC endpoints of 0.00V and 0.41v, but9 E$ V9 t6 b. V' M' O) o" ^
% F5 ?2 H6 }: P# r/ d3 x7 b# _ different voltages (-0.00V and 0.40V),
3 d( y- z# `+ M* b$ q. z a difference of 0.66% and 2.16%, respectively." ]0 c. b7 p+ {2 ]. J0 P7 W
WARNING - Model lvc120s020caaaaaaaio: The [Falling Waveform] 8 o; U7 {: y+ V, h' U3 ^
: }9 r w) W3 ^9 Z! w2 | has MIN column DC endpoints of 0.75V and 1.14v, but5 O% b# N; ]' _+ F4 h
; h/ N1 s/ e/ T# ~3 o different voltages ( 0.74V and 1.14V),4 E8 \9 }7 [: X! E* I# P3 t
a difference of 2.89% and 0.47%, respectively.3 t" m6 d7 j7 }: Y) ^0 f/ E7 f- p/ P
WARNING - Model lvc120s020caaaaaaaio: The [Rising Waveform] ( M% B' \7 Y e+ F( ]
with [R_fixture]=50 Ohms and [V_fixture_max]=1.26V
- C" }! z7 L6 z9 ~ has MAX column DC endpoints of 0.91V and 1.26v, but
$ J, E0 H8 t0 k6 M an equivalent load applied to the model's I-V tables yields5 j/ J @! ~* w
different voltages ( 0.90V and 1.26V),
; G; M# u" _. ]1 K+ q* q' S a difference of 2.23% and 0.43%, respectively.
* c0 n, _$ ^5 z/ a7 Q6 vWARNING - Model lvc120s020caaaaaaaou: The [Rising Waveform] * A! _) `9 G' e2 C2 ]" l
0 c4 T* u L% ^; y8 S8 ~ has MIN column DC endpoints of 0.00V and 0.41v, but
8 w! x9 L) w- }$ O$ ~2 y$ s an equivalent load applied to the model's I-V tables yields* k% w( a( @4 i2 o; q& Y
different voltages (-0.00V and 0.40V),4 V, o& o8 r4 G6 s5 v
5 g' T+ C7 y: ~! ~1 BWARNING - Model lvc120s020caaaaaaaou: The [Falling Waveform]
P! l; C- {; J) v2 O8 a9 W8 d with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V" _/ }' P- E) Q8 {$ |! d( a6 l R
1 v! N$ K' x4 v# V an equivalent load applied to the model's I-V tables yields
: r& O2 d" \( ]- B! q2 U% l different voltages ( 0.74V and 1.14V),1 P% O7 q* x2 T8 D
a difference of 2.89% and 0.47%, respectively.2 g5 z8 b# F9 f7 k E( |: h
+ o: ^: p, `# G8 a C o& G with [R_fixture]=50 Ohms and [V_fixture_max]=1.26V
. b% p" F7 ]% W has MAX column DC endpoints of 0.91V and 1.26v, but
. k( X- a$ b" `5 ~ an equivalent load applied to the model's I-V tables yields
K6 ]5 Z6 f, G5 B" u8 n6 n2 d5 p7 X different voltages ( 0.90V and 1.26V),( M3 Y$ L g: q( X& b3 O
) j- y6 K, v9 w% n6 u0 fWARNING - Model lvc120s020eaaaaaaaio: The [Falling Waveform] ' Y7 W7 \& K* {& K9 T, f
$ {" M; z! ^2 L has MIN column DC endpoints of 0.75V and 1.14v, but
/ l8 Q6 X8 e/ ~) g2 ]5 _0 Z* l an equivalent load applied to the model's I-V tables yields0 F, U" z" L; U7 D2 O. t7 M( k9 C
! e5 Z8 U1 l# C' M5 \ a difference of 2.07% and 0.00%, respectively.* s( G$ H4 g& v- h0 ~5 B( y
WARNING - Model lvc120s020eaaaaaaaou: The [Falling Waveform]
3 i2 D% j5 v `# ^4 c7 T9 H' o with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V
( q/ l1 F# J6 @. ~: E$ D, j' v has MIN column DC endpoints of 0.75V and 1.14v, but
3 n# g, n g* D5 P an equivalent load applied to the model's I-V tables yields
3 l5 M9 H+ f4 O: H) h, ?6 w# F different voltages ( 0.74V and 1.14V),
v0 p# \ P/ ^! b$ X" H6 h a difference of 2.07% and 0.00%, respectively.
" Q- j0 e# E/ ^" aWARNING - Model lvc120s020gaaaaaaaio: The [Rising Waveform]
2 s3 c, i6 }; Y6 d5 c with [R_fixture]=50 Ohms and [V_fixture_min]=0V t1 A1 a% N- y1 S% N3 M+ B
0 @2 b- Q, Q" F4 i8 N6 _5 h an equivalent load applied to the model's I-V tables yields0 W8 |; }* ^5 J0 A: V9 ^% v' [- z4 d
5 s" K2 r4 `; R- I a difference of 0.66% and 2.16%, respectively.
) L+ u( |! |/ j; y+ VWARNING - Model lvc120s020gaaaaaaaio: The [Falling Waveform]
" I- \0 M# i y9 o' ^4 \" g with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V- J2 A/ ~/ j+ f& ]; ]' k- b& ^
. `* i; [* L* ^# x {/ T+ p$ M an equivalent load applied to the model's I-V tables yields
; M+ Z: a; Y. [/ ~% L4 L. F0 D9 a different voltages ( 0.74V and 1.14V),5 m' D/ a' K" Y! U0 u
5 k8 ]# f% S, l: x3 RWARNING - Model lvc120s020gaaaaaaaio: The [Rising Waveform]
/ [ b6 k4 Q% l5 s2 ~ with [R_fixture]=50 Ohms and [V_fixture_max]=1.26V
( {9 }! V; y2 q3 s4 _ b7 t# r( W has MAX column DC endpoints of 0.91V and 1.26v, but
# {/ R& u7 O- G* E, T- r0 D an equivalent load applied to the model's I-V tables yields) [& Z# ]- u' E: G' k; K7 [ H) V9 ~
4 t3 A, ? c: t1 @ a difference of 2.23% and 0.43%, respectively.* E: I- S2 {7 o% e7 z
WARNING - Model lvc120s020gaaaaaaaou: The [Rising Waveform] $ ^% E; Z" x) N( C0 g5 y# k
% h+ ~# X7 I1 s+ M has MIN column DC endpoints of 0.00V and 0.41v, but
0 W" P' r$ s$ A2 N+ o8 ~ an equivalent load applied to the model's I-V tables yields
% G/ F# a3 }0 H2 F2 n& I different voltages (-0.00V and 0.40V),# W G5 T/ b" Z% q4 j I8 E3 {
a difference of 0.66% and 2.16%, respectively.; Q; j4 ?, Q0 D8 f
WARNING - Model lvc120s020gaaaaaaaou: The [Falling Waveform]
, p _, D% S$ |4 z with [R_fixture]=50 Ohms and [V_fixture_min]=1.14V6 p& K5 p/ }1 w+ W; `( ]
2 u' K: X6 H9 V' w6 C0 i! |& L an equivalent load applied to the model's I-V tables yields
* d. u4 |* a( y5 g different voltages ( 0.74V and 1.14V)," V' `0 G# L( L, E0 K0 P# I. N4 V
) P& C* m% ^0 A" rWARNING - Model lvc120s020gaaaaaaaou: The [Rising Waveform]
6 ^: N, {7 Q3 _7 F& d with [R_fixture]=50 Ohms and [V_fixture_max]=1.26V* T1 H! v0 E* L
( _/ r5 @0 ?$ M, g2 o an equivalent load applied to the model's I-V tables yields
7 v7 u- Q# o; v+ \ different voltages ( 0.90V and 1.26V),
9 S1 z4 Q! ]5 x* W) C a difference of 2.23% and 0.43%, respectively.
0 l# U7 }0 s* E% Y/ p: {WARNING - Model lvc120s040haaaaaaaod: The [Rising Waveform] % H5 [# y, y x. ~# A3 V! ^
with [R_fixture]=50 Ohms and [V_fixture]=1.2V
1 t, O7 T3 {* v has TYP column DC endpoints of 0.83V and 1.20v, but
. D; C- T6 e- V) a# g, M an equivalent load applied to the model's I-V tables yields& c: m: D% W; ^# U6 H0 l5 K
different voltages ( 0.85V and 1.20V),
' G2 q: W+ R- f% L a difference of 4.83% and 0.00%, respectively.& u- B$ \3 U% y9 I3 X/ p
+ ^! G8 [. c( R7 O" Y( `Errors : 14 {* p! a1 G6 O9 l' B
Warnings: 133/ X) O D0 w$ X' {
4 N9 Z# o' Q9 a1 f' gFile Failed5 D P) H3 h6 s# z% c* o3 K
