我先是 AD的PCB 转换成 pads 再转换成EE文件,在EE中将线画好。& {$ X) B2 j! x0 t1 a! E
然后用PADS,再导入EE画好的PCB,转换是成功,有提示转换问题,只有元件不见了,其它的还有。怎么解决!!!
! V' M! H5 e* }
1 H* [* h9 s. S& H# P# X5 |/ I& M# J4 m8 j: O8 o
转换提示内容如下
% q( } `/ j+ {# S; ]0 L4 WExpedition to PADS Layout Design and Libraries Translator (Version 9.5) 01/08/13 13:54:53
" n( }2 r* E# b: f1 I! lCopyright (c) 2012 mentor Graphics Corp. - All rights reserved
. v. q" f) {1 w4 ]! [/ @
8 }: S8 N+ [, W7 ?! b3 B------------------------------------------------------------
8 D1 v( `! n3 C: ?" HInput folder: D:\1\EE\PCB\EE.pcb& e2 h( s5 z% T, G' L' [
Output folder: EE_pads_5.pcb
" y2 [) q& H7 w5 K* f9 y: Q& a, c4 m7 \) g- m. B4 Y( F7 x$ q. ~
[I] Preparing data...' f* u& R9 Y: f# v; ?9 P; { }- g
Output file: EE_pads_5.pcb / o# O7 K U0 H0 E
[I] Loading...
$ C; [$ @: \. F; F( U2 X[I] Translating Expedition design files from 'C:\Users\ADMINI~1\AppData\Local\Temp\' to PADS Layout design file
6 z% [( x+ f+ E[I] Reading Pad Stacks...
q8 C& c: R& J: r4 {0 |[I] Reading Cells...# R% n5 M. m2 U m7 f5 J% s' r
[I] Reading Part Numbers...6 r8 d$ z/ m% F) S6 _/ `9 h
[I] Reading Job Prefernces...
- p/ L8 }0 _. f2 l) a[I] Reading Net Classes...5 j m3 y; E. A
[I] Reading Net Properties...! w# U: d0 w7 [, Y( s
[I] Reading Layout...
4 y$ k% `0 \: s8 a: j[I] Translating data... B* X% B4 l# e8 O6 J5 x3 T! i
[W] All coincident Pad Entry rules are translated to Default Rules level
2 a- L' D! _, H! [* ]+ c+ e+ n[W] Discriminate Pad Entry rules found, and the rules were not translated. q: i! _' O0 u6 N1 a* \0 f! d
[W] Route grid is not set. Primary part grid is used for setting design grid.( Y4 ]+ E4 Z1 G( g, Y/ Z: ]
[W] Part type 'RES' is not found, and the component 'R6' was not translated." R f2 [. M7 T* u2 n! \, U& Z
[W] Part type 'RES' is not found, and the component 'R9' was not translated.5 e3 z8 J5 J" ~' }
[W] Part type 'RES' is not found, and the component 'R10' was not translated.
! D" P/ T% |% d# z2 p[W] Part type 'RES' is not found, and the component 'R5' was not translated.3 e! A9 c' _7 z, O2 j
[W] Part type 'RES' is not found, and the component 'R8' was not translated.9 M$ m! `4 t3 @- }
[W] Part type 'RES' is not found, and the component 'R7' was not translated.
* U. F9 b- s7 M4 [" Z( E[W] Part type 'RES' is not found, and the component 'R4' was not translated., b6 l6 C1 P, O4 W2 [ ?: f- Q
[W] Part type 'RES' is not found, and the component 'R3' was not translated.0 [! O: |. J' d* v3 z
[W] Part type 'RES' is not found, and the component 'R2' was not translated.5 m5 _5 e6 i5 J5 |: k$ R
[W] Part type 'RES' is not found, and the component 'R1' was not translated.1 \4 \/ x, ?. @" U; L" ^( F
[W] Route outlines are not supported, and was not translated.
: q* H0 O9 o0 H [3 X7 V[W] Pin name 'R7-1' has wrong format. The pin was not included into the net 'GND'.2 J; K, @: Y% \3 G) F6 S
[W] Pin name 'R6-1' has wrong format. The pin was not included into the net 'GND'.
" e) ?0 \; u. j. e[W] Pin name 'R8-1' has wrong format. The pin was not included into the net 'GND'.
* w5 |1 ^. j' i5 t2 O* y# R- v" \[W] Pin name 'R9-1' has wrong format. The pin was not included into the net 'GND'.0 v8 } M/ U% l! Y) T
[W] Pin name 'R10-1' has wrong format. The pin was not included into the net 'GND'.6 _0 A6 _$ I3 ~4 m4 m! ^+ O# y
[W] Net 'GND' don't have properly pin pair. Vias of the net were not translated and traces were translated to open coppers.
: L7 q! E" I. w( W[W] Pin name 'R1-1' has wrong format. The pin was not included into the net 'NETR1_1'.8 k! ] p. e6 P% H! k3 L; O
[W] Pin name 'R6-2' has wrong format. The pin was not included into the net 'NETR1_1'.
2 E0 z/ s/ C) z6 n7 p. L/ P[W] Net 'NETR1_1' don't have properly pin pair. Vias of the net were not translated and traces were translated to open coppers.
8 h5 U: x) l2 E/ m: L/ i3 Y! P) n[W] Pin name 'R2-1' has wrong format. The pin was not included into the net 'NETR2_1'.; z- I2 q4 Z% o6 B2 I
[W] Pin name 'R7-2' has wrong format. The pin was not included into the net 'NETR2_1'.# H$ u a& n3 W9 u- ~/ g2 V$ W
[W] Net 'NETR2_1' don't have properly pin pair. Vias of the net were not translated and traces were translated to open coppers.
$ f) M! ~& ?# G[W] Pin name 'R3-1' has wrong format. The pin was not included into the net 'NETR3_1'.0 k5 G1 w6 C T- W
[W] Pin name 'R8-2' has wrong format. The pin was not included into the net 'NETR3_1'.
* p% c' H4 N s' z: g( P k( i" E[W] Net 'NETR3_1' don't have properly pin pair. Vias of the net were not translated and traces were translated to open coppers.
' H2 W& ]. E# _[W] Pin name 'R4-1' has wrong format. The pin was not included into the net 'NETR4_1'.
9 T% |5 n$ E( y% p D# x& g% d[W] Pin name 'R9-2' has wrong format. The pin was not included into the net 'NETR4_1'.- F4 l6 _. }% e! x8 k1 i* D( K, c
[W] Net 'NETR4_1' don't have properly pin pair. Vias of the net were not translated and traces were translated to open coppers.; o7 H2 ]5 G# |8 u1 Q5 I
[W] Pin name 'R5-1' has wrong format. The pin was not included into the net 'NETR5_1'.7 R: n! w9 x( j, n3 k: H, c
[W] Pin name 'R10-2' has wrong format. The pin was not included into the net 'NETR5_1'.2 S- M3 H1 }3 Q3 i$ L+ I2 V+ B
[W] Net 'NETR5_1' don't have properly pin pair. Vias of the net were not translated and traces were translated to open coppers.; K/ }4 {) J# E" V' i5 k
[W] Pin name 'R2-2' has wrong format. The pin was not included into the net 'VCC'.
4 Z# P, c* v8 Z[W] Pin name 'R1-2' has wrong format. The pin was not included into the net 'VCC'.* ^$ ]" X9 O- `
[W] Pin name 'R3-2' has wrong format. The pin was not included into the net 'VCC'.' q0 B! b% Q) _7 C
[W] Pin name 'R4-2' has wrong format. The pin was not included into the net 'VCC'.
7 @, a; q8 F' F. b# C. g) X! Q/ W3 G[W] Pin name 'R5-2' has wrong format. The pin was not included into the net 'VCC'./ E0 ~% S" g. _
[W] Net 'VCC' don't have properly pin pair. Vias of the net were not translated and traces were translated to open coppers.
$ a7 H. H2 @- }8 ?; G0 z[I] Completed
f, N, _6 y- J |
