返回列表 发新帖
楼主: phonse
Cadence Allegro SPB V16.60补丁Hotfix_SPB16.60.002_wint_1of1
16#
发表于 2013-1-28 10:36 | 只看该作者
补充一个下载网址:2 @) `- X/ R$ {) G6 z
http://www.orcad.nl/patches/Hotfix_SPB16.60.002_wint_1of1.exe
/ o& p$ b% |& t
1 c) v( g4 F% m7 I4 ZCadence SPB16.6 SuperHotfix002发布,具体修复问题如下:8 p% L: m1 m& p4 F8 Z
DATE: 12-21-2012   HOTFIX VERSION: 002  J  g; m! U4 o
===================================================================================================================================( H( ~* D  ?. S. J' o
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
' D# n1 \; C1 q9 n===================================================================================================================================
! ?' ]3 d) h) V' g) I7 r' K491042  CONCEPT_HDL    SECTION          Prevent PackagerXL from changing visibility on SEC attribute
: b3 l* c! z  j4 G863928  ALLEGRO_EDITOR INTERACTIV       Segment over void higlights false "nets with arc"1 w, Y0 R& ~! {% F+ u  T, {. _
1067272 PCB_LIBRARIAN  CORE             Unable to retain the symbol outline changes
5 p2 n, |% U* T  o1074820 ALLEGRO_EDITOR GRAPHICS         losing infinite cursor tracking after selecting the add text command with opengl enable3 S- S1 A1 L2 Y  U. [; \+ c
1075622 CONCEPT_HDL    CORE             PDV Edit Symbol in DE-HDL all editing functions disabled since Hotfix 33
" A3 u4 P1 E+ Y  s+ W9 A' S1076986 APD            WIREBOND         Wirebond Adjust Min DRC does not maintain the finger position in the same sequence) l! c1 s( o3 U6 A7 U7 g  b! |
1078031 SIG_INTEGRITY  REPORTS          Requesting improvement to progress indicator for report generator* l+ k/ r! v: s0 i
1080213 SIP_LAYOUT     WIREBOND         Wrong behavior of Redistribute Fingers Command( a, f+ z7 T7 O2 v" ]' b
1080667 ALLEGRO_EDITOR GRAPHICS         Allegro lines with fonts not displayed correctly in 16.68 F9 b& W7 L/ W7 w& L
1080982 CONCEPT_HDL    CORE             Crash of Allegro Design Entry during a copy of a note.! j/ A; t6 B+ V- N$ \
1081200 CONSTRAINT_MGR OTHER            In the DIFF_PAIR worksheets various Analysis seem to take a long time to complete." C$ D& |. k. P; r
1081553 CONCEPT_HDL    OTHER            Model Assignment can not translate M (Milli-ohm) property value of DE HDL.
4 P9 P  L2 B  h. Z1081696 ALLEGRO_EDITOR INTERACTIV       Compose shape not working when radius is set to 1.0( l' J' s5 `$ F
1082595 ALLEGRO_EDITOR COLOR            Infinite cursor remains white even we change background to white6 f6 {/ j  F/ X: B! j- c9 g4 e
1082704 ALLEGRO_EDITOR GRAPHICS         infinite cursor disappears when using Display>Measure
: P. q& b$ A( O- L1082715 SIG_EXPLORER   INTERACTIV       Single line impedance for BOTTOM Layer is not calculated in cross section upon changing the thickness of dielectic layer
) `' g+ _5 s$ [1082774 ALLEGRO_EDITOR TECHFILE         Import techfile command terminates abnormally when importing a generic techfile.
# P. H- U# [$ Z( J' Q1082820 CONSTRAINT_MGR UI_FORMS         The configure generic cross-section pull downs do not work.4 x- H  A$ _; e
1083133 SIP_LAYOUT     INTERACTIVE      SiP will crash when using the beta Pad Rename command to change a BGA pads name.6 b& f7 f+ U  t( D! Z, T
1083158 ALLEGRO_EDITOR GRAPHICS         The cursor chage to Arrow head for Shape Select is more sensitive to location in SPB 16.6
" N5 Y$ Q+ B" ^) {* G4 l. Q1083533 CONCEPT_HDL    CONSTRAINT_MGR   Bug -Net-count under few of the netclasses are not in sync between Schematics & Layout; s) ^7 A) v3 K
1083637 PCB_LIBRARIAN  CORE             Save As is not renaming the NAME in the symbol.css file- ^6 l4 g( M. \4 X
1083934 ALLEGRO_EDITOR PAD_EDITOR       Error(SPMHUT-41): File selected is not of type Drawing.
$ J: [/ h  J4 T1084148 CONCEPT_HDL    CHECKPLUS        The CheckPlus hasProperty predicate fails in the Physical environment./ R: U$ T; g+ ?$ P/ M1 e
1084166 SIP_LAYOUT     DIE_ABSTRACT_IF  Updating sip layout with new die abstract doesn't properly update IC_DESIGN_CELL* properties4 r  \- M# B! F) F6 T8 b" ]
1084285 CONCEPT_HDL    INFRA            Corrupted dcf was never fixed and caused PXL error
9 g- o" O; J4 A9 G& n  B: R: v1084441 CONCEPT_HDL    CORE             Assigned net property value changes to numeric3 |4 k, g) \* Z" o% _+ b3 u0 \& j% y& |
1084542 ALLEGRO_EDITOR DRAFTING         Dimensions associated with frect doesn't rotate with the symbol.- d* p+ [/ m- G/ x
1084736 APD            IMPORT_DATA      Import SPD2 file from UPD-L shape Pad and text issue
; r; N3 o# H  X) V/ i1085008 ALLEGRO_EDITOR INTERACTIV       Relative (from last pick) option in the Pick dialog not working for pick command; n0 X, P$ _% H6 U* O6 U
1085139 ALLEGRO_EDITOR GRAPHICS         Infinite Cursor disappear during Add Connect if Infinite_cursor_bug_nt is enabled
8 o, S" ]* z1 y1085187 SIP_LAYOUT     INTERFACE_PLANNE netrev with overwrite constraints fatal error
4 H+ }5 S: }! [# ^- i1086402 ALLEGRO_EDITOR GRAPHICS         Infinite cursor dissapear when using command like add connect or Place manually with opengl enabled.
8 {: R! e- P6 X. p1086905 PSPICE         SIMULATOR        PSpice crash while simulating circuit file with BREAK function
( R( d3 B9 L4 C! z1087770 ALLEGRO_EDITOR EDIT_ETCH        Allegro crashes on a pick with the slide command.
, d* G4 \1 F% @+ S6 V1088412 SCM            CONCEPT_IMPORT   why reimport block adds _1 to the netnames?
5 E% E' ~$ j" i& N( L! `1088958 CONSTRAINT_MGR INTERACTIV       annot create Differential Pairs out of nets that belongs to a Net Group
5 S, A) K  i+ D2 P( g* S1089336 ALLEGRO_EDITOR GRAPHICS         infinite cursor and pcb_cursor_angle
7 C$ }3 g2 H& y5 b; |9 a1090689 ADW            LRM              LRM: Unable to select any Row regardless of Status
2 @. s/ O! `2 Q4 [+ E. i- f- Q; }" v1090955 ALLEGRO_EDITOR OTHER            Cancel command crashes PCB Editor when add rectangle: I% l/ N- P4 U2 D+ ^$ k# U8 m' p; s
1091047 ALLEGRO_EDITOR REPORTS          The "Dangling Lines Via and Antenna� report seems to be missing vias that are antennas.
) R% E, c3 F' e7 R1091218 ADW            LRM              LRM is not worked for the block design of included project
0 s3 m8 g: K, E1091443 ALLEGRO_EDITOR OTHER            Crash when toggling suppress pads4 }( }- Y8 L3 H8 x- c% z% R$ x
1091706 ALLEGRO_EDITOR EDIT_ETCH        Allegro crash while routing after setting variable acon_no_impedance_width5 S# k( K% y  ^" c5 t
1092916 CAPTURE        OTHER            Capture crash9 |; s6 M3 u/ z7 z3 V* [& D
1093573 ALLEGRO_EDITOR DATABASE         team design opening workflow manager crashes allegro.  possibly corrupt database
) }8 {/ A8 c- ~! u! V" C8 B0 R% q- m% B. i/ O, [) g* ?
7 G* e# U: N# E0 M$ R
17#
发表于 2013-1-28 11:12 | 只看该作者
周末发的新补丁,都不休息的呀" u& H: A4 w: \
" E: I: I3 P1 t+ o谢谢楼主
    奋斗
    2025-11-4 15:00
  • 签到天数: 46 天
    [LV.5]常住居民I
    18#
    发表于 2013-1-28 11:54 | 只看该作者
    micdot 发表于 2013-1-28 10:29
    . s! b  l9 l7 C% G$ s+ k6 S0 u我所理解的,根据有关网友的介绍以及自己的试验,只装002的补丁即可,001的补丁就不用装了。
    * p$ V8 _' C% x4 X! D9 \
    非常感谢及时回复!
    19#
    发表于 2013-1-28 13:25 | 只看该作者
    已装好,解决了不少BUG。
    20#
    发表于 2013-1-29 09:11 | 只看该作者
    谢谢分享。
    21#
    发表于 2013-2-2 10:44 | 只看该作者
    谢谢分享!
    22#
    发表于 2013-2-2 10:59 | 只看该作者
    之前有在win8的系统上装了16.5版本的Candence,Capture还好,等上一两分钟还是能运行起来的,而Allegro运行后,整个系统都快崩溃了,慢的很,然后也无法启动。不知道现在16.6版对于WIN8的兼容性好些了吗?
    23#
    发表于 2013-2-5 22:12 | 只看该作者
    下载下来再说,谢谢分享' K$ j" m$ L, ~% M7 q+ g2 o# W
    24#
    发表于 2013-2-7 10:39 | 只看该作者
    谢谢分享!!!
    奋斗
    2025-9-10 15:12
    25#
    发表于 2013-2-19 09:25 | 只看该作者
    为什么这两个链接都下载不了了?
    26#
    发表于 2013-3-4 10:39 | 只看该作者
    已删除了,谁还有链接?
    27#
     楼主| 发表于 2013-3-9 12:09 | 只看该作者
    呵呵。。网盘忘密码了。。
    GMT+8, 2025-11-5 10:53 , Processed in 0.156250 second(s), 19 queries , Gzip On.
