ERROR: Bad data for Part Number: TOP266EG-V Package in the$ G: }& w/ U9 [& a" U$ a
Parts DataBase for symbols with Part Name: New and Part Label: (null).; ^2 b K5 e2 G# v$ @" {$ V
The relevant symbols are:1 C) w9 f7 C$ W I# y" \
5 F- P8 |3 D$ x* U! q- l
Block Auxiliary(AC), Page 1, Symbol $1I574 8 e: d0 m1 N2 ~- V' ?- h8 I
1 C' e5 x6 U5 V% ?4 h4 m
1 packaging error has been found.
. [ D6 K C8 K3 C* nFor those errors that only involve the application of wrong4 t/ j6 p) X% w( V& r* [
pin numbers, either repackage the schematic by hand or! S/ m! r; c4 V" ^$ [' ?, V0 `
simply remove at least one pin number per symbol to enable0 C6 p8 o; n8 F: ?; D/ T: |4 D$ H6 p
automatic packaging when you run this procedure again.% o* J% H0 x/ @& t& @; q
4 u: g! e6 K5 K) o
/ g4 u% ~. T# N' Y; e5 N% W* w6 z3 L
Testing of Packaging is being terminated with 1 errors and 0 warnings.
9 w( Q: W; M: p3 v( K: r0 o4 z7 J; PDesign has NOT been packaged.
& Y. U' R9 P! L5 v% Z5 v9 {: ?" i1 T+ J: E! T
