再附上 PoE+ 規範 EEE 802.3at 上的一段話︰9 B- m7 E. L( c
4 W% t& a, l1 D' m8 t2 b) d
PDs and PSEs shall provide isolation between all accessible external conductors, including frame ground (if any), and all MDI (Media Dependent Interface) leads including those not used by the PD or PSE. Any equipment that can be connected to a PSE or PD through a non-MDI connector that is not isolated from the MDI (Media Dependent Interface) leads needs to provide isolation between all accessible external conductors, including frame ground (if any), and the non-MDI connector. Accessible external conductors are specified in sub-clause 6.2.1 b) of IEC 60950-1:2001./ _+ ]! u" Q* I! b$ x* b6 q
) j6 `" n. {4 K' t3 ~This electrical isolation shall withstand at least one of the following electrical strength tests:
5 C. G; g) s0 v1 i( Y! f" `: z* I' `! T+ G S
(1) 1500 VRMS at 50 Hz to 60 Hz for 60 seconds, applied as specified in sub-clause 5.2.2 of IEC 60950-1:2001.9 q+ {- A) d3 b8 }. _( `# S4 d
; D7 Y/ r0 h+ O- J* B1 H, [
(2) 2250 VDC for 60 seconds, applied as specified in sub-clause 5.2.2 of IEC 60950-1:2001.1 z V) u: {# K! Q O3 j
1 T" p3 e, k& p" A# f
(3) An impulse test consisting of a 1500V, 10/700 μs waveform, applied 10 times, with a 60 seconds interval between pulses. The shape of the impulses shall be 10/700 μs (10 μs virtual front time, 700μs virtual time of half value), as defined in IEC 60950-1:2001 Annex N." Y+ C6 A; I0 W9 h
" N7 d) \4 d6 n* I1 X{:soso_e185:} |
