查看: 4578|回复: 0
mentor-dxdesigner 求帮助
发表于 2013-6-20 10:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用的是mentor2005   文件项目是 xilinx ml605 原理图文件
( I) o  s( Y% k* d3 V/ {我的目的就是要在源文件上删除点东西然后更新到 pcb(allegro  .brd 文件)上。
, W2 Z1 {+ [+ L$ H# s下面是遇到的问题:; L& g9 o; l  D9 N( T
1、对工程做  save+check  没有报错
! [$ B# u7 ]7 T, T. K6 T  i! ?4 S2、然后做  Tool->Create Refdes
) o8 y, \2 \; w6 ^1 r1 S' Z0 I     在ViewPCB 中  netlist Format 选择 cadence Allegro 15.x    其他选项默认不变  8 x3 P4 G, \+ c0 ^2 J# i/ v# j
3、直接Run  5 C' v; `  j( x0 H/ j* `$ _4 U; I
+ V; D3 G7 I6 I* |6 A; R2 `
$ Z& l" h4 e& K& P8 f1 ?1 Y0 [; P2 u* |. f4 K+ C; a4 H' r% o% t
pcb: Error 6091: ml605 com $32I1951: Symbol DXDESIGNER_LIB:ST2378E_1 missing for hetero device IC
9 x5 Z  D3 h# `" ypcb: Error 6091: ml605 com $32I1952: Symbol DXDESIGNER_LIB:ST2378E_1 missing for hetero device IC* c" w5 `1 j! |, T+ w! l) b
pcb: Error 6091: ml605 com $32I1953: Symbol DXDESIGNER_LIB:ST2378E_1 missing for hetero device IC
8 I2 [6 R5 V, S  i5 d: L0 ?6 i8 Wpcb: Error 6091: ml605 com $32I1954: Symbol DXDESIGNER_LIB:ST2378E_1 missing for hetero device IC
0 r3 F" U4 Z; x7 H7 @pcb: Error 6091: ml605 com $32I1955: Symbol DXDESIGNER_LIB:ST2378E_1 missing for hetero device IC
/ R8 H- v+ D, h5 }& Fpcb: Error 6091: ml605 com $26I353: Symbol DXDESIGNER_LIB:TPS3808_1 missing for hetero device TPS3808G25DBVT_SOT-23-6
. x' x/ N+ B* l- ]* y* wpcb: Error 6091: ml605 com $45I2: Symbol DXDESIGNER_LIB:TPS51200_1 missing for hetero device TPS51100_SON-10
* o5 _$ O9 d/ X" ]pcb: Error 6138: ml605 com $10I669: Multiple symbols DXDESIGNER_LIB:RES device 00, are inconsistent
- d5 z% ^! [$ ?2 |pcb: Error 6138: ml605 com $33I462: Multiple symbols DXDESIGNER_LIB:RESH device 00, are inconsistent
# P6 W2 i6 P5 g# j, o6 Dpcb: Error 6138: ml605 com $22I162: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent
0 Y5 B6 g7 |7 O$ N! D2 h: ppcb: Error 6138: ml605 com $25I551: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent6 o0 S( o3 z) K- U" f& T& u8 b
pcb: Error 6138: ml605 com $25I553: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent
' z  A0 H8 A8 O5 g, _( x9 fpcb: Error 6138: ml605 com $26I176: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent7 ]0 N3 n# @: j) d6 s( w+ P( v# R' K
pcb: Error 6138: ml605 com $26I192: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent
( N+ b' t  E1 opcb: Error 6138: ml605 com $26I193: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent0 M/ y7 q" j! v9 @  u. K
pcb: Error 6138: ml605 com $26I194: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent
6 c7 l6 Z0 [$ L# |pcb: Error 6138: ml605 com $26I195: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent! Y4 y' s) B# J  c  h; q6 K. C( i
pcb: Error 6138: ml605 com $26I196: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent# b0 u3 Y* A- Z1 D8 d
pcb: Error 6138: ml605 com $26I197: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent! x$ r" O( b1 Z! l3 F0 j
pcb: Error 6138: ml605 com $26I198: Multiple symbols DXDESIGNER_LIB:RES device 100_0402, are inconsistent6 ~$ @4 F, \3 n& r8 @; y" n
! z; U0 y- y8 ~' H- M) l. m1 x9 P0 E% g$ x& z5 W
( m5 p, F( D$ j- z, o) mError 6138   这种错真不知道怎么弄了
. x- }) w4 ]9 ^. b9 a求帮做  我纠结了一个礼拜了
( t& d/ ?3 `, v0 _6 C/ J本人对 Dxdesigner  不熟悉 第一次用这个) d: N+ y& U; P6 p1 m/ A9 v; p
: L  L/ L0 p; ]7 W& [, L# I
GMT+8, 2025-7-22 03:21 , Processed in 0.109375 second(s), 24 queries , Gzip On.
