我在转TI的一个USB收发器的IBIS文件是,Parse没有问题。但是在转换成IBIS文件是却不OK,我现在将Log File 粘贴在下面:
: a, B+ Q: A% w- Y _, _; w
6 `. f- q, a6 Y: p2 {" E! P# K: a9 W- A8 Y2 Q" K( [
T4 d& e& O" i! n( a* K
RUNNING IBISCHK COMMAND: ibischk4 "E:\tusb.ibs"
+ v2 g5 l+ R0 R R6 xIBISCHK4 V4.2.0
1 H* K4 |& I; f2 |2 _+ l3 ]
& K+ b/ Y, Y2 W: B- R0 p: j" oChecking E:\tusb.ibs for IBIS 4.2 Compatibility...+ T* W1 V4 @2 k1 Q
M& d5 i7 u, ^+ ^; v$ Q x
WARNING - Model FZP18_PD_PI_10P_3P3 Pulldown Minimum data is non-monotonic" Z: q; `1 m3 A4 J$ y- U" U
WARNING - Model FZP18_PD_PI_5P_3P3 Pulldown Minimum data is non-monotonic
+ ]0 H* O& R4 g6 FWARNING - Model FZP18_PU_PI_10P_3P3 Pulldown Minimum data is non-monotonic
% Y( y9 m7 G7 I0 W m$ |WARNING - Model FZP18_PU_PI_5P_3P3 Pulldown Minimum data is non-monotonic
& w0 M# X8 W% F! fWARNING - Model HYPBFZP18_PI_10P_3P3 Pulldown Minimum data is non-monotonic3 X9 A3 R/ X' \5 C2 \9 T
WARNING - Model HYPBFZP18_PI_5P_3P3 Pulldown Minimum data is non-monotonic- V1 z7 D9 |+ Q
WARNING - Model usb3_WODE: The [Rising Waveform] 9 J( l+ N: I1 i. f* q, G2 {5 B
with [R_fixture]=50 Ohms and [V_fixture_max]=1.155V( z/ A$ o. Q1 t' Z. v7 M/ f$ Z5 h
has MAX column DC endpoints of 0.60V and 1.12v, but
: Z# J) u) m( D' R. v" }4 ^" T4 t an equivalent load applied to the model's I-V tables yields
7 z( J3 \* n7 Z8 w different voltages ( 0.61V and 1.12V),% s: r! P$ R# O; \) z/ F
a difference of 2.74% and 0.09%, respectively.# h# W: j# I K0 d
WARNING - Model usb3_WODE: The [Falling Waveform]
' x; x- ~; _1 ^* W; W with [R_fixture]=50 Ohms and [V_fixture_max]=1.155V$ x1 s+ C) h* g
has MAX column DC endpoints of 0.60V and 1.12v, but: @$ o( u6 Y: Y5 \+ h6 _
an equivalent load applied to the model's I-V tables yields& G2 N4 x. s3 @* o5 t7 ^
: y4 W0 Z6 ]- y; T5 r( } a difference of 2.66% and 0.06%, respectively./ O9 f$ C& e8 W( T/ D, X2 ]+ U. B9 @
WARNING - Model usb2_LS_RC Pullup Minimum data is non-monotonic3 L; E! W7 G' i
WARNING - Model usb2_LS_R Pullup Minimum data is non-monotonic2 u3 v3 T& R, V9 Y/ @1 f
" ^2 |9 o2 ?# O7 G3 O
Errors : 0
: m6 Y9 d; p7 l2 `Warnings: 10
7 O) u9 ]/ W! l7 P5 }' u/ F' j/ H0 G' J
File Passed
; |( ^. r B( h$ c ^# {
2 }6 N5 A' ?* k3 f I. }- I2 NEND OF IBISCHK COMMAND OUTPUT
) a( G9 O* t7 D k1 q. \' F0 K5 x4 n5 l" J, ~
8 }# D4 [5 a: G# @4 z: v! _
READING IBIS FILE E:\tusb.ibs, N( ~; ?8 p4 O! j- { V$ Q
+ {) g( Y3 |( f4 B4 A. B5 ]
ERROR @line 44: Syntax error after parsing the token <Driver Schedule> :
% G/ M4 E. k( Q! w* T+ L The previous token began on line 44 and was <[> & p7 M0 J# @0 U1 W2 X
! z- Y# {7 h* m3 e( u U; DRUNNING DMLCHECK for E:\tusb.dml
9 M% a/ b, B" G3 J0 y/ z/ i7 @- n3 P8 N
- H8 Q; o8 k/ H- |( d Z
Translation failed due to IBIS2DML errors.) p! A1 c2 V( K& S# o
Output saved as E:\tusb.dml.txt.) a% T/ |: i# ~, K0 K* S+ b
Run ibis2signoise -d, a DML will be generated.
" m" T$ U: B0 H0 z' G V# e3 @! jExamine it with line numbers from the log message.
: j3 n9 n; S+ k8 ]6 q
* Z4 K4 m$ n# K% c' `3 P- F
, S, w7 Y2 s& F! e" } {4 E希望大家能帮我看看这个问题到底是怎么回事!!!
7 O' e* L ?/ m1 H
' \6 F7 m6 r$ |. G& r上面说 Line 44 有语法问题,我把 Line 44 的内容页粘贴如下,谢谢!! 下面第一行就是Line 44 !!
- }/ X7 e* ^9 A# o7 |9 i9 m- {5 d
[Driver Schedule] keyword. For example, using HSPICE, refer DE_hspice.sp* N6 J5 W0 m9 I% T2 a1 W8 J. t
in the correlation report
: C/ j% r0 I6 d9 C5 {; a. t - To test USB2/USB3 IBIS models using HSPICE look for spice set up files
/ }# X) w/ ]0 |& q! G/ w inside the TUSB8040 correlation report \$ N/ n# S! _% I
- Digital Buffer models are from SR60 standard cell library for TUSB8040
: E4 H8 M) A ~& @, u4 D7 @% l) o( U5 ~ - Non-Monotonic pulldown warnings related to digital buffers is per
# ?/ k9 l# s' Q4 V# B. [7 I simulations ! j$ c% L3 r# o4 W- o/ R
; T9 g+ l$ z( U8 E% @4 F
谢谢 |
