查看: 2545|回复: 1
求助关于Concept层次化设计时的参考名重复
发表于 2012-11-26 10:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
问题描述:. Q7 v9 ?7 f6 E0 d+ G) E: z+ i
1.绘制了两个子模块的设计,generate view 生成了module(MA,MB),在顶层调用MA,MB时候,输出设计后,报告在MA中的U1与MB中的U1重复;
; ]: x! m8 F  _5 T8 R. y具体报告如:* y8 _9 K  l3 |: z  |6 l% F- u
#1   ERROR(SPCOPK-1138): A hard location was found on instances of different ~
" c) L; x5 O" M( M, Yphysical part types.  Refer to error (1149) for a complete list of instances a~
- u6 W+ W+ Z  C. [& ?& u$ ^& ^ssigned this location.
! J, j6 h9 D' k        Schematic instance: @BASE_DEVICE_LIB.MOBILE_DEVICE_STM32(SCH_1)AGE2_~
+ E# U; }& N+ T# L, p& [I25@BASE_DEVICE_LIB.BASE_STM32F103P100(SCH_1)AGE3_I1@ZTE_VLSI.STM32F103VBT6_~4 c, S; @1 b3 k$ a: O: h. F
LQ100N(CHIPS): k* t" q" Q: [: C
        Physical Path: @base_device_lib.mobile_device_stm32(sch_1):page2_i25@b~9 F( |/ ~# d% ?2 Q" @1 a
ase_device_lib.base_stm32f103p100(sch_1):page1_i1@zte_vlsi.stm32f103vbt6_lq100~
- D3 Y- \4 J8 n+ xn(chips)! a' n4 H/ Q! T) A2 O" j
        Instance physical part: STM32F103VBT6_LQ100N-STM32F103A5 Z/ v8 ~" k' Q; U
        Package: U1
, {+ `% U. p0 Q3 q; _4 ?  E        Package physical part: TPS7044X-TPS7044X
8 ]" D, K1 v! k6 |) N        The same value for location on instances of different physical part na~3 D. e, x4 b% Q9 n# H& i
mes is not supported. Correct the location for the appropriate instance(s) in ~4 v. i$ u# C% I0 k5 ?9 b" w4 k
Design Entry HDL.
" B3 ^" f, {8 K. K! v% G
) A  w! F4 j+ @, l# m! q7 v它的意思是我的元器件是一个Hard location,而我在建元件库的时候定义是$location,当放置该元件后,在Attribute里发现元件变成Location了
2 U) l9 p: G+ m7 C3 k- V$ s6 _
3 V$ W6 s: U7 G) |求助,如何解决这个问题。
发表于 2012-11-26 22:45 | 只看该作者
右键attribute中直接更爱location就行了
参与人数 1贡献 +5 收起 理由
jacklee_47pn + 5 熱心助人!
GMT+8, 2025-10-26 23:48 , Processed in 0.125000 second(s), 27 queries , Gzip On.
