VIH overshoot: VIH,max = VDDQ + 1.2V for a pulse width ≤ 3ns, and the pulse width cannot: g$ \) x! |5 i3 Z/ V: f& e
be greater than one-third of the cycle rate. VIL undershoot: VIL,min = –1.2V for a pulse
% c" Q; h' `. u% gwidth ≤3ns, and the pulse width cannot be greater than one-third of the cycle rate.
$ u' P. e' d% m; ~* S
0 @6 \7 S8 B4 e* W7 y! ?* k- B; s$ U/ M6 r大家是如何理解这段话的,比如供电电压为3.3V,是不是只要过冲电压小于4.5V,下冲电压大于-1.2V就可以了,我不大理解for a pulse width ≤ 3ns, and the pulse width cannot be greater than one-third of the cycle rate ,这句话是说的啥意思呢??? |
