查看: 89|回复: 0
ZCC7008B-23V 8A同步降压 替代RT6258B
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
     楼主| 发表于 2025-1-7 17:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    3.3V/8A Synchronous Step-down Converter
    6 X  [/ v5 c& ]" tThe ZCC7008B operates at high efficiency over a wideoutput current load range with fixed 3.3V output voltageand capable of delivering 8A load current. lt supports awide range input voltage from 4.5V to 23V.AdaptiveConstant-On-Time (COT) control mode provides fasttransient response, eases loop stabilization, andoperates with a low-cost electrolytic capacitorZCC7008B also integrate a 100mA LDO and bypassswitch for efficiency improving.ZCC7008B provides complete enable control, under/overvoltage protect, short circuit protect, valley current limit,thermal shutdown function features.ZCC7008B provides compact solution for TCON powersystem# u' z+ Z) {% [" _. t% e8 `
    Features' I) H% s3 w! G8 N+ H6 c
    4.5V ~ 23V Input Voltage Range
    7 z/ |3 V; }) y. b; v9 Q4 d9 KFixed 3.3V output voltage3 Z0 i$ s& _" O$ _/ N
    Supports 8-A continuous output current
    & `" e7 q8 [# Y8 q$ C2 U( D! ZIntegrated 20mQ High side FET and 10m0 low side FET3.3V LDO capable ofsourcing 100mA
    ; ~2 B1 {2 E" G) I: H3 }Internal +1% reference voltage at 25°C
    5 G2 {0 M" H- [9 I2 @+ \3 ^3 X% fIntegrated bypass switch, typical Ron is 1.500 g7 C$ ~+ V# |9 a
    Internal 0.6ms soft-start$ t: v/ j5 s! J
    Max switching frequency up to 500kHz4 V9 |4 @8 B  T! y) U' i
    fast transient response with COT control mode) K$ t( n  y7 D& B# O
    Power good indicator+ ?5 e4 w  q! u# h; |. ]" I
    Ultrasonic Mode
    " c( z* F; W/ L/ `) s% kIntegrated protections for Uv, Ov, OT, and OCP40°C to +150°C operating junction temperature; O. s: w( o; T/ ~& V; y) g
    AQFN3X3-12 FC Package
    3 k4 s0 a4 ]1 O3 T  N3 FApplications# S8 b1 ^% W0 v, S
    Notebook Computers1 w- D+ Z% ^6 ^2 Q3 x# |
    Notebook, Tablet Computers
    , M' v* N. Y4 y( CGeneral power supply for 3.3V output) M$ j" U  K$ @: \
    GMT+8, 2025-11-5 10:53 , Processed in 0.140625 second(s), 23 queries , Gzip On.
